Showing results for tags '7'.
Hello everybody! This is the first MOC I present on Eurobricks. My most popular MOC yet is the 3 speed auto gearbox (https://rebrickable.com/mocs/MOC-33711/lbrix/3-speed-auto-gearbox-overworked-version/?inventory=1#comments). But now to this gearbox: At first ask yourself this question: Which sense has a normal D-N-R gearbox in a manual technic car? It has no sense. It makes no difference if you are in the forward gear or in te reserve. But with this D-N-R gearbox it makes a difference, because if you are in the forward gear, you can not push the car backward and if you switch in the reserve gear, you can not push the car forward. If you want to build this gearbox into a technic car, you have to connect the grey connectors to the wheels and one of the black ones to the fake engine. For more information check out this MOC on rebrickable (maybe it is not approved yet): https://rebrickable.com/mocs/MOC-47985/lbrix/alternative-d-n-r-gearbox/?inventory=1#comments No I wanted to ask you, what you think about this D-N-R gearbox? Here is an video of my gearbox:
It all started with this small tank based off of the m3 Lee, I wasnt very happy with it but I loved the engine, so I kept it around I later redid the turret to be more round This was the first design that was called the Arnam, named after a famous admiral in the Legion Republic (this is a whole universe my friend and I came up with) despite this being a Senate tank It had 2 main guns, but was very tall (I was still obsessed with the engine) and track protection, I don't have chain link pieces on hand, so the tracks are bare I then retooled it into the Arnam Mk II, which had a decent slope to the from armor, but was built in the same frame as the original tank I had built roughly a year prior This version incorporated a new version of track protection that would be used to this day Finally, after a solid year of redesigns I came to a difficult realization. I needed to reduce the detail of the engine compartment in order to have the tank work both structurally and aesthetically. I removed the old droid bodies and halved the overall height of the model. This is the Arnam Mk V The driver gets in through this hatch in the bottom the engine bay has been reduced to a lever and a telephone piece to allow the height reduction. This is the first tank I will give you the tech specs of. It has 1 AG (weapons manufacturer) TC (weapon type) 413 110mm cannon 3.5 inches of armor on the sides and rear 4.5 inches of armor on the front and turret Crew of 3, commander, gunner, driver (no loader as the gun is auto-loading) Multiple add one for various missions The commander's cupola can be replaced with a 30mm auto cannon and 2 .50 caliber machine guns The missile interference system (MIS) which messes with incoming guided projectiles and makes them not hit their target And the cluster of guided missiles that can be fired at enemy aircraft However there was room for improvement. I felt that the turret was too much like a WWII panther tank and not like a modern tank. So last week I ripped apart the old turret and built the Arnam Mk VII It has 1 AG TC 424 150mm cannon 4.5 inches of armor on the sides and rear 5.5 inches of armor on the front and turret Crew of 3, commander, gunner, driver (no loader as the gun is auto-loading) Various add one similar to the Mk V, with the exception of the MIS, as this is now built into the turret Optional 20mm auto cannon in the hull (adds a 4th crew member) Secondary turret in place of commander's cupola And 2 different sensor packages There are no missiles, as the role of a missile firingntank was delegated to the Honey Badger super-heavy I also added this hinged piece to cover up the gun when elevating The driver's viewport is underneath the 1x2 dark red tile I will likely update with either a stud.io file or chain link pieces, whichever comes first Stud.io model is here. https://www.bricklink.com/v3/studio/design.page?idModel=246061
Hi, I have Lego Ninjago LE 20 #7 and minifigure LE series 17 #2. I would like to get ninjago #12, 13, and 14. I'd like to also get the minifigure LE series 17 #7 and 13. Is there a good place to swap for these or something? I'm new to it and like the idea of having odd varieties of characters. I'd like these specific ones though. Thank you for commenting!
Hi everyone! I'm quite new, but I build lego Star Wars MicroMOCs; in other words 'mini minikits'. I got my ideas from the Star Wars advent calendar series- style micro kits. I have built over 200 so far and I'm still going, so if you want to see any of these regularly, check out my facebook page: https://www.facebook.com/James.Arts2172 and my YouTube Channel "James_Arts_2172: Lego" https://www.youtube.com/channel/UCmYOMZz6DyvM1euY2qrRfpA All I did was go through every page of both DK Star Wars Visual Dictionaries and build every single ship and vehicle in them. Of course I have made many more besides (2014-present sets, Ep 7, Rogue One, Clone Wars, Rebel, Force Unleashed, Old Republic).
Built for the 7th annual Expand the Winter Village Contest. All the doors open, there is a pop out ice block function, and a secret compartment under the house for hiding presents. The building itself was inspired by this model. It was quite an enjoyable build process, especially the wooden porch section. The ice house is particularly busy in the winter months, as blocks of ice are cut and then put into the storage shack to await delivery via truck to customers’ homes. Lots more pictures on Brickbuilt Thanks for looking, C&C welcome!
- 19 replies
- winter village
- 7
- (and 4 more)
