Showing results for tags 'trophy truck'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 19 results
  1. This is a small AWD Trophy truck that I was able to build thanks to the new components in the Skyline, specifically the 4L links and the 4L CVs: The biggest challenge with this model was in finding a solution for the FWD which would allow for high suspension travel and a good steering angle while being limited to 25 degrees of movement of the CV joints. I decided to bring the front suspension arms closer together, therebye creating the following suspension geometry which forces the front wheels to move in an arc: This in turn has several advantages: Reduces the angle the CV joint has to carry the power on the outboard side Allows for a higher steering angle Increaces the ground clearance on the bottom As such the front suspension is supported by 2 soft shock absorbers. Notice how the L liftarms hold the suspension together, supported by a white bar that goes through the cross hole: The rear suspension uses the normal equal length parallel arm design and it's supported by a combination of a hard and soft shock absorber which are placed at an angle to simulate a progressive setup: The front axle also uses double steering rack simillar to 42160 with 4 steering links to keep the front steering system as accurate, robust and stiff as possible (Please note, there are no 4L link yet available in LDD): Originally the driveline used a 12:20 gearing from the motor to the main shaft and than the 20:28 to the wheels. I used a couple of bevel 20 tooth gears so that a 5x11 panel could fit under them to protect the gears. But during video shoot, the solution proved to be a weak point, so I redesigned the driveline to use a pair of 16 tooth gears and a 12:28 diff combo which gives me the same gear ratio, yet with added strength: The only weakpoint left were the small CV recepticles: But after reducing the current limtiters from 2 to 1.5 A, I have yet to suffer a failure, even when suddenly changing directions. You can see the model in action here: I have to say this is a really compact, fun and almost indestructible model and I'm really happy how it turned out. Now if only LEGO could come up with a 4L version of the large CV joints...
  2. So I have been meaning to post this for awhile, so here are the few reworks I made. Updated Feature List -Full Body Suspension Front: Soft Double Wishbone Suspension Rear: Hard 360 Live Axle Suspension -Positive Caster Angling -Working Steering Wheel (controlled by servo) -Working V6 Engine & Spinning Fan -Altered Body Shape and Structure -Fake Engine Intake -Opening Hood -Cab interior (Dash, Folding Chairs, and Steering Wheel) (The working steering wheel function has been removed to reduce unnecessary wheel pivoting and weaker steering/suspension/axle structure) -The Working V6 Here's a video of it: Hope you like it! Have fun building!
  3. Hi everyone, Here is my newest MOC: A trophy truck. This moc is based on a trophy truck designed by TSCO, here is its introduction page: https://www.race-dezert.com/home/tsco-racing-aussie-trophy-truck-157676.html The specs: 2xL motor for drive 1 servo motor for steering Realistic and robust frame Double wishbone front suspension 3 link rear suspension Video: Instructions: https://rebrickable.com/mocs/MOC-50190/falconluan/tsco-racing-aussie-trophy-truck/#comments I'm trying to make the look of the car as authentic as I can, especially for the frame part. Here are some comparison pics: Am working on the shell now, please stay tuned. Any feedback is welcomed! Thanks for watching!
  4. Built this Trophy Truck Yesterday. Inspired by @Zerobricks Epic Rolug Trophy Truck, I built this truck with the same idea/principle in mind. Powered By 2xL motors & a Servo for steering. Features (So Far) -Full Body Suspension Front: Soft Double Wishbone Suspension Rear: Hard 360 Live Axle Suspension -Positive Caster Angling -Working Steering Wheel (controlled by servo) I may add a Light kit on my V.2 Design..... I don't know. I do plan, however, to add a working V6 or V8 under the hood. Because of the way it the suspension works, it is quite flexible..... .....ando you can fit five of these under one wheel with the other 3 wheels still touching the ground. Underside: Here's a video of it: Hope you like it! Have fun building!
  5. I am working on a trophy truck. I am having problems with the rear live-axles articulation. It only turns about 20 degrees. Is this because the links are located far away from the ball joint or is it something else?
  6. Here's my next MOC: I-Beam Suspension Trophy Truck Size: 36L, 16W, 16H, cm Weight: 702g Parts: 843 Features: - Independent front I-Beam suspension - Live axle rear suspension - Opening doors with locks - Opening bonnet with holder - HOG-steering - Fake engine - Modular construction Video: More pictures: Instruction available on Rebrickable: https://rebrickable.com/mocs/MOC-102687/paave/i-beam-suspension-trophy-truck/
  7. Hi, It lasted a bit, but I managed to finish this project and here I am. I would like to share with you my latest MOC - Armored Trophy Truck. It was designed mostly to test new Buwizz 3.0 unit and Buwizz motors. I also wanted to increase my own experience in building fast MOCs this time. As there are many trophy trucks out there created by many great builders I tried to take some different approach. So to protect cabin and motors, I put armor on my creation :) Thanks to panels both motors and cabin are protected from dirt, dust and stones. I also added roll cage to protect the driver. More details and presentation how fast this truck is you can check on the video below. Instructions are free of charge, I hope many of you will be able to build it and have fun playing with it outdoors as I did. Link: https://rebrickable.com/mocs/MOC-94026/keymaker/armored-trophy-truck-rc/#details Details and main functions: • dimensions LxWxH: 36x16x14.5 cm • weight: 1.22 kg • RWD drive (2xBuwizz motors) • steering (C+ L motor) with positive caster • double wishbone suspension at front • live axle suspension at rear • additional suppressors in rear suspension to protect frame during high jumps • high ground clearance • front, rear and whole truck chassis are protected against dirt, dust and stones • roll cage • rear wheels are connected via portal hubs - gear ratio can be adjusted More photos: https://bricksafe.com/pages/keymaker/9.-armored-trophy-truck
  8. Here is my first attempt of building a rc trophy truck: Thanks to @brickosouch for the Inspiration and sharing the stl files for ball bearing lift arms!
  9. This is my entry for BuWizz Fast Car competition. Features: - RWD with differential - Front independent suspension with positive castor - Rear live-axle suspension with long trailing arms - RC/Buggy motor for propulsion - Servo-motor for steering - BuWizz 2.0 I wanted to make a fast and agile car that will provide some real "turbo" experience of driving. The appearance is much inspired by BJ Baldwin's trophy truck. I recorded video in the last days of March, when we still had a lot of snow and it was a bit of luck to find some clean place to make video. I am still learning how to make good videos and this was a nice experience. If you like my entry, you are welcome to vote:) https://buwizz.com/buwizz-fast-car-competition/
  10. Long story short, I felt the need to improve on my two earlier models - BJ Baldwin's Trophy Truck (which looked awful because of the wrong proportions) and Tatra Dakar Truck (which was too tall and unstable at high speeds) - and thus this model was created. Essentially, my plan was to re-use the Tatra's propulsion system (2 x Lego RC motor + 2 x SBrick + 2 x Lego 8878 battery) in a lower, more stable chassis, and to add a body looking like a proper trophy truck on top of it, keeping the whole thing as light as possible. The finished model weighs just 997 grams and reaches a top speed of 15 KPH (with 120 grams added in form of a camera). Top speed was measured using GoPro 5 camera with GPS enabled. Photos & some reading: http://sariel.pl/2017/06/ford-raptor-trophy-truck/ Video:
  11. Hi, This is my WIP topic for a new Trophy Truck that I am planning (mainly because I have never used my Unimog tires). Tips are appreciated. Here is the steering system (I modified it from an abandoned chassis attempt) And here is the back of the chassis. It uses 2 RC motors with independent suspension. NOTE: The cross block in between the motors is only attached to one of them. It is used to prevent the motors from bending into each other. I hope that this will work well!
  12. TROPHY TRUCK MAD Since I have started building Lego technic I always want to build a trophy truck which can jump more than 20 cm drop. I have tryed many times to build fast chassis but drop resistant. And now I have made it, and all I have to say is: simple motor placement exactly on the wheels.
  13. Hi, Does anyone have any good tips on creating bodywork on MOCs? I got a lot of them from a friend + I have a lot to begin with. Any panel can be used in a suggestion (I probably have it). I am trying to add (detachable) bodywork to my Trophy Truck -TechnicRCRacer p.s. anyone know why this website takes forever to load? (in U.S.)
  14. Hi! I am trying to create a Trophy Truck, but the steering system is giving me trouble. Whenever I turn, the wheels get stuck and the whole car slows down. I am using the pre-2011 style hubs and suspension. Anyone have any tips? -TechnicRCRacer image removed due to limitations
  15. Dear moderators, please rename this topic to [MOC] Trophy Truck "Double Trouble" Hi everybody! Video is available, enjoy and comment! Here comes double trouble. Twin powered double trouble True liftarm energy! This is my new Moc. And it is ready: I am working on photo/video. UPDATE Here is some photos and info while you wait for video. Specs: Soft long travel suspension. Front independent with postive caster Rear live axle with built in Buggy motors. Rear wheel drive Self made stickers Tires RC4WD Dirt Grabber 1.55 (74 мм) - thats a copy of real BF Goodrich AT tires Spare tire RC4WD Mickey Tompson Baja MTZ 1.55 (83 мм) Weight is 1100 gr Electrics: Steering SERVO, Flying Propulsion 2x Buggy motors Fueled by 2xLiPo 3xLED lights Controlling thru 2xSBrick Internal space is filled with electronics. Unfortunately there is no free space for cockpit. Love this suspension, its articulation is great for me. I am happy seeing how it works) Suspension travel is about 4L. I will drop down and show it on video later. You know, LEGO suspension is always jerky, so you cant make big mocs drive straight, especially when it is fast and big. Positive caster helps to return wheels in center postition and fights with steering system backlash. It also makes shock absorbers work smoother and softer, IMHO. I dont like demonic "Monster" theme that is everywhere now...but this is good) Very good and realistic tires. Sad that there is no similar proportions tires in LEGO assortment. These are 75 mm with wide almost equal to medium 43 mm racing wheel. Spare tire is another type, cause I dont have 5-th Dirt Grabber. These 83 mm tire also fit in the arches, but they are bigger and harder for LiPos to rotate without stress... Model is driving fast enough for its weight and even drift donuts indoor, but outdoor shows the the weakest part - LiPo. I should try to lock differential thermistor for insane driving. After "baja" outdoor drive I replaced all damaged wheel axles and going to film its indoor's donuts and at asphalt outdoor to reach maximum speed. I hope it can reach at least 10 km/h. So "why double trouble"? - it is hard to fuel buggy motors. And here we have double of them. Here is full photo album http://www.bricksafe...rm8/BajaTruckDT
  16. Hello again, Today I present to you my final MOC before I begin college. At the beginning of the summer I had some trouble with the custom battery in this model so I had moved on to the corvette. Unfortunately I did not finish the corvette in time, but I did resolve the battery issue in this truck. This small scale trophy truck was constructed off the guidelines given for the real life truck. These trucks are massive, with 39 inch tires, and suspension travels of 24-28 inches in the front and almost 30 inches in the rear. The wheelbase is about 125 inches long and 93 inches wide. The somewhat light and agile body is paired up with a 700+ horsepower motor, making for one very fast vehicle. My goals in this model were speed and long suspension travel. In order to overcome the battery pack limitations, I purchased one of z3_2drive's custom batteries and receivers. This rechargeable battery really packs a punch. Drive is powered by a buggy motor and the steering by the servo motor. Now time for some photos! In an attempt to make the model stick out even more, I used the very unique blue panels from the 41999 BOSS Crawler. Though it did pose some limitations in the bodywork, I think it looks really, really cool. I also really like how the back turned out. Though the real trucks often do not have lights in the back, they certainly help to dress it up. The spare tires and the grill hide the rechargeable battery. Here you can see the large suspension travel in the back. Trophy trucks usually have 4-link suspension in the rear, which is what I emulated here. Just like the real trucks the rear suspension is dampened. For my model, I used the old pneumatic cylinders with only one port at the bottom. You can also barely see the battery hang down from above. Here you can see the underbelly, I am starting to get the hang of building studless! And the video, one of my bests to date. And more pictures: http://www.brickshel...ry.cgi?f=546838 I hope you enjoyed looking at this model as I had making and driving it. As I am leaving for college tomorrow without my legos, there will be no more creations until winter break. I will continue to lurk though! Regads, Tim
  17. Hi there guys! It's been a while since i built something, mainly due to grand theft auto V ahah... Anyway, i got sponsored by an italian lego shop called Mangiobricks so i decided to build something with their logo like it was a racing team :D I got inspired by Egor and his sunset truck so i decided to build my own version of a trophy truck! It has 95% tubolar chassis to keep it light and simple and the body can be dismounted completely, without compromising the rigidity of the chassis itself. Suspensions are really soft to absorb every bump and avoid rolls what else...the RC motor does its job, the truck drifts on smooth surfaces :D Measures: 30,5cm x 14,5cm x 13,8cm Weight: 550g Features: - Front independent suspensions - Differential - Tubolar chassis video:
  18. Hello all, While I was waiting for my BL order for my TC10 entry, I worked on a small trophy truck. It has indepentent rear trailing arms, drive from 2 L motors, steering from a Servo motor, power from a 9 volt battery through a Minizip cable, and an Sbrick. It isn't complete yet. Some pictures: Thanks for reading!
  19. it'll be so nice to finally be able to work on something else for a change... btw this is really a show model so don't expect crazy performance. here's another one. thank zux for it
