Showing results for tags 'racing car'.
Baby Porsche or VW Beetle tuning? This is a fictitious race car, I hope you like it :) You can support it on Lego Ideas: https://ideas.lego.com/projects/68cb5ef6-6e2c-40fc-9dca-0e4b7f3fe64a It is a studless build in Speed Champions scale, but with City wheels. I used only standard LEGO elements, the slopes with stickers are part of the set called 1968 Ford Mustang. Baby Porsche 01 by László Torma, on Flickr Baby Porsche 02 by László Torma, on Flickr Baby Porsche 03 by László Torma, on Flickr
Hello everyone, this is the latest work of MTC lego studio:AZURA LMP2 Racing Car Designed by CrMo2001 Here are detailed introductions to this work: -Long 47,Wide 21 (Lego unit) -2 × “control+ L motors” for propulsion -1 × “control+ L motors” for steering -LEGO Bluetooth control module -Front and rear independent suspension -Technic parts build chassis, Brick parts build appearance When designing this car, there are two main points, one is the suspension, the other is the appearance. The size of CONTROL+ components is very large, while LMP racing car is very low, so the Bluetooth hub is put in the middle, the front bridge module is on the front side, the drive motor is placed on both sides, and the layout of the rear bridge module is on the rear side. Otherwise, the height will exceed the limit and the appearance production will be affected. In a real LMP car, the driver's seat is not centered but, by habit, left or right. So I put the driver's seat on the left and the steering motor on the right in a symmetrical position. The CONTROL motor has a built-in code disk, so the L motor can be used as a servo motor and can be customized with Powered UP. The motors on both sides drive the wheels on both sides respectively, and the transmission systems on both sides are independent. This also eliminates the differential. The power of the motor is first transmitted to the middle shaft through four 16-tooth gears, and then to the wheels. To prevent transmission interference, 16 teeth on both sides are staggered by 1 unit. For the design of the exterior, I pay more attention to the continuity of the lines of the vehicle. In some places, in order to better shape the curved surface, the Technic parts are used. Brick parts are not dominant in the construction of some complex curved surfaces, but cylindrical and flat surfaces are basically preferred. I made my first attempt to add a clear windshield to the MOC. The windshield comes from 76139 (1989 Bat Mobile), and a black printed vertical line in the middle is worn away. In practice, the windshield is slightly lower in height and the front is too steep. But I couldn't find a better one than to 3D print one. Here is a more detailed picture, hope you can enjoy it. The LMP race car has a drop-shaped cab, which I tried to recreate with Lego. Some airflow channels are left on the side. Front and rear The Building Insitructions will be released in the near future, so stay tuned! Thanks for browsing!Thank you!
- 14 replies
- racing car
- azura
(and 3 more)
Tagged with:
Hello, feel the speed! It is my own hypercar concept inspired by real hyper and supercars. It is a 6 studs wide, studless model built from standard LEGO elements. The overall size is similar to the Speed Champions sets, but the wheels are from City sets as I wanted to keep the height to length ratio closer to the real sports cars. It can be combined with my other MOC Hybrid Truck which will be available on LEGO IDEAS soon too. If you like this car, please share and support the it on LEGO IDEAS: https://ideas.lego.com/projects/44e6dbbf-734f-4b38-84c7-2075b09495bb Many thanks! LEGO Hypercar concept1-02 by László Torma, on Flickr LEGO Hypercar concept1-01 by László Torma, on Flickr LEGO Hypercar concept1-03 by László Torma, on Flickr
- super sports car
- vechile
- (and 30 more)
TLDR: Super-detailed fully-modularized Creator-scale 16-wide MOC build of beautiful 1999 Le Mans-winning FIA LMP prototype. 903 pieces (including 3 round-plates-with-strings, 6 whips, and 8 “non-Lego” custom wheel parts). 1/15.2 scale: 16 stud wide, 38 stud long, 23 stud wheelbase Winner - with a bit of luck - of an exceptionally rough and tumble 1999 Le Mans in the hands of Joachim Winkelhock, Pierluigi Martini, and Yannick Dalmas. The LMR was the second iteration of BMW’s LMP car, designed and constructed by BMW with Williams F1, powered by a development of the BMW S70 V12 which the McLaren F1 had used to win Le Mans a few years prior. Longtime BMW racing partner Schnitzer Motorsport ran the team at Le Mans proper as well as in the American Le Mans series. The low and sleek car looked like a ufo compared to the competition. The LMR has a fairly simple and compact shape, but it’s not a brick… the subtle lines are quite refined and put up a challenge to capture smoothly in Lego. The entire nose build is a circus of surfaces all at slightly different angles, their mountings dotted here and there in precise positions over the tub structure. The roll-hoop and engine hump cowlings are jammed full of more angles and curves. The rear fenders tumble and taper back to those extremely compact multi-directional-snotted wing mount and taillight assemblies. The sidepods look simple but are full of some connections voodoo for their multi-hinged lower surfaces. The car's so slim there's really nowhere to hide much supporting structure. Wheel inserts and brake discs are designed in Cinema4d and fit into the back axle tubes of Lego's Icons wheel #42716. The spoke shape, offset and hub proportions were refined through a sequence of paper prototypes to dial in their scale, then the final design was high-resolution SLA resin printed and sprayed with Tamiya TS38 gunmetal (as are the backs of the Lego wheels). Graphics are a mix of printed stickers and cut vinyl. It's not quite perfect: the indigo color-shift blue vinyl turned out a bit too dark - needs a much larger surface area and strong light to really sparkle - and those delicate air-flow pinstripes need to be metallic on transparent substrate so the different white materials aren’t as noticeable. The open cockpit captures various details; Pi/BMW M digital dash, switches panel, electronics boxes all carefully studied, drawn in Illustrator, and shrunk down to scale. (I forgot to do the Emergency markings, so these are swiped from a 1/24 model and comically small) The rear bodywork is a large single assembly that lifts off, revealing that glorious V12. The rear wing and trailing edge of the bodywork (with those complex little taillights) is cantilevered off the end of the transmission. The intake airbox assembly lifts off to reveal 12 intake trumpets, the oil tank and engine ancillaries. Getting the radiators attach at angles flush with the wing plates on the ends of the sidepods was a triumph of Lego maths... A few stickers for the radiator faces and the cam covers provide some texture. The sidepods, splitter, and engine drivetrain are all separate from the tub following the construction and design typical of these cars; the bare chassis of these masterpieces of design and packaging is one my favorite views… The tub itself has a raised footbox with a rounded 'boat prow' profile which helped to channel airflow from the upswept nose underside out through the open sidepods. The remaining flat floor continues back to under the rear axle where the shallow diffuser tunnel kicks up. As always, thanks for looking and thanks for the inspiration, Prototyp These photos up at Flickr: https://www.flickr.com/photos/prototyp/ Stop by and say hi: https://instagram.com/prototyp_brickworks
- 8 replies
- creator expert
- prototyp
(and 5 more)
Tagged with:
Hi, guys! I know that, there is February yet and we're before March release, but let's start new topic! So, at first I want to say that 2023 wave is amazing. New brand, new mudguards, new windscreens! Whoah! And there are my speculation/cars I want to see in Speed Champions 2024: ~ Porsche 911 GT2 RS Clubsport 25 ~ Porsche Taycan ~ Audi e-tron GT ~ BMW M6 ~ BMW M4 GT3 & BMW M3 1991 ~ Ferrari 499p LMH ~ Ford Focus RS 2021 ~ Honda Civic Type R ~ Cadillac LMDH What do you think about my cars? What cars would you like to see? Show your speculation/wishlist.
- 352 replies
- chrome
- s1
(and 176 more)
Tagged with:
- chrome
- s1
- pirelli
- slick tyres
- slicks
- tyre
- slick
- tyres
- stripe
- striped
- orange
- stripes
- bolide
- red
- mclaren f1
- imsa
- daytona 24h
- le mans 24h
- wec
- le mans 24
- 24h lemans
- 24h le mans
- racings
- formula one
- formula1
- limit
- formula 1
- f1
- bmw
- lotus
- lamborghini
- jaguar
- bugatti
- koenigsegg
- pagani
- dodge
- camaro
- speed
- chevrolet
- corvette
- lego
- champions
- lego speed champions
- lego speed
- lego champions
- speed champions
- 2022
- speculation
- rumors
- 2024
- 2023
- new
- f&f
- furious
- brick
- fast
- fast and furious
- bricks
- elements
- part
- moc
- parts
- parts list
- instructions
- custom
- own
- cae
- my
- my own custom
- cars
- vehicle
- vehicles
- tire
- tires
- windscreen
- windscreens
- lego vehicle
- circuit
- mudguard
- daytona
- le mans
- mans
- spa-francorchamps
- 24h
- nürburgring
- lap
- laps
- racing
- race
- motorsports
- motorsport
- racing car
- racing cars
- finish
- line
- week
- finish line
- imola
- e-tron
- monza
- racing vehicles
- racing vehicle
- gear
- top
- top gear
- racing week
- weekend
- season
- summer
- spring
- fall
- autumn
- winter
- curious
- did you know?
- predict
- imagine
- prediction
- dream
- ferrari
- i want
- mclaren
- porsche
- audi
- ford
- limited
- edition
- motor
- etron
- quattro
- e-tron quattro
- ken
- block
- ken block
- hoonigan
- hoonitron
- gymkhana
- electrikhana
- ev
- electric vehicle
- mustang
- ford mustang
- dark
- horse
- dark horse
- m4
- gt3
- v8
- m
- hybrid
- m hybrid v8
- gt3 class
- aston
- martin
- aston martin
- safety car
- mercedes
- amg
- coupe
- g63
- off road
- off-road
- rally
- f40
- competizione
- nascar
- next gen
- next gen nascar
- sl63
- amr23
- mcl60
- v12
- vision
- gt
- supercar blondie
- concept
- forza
- virtual
Hi this is one of my F1 MOC cars. Its an 1980's ish Ferrari. google search for the car type . I have a Stud.io file if any one would like to make it. I still have to get some right parts for my real model.
- 4 replies
- speed champions
- f1
(and 1 more)
Tagged with:
Hi this is one of my F1 MOC cars. Its an 1980's ish Williams.google search for the car type . I have a Stud.io file if any one would like to make it. I still have to get some parts in the right colours.
- 1 reply
- speed champions
- f1
(and 1 more)
Tagged with:
Hi this is one of my F1 MOC cars. Its an 1979-1980's ish Mclaren. google search for the car type. I have a Stud.io file if any one would like to make it. As you can see my real model still has 3 more bits to change.
- 10 replies
- speed champions
- f1
(and 1 more)
Tagged with:
Hi this is one of my F1 MOC cars. Its an 1980's ish Renault. google search for the car type. I have a Stud.io file if any one would like to make it. As you can see my real model still needs a few bits I have to buy but it is complete apart from the wrong colours on a few bits Dave
- 5 replies
- racing car
- f1
(and 1 more)
Tagged with:
My MOC of a Jordan F1 car around 1998 ish. Images for car type. I have a Stud.io file if any one would like to make.
- f1
- racing car
(and 1 more)
Tagged with:
Hi this is one of my F1 MOC cars. Its an 1990 ish Williams. Image of car type I have a Stud.io file if any one would like to make.
- 1 reply
- f1
- racing car
(and 1 more)
Tagged with:
I saw this while I was looking at Vintage F1 cars to try to make. Lego Ideas Lotus 79 by Kozy . I did a model of this in Stud.io picture below. Took me ages to figure out how the front was fixed on. I like the model but I had a go at my own loosely based on his model design. Mine is 1 brick shorter and I got the side pods and rear wing 1 plate lower, which I like more as it fits better with my other vintage F1 models. I was surprised that when I finally finished my Stud.io model that I has all the bits to make it. Although not in the right colour yet. Google search for this car type. The 24307 Part the 1st plate on the side pod. As I have seen the 2018 Speed champions sets. I was thinking that the new triangle tile like on the ford fiesta rally car might be better. But they may not make it in black and I don't know it's ID number. 1st pic is the Stud.io render of the model by Kozy. 2nd n 3rd my real life as is and the finished Stud.io render. Dave
- 2 replies
- speed champions
- racing car
(and 2 more)
Tagged with:
Hi this is one of my F1 MOC cars. Its an 1960's ish Lotus.google search for the car type . I have a Stud.io file if any one would like to make it. This model is complete. It was a carry on trying to get the Dark green 1 x 2 tiles at a good price some sellers wanted over £2 each!
- 5 replies
- racing car
- f1
(and 1 more)
Tagged with:
Hi this is one of my F1 MOC cars. Its an 1990 ish Mclaren. Google search for this car type I have a Stud.io file if any one would like to make it. This one is almost finished I just need to find 2 tiles 2 x 3 for rear wing, I got 2 x 4 on at the moment. This is one of my fav moc's I have made
- 1 reply
- speed champios
- f1
(and 1 more)
Tagged with:
Hey everyone. I had a go at my own design for a Can-Am race car inspired by the McLaren M8 series. Your feedback is welcome.
- 1 reply
- Race car
- racing car
(and 1 more)
Tagged with:
