Showing results for tags 'small scale'.
Well, I was not really 100% happy with the buggy I made and in that post I asked for advice on drive axles. Unfortunately as I mostly only have old pieces (pre dark-ages) I could not make most of the suspensions So I tried one that I could use (I originally wanted to make a mini front wheel drive car) and made a mini car with what I could. I'm really proud of what has turned out, the truck looks like a jeep/hummer as is so freaking cute I designed the chassis so that the bodies are interchangeable. I think that a competition where everyone is to make a body for one type of chassis would be really cool, but i'm not famous so it seems far fetched Thanks guys, <forgot to add> The reason this car is a little slow is that my family forced me to purchase rechargeable batteries meaning that the output is 7v not 9v. I would get a buwizz but that is expensive
- 8 replies
- moc
- technic rc
(and 3 more)
Tagged with:
A few of you may have seen my earlier post about an axle, and this is where it has ended up. This is a chassis for a long wheelbase, lifted pickup truck. It features 4 wheel drive, steering, and solid axle suspension with coil shocks in the front and leaf springs in the back. Soon I will be building a Ford F-250 body for it. But enough talk, here are some pictures. Front axle, with panhard bar: Rear axle and leaf springs: Comments, criticisms, and suggestions are welcome!
- 13 replies
- technic
- pickup truck
(and 1 more)
Tagged with:
This model is the next generation of my Nissan-skyline-r34. On this version I reworked many things, such as engine, interior and exterior, improved stability of the model and made it more realistic in comparison with previous version. Instruction: https://rebrickable.com/mocs/MOC-65812 Dimensions: 37.5x15x12 stud (30x14.5x9.5 cm)Functions:1. Working Steering wheel2. Openable doors3. Working V6 engine4. Openable hood5. Openable trunk6. Adjustable spoiler7. Detailed exterior and interior
Designed model is based on my previous model Ford Bronco, but created in pickup version with fully reworked rear suspension and body (look and feel I kept as it was in previous Bronco version). During creation of this model, modular build concept is used to simplify the building process by splitting the overall process on three stages. Instruction: hereDimensions: 16 x 38 x 20 studWeight: 1100 gFunctions: Steering Control+ L motor Drive Control+ XL motor Front independent suspension Rear 3 link suspension Openable doors, hood, trunk Detailed exterior and interior Adjustable seats Modular building (body can be easily detached) Quick access to the battery box for batteries replacement You can change the torque just by replacing gears in the chassis
Designed model is based on the Ford Bronco revealed in 2020. During creation of this model, modular build concept is used to simplify the building process by splitting the overall process on three stages. Follow me on Instagram @anton.kablash Instruction you can download here: Ford Bronco InstructionDimensions: 16 x 38 x 19 studWeight: 738 gFunctions: HoG (detachable) Working steering wheel in the cab Front independent suspension Rear 3 link suspension Working engine Openable doors, hood, trunk Detailed exterior and interior Adjustable seats Modular building More photos in the Ford Bronco Album
- 22 replies
This model based on one of the famous Volvo truck - Iron Knight. The main idea was to replicate this truck in small scale and use for this just parts from Lego set 42123 McLaren Senna. Definitely not all shapes and parts of the original truck I was able to build properly, but I think it is compromise in scope of limited range of parts. Instructions: link to intruction Dimensions: 15x37x15.3 studWeight: 516 gFunctions:1. HoG2. Working V8 engine driven by rear axle3. Openable doors4. Detailed exterior
- 10 replies
Instruction can be downloaded here. After second version of the Ford Bronco I decided to build another pickup from Ford, really love powerful truck with double rear wheels and also I wondered to use handlebars as part of the front grill and now you can see how this part is used in the model.As usually I am trying to follow some rules regarding the building process, therefore in this model I also used modular building, to simplify the process model is split by 4 steps.Dimensions: 18.5 x 46 x 15 studsWeight: 952 gFunctions: HoG (detachable) Working steering wheel in the cab Working V8 engine Openable all doors, hood and trunk Detailed exterior and interior Adjustable seats Modular building
Hello! Some years ago I made a miniature version of the 8868 classic technic set. It's a 1:2 scale model of the original set. The pictures could be better, but I made them in 2010, back then I didn't care much about lights and background. Original: http://www.brickshel...y.cgi?i=3727866 My version: Folder: http://www.brickshel...ry.cgi?f=429085 I tried to make a model also of the V6 engine: Like the original, it has a pneumatic compressor: You can control the small pneumatic cylinder which can raise/lower the claw arm in the back with this pneumatic switch. In the original 8868, this switch is placed similar. (there are sticker copys about the original's stickers to show the arm's positions) You can steer it with HOG, and a micromotor drives the vehicle (unfortunately back then I used a cutted piece in the drive shaft, but it can be made with regular Lego pieces - I"m planning to make this mini 8868 again in a better way) Of course, it has cables for powering the compressor's 71427 motor and for the micromotor. The claw arm can be only raised, and a small rubber band is responsible for the backward movement: With the small 8t gear in the right side of the cabin you can rotate the upper structure. This is the mechanism to make it: http://www.brickshel...y.cgi?i=4453741 Video:
- 23 replies
- mini 8868
- air tech claw rig
(and 3 more)
Tagged with:
Hi everyone! This is my new MOC, a small scale version of my past Land Rover Defender 90, with which I got really frustrated. ( http://www.eurobricks.com/forum/index.php?showtopic=101819&st=0 ) It's approximetely technic figures scale. It has hand of god steering and suspended rear axle. Also you can open doors, hood, and back. Hope you liked it! See ya soon!
