MCNwakeboard Posted June 28, 2013 I finished building a suspended rail in the kid's room and thought I would share. Share this post Link to post Share on other sites
JopieK Posted June 28, 2013 Hope your engine driver isn't afraid of heights ;) Nice job although I would be concerned about the train falling, I notice the tracks do move a bit. Share this post Link to post Share on other sites
MCNwakeboard Posted June 28, 2013 Yes, there is some movement for sure since they are held up by 2x8 plates with only one side anchored in. I've had the large wheels come off a bit with the Emerald Night but haven't had problems with the Maersk Train. The corners were by far the hardest but I just built a base with plates and it seems to hold up well. Share this post Link to post Share on other sites
kieran Posted June 28, 2013 Its amazing that the only non LEGO in that solution is the screw in the bracket, brilliant Share this post Link to post Share on other sites
msx80 Posted June 28, 2013 Fantastic idea, i love it! :) btw you could try and build triangular support like the ones for shelves (like this one), maybe with standard click hinges. It should greatly reduce whobbling. Share this post Link to post Share on other sites
Hrw-Amen Posted June 29, 2013 Great idea for the children to lay in bed watching the train go around. I was thing of similar but the height meant scenery would have to extremely restricted and I want to be able to interact with it. Nonetheless this is a nice idea and I am sure the children will enjoy it no end. Share this post Link to post Share on other sites
fred67 Posted June 29, 2013 Nice to see an implementation of this in LEGO; it's really neat, and your nearly all-LEGO solution is cool. I decided not to do a suspended track for various reasons, but I think it worked out well. Share this post Link to post Share on other sites
MCNwakeboard Posted June 29, 2013 (edited) Thanks for the comments and suggestions. I created a shorter movie with the Maersk Train that shows the track from a bit further out. Edited June 29, 2013 by MCNwakeboard Share this post Link to post Share on other sites
dr_spock Posted June 30, 2013 Nice work. I like your implementation. Could the flexing work the plates loose over time? Share this post Link to post Share on other sites
Spitfire2865 Posted June 30, 2013 Maybe you could build a more sturdy brick base for the straights like you did on the curves. Share this post Link to post Share on other sites
SavaTheAggie Posted June 30, 2013 (edited) Very cool. None of my trains would clear the curves though, or in some cases the straights, either. :) Still, a very ingenious minimalist design. --Tony Edited June 30, 2013 by SavaTheAggie Share this post Link to post Share on other sites
timmyc1983 Posted June 30, 2013 This is super cool very lucky kids. What I would have done to have something like this in my room when I was a youngen Share this post Link to post Share on other sites
jfbat Posted June 30, 2013 Love the idea, but would be really worried one of the trains might fall off in time... Share this post Link to post Share on other sites
ronenson Posted June 30, 2013 Nice, very nice. Can your kid actually switch the train off, or do you have to do that? (Switching off as in: preventing the battery from draining, not just stopping the train). I can imagine it's hard to reach, which may be intended, depending on the age. Share this post Link to post Share on other sites
MCNwakeboard Posted June 30, 2013 Thanks for the comments. It has been up a week and I haven't noticed any flexing plates, but it is very possible over time. From the screws that I have tested, they seem to be hold up well. I usually stop the train in the corners since there a bit more support there with the Lego plates. I did consider using long plates to support the straight tracks but since the wall supports are 10 inches apart (two tracks) it would be fairly expensive to purchase long plates. Clearing the corners was challenging for the Emerald Night, specifically for the blinders in the front as you might have noticed it was changed in the film. I have to switch the battery on and run it for the most part, mostly be design since he is 10 months old. Share this post Link to post Share on other sites
nayrsllim Posted July 2, 2013 In Austin Tx, they have a McDonalds that is right next to a ToysRUs right off of rt 35 that has two different LGB trains that travel around the top of the ceiling like this. They go back into the kitchen and then come back out and sound off the horn. I never thought to do this with lego trains though. I have one set and when I have kids I am going to attempt to do this as long as my lady lets me. The extra track had to be pretty pricey.... Share this post Link to post Share on other sites
Carefree_Dude Posted July 3, 2013 (edited) Couldn't you use reverse slopping peices to build more of a bracket, so that the weight of the track pushes against the wall more, making it more stable? Or perhaps some technic crossarms that go down diagonally? Basically I mean make something so the track goes like this: At the bottom, you could stick another bracket and screw. _____________ ||||||||||||||||||||||||||||||/ ||||||||||||||||||||||||||||/ ||||||||||||||||||||||||||/ ||||||||||||||||||||||||/ ||||||||||||||||||||||/ ||||||||||||||||||||/ ||||||||||||||||||/ ||||||||||||||||/ |||||||||||||/ ||||||||||/ ||||||/ Edited July 3, 2013 by Goldenmasamune Share this post Link to post Share on other sites
MCNwakeboard Posted July 3, 2013 Couldn't you use reverse slopping peices to build more of a bracket, so that the weight of the track pushes against the wall more, making it more stable? Or perhaps some technic crossarms that go down diagonally? Basically I mean make something so the track goes like this: At the bottom, you could stick another bracket and screw. Yes that is an option similar to the one that msx80 suggested with a triangular support. Most of the stability issues are related to the track connections that don't have a wall support as those are only used every two tracks. Using the reverse slopes is an option but would require quite a few pieces. A diagonal technic cross arm would be a good option, just not something I had in the initial planning and but probably something I could test out to see how much it helps. Share this post Link to post Share on other sites
Dat Lego Posted July 6, 2013 That's amazing, love to have that in my room! Great work 'MCNwakeboard' Share this post Link to post Share on other sites
Gavinfuzzy Posted July 15, 2013 (edited) Cool way of execution, love the lego L as mounting brackets. Was thinking about doing something similar, but half my room is blocked off with full height cupboards. So to make a loop, I would have to have suspended track across the middle of my room. Seemed to risky. Not only for the train, but also for my safety. Well, if i were to do it, I would have mounted wooded planks around the wall, then put the tracks on the planks. Would probably result in a less shaky railway... Edited July 15, 2013 by Gavinfuzzy Share this post Link to post Share on other sites
Only Sinner Posted July 15, 2013 That's cute. It sounds like the baby is really enjoying his train setup! Share this post Link to post Share on other sites
