Showing results for tags '75972'.
I was inspired by Overwatch set 75972 (Dorado Showdown) to create this modular small town auto repair shop with 1950s tow truck. I call the building Smokeys Garage. The building features a raised platform for cars to roll onto and be worked on, with folding ramps to keep the broken-down vehicle (in this case a dark blue Ford Anglia set 75953 MOD) in place. The front of the building. I've been working on this tow truck and building on and off basically since the Overwatch theme released in 2019. The rear of the building featuring a few empty oil barrels and some old engines. The main floor of the building, with the ramps lowered for receiving a broken-down car. Several types of tools hang from the walls. Upstairs on the second floor is the employee break room. The eight wide hover-truck from Overwatch set 75972 has been turned into a 6-studs wide 1950's-style tow truck. Rear of the truck. The hook is too high off the ground to actually pull anything... The cab roof is removable to seat the driver behind the wheel. This 1960s car is a heavily modified version of the Ford Anglia in the 2018 Harry Potter set 75953 - Hogwarts Whomping Willow, remade into dark blue. It has broken down, and is being worked on at Smokeys Garage. (my most recent modular building) The rear of the Anglia. The car has an opening trunk and cabin doors, and also seats one figure. EDITED 8/14/24: So, it's taken quite a while, but it's finally done! Enjoy the MOC!
I finally took pictures of this MOD of Overwatch set 75972 I've been working on basically since the set released in 2019. It's been turned into a 6-studs wide 1950's-style tow truck, and seats one figure at the wheel. The front of the truck. The rear of the truck. The cab roof is removable to seat the driver behind the wheel. NOTE: The vehicle might get changed to black later on because a printed grille (the same part type I'm already using here) in CITY 4+ set 60435 is coming out, and I always wanted the grille on my tow truck to be more pronounced. Only time will tell if this truck gets color swapped or not... Thoughts?
Welcome to Mr. Ham's food stall, where you can get your just-caught fish; fresh apples and cherries too! Mr. Ham just moved to Lego City from the faraway land of Ninjago, where his stall was under constant threat of destruction from Lord Garmadon and his aquatic army. Mr. Ham's nerves are still a little raw from the ordeal, and if he's not at his stall you can most likely find him cowering behind the service counter in fear... but don't hold it against him. You try being attacked almost everyday for 16+ years! This model is a mashup of sets 10229 - Winter village Cottage, (for most of the truck) set 70607 - Ninjago City Chase, (for the food stall itself and fancy light poles) and as-yet unreleased set 75972 - Dorado Showdown (the inspiration for the building itself). Together, these sets make a fresh food market with an apartment for the stall / truck owner upstairs. The rear of the building. As you can see, the building folds on the hinges seen here to allow for access to the inside details, which locks shut on a Technic pin. The upstairs apartment features a bed. The rest of the furniture has yet to be unpacked, as evidenced by the boxes and crates in the corner. The downstairs stall has a table and bottle of root-beer, plus a garbage can and barrel of more root beer. (to refill the bottle that soothes Mr. Ham's nerves) As soon as Mister Ham's nerves calm down, he plans on using this vintage stake-bed truck to deliver groceries to the bigger customers and to pick up supplies from his sources, instead of paying to have it dropped off at the stall. Rear view of the truck. The roof comes off the truck to sit the driver inside. (minus the hat) This is Mr. Ham (photo from BrickLink). When he is driving his truck, his hair looks like this. (NOTE: LDD is missing six of one part in dark bluish gray for the upper window frames on the front side that are just floating there. They will be replaced with the proper bracket when built in real life... whenever that will be!) The LDD file for the building and truck can be found here at Bricksafe . As usual, comments, questions, complaints and suggestions are always welcome!
I was inspired by set's 75972 (Dorado Showdown) and 75953 (Hogwarts Whomping Willow) to create this small town auto repair shop with flat-bed tow truck called Smokey's Garage. The building features a raised platform for cars (such as the Anglia) to roll onto and be worked on, with folding ramps to keep the broken-down vehicle in place. NOTE: The front of the building is missing sixteen of this part in dark bluish gray above the second floor windows and the side door on the first floor. Also, two of these printed 2 x 4 tiles go on the hanging sign out front of the garage. The front of the building, with the ramps lowered for receiving a broken-down car. The rear of the building folds open to allow access to the inside. The upper floor is the break room, with a rock-n-roll album on the table, and hi-fi stereo system in place to rock around the clock..... at least during business hours! Here is the album piece. The rear of the building. This truck is basically a stretched version of the hover-vehicle in the Dorado Showdown set. It is missing two light-bluish gray ones of these (used as the back of the headlights in the set) as they don't fit where they are supposed to go in the model due to a LDD glitch. I added regular-size wheels, and safety stripes to the deck, which sadly does not lower into a ramp like a real truck would... but it does just barely fit the Anglia IRL! Here is the flatbed tow truck and the '67 Anglia in real bricks, plus the two workers Charlie "Smokey" Jones (on left) and Caroline "Carol" Jones (on right). Smokey owns the garage when this picture is taken (It's 1969 in-universe) and does the heavy diesel work and home cooking, while his wife Caroline does the gasoline engines and book keeping. They have a daughter, named Josephine Jones (nicknamed "Jo" and isn't present here) who is in training at trade-school to become a mechanic. She will shortly join the family business in 1970, and takeover from diesels when Smokey dies in 1976. Carol stays on until 1983, when she retires to work on restoring a Ford Model A as a pet project. Jo renames the business "Jo's Garage" in 1985 after moving to a new location (seen in set 10264, Corner Garage) in the downtown area when the older building became too outdated and small. She continues to run the garage today, even bringing her son Franklin into the family trade as of 1997.. NOTES: I just bought the Dorado Showdown when it was $18 (US) from Amazon and then I went and subtracted all the parts I could find for this project in my own parts bins from the BrickLink file. The truck and Anglia themselves are finished already without ordering anything, and the building is down 200+ bricks from when I started looking for parts... still need to order around 520 more. Keep your eyes peeled for real-world pictures of the vehicles, coming soon!
It's high noon! And you know what that means - it's time for a showdown! A Dorado Showdown to be exact. Dorado is a city that is located at the coast of Mexico and powered by giant ziggurat-like fusion plants and today is Festival de la Luz in Dorado, an annual celebration of the end of the Omnic Crisis, so let’s join the festivities! About Overwatch For those who are unfamiliar with Overwatch, click below for a brief summary of what it is: Set Number: 75972 Name: Dorado Showdown Theme: Overwatch Year of Release: 2019 Pieces: 419 Minifigs: 3 Price: £29.99 / $29.99 / 29.99€ Links: S@H Brickset Bricklink S@H description: The Box I am detecting a pattern with these Overwatch sets where the front box art has the wrong background and the back has the correct one. This set is no different as the background isn’t even from the right map. It’s from the Dorado Deathmatch map, not the Escort map that the set is based on. Close enough, I guess, but still a strange choice. We can see Soldier: 76 moving the payload through the first choke point from the Escort map while Reaper is trying to attack him and McCree seems to be hanging on for dear life in the back. A very colorful and action-packed image. As always, you got the white Lego Overwatch logo with Tracer up top, a Blizzard logo in the lower corner, and the set info written in the in-game font on the left. Sure enough, the back of the box features the correct Dorado map in the background, showing the bridge right where it should be. The art depicts the set from a different angle and shows the minifigs with name tags locked in what I can only describe as a Mexican stand-off (get it? ). What’s a bit strange, though, is that the picture is in portrait format and therefore sideways, resulting in the two tabs for opening the box being at the bottom. The top of the box features the set name in six different languages, an ad for the Lego Life app, and a line-up of the three minifigs at actual scale. On the bottom there is a bunch of choking hazard warnings in different languages. One side of the box has a render of the minifigs striking poses with their weapons while the other side just has the Overwatch and Lego Overwatch logos. Contents Inside the box you will find three numbered bags, a sticker sheet, and two instruction booklets - one for the fruit stand and truck and one for the building. Instructions The first pages of the instructions show you how to build the set using the numbered bag system and how to download digital building instructions using the Lego Life app. I've tried it, though, and it doesn't work as these sets aren't available on there yet. Here is a random instructions page. Like with all the Overwatch sets, the call-outs are pretty clear and the light blue background is pleasant. Notable Parts We get a few parts in rare colors in this set such as dark red and yellowish orange. We also get that new candle flame piece from the Wizarding World sets, a bunch of the 1-stud brackets, and the new gun mold that is used for many of the weapons in this theme in dark gray. The only part that is printed in this set unfortunately is the 1x1 trans-light-blue cylinder with a slanted red cross on it. Every other decal is a sticker, like the silver decoration on the grill of the truck (sorry I forgot to take a picture of the part before applying the sticker). The minifigs We get three minifigs in this set: Soldier: 76, Reaper and McCree. It makes sense to include Soldier: 76 in a Dorado based set since he is seen serving as a vigilante in that city in the animated short “Hero”. Soldier: 76 a.k.a. Jack Morrison and Reaper a.k.a. Gabriel Reyes have quite a history together, so it also makes sense for them to appear in a set together. They were both turned into super soldiers by the soldier enhancement program, America’s initial answer to the Omnic Crisis. They joined Overwatch together and rivaled each other for the leadership of the team. After Overwatch’s headquarters got attacked and the team dismantled, the two were presumed dead, but later reemerged as the vigilante Soldier: 76 and Talon terrorist Reaper. During his time at Overwatch, Reyes also recruited outlaw Jesse McCree who was a member of the Deadlock Gang. I guess that’s why McCree is included here as the third hero. They all look pretty good, especially Soldier: 76 with his gunmetal jacket and pants. He gets a cool new ruffled hairpiece while McCree and Reaper each get a new type of cape to represent their poncho and trench coat respectively. The printing on their heads and torsos is nicely detailed, but McCree is the only one who has leg printing sadly. Soldier: 76's heavy pulse rifle and Reaper's Hellfire shotguns are brick-built while McCree comes with a standard revolver to represent his Peacekeeper. I don't mind these brick-built solutions at all, although Soldier: 76's rifle looks quite massive, even considering how big it is in the game. When compared to their video game counterparts, they hold up pretty well. It's unfortunate, though, that McCree doesn't have his signature cigar and belt buckle that reads "BAMF", but it's understandable that they wanted to make him more kid-friendly for the set. Also, Reaper's mask looks a bit scrunched and not as long as it should be, but I can see why they didn't want to create a new mold just because of that, so this is as good as they could do. However, I do like how the McCree minifig has one dark tan hand and one gray hand. That's good attention to detail. The figs look quite good from the back as well. Soldier: 76 has some nice back printing that shows his number and McCree's back has plenty of detail as well. Reaper's slim cape is probably as close as we will ever get to an official minifig trench coat, and it does the job fairly well, so I'm OK with that. Reaper has some back printing too. Here he is with McCree with their capes off to get a better view of their printing. None of the figs have an alternate face, but that's excusable. To make up for that and his missing cigar, McCree comes with a hairpiece for when he is not wearing his cowboy hat which is a nice bonus. While it may make sense for Reaper to appear alongside Soldier: 76 and McCree, it's still disappointing that he is in this set because he is exactly the same one that appears in the Watchpoint: Gibraltar set. Below you will see the full roster of playable characters that are currently available in the game. With so many to choose from, it's unfortunate that we already get a repeat in the first wave. For instance, Sombra would have made a better choice since she is from Dorado. Oh well. The Build The first bag contains the parts for the power generator, market stand, Reaper, McCree, and their capes in a separate box. These two builds are fairly simple and are finished pretty quick. Since we don't have a building to attach the string of lights to yet at this point, the instructions have connect them to the top of the power generator for now. That way the lights will have power until we can plug them into the building. The generator has SNOT plates all around it that not only look accurate, but keep it stable as well. I also like the little bull-shaped pinata and the way they used diamonds to represent low-poly light bulbs, although there are far too few lights on the chain. Like in the other location-based Overwatch sets, there is a small health pack included here even though there is none in this particular area of the map. Maybe TLG just wants to send a message to kids about how healthy fruit is. Either way, I'm always happy when these health packs are included. The fruit stand itself is pretty basic and the posts holding up the canopy are a tad flimsy, but it looks fairly accurate. The second bag contains Soldier: 76 and the parts for the truck. The truck is built around a couple of long Technic beams which keep it stable. Note the dark gray 1x2 plates with rail towards the front which are cleverly used to later hold the fenders in place without making the fenders look too thick. At the end of bag 2, the truck is finished and looks quite good with its mix of 1950's and futuristic aesthetics. I like how they used 1x6 tiles on the sides of the cabin to keep the back wall of it steady. The truck looks good from the back too, although it's missing its rear lights. I don't know what the regulations for hovertrucks are in the future, but I don't think this is up to standard. The flatbed of the truck has a 2x2 jumper plate that is used to easily mount the power generator at a 45 degree angle. The third and final bag contains the parts for the building. Lots of tan and gray here. Despite its size, this is a pretty simple build since it's mostly made out of large plates, bricks and wall elements, so I won't bore you with in-build shots of it. This is what it looks like when finished. It may be a simple building, but I do like how they used SNOT tiles to represent the archway and stepped window frames. The backside is open and completely empty aside from a single candle. There is no roof over the doorways on each side, making the roof look unfinished. While this hallway is empty in the game too, I think they could have at least included a few more candles. There are three stickers that you need to apply in this part of the build. One of them is on the right side of the building that depicts an ad for Lucio with graffiti over it and the old Overwatch poster that Alejandra removed in Hero, although it should have been on the inside of the bridge, not outside. Still, it's a nice reference. Instead, the inside of the bridge features a seal that reads "Justice" and "Jack Morrison" with a relief of Morrison in the center. There is no such seal in the game, but I guess they just wanted to add something to make these walls more interesting. Directly on the other side of the seal there is graffiti of Gabriel Reyes shrugging. The messy look of the graffiti provides a nice contrast to Morrison's nice and clean seal on the other side and fits Reyes' rogue personality. It hints at the idea that these two former leaders of Overwatch are in some ways two sides of the same coin. Pretty deep for a couple of stickers. Spare Parts The good news is that there are several of the usual small pieces left over after the build which include an extra candle flame, so at least you can add one more candle to the building if you have another white cylinder as well. The Completed Set Once you put it all together, you get quite a nice scene. It really looks like something straight out of the game. If you compare it to the image below from the game, they managed to capture the look of the Dorado marketplace and the payload very well. The truck is spot-on and is only missing its rear view mirrors. You can see the market stands in the back and the building with the archway on the left. If you look at the building in the screenshot above, you will notice some differences to the building in the set. There are no lanterns and instead there are some banners and street signs on its facade. That's because the building in the set seems to be based on the backside of the bridge rather than the market-facing side. As you can see in the screenshot below, the backside does have the lanterns and no banners, so if you compare the set to this image, it's pretty accurate, except for the missing plants and strings of light under the bridge. It's strange, though, that they chose to do this. Play Features Even though this is a playset, there aren't too many play features. The roof and windscreen of the truck are only attached by two studs, so they can easily be removed to seat a minifig inside. There's only one seat, so there's plenty of room to store the minifig's weapons. The truck has train wheels hidden underneath, so it can easily be rolled around, and the bridge has plenty of clearance for the truck to move through under it. I'd actually love to see a MOC of the entire map where the payload moves down its path on train tracks. Also, the shutters on the windows of the building can be lifted up so that the heroes can shoot out of the window. And... that's basically it. No trap doors, no flick-fire missiles, nada. I guess that's accurate to the game, but I was still expecting a bit more. Ratings Design: 4/5 - Visually, they pretty much nailed the look of Dorado. The truck is spot-on, the fruit stand is simple but serviceable, and the building, while based on the wrong side, looks accurate as well, although I wish they would have fleshed out the roof and back a bit more and included a few more candles and light bulbs. Build: 3/5 - Aside from a few good uses of SNOT, there is nothing too challenging in this build, but it's not bad. Minifigs: 4/5 - 3 Minifigs is a decent number, although only two of them are exclusive to the set. They look very close to the characters in the game, and while some minor details may be missing, the extra hairpiece for McCree makes up for it. Playability: 2/5 - You can roll around the truck and open the windows on the building. That's it. Not a whole lot of playability for such a decently sized PLAY-set. Parts: 4/5 - There is a good number of parts in rare colors. Price: 5/5 - At a mere 7.2 cents per piece, this might just have the best value for a licensed set I've ever seen! Overall: 4/5 - I think the designers did a good job recreating this part of the Dorado Escort map in such a fairly small set. You get a few good minifigs, some useful parts, and some decent looking scenery. There could have been more play features and details, and it would have been nice if they would have at least given Reaper a different skin or something to make him exclusive, but at such a ridiculously low price I can't even be mad. Even if you're not an Overwatch fan, the set is worth getting for the parts alone. Thanks for reading and please check out my other Overwatch reviews! If you'd like to learn how to do high-quality reviews like this, come join the Eurobricks Reviewers Academy! Special thanks to TLG for sending me these sets for review. Lego Overwatch sets are currently available for pre-order and will go on sale January 1, 2019! What do you think of this set? Will you be buying it? Let me know in the comments and vote in the poll above! Oh, and if you're an Overwatch player, shoot me a PM with your player name so that we can play some games together! Fun Fact: When there are two or more of the same hero on a team, it's referred to as a hero stack.
This model is revamped version of set 41134 (Heartlake Performance School) with parts of set 10217 (Diagon Alley) and a heavily modified version of the truck from set 75972 (Dorado Showdown) thrown together to make this classical styled bank. The time-frame is set in the mid to late Roaring Twenties, when gangsters like Al Capone ruled Chicago's speakeasies and bank robbers such as Bonnie & Clyde ran rampant across the USA. (Of course, the law was always at their heels, and eventually justice was served.) This is the fourth version, which is set to replace my Gringotts bank model, which has become a sore spot on my layout as it's just too small. As before, this bank features a fancy entrance with Greek columns going up and creating a balcony on the second and third floors. The model features a detailed interior, and is open-able like a dollhouse to provide access to the inside. Also, the black 1 x 4 brick above the front door should have this BANK print on it. The rear of the bank has a second story fireplace flue. The model is open-able like a dollhouse to provide access to the inside, as you can see by the hinges on this side. Inside the front half and on the lower floor, we have two tellers desk with spots for four customers total. The upper floor features counting desks, along with half of the the money-filled vault. The lower floor on the back half features a staircase to the upper floor, a controlled access point to the behind-the-scenes part of the bank and the bank managers desk. The upper floor features the other half of the vault with the rest of the $14,800 in hundred dollar bills. (I transferred all the green bricks into 1x2 plates, then times by 100 to get that number.) This model was partially inspired by 2019 Overwatch set 75972 (Dorado Shwodown) which I reverse engineered from a picture last week into the front half of the truck seen here. The rear of the truck. The rear double-doors open to stash valuables, the roof section comes off, and the driving compartment seats one mini-figure. Thank you for looking at these models. Any comments, be they helpful, quizzical, or critical are welcome at any time. Thanks again for reading!
