Showing results for tags '42125'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Alternative Brick Brands
    • The Brick Frontier
    • CaDA
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 9 results
  1. Here it is, the return of the Ferrari brand into Technic:
  2. This is my alternate model for the 42125 Ferrari 488 set - Ferrari F12 Berlinetta Scale: 1:10 Parts: 1181 Size: 45L, 20W, 12H, cm Weight 988g - Independent suspension - Working steering wheel - Fake engine - Opening doors with limiters - Opening front part of the bonnet You can find the building instruction on Rebrickable: https://rebrickable.com/mocs/MOC-66207/paave/ferrari-f12-berlinetta/#details
  3. Travel back 90 years in the past and rebuild your LEGO Technic 42125 Ferrari 488 GTE into this replica of 1931 Hot Rod FORD Model A. All required parts comes in the set 42125 and no additional or spare sparts are needed. If you own the Ferrari 488 GTE, you can completely build this alternate Hot Rod with no restriction. This model uses 1329 parts of the set, which are 79.3% of the parts of the Ferrari 488 GTE. Follow this link to show all pictures, renderings, 360° animation and the story about the design process of this MOC. You can find this model with instructions here on rebrickable. Features & Functions independent suspension in front and back steering with knob (in the back) engine with 8 cylinders, driven through diff by the real axle openable doors openable tailgate with lock to locate the trunk box to transport usefull things that fits inside the trunk overnight bag that fits inside the trunk lifting jack to lift up the car 41cm x 23cm x 15cm (with closed doors) Here are some impressions of the model: Box and overnight bag The model comes with a transporting box and an overnight bag. Both fits inside the trunk very vell. Lifting jack Luckily there are enough parts left over to build a cool lifting jack with locking function. You can lift up the entire car and it stays in position. Version Cabriolet The model and building instructions are designed to make a Cabrio as well. Therefore, the roof is detachable easily for a quick summer drive. Scale, Sticker & Stability The Hot Rod fits in scale, vintage style and playability with my Vintage Custom Pickup - alternate build of 42111. I have never tried this model with stickers, but of course it is buildable and could look more "racing-ish". I am excited to see the first user photo of this model with stickers applied. Some people report about problems with the stability of the Ferrari 488 GTE - be sure, this Hot Rod is designed to be solid as a rock. What makes this model special The wheels are mounted in opposite direction, which is not really common, but looks way better on this model. Unfortunately this way the rims does not fit the wheel hubs. As a reason, this model can not use the wheel hubs for mounting the wheels, but uses two of the rear hubs as the headlights. If you have already connected the two parts of the wheel hubs (the light bluish with the dark bluish one), be careful separating them. Because the model can not use the front wheel hubs, these hubs are custom brick built in a clever way and works perfect. The real car Of course this Hot Rod FORD Model A is based on the real car. Here are some pictures of the 1931 original model: Instruction You get a premium high quality PDF-instruction with 412 building steps on 259 pages with clear images. Yes, this is a 18+ set, but the instruction is easy to follow. You can get the instructions for 9.90 EUR on rebrickable. Here are some example pages of the instruction: Have fun with this model. I wish you happy building and promise an enjoyable building experience, as well cool playing and displaying. Thanks for the attention.
  4. My next alternate model of the 42125 set - Dune Buggy It's a replication of the well-known Meyers Manx dune buggy. Also the BF Injection in the GTA games. Size: L35, W19, H13, cm Parts: 665 Weight: 610g. Features: - Opening bonnet and trunk - Full independent suspension - H4-engine - Working steering wheel. A width is 2 studs shorter, than it's in the original set, so I used the floating differential suspension system. Working well. See the video: Instruction is available on Rebrickable: https://rebrickable.com/mocs/MOC-76011/paave/dune-buggy/
  5. Since the 42125 Ferrari set has blades... The features are: - Rotating propellers - Collective pitch control - Folding blades Video: More photos: Rebrickable page: https://rebrickable.com/mocs/MOC-68779/paave/helicopter/#details
  6. The car definitely needs a topic like this to look more like the real thing and make it better overall. Here are some ideas: lower the car, fill all holes in the chassis and the bodywork, flip the small panels on top of the the doors around, get rid of all visible blue pins and coloured axles, different wheels, improve the interior by filling all gaps, make the side skirts out of some technic beams like on the 42096 instead of these stupid rotor blades, different steering wheel, ......
  7. Maclaren Senna Sabre 1:10 scale. Just basic functions but with lever operated doors. Normal Senna built on this chassis coming soon. McLaren Senna Sabre by James Tillson, on Flickr McLaren Senna Sabre by James Tillson, on Flickr
  8. Ferrari F40The most iconic supercar from the edgy eighties. The last hardcore beast signed off on by Enzo. The absolutely definitive Ferrari. The legendFunctions- Working steering wheel- 5+R dogleg gearbox- Fake V8 working engine- Independent double wishbone suspension at all 4 wheels- Openable doors, front and rear clamshell- Manually operated pop-up headlights Design and InspirationThis creation is inspired by the fantastic work of @jorgeopesi from 7-8 years ago, reborn with contemporary Lego Technic pieces. I kept the gear shift mechanism of the original, and changed the gearbox to a modified version of @Rudivdk's 5+R manual transmission. Some exterior solutions also take reference from jorge's version, but everything else from steering, suspension setup to engine, body panels etc are my own designs. It's not a mod by any means, but hopefully a worthy remake. With the evolution of LEGO parts palette over the years, I have also managed to add more details to the model, such as: - cooling slots under the rear spoiler - exhaust manifold and a see-through rear grille - detailed interior and more representative racing bucket seats - detailed engine bay with all the bells and whistles (intercoolers, airboxes, etc) - as well as, the iconic line that runs across the entire car - also worth mentioning is the 3-piece rod hidden in the rear bumper that supports the rear clamshell when it's opened. Construction The car was originally built with parts from set 8145, 8070, and additional parts from my parts bin. However, 2x 42125 is also a great base, which provides 70% of the parts. The missing 30% is listed here. When making instructions, I have also tried to substitute expensive parts such as Red 14L soft axles, or Red 1x6 thin liftarms with more affordable solutions. The wheels used in the instruction are also from set 42125 to save cost, but if you want to use standard technic 56mm D wheels - part 15038, just need to use 7L liftarms instead of 6L as the rear wishbones. These wheels will stick out a bit and provide a slight rake, giving the car a more aggressive look. The wheels used in photos are third party/non-lego parts. They are great (provide a good offset between the front and rear wheel covers, making the rear wheels look "deeper") but perhaps not for the purists. You can send me a private message if you want to know where I get those wheels from, but note that I'm in no way affiliated with the seller. Neither can I guarantee the quality of the product nor seller's trustworthiness, so tread at your own risk. Instruction hereThe instructions booklet is 666-page long and contains 828 steps (talk about "Manifest" if you watch that show :D). You will find 11 modules and 10 assembly stages in between to combine the modules to form the final model. You can follow the instructions in the chronological order of the pages, or skip around, build all the modules first (in whichever order you like) and then follow the assembly steps, just like how real cars are built in the factory. Either way should bring you a enjoyable building experience. Thank you for reading this far. I hope you enjoy the write-up. Look forward to hearing your thoughts More pics here (bricksafe) Sneak peeks of my upcoming creations
  9. Here's my replication of the Ferrari Daytona SP3 made with the 42125 parts. Not perfect shaping, but the best panel configuration, to my mind. Coming with the free instruction Features: - Opening doors, bonnet, trunk- Independent suspension- Fake engine- Working steering wheel Video (including instruction): More images: Rebrickable page: https://rebrickable.com/mocs/MOC-108295/paave/ferrari-daytona-sp3
