Showing results for tags 'le mans'.
Well, well... It's almost half of the 2025! This year's Speed Champions was amazing! All F1 cars, F&F and also amazing summer's release! Just whoa! Let's start discussion about 2026 cars!
- 57 replies
- lego speed champions 2025 rumors/speculations 2025 × lego × town × speed × champions × speed champions × le mans × wec × fia × f1 × wrc × erc × imsa × fe × formula 1 × formula one × formula e × car × cars × vehicle × racing × race ×
- lego
(and 108 more)
Tagged with:
- lego
- speed
- champion
- champions
- 2025
- 2026
- town
- city
- car
- vehicle
- race
- racing
- circuit
- le mans
- de la sarthe
- spa-francorchamps
- 24h
- nurburgring
- racetrack
- raceway
- wheel
- wheels
- tires
- spoiler
- rumour
- rumors
- hot
- hot topic
- lm
- lmh
- lmdh
- lmgt
- lmgt3
- gte
- gt
- gt2
- gt3
- gt4
- wec
- imsa
- adac
- wrc
- erc
- pit
- pit stop
- fuel
- drag
- dragster
- nascar
- indycar
- ferrari
- porsche
- mclaren
- lamborghini
- audi
- ford
- mercedes
- cadillac
- toyota
- peugeot
- alpine
- acura
- honda
- hyundai
- glickenhaus
- vanwall
- vandervell
- genesis
- hypercar
- nissan
- lexus
- rc f
- corner
- curves
- indianapolis
- mulsanne
- arnage
- tertre rouge
- pirelli
- michelin
- dunlop
- good year
- wet
- slick
- red bull
- kick
- sauber
- bwt
- haas
- f1
- f2
- f3
- f4
- lmp1
- lmp2
- lmp3
- alfa romeo
- sebring
- volkswagen
- isotta fraschini
- duqueine
- ligier
- oreca
- futer
- old
- winter
- summer
- spring
- autumn
Well 2024 LEGO Speed Champions released 2 last cars (F40 & NASCAR) so came time to discuss about 2025. Somewhere in internet I read LEGO go all in F1 cars in 2025. What's your thoughts?
- 135 replies
Pleased to have completed this, but it's a little bittersweet as even with the smaller wheels the nose is not quite low enough. But I can't change that as I had to put emphasis on the smoothness of the slope from tip of the nose to the top of the mudguard. Thanks for viewing :) KMP
- 7 replies
- speed champions
- toyota
- (and 4 more)
TLDR: Super-detailed fully-modularized Creator-scale 16-wide MOC build of beautiful 1999 Le Mans-winning FIA LMP prototype. 903 pieces (including 3 round-plates-with-strings, 6 whips, and 8 “non-Lego” custom wheel parts). 1/15.2 scale: 16 stud wide, 38 stud long, 23 stud wheelbase Winner - with a bit of luck - of an exceptionally rough and tumble 1999 Le Mans in the hands of Joachim Winkelhock, Pierluigi Martini, and Yannick Dalmas. The LMR was the second iteration of BMW’s LMP car, designed and constructed by BMW with Williams F1, powered by a development of the BMW S70 V12 which the McLaren F1 had used to win Le Mans a few years prior. Longtime BMW racing partner Schnitzer Motorsport ran the team at Le Mans proper as well as in the American Le Mans series. The low and sleek car looked like a ufo compared to the competition. The LMR has a fairly simple and compact shape, but it’s not a brick… the subtle lines are quite refined and put up a challenge to capture smoothly in Lego. The entire nose build is a circus of surfaces all at slightly different angles, their mountings dotted here and there in precise positions over the tub structure. The roll-hoop and engine hump cowlings are jammed full of more angles and curves. The rear fenders tumble and taper back to those extremely compact multi-directional-snotted wing mount and taillight assemblies. The sidepods look simple but are full of some connections voodoo for their multi-hinged lower surfaces. The car's so slim there's really nowhere to hide much supporting structure. Wheel inserts and brake discs are designed in Cinema4d and fit into the back axle tubes of Lego's Icons wheel #42716. The spoke shape, offset and hub proportions were refined through a sequence of paper prototypes to dial in their scale, then the final design was high-resolution SLA resin printed and sprayed with Tamiya TS38 gunmetal (as are the backs of the Lego wheels). Graphics are a mix of printed stickers and cut vinyl. It's not quite perfect: the indigo color-shift blue vinyl turned out a bit too dark - needs a much larger surface area and strong light to really sparkle - and those delicate air-flow pinstripes need to be metallic on transparent substrate so the different white materials aren’t as noticeable. The open cockpit captures various details; Pi/BMW M digital dash, switches panel, electronics boxes all carefully studied, drawn in Illustrator, and shrunk down to scale. (I forgot to do the Emergency markings, so these are swiped from a 1/24 model and comically small) The rear bodywork is a large single assembly that lifts off, revealing that glorious V12. The rear wing and trailing edge of the bodywork (with those complex little taillights) is cantilevered off the end of the transmission. The intake airbox assembly lifts off to reveal 12 intake trumpets, the oil tank and engine ancillaries. Getting the radiators attach at angles flush with the wing plates on the ends of the sidepods was a triumph of Lego maths... A few stickers for the radiator faces and the cam covers provide some texture. The sidepods, splitter, and engine drivetrain are all separate from the tub following the construction and design typical of these cars; the bare chassis of these masterpieces of design and packaging is one my favorite views… The tub itself has a raised footbox with a rounded 'boat prow' profile which helped to channel airflow from the upswept nose underside out through the open sidepods. The remaining flat floor continues back to under the rear axle where the shallow diffuser tunnel kicks up. As always, thanks for looking and thanks for the inspiration, Prototyp These photos up at Flickr: https://www.flickr.com/photos/prototyp/ Stop by and say hi: https://instagram.com/prototyp_brickworks
- 8 replies
- creator expert
- prototyp
(and 5 more)
Tagged with:
Hi, guys! I know that, there is February yet and we're before March release, but let's start new topic! So, at first I want to say that 2023 wave is amazing. New brand, new mudguards, new windscreens! Whoah! And there are my speculation/cars I want to see in Speed Champions 2024: ~ Porsche 911 GT2 RS Clubsport 25 ~ Porsche Taycan ~ Audi e-tron GT ~ BMW M6 ~ BMW M4 GT3 & BMW M3 1991 ~ Ferrari 499p LMH ~ Ford Focus RS 2021 ~ Honda Civic Type R ~ Cadillac LMDH What do you think about my cars? What cars would you like to see? Show your speculation/wishlist.
- 352 replies
- chrome
- s1
(and 176 more)
Tagged with:
- chrome
- s1
- pirelli
- slick tyres
- slicks
- tyre
- slick
- tyres
- stripe
- striped
- orange
- stripes
- bolide
- red
- mclaren f1
- imsa
- daytona 24h
- le mans 24h
- wec
- le mans 24
- 24h lemans
- 24h le mans
- racings
- formula one
- formula1
- limit
- formula 1
- f1
- bmw
- lotus
- lamborghini
- jaguar
- bugatti
- koenigsegg
- pagani
- dodge
- camaro
- speed
- chevrolet
- corvette
- lego
- champions
- lego speed
- lego champions
- speed champions
- 2022
- speculation
- rumors
- 2024
- 2023
- new
- f&f
- furious
- brick
- fast
- fast and furious
- bricks
- elements
- part
- moc
- parts
- parts list
- instructions
- custom
- own
- cae
- my
- my own custom
- cars
- vehicle
- vehicles
- tire
- tires
- windscreen
- windscreens
- lego vehicle
- circuit
- mudguard
- daytona
- le mans
- mans
- spa-francorchamps
- 24h
- nürburgring
- lap
- laps
- racing
- race
- motorsports
- motorsport
- racing car
- racing cars
- finish
- line
- week
- finish line
- imola
- e-tron
- monza
- racing vehicles
- racing vehicle
- gear
- top
- top gear
- racing week
- weekend
- season
- summer
- spring
- fall
- autumn
- winter
- curious
- did you know?
- predict
- imagine
- prediction
- dream
- ferrari
- i want
- mclaren
- porsche
- audi
- ford
- limited
- edition
- motor
- etron
- quattro
- e-tron quattro
- ken
- block
- ken block
- hoonigan
- hoonitron
- gymkhana
- electrikhana
- ev
- electric vehicle
- mustang
- ford mustang
- dark
- horse
- dark horse
- m4
- gt3
- v8
- m
- hybrid
- m hybrid v8
- gt3 class
- aston
- martin
- aston martin
- safety car
- mercedes
- amg
- coupe
- g63
- off road
- off-road
- rally
- f40
- competizione
- nascar
- next gen
- next gen nascar
- sl63
- amr23
- mcl60
- v12
- vision
- gt
- supercar blondie
- concept
- forza
- virtual
Hello Porsche and Speed Champions fans, Porsche 906 aka Carrera 6 is a street-legal racing car from Porsche. It was announced in January 1966 and 50 examples were subsequently produced, thus meeting the homologation requirements of the FIA's new Group 4 Sports Car category to the number. The type would also compete in modified form in the Group 6 Sports Prototype class. For the year of the car's debut in 1966, it achieved numerous victories. The main inspiration came from a plastic toy car which I received as a child. Building instructions are available on the following links: https://rebrickable.com/mocs/MOC-106735/_TLG_/porsche-906 It is a studless build in the new, 8 studs wide Speed Champions style. I wanted to create a sleek model which is as accurate as possible in this small scale. I prefer the brick built solutions to keep the flexibility of the used parts in further builds, and therefore only a standard vehicle registration plate sticker is used. My intent was to keep the width-length-height ratio of the real car and this size makes it possible. The model contains lots of details: for example the emblematic front, the side view mirrors, the side air intakes etc. . Maybe the most challenging one was the iconic headlight, lots of solutions were tested before the final one. I tried to fill every unnecessary gaps and therefore some tricky build techniques are used. The model has space for one minifigure. I suggest to use a helmet or small hair. Thanks for visiting, _TLG_ Porsche 906 - Instructions 1 by László Torma, on Flickr Porsche 906 - Instructions 2 by László Torma, on Flickr Porsche 906 - Instructions 3 by László Torma, on Flickr Porsche 906 - Instructions 4 by László Torma, on Flickr Porsche 906 - Instructions 5 by László Torma, on Flickr Porsche 906 - Instructions 6 by László Torma, on Flickr Porsche 906 - Instructions 7 by László Torma, on Flickr Porsche 906 - Instructions 8 by László Torma, on Flickr
Hello Speed Champions fans, Black Arrow is a ficticious hypercar which was designed for a "Hypercar building contest" hosted by sfh_bricks on Instagram. I tried to design something really cool inspired by the cyberpunk culture. Building instructions are available on the following links: https://rebrickable.com/mocs/MOC-119144/_TLG_/black-arrow-hypercar-concept It is a studless build in the new, 8 studs wide Speed Champions style. Some rules had to be followed: only certain types of car bases, wheels, fenders and windscreen are allowed, cockpit have to be closed, fixed dimensions (wheelbase, width, and maximum length), build must fit a full minifig with helmet. I prefer the brick built solutions to keep the flexibility of the used parts in further builds, and therefore stickers are not used. My intent was to keep the build smooth and to add lots of details: for example the air intakes, the rear wing, the side view mirrors etc. . Maybe the most challenging one was the double headlight. I tried to fill every unnecessary gaps and therefore some tricky build techniques are used. There are two versions of the front assembly : 1) the double headlight version which is a bit more extreme and 2) the simple headlight version which is more solid and sturdy. The model has space for one minifigure. I suggest to use a helmet or small hair. Thanks for visiting, _TLG_ Black Arrow 01 by László Torma, on Flickr Black Arrow 02 by László Torma, on Flickr Black Arrow 03 by László Torma, on Flickr Black Arrow 04 by László Torma, on Flickr Black Arrow 05 by László Torma, on Flickr Black Arrow 06 by László Torma, on Flickr Black Arrow 08 by László Torma, on Flickr Black Arrow 07 by László Torma, on Flickr
This is my latest finished pair of Le Mans race cars from the 2017 race: Chevrolet Corvette C7.R. The scale is 1:20, like in Legoland. This is purely display model without interior, engine or functionality (apart from rolling wheels). There are building instructions here: http://brickhub.org/i/220 The sticker sheet includes the stickers of the #63 and #64 models. Construction started after the race where I was asked to build this model. Members from my local LUG were helpful in giving me constructive criticism, and the design of the car only took around 3 weeks. As usual I use Griddy for the design document: Here are some shots from the construction process: You can see how I struggled with getting the lines on the sides right: And some times progress was... reversed: The body work below the windows was also a challenge: The rear end has mostly undergone refinements rather than complete redesigns: And the same can be said for the front: As you can see, I'm using both sides to experiment with various ideas: Also the roof has received many reconstructions. The transition between the windscreen and roof was difficult to get right: See how the windscreen is flush with the side windows, but not the roof here: Finally the car was finished and I added some simple paper-based stickers: I'm quite pleased with how the it was possible to build in this angular fashion and still end up with a easily recognizable result. Next up on my "2017 Le Mans GTE PRO" grid recreation will be either the Porsche, Ferrari, or Aston Martin. LEGO911 has already made a very nice Ford in this scale, so I will focus on those other models first... and of course the impossible TS050!
This is my 1:8 scale model of the famous Jaguar D-type customer race car. It won Le Mans in 1956 and in 2016 became the most expensive British car to sell at auction (about $20million). I used scale drawings and tried to be as accurate as possible, even with suspension points etc. The front clam shell and boot (with spare wheel) open but I couldn't get the (tiny) doors to open and keep the right side profile. To be exactly the same scale my Stratos should be 3% bigger but they look nice parked together. There was also a factory race car with a closed cockpit and a road car called XKSS. I will be making both of these too.
I have built a custom Le mans lmp1 class racing car. this car would race in the 24 hours of Le mans, held every year in June. Feel free to leave comments and feedback, would love to hear what you have to say. More pics on bricksafe here.
Update! I have updated the model substantially and made building instructions Instructions here: http://c-mt.dk/instructions/models_car-Porsche919.htm See my last post for more images of the latest updated model This is Porsche's entry into the LMP1 Hybrid class of Le Mans 2017. It will most likely be either this car or the Toyota TS050 Hybrid that wins the big race next weekend. This model is in scale 1:20. Shown here is the #1 car driven by Neel Jani, Nick Tandy and André Lotterer. Notice the "24H Le Mans" plackard on the side indicating the Le Mans trim. It will be easy to change to the #2 car (the other Porsche 919 Hybrid at Le Mans) by simply changing the three parts with the "1" to "2". This car can not be uploaded to LEGO Ideas because of the ongoing LEGO/Porsche collaboration. It would have been cool with a "The hybrid LMP1 cars of Le Mans 2017" project. For WIP pictures of this model, see the Toyota TS050 Hybrid topic:
With the 24 Hours of Le Mans approaching this weekend and seeing some other LMP cars on here recently, I decided to post as well! This is the Audi R18 in 2016 colors, on its last race year, more description below. I've been fascinated with the Le Mans 24 hour Endurance race since I was a little boy. My father shared his passion for auto racing with me and naturally, I also got hooked! After recently visiting an World Endurance Championship race this year and seeing a life sized Porsche 919 made half out of Lego and half out of a real car, I couldn't resist designing my own (although not quite as big). I know there are already a few current Lego sets that feature racecars like Speed Champs, but I wanted to design one that had a higher level of detail and really showed off the beautiful design of the LMP class. This design was done using the studless technique to keep the aerodynamic feel of an actual car. It is quite sturdy and uses standard Lego bricks/panels/slopes without requiring specialized body moldings. The car measures 11 inches (28 cm) long x 5 (12.7 cm) inches wide x 3.5 inches (8.9 cm) tall and is equivalent to 1:16 scale. It is just a bit bigger than minifig scale, although a minifig will fit inside the cockpit after removing the roof which easily comes off of two studs. The car can roll on a flat surface and has about 4 mm of ground clearance. I added racing numbers on the side panels and front for fun. Obviously more stickers could be added to make the car look even more like an actual car highlighting all the team sponsors, but I chose to keep the look clean.
The car is finally done with building instructions and all! The model can easily be modified to be the #7, #8 or #9 car - simply exchange the side mirrors and number plates (if you build it with stickers) The model is by far one of the most complex cars I have ever built. You can see all the details in the instructions: https://brickhub.org/i/428 The most challenging details are by far the triangular sections of the livery. While these are stickers on the real race car, I want to have as much being brick built as possible. This is also the reason why the model looks decent even without stickers. I hope you enjoy the model and instructions. This is probably the last model in a while for which I will make stickers in the instructions. I have completely underestimated the effort involved! BELOW IS THE ORIGINAL WIP POST: . I want to build a Toyota TS050 with the low downforce package to be used at Le Mans this year. We will see this package for the first time at the race at SPA this weekend. First I have to determine the size. I'm currently considering 2 scales, so please give me other suggestions if you have any. The first scale is 1:20 (LEGOLAND scale). It is proven and well known. I have experience building in this scale, but it might not be large enough to capture the details that I would want. The other scale would be where the Porsche GT3 wheels fir (roughly 1:10). This scale allows for all details at a high level, but sacrifices the windscreen and might take too long to build: I would like to have the model ready for Le Mans this year (hence the low downforce package) My goal is to have a non-functional model where emphasis is on adding visual details. Experienced builders and enthusiasts. Which scale do you recommend? I will use this thread to show the complete design and build process. Feedback (both positive, constructive and "Boo - Toyota will never win") is welcome. Update I have started designing it in scale 1:20 The base dimensions are: Length 4650mm => 29 studs Width 1900mm => 12 studs Height 1050mm => 16.4 plates ~ 5.5 bricks. I'm using this as my design sketch. It is made using Griddy and... mspaint :)
Hi all, When I originally made the MegaMOC 2014 Le Mans Series Racing diorama, I would have liked to do it with CLASSIC (1960-70) cars. But I simply didnt dare to do it; The cars seems extremely complex! But lately, other builders have turned out some pretty impressive classic racecars. Here´s some "tests" of mine, to see what could have been, had I dared to go down this route; First off, a Ford GT40, inspired a lot by GallardoLU´s do; Okay; so the car is held deliberatly in a single tone. Lovely racing colours and stickers are not done for this "what-if" builds... The car has taken quite some time to do, but -curiosly enough- the finished result does not use particulary complex constructions. Nothing illegal, and the car roll really well. One of the important point of a GT40, is it´s height; This car is a stunning 3 plates lower than f.x. my McLaren F1 GTR! (No, I doesnt fit a whole minifig...) Second up, I tried to cram M.Cara´s fantastic Prosche 917K down to 6(7) wide. Here is the result; Of course, no minifig can be seated here... Car rolls very well, and construction is not illegal, although highly unorthodox (I mean; just look at some of the pieces used...) The idea to use the white teeth, which curves exactly like a curved slope 1x4, comes from M.Cars´s car! (It´s the only place I´ve seen that used) Needless to remind you all, that a heavy set of Martini Racing stickers REALLY does this construction a huge favour!!! A last farewell photo of some of my latest cars together; Ciao!
