Showing results for tags 'buggy motor'.
Yo there. After complete lack of inspiration and miserable attempts at building came up with this. Probably will need some color randomization or something, otherwise getting there so far. Imo shall an apocalypsis start, gasoline would be real tough to find (diesel seems to be more omnivore) so electric buggy powered by a mini nuclear reactor mwahahahahah. Albeit getting uranium might be harder than fuel... or not, who knows. Pictures taken with smartphone as the camera is being repaired and camcorder doesn't take great pictures, sorry for of quality for now. Powered by BuWizz V1, twin Buggy Motors directly powering tumbler wheels from fastest output, front hockey spring rtc through m-motor. Rear winch through m-motor worm-8 teeth gearmesh and single pulley in the hook itself using mechanical advantage principle. Cya l8tr
Now for something completely different: A Spyder from the future - the Turbo Racer's AMC Ultra - and its opponent - the Police Interceptor MM Falcon PS (both based on @rm8's chassis for his AWD prototype) Now you can play Outrun - but for real! UPDATE: This series of RC cars will get updated in the future with new additions. UPDATE2: It was time for a logo and here it is (might be subject to change)
- 14 replies
- futuristic
- rc
(and 4 more)
Tagged with:
Good people of Eurobricks, let me give you my first take on the planetary hubs: Please excuse me for the lenght of the video, it's meant to show the developement stage by stage. I had big expectations towards the new hubs, since they've been announced. I realised, these hubs will solve the problem of the stress on drivetrains, yet will raise a new challenge. Due to the increased torque on the wheels, the frame (chassis) and the bracing of the suspension will be the new weak link. A wanted to have a finalized rig to the date of the release of the hubs. The backbone of the design came from a five years old chassis concept, it was a non motorized chassis: To mimic the geometry of the new hub, I've used the old ones with some extension, so it can be easily swapped, when time comes: The concept of the chassis came together quite well, thanks to using techniques well practiced in my early years. But there was still a long time till the release of the new hubs. Driven by curiosity, I've planted two PF XL motors in the middle of the chassis, making them drive two axles each. One for the front axles, one for the rear ones. No additional gearing has been added, the motors were connected straight to the differentials. Of course it had to be tested, hat's the part around one minute into the video: https://youtu.be/PGQpUrOS-NQ?t=59 Came with a surprisingly satisfying result, despite the usage of the old cv's and hubs, yet it was understandably far from being a "crawler" it meant to be. Also at this point I was short of claas tyres, so I've used some similar size rc tyres on the front 4. Got the tyres eventually, still a lot of time till the hubs coming though. As the final design was gonna use 4 buggy motors, time came to make the change: Same principals, like with the XL motors: No gearing added (slow output used), 2 motors drive the front, other 2 for the rear axles. Now feeding that much buggy motors would require 4 buwizzes. Or one well sized rc lipo that can comfortably supply 2 sbricks. 4 buwizzes cost about 400-450 pounds, while the lipo comes for 30 pounds. Any question? At this stage (still no new hubs) it was an obvious, yet pretty crazy idea to hit the tarmac. So I did. That's what you see at 2:16 in the video: https://youtu.be/PGQpUrOS-NQ?t=136 I had a lot of trouble that day with the bluetooth connection, brought a head on crash int o a container. It was heart-, but no plastic breaking. Finally the hubs came by the post and the picture got full. I've also planted another servo for steering (2 in total now) Indoor durability test at 3:27 https://youtu.be/PGQpUrOS-NQ?t=207 Climbing test (60 degrees) at 4:18 https://youtu.be/PGQpUrOS-NQ?t=257 Hereby I apologize for the dark enviroment at this recording Peek on the suspension at 3:12 https://youtu.be/PGQpUrOS-NQ?t=191 Lego should not be used outdoors... ahm, okay... Outdoor test from 4:55 in the video. https://youtu.be/PGQpUrOS-NQ?t=295 I came to the verdict, that the new hubs worth their money. In a usage that abusive, you see in the video the hub-cv connection definitelly require some lubrication. I've been using silicone oil and no downside appeared so far. Here is the difference it makes: That's it so far, a little spoiler at the end of the video. Hope it's gonna catch some expert eyes...
- 8 replies
- planetary hub
- 8x8
(and 4 more)
Tagged with:
So recently I redesigned my Offroad Buggy, making it more compact with full suspension & better body design. It took about 1-1.5 hours to build. The car is powered by a single buggy motor (slow output), and steered by a servo. It is 39 studs long, 21 studs wide, and 15 studs high. The front hood opens up to make suspension change easier and to reveal the fan (I had hoped to add a V6 & more pipes/tubes from the fan, but I ran out of room) Here's A cutaway of the side- I used soft wishbone suspension in the front and hard suspension in the back, but both can be swapped for fully hard or soft. The rear drive is straight motor to axle, so no differential. And here's the underside: Here's a short video of it in action: Hope you like it! Have fun building!
- 2 replies
- moc
- buggy motor
(and 2 more)
Tagged with:
This is my attempt at building a proper and most importantly; fun to drive ripsaw with somewhat realistic performance. The 8 buggy motors and 4 BuWizz seem to do the trick.. I tried to replicate as much as i could from the original design, obviously the drive-train works differently; the real EV1 has 1 motor with a clutch system in the rear differential to power the tracks from the rear alone, which i did try to replicate by adding the fake V8 and rear diff, which does function, but i disconnect it most of the time while drive outside because it has a habit of getting jammed by leaves, rocks and twigs, the gears used to connect to the fake V8 are all exposed. Here the sprockets are powered in the front and rear and each is connected directly to the slower output of 2 buggy motors, giving this thing crazy speed and torque. The suspension is set up like the real EV1 and works fine, but does require a track tension system, the real thing has a suspended front sprocket to keep tension on the tracks, in this case it would mean loosely suspended buggy motors, an idea i did not like and did not try, yet. I am using a simple lever, spring and wheels to keep tension on the track but it works fine and looks ok. For the body i tried to capture the look and feel of the real thing, using as little as possible panels and using beams for the boxy look with just the exposed framework seemed the right thing to do, i am sure it is filled with illegal connections, i go by the rule: "if it fits without force, it fits". The body is surprisingly solid, it can be lifted from several positions and it can take some abuse from driving, and abused it, i have.. The are 2 seat for Technic figures and the electrical wiring functions nicely as a seat-belt for them. I have added 2 sets of LED's on the top bar, i do not think the real EV1 had that, but it seemed the most "natural" position to me and it works nicely since they are aimed down a bit. And here you can see it in action! please leave a like if you can and help out my tiny channel: I hope you like it!
Good Day. Continuing my futuristic series of racers (Ximos , Xonox & Azimus) is this one - popularly called "Bugeye" in Xalax races - Scarab in 1:10 scale Features: BuWizz v1 2x Buggy motors RWD independent suspension m-motor with return to center working steering wheel detailed 1:10 openable canopy light up power core and "dashboard" Overall this was just a filler build with very basic chassis that served as a test platform - bucket seat with actual driver, front suspension with only one shock (part #48912), independent suspension built around buggy motors. This was as well an excuse to use some "new" Bionicle parts on a build and SILVEEEEEEEEEEEEER!!!!!! In the end it turned out OK, but steering was somewhat weak leading to a crash into my pet roomba effectively destroying the car (driver was okay so crash safety test passed?). Incomplete LDD file (the chassis and seat is there, only missing bodywork, power core and steering wheel/dash assembly. download Bonus: Crashed car and fuming driver. Cya later!
- 9 replies
- buwizz
- buggy motor
(and 1 more)
Tagged with:
Hi everyone, I have many lego technics sets and thousands of lego bricks for making MOCs and MODs. Therefore, I would like to share and introduce my new channel on youtube. I would happy to share and help or ask help from you by touching your interests what I did. Please subscribe and keep watching my videos, I will upload at least one video every week. Many thanks in advance for watching, Keep building and happy bricking!!
- lego technic
- lego rc
- (and 7 more)
A few months long ago, I bought the 5282 Rc Buggy controller to work with the battery box and the buggy motors. As of yesterday, I found out that my controller's left switch (The Very Important Drive Switch) had up and died, leaving the other 3 switches working fine. (2 toggle on the back, steering on the front) I have tested my two buggy battery boxes (6293c01 & 6272c01), cables, and buggy motors and they all work fine. I was wondering if anyone else has had this happen to them before, and whether you all think I should buy a new one or get it repaired. Picture of what the controller looks like:
- 4 replies
- broken
- buggy motor
(and 3 more)
Tagged with:
Hey all, this is my first post! I built this car roughly in an hour. It is based off of the Baja Buggies that are pretty awesome, and inspired a bit by the Class 1 Unlimited Buggy by Agrof. This car is powered by a Buggy Motor to a differential, and steered by a Servo. I think I will try to add Long Travel suspension to it, but for now it has no suspension. Let me know what you think- I would love advice! :) (Edit) Here's the Underside of the Car
- 4 replies
- racing buggy
- ir
(and 7 more)
Tagged with:
Having finally set free the buggy motors from TC16, it was time for something speedy again. Having seen the new 2019 transporter, that scale got me again, so making a car "compatible" with that set was very interesting. And having 8649 box on display made it clear which one I wanted 2 make. After a day of non-stop building this abomination somewhat resembling the original was born: The build was based off this year's Corvette wheelbase - 20x15 studs. 8649 has oversized wheels, giving it a cartoony apperance, but that wouldn't work for this one as space in the rear was required for a double buggy motor setup. Low profile tires in combination with old rims were a perfect tuner combo and gave resemblance to the 68.8 six spoke wheels. This also allowed to place the rear wheels much closer to the buggy motors using a non-standard 36z - 16z gears combo (1:2.25) with half-stud on-axis offset [see picture below] powered through the slower, outermost motor output to an approximate 2000rpm to the rear wheels. This gear combination resulted quite reliable when braced properly and withstanded all crashes, slides and racing that was thrown at it. In contrast, the front axle is a real mess. Having to place the m-motor right after the BuWizz made it really weak, and the flex axles make it hinge forwards. It does stay in place though due to all the bracing, so good enough? Also low-pros are amazing for drifting, which makes this vehicle very enjoyable to play with . Bodywork-wise it is NOT a "modern beauty" but carries the approximate lines of the original model. All the interior details are present - double NOS bottles in the rear, Red bucket seats and a tuner steering wheel (RHD version for some JDM powah ). Supercharger was a no for me - it looked terrible on the original. Big a$$ exhausts were kept to annoy the neighbours In the end it is not fully compatible as it probably wouldn't be able to drive up the ramps, but does drive cool. Welp, here's the video and LDD file https://rebrickable.com/mocs/MOC-26855/syclone/mini-rc-nitro-menace-8649/ Best Regards, Dan. Cya later!!!
- 7 replies
- buwizz
- buggy motor
(and 2 more)
Tagged with:
MPATEV-01 -> Multi Purpose All Terrain Vehicle 01 LDD file DOWNLOAD The attachments and other photos: WIP TOPIC MPATEV-01 -> Multi Purpose All Terrain Vehicle 01 Hello there! haven't been on the forum for some time and seeing such a contest pop up was a truly delight. Of course first ideas were of the movies "Martian", "Avatar", and "Interstellar", and the idea of building a spaceship seemed exiting. Therefore, i made a sketch of a VTOL transport ship: However building a freighter or a spacestation didn't exite me so much afterall (absolutely nothing to do with my unfinished tc15 plane ) so the next obvious idea was a rover. A human-manned one of course. Seeing that the currents WIPs were using wheels, I had a quick browse through lego sets of space/sci-fi themes and quickly found the Exo-Force 8118. It had a combination of double tracks in front and a single wheel in back that got me interested, as it was unusual and cool-looking, so this sketch came to life: It was originally planned to use brick-built tracks on front but small track links with turntables for central wheels should work. Most probably double offroad motorcycle tyres on rear (better start saving up for PP wheels duh). Obviously doubly buggy motors with 1.667:1 reduction + nuclear reactor BuWizz to power this thing. Current progress:
[MOC] RC drift car
syclone posted a topic in LEGO Technic, Mindstorms, Model Team and Scale Modeling
Aircraft ain't my thing, dumb ideas are Basically rear end was a concept from 2016, rebuilt it in october last year as I wanted to test whether a counterweight placed in the rear of a vehicle would help with "drifting". Of course, this was paired with the best lego motors (2x mythical buggy motors), BuWizz (1.0 ) and not the grippiest floor tiles, producing a very fun experience (donuts, 180° turns, and if lucky, something resembling a drift). The steering department was done with a M-motor RTC-ed by a hockey spring as always. Controlled using the beta BuWizz app, which was a nice experience and luckily suffered a lot less connection issues than the older counterpart. Bodywork. Tough department. Looking back at it, could've done a better job on the front, but wanted to try something different to classic bionicle eyes. Was able to place 2 Technic figures inside tho. The video was thrown together today (3 months after finishing ) so as to finally dissasemble this thing. Any additional pics will be in the same Brickshelf folder. INSTRUCTIONS Download here (302.9MB) And the mandatory belly shot: Thanks for reading!- 6 replies
- buwizz
- buggy motor
(and 2 more)
Tagged with:
Hello everyone! It's been a little while since I last posted; things have been busy with school, some health problems, and other things, but now I'm back with a fresh MOC, a RAM pickup truck, powered by BuWizz and 2 buggy motors! Here's a video of the model: I was fairly satisfied with the result. In low gear, this thing generates a ton of torque and still maintains decent speed, although the open differentials and low ground clearance make it struggle off-road at times. In high gear, the truck achieves decent speeds, but only on very flat surfaces. The biggest issue in high gear is that the whole drive train spins very fast, to compensate for the gearing down of the planetary hubs, and so a lot of energy is lost to friction. In summary, the features are: • 4x4 drive with 2 x buggy motors • Planetary wheel hubs • 2-speed gearbox • IFS and live axle rear suspension • PF LED headlights Here are some more photos of the model: The full photo album is on my BrickSafe here: https://bricksafe.com/pages/Teo_LEGO_Technic/ram-pick-up Overall, it was a fun little experiment. For my next MOC, I'm planning to build a rock crawler to compete in a local truck trial competition here in Toronto (If anyone is interested, please reach out, we will gladly take new contestants ). Hope you guys enjoy it! Any constructive criticism is much appreciated, as always, although I will say I'm done with this MOC and won't be making any changes, but I can use ideas on future builds.
So I was working on a trophy truck/buggy sort of thing with powered up in Bricklink Studio and I was wondering if it is possible to use a buggy motor with an adapter cable together with the large technic hub or train hub. If someone has the proper components to test this idea out, I would really appreciate it. Here is the sort of thing I am trying to build.
- 17 replies
- pu
- powered up
(and 1 more)
Tagged with:
You can find a sneak preview od the 3D printed sample on our IG: https://www.instagram.com/p/CLAKIt3B0PG/ Performance is around 10% faster RPM and torque compared to the 5292 motor (cca 20% more power). The polyfuse protection will be increased from 0,9 A to around 1,35 A - still testing the balance between performance and longetivity. Improved attachment possiblities, everything fits as it should in the studless building system The final version color will be between LGB and DBG. It will come with a 30 cm long PF cable plug, so it's compatible with BuWizz 2.0 and PF. Preorder here: https://buwizz.com/shop/buwizz-motor/ More info when it becomes available.
- 30 replies
Good Day! So I was really bored this friday, and wondered how small a buggy motor powered car can be, just for pure interest. As it turns out, 2 buggy motors don't occupy that much space XD. So here it is, mini-size car powered by two beasts, Azimus! Needless to say, it's crazy fun! Design was inspired by Lexus concept vehicle from Minority Report, and Deora II from HotWheels. Albeit it was mainly made that way to accomodate the BuWizz as low as possible and turned out different from both. Pics on G-Drive and Brickshelf whenever it approves. Video&photos below (click to enlarge) https://www.youtube.com/watch?v=RCORMtsr1JY Have a Nice Day!
Yes, it's an airplane that can drift! (or rather do doughnuts) But first, I think the video is the best introduction: Cool, isn't it? I was actually very surprised how well it worked when I first tested it - especially considering how bad my previous MODs were.. (in fact, it's probably the only RC set MOD that I've done that worked at all!) It was quite a challenge to fit all the electrics in such a small body, and was actually the main reason why I only kept one of the original functions... Features: Steering - powered by PF servo. Drive - geared down 3:5 from fast output of buggy motor. Motorized wings (not RC) - powered by PF M-motor. Easy to remove battery box - if not using rechargeable battery. Other Specs: Weight: 650g (with rechargeable battery) Original functions kept: 1 (out of 3) Theoretical top speed: 14km/h (at least) Links: YouTube: https://www.youtube.com/watch?v=6pTW9vclg0c Bricksafe: https://www.bricksafe.com/pages/mocbuild101/9394-rc-dragster-mod Contest voting: https://www.eurobricks.com/forum/index.php?/forums/topic/162664-ams-2-dragify-your-set-voting More photos: Enjoy! And don't forget to vote!
Hi everybody! Thats my new 4x4 rock crawler. So,here it is Specifications: -4 link suspension -portal axles -rc 108 mm tires -3s li-fe battrey -2 buggy motors -1 sbrick I hope you like it Let's see it in action!
- 14 replies
I found another use for clear 24116 panels... Lotus 340R. Lotus 340R 3 by James Tillson, on Flickr It has a LiPo, V2 and a buggy motor. It is only 600g and is way too fast for my kitchen. It has been crash tested (a lot). Lotus 340R 2 by James Tillson, on Flickr Lotus 340R 1 by James Tillson, on Flickr Video and better pictures coming tomorrow.
Hi everyone, Finally, I have finished a project which I was building since last September. It is the scale model of the Intrac 2011 snow blower which is/was often used in the swiss alps by the army and other communal parties. It was the aim to create another working snow blower after the success of the snow blower from last winter. The blower is powered by three buggy-motors which are all controlled by a separate Sbrick. Each track is driven by two PF XL motors. The snow blower shoot direction is controlled by two 9-volt micro motors and the height of the snow blower by one PF L motor. As power source I used two Buwizz as battery or a custom lipo battery. After a certain time in the cold I had the replace the Buwizz with the custom lipo battery. Cheers FT
- 74 replies
- lego
- lego technic
- (and 12 more)
Good Day. This is a small desert-rally styled offroader that was made in roughly 8-9 hours during New Year's holidays. Weight of 637g. Powered by BuWizz v1. Features: -4x4 drive with slowest output of buggy motor -Return-to-center steering (m-motor) -Independent suspension on all wheels -Over 2 studs of clearance under the car -Openable doors, bonnet and trunk. -Detailed engine bay & interior -Stickers all over the car, including rear-view mirrors & rear lights -Minor detailing on the outside (lightbar, antenna...) The suspension mechanism relies on the vertical movement of the drive input of the axle , changing main pivot point from one CV to another, allowing for each wheel's independent movement from each other. Video: Photos: Thanks for reading!
First of all please watch the teaser video from last week :) A couple of months ago everyone and their grandma tried to build an RC car going faster than 40 km/h. Although I don't have a properly working old Technic RC unit with the remote (somehow I have only faulty ones), I have the necessary amount of buggy motors and 2 BuWizz units, so I had to give this a try :) The build is not 100% pure Lego (although BuWizz is built to be used with Lego), but it still has the fun factor and of course the challenge :) The whole process turned out to be much-much longer than I expected, but at the end it was a success! I spent several weeks creating, improving and testing the car. The basic idea was to use 2 BuWizz units, 4 buggy motors and 4 Technic motorcycle wheels and to add only the minimal amount of components to remain light and fast. It had to be solid enough to survive all the crashes during the tests and record breaking attempts. I had dozens of tests at various locations until I found a proper track and the final configuration of the car was created. During this time a lot of parts had to be replaced as the axles were bent after a couple of runs, you can see the examples in the video. The car does not have a conventional steering to reduce weight. For the speed runs only small adjustments are needed, so the direction of the car is controlled by the speed difference of the wheels - there are two control sliders on the phone for each side of the vehicle. The faster output of the buggy motors is used, the gear ratio is 3:1. I tested several combinations to drive the wheels, the most successful one turned out to be the usage of 36t and 12t beveled gears. The speed was measured with the on-board GPS unit. The car was controlled mostly with my phone, but for the fastest run I was using an iPad (longer range). Even like this at full power the car ran out of range very quickly. I think it would be possible to go even faster with this car, but that would require a completely flat surface and a chase vehicle to ensure the controller stays in range. Maybe another time ;)
Updating the first post to have all three RC mods in one place. 1st version - Power Functions motors & SBrick control This is a quick and dirty upgrade, it started as a test to see if 2 or 4 L motors can drive the set properly, but things escalated quickly :) The aim was to add the PF components without taking apart the set completely or to change original structure, so obviously there are more elegant ways to hide all the motors and to upgrade the suspension and the drive train. The list of the added elements: 4 PF L motors (drive) 1 PF Servo motor (steering) 3 PF M motors (functions) 1 PF switch 2 8878 Battery boxes 4 PF lights 2 SBricks The 4 L motors can drive the car, but it has no extraordinary performance due to the added weight. The servo motor is struggling sometimes (especially when the car is not moving), it'd need another servo motor or some other solution for the steering to work smoothly. 2nd version - pickup-style body, 4 buggy motors, 2 BuWizz units After the first attempt I wanted to build something faster, so I had to reduce weight and add more power :) The back part of the truck was removed, I removed also a lot of non vital elements (like the fake V8). 4 Buggy motors were added and they were powered by 2 BuWizz units. The results was pretty fast considering the tracks and could handle the obstacles well. 3rd version - tracks removed, wheels added, pickup-style body, 4 buggy motors, 2 BuWizz units This is my third and last Lego 42069 Extreme Adventure remote control mod. After the previous version I did not plan to create another one but I was convinced by some comments on my YouTube channel (thanks for the tip!). Although I really liked 42069 on tracks, I realized that the top speed was limited by the construction so the 4 buggy motors could not show their full potential. I removed the tracks and added the wheels from the 9398 Crawler set. The pickup-style body was kept from the previous mod to ensure the car is as light as possible. The axles were rebuilt completely to fit the buggy motors and the wheels. The car is driven by 4 buggy motors and there's a PF Servo for steering. It is controlled and powered by 2 BuWizz units. It became surprisingly fast, I was curious so I added a small GPS tracker to measure the top speed - you can check the result in the video :)
- 36 replies
- power functions
- sbrick
(and 2 more)
Tagged with:
Im new to this forum so hi everyone ;) i have fun with PF from few months, and i want to buy a li-po and customize it to lego, i got two of real power hungry buggy motors, and i want to feed em' as much as i can :D I only need to know which voltage is maximum for motors, and for reciever, i have maken a research across internet, and ive heard that motors can handle max 16volts , and reciever just 9 volts, but ive heard too that motors can handle max 12 volts and that reciever too, on many forums i have read different numbers, so i have to ask here :) i have found light and small 14,8 volt li po 850 mah, in good price and i like it, but i dont want to burn my buggy motors and rest of PF, im wondering too about rc unit voltage, if it have 6 aa 1,5v bateries fully charged, it could generate 9v as normal pf battery box but when i compared them, rc unit is way better, and buggy motors are way faster, i hope that someone can help me :)
- 53 replies
- pf
- power functions
(and 7 more)
Tagged with:
Here is my Fiat 500 Abarth. Just like the real car it has the motor hanging out the back. It uses V2, LiPO, servo and a buggy motor. It is 450g It uses a direct drive from the fastest buggy motor output, no diff and plenty of positive castor. It has a tiny turning circle and will over steer. Video coming soon.
