SNIPE Posted July 28, 2024 Posted July 28, 2024 (edited) 3 hours ago, Lipko said: I'm waiting for the macaroni version of all those angle connectors. The only advantage of the macaroni connectors is that they allow an 8 tooth gear to be placed on the outer corner without it jamming the teeth, where as a #6 connector will jam the teeth, so therefore I don't think we will see macaroni #3 #4 #5 #7 connectors soon Edited July 28, 2024 by SNIPE Quote
Lipko Posted July 28, 2024 Posted July 28, 2024 6 hours ago, SNIPE said: The only advantage of the macaroni connectors is that they allow an 8 tooth gear to be placed on the outer corner without it jamming the teeth, where as a #6 connector will jam the teeth, so therefore I don't think we will see macaroni #3 #4 #5 #7 connectors soon Aesthetics Quote
Ngoc Nguyen Posted August 1, 2024 Posted August 1, 2024 Is there any round System piece that is transparent and is smaller than 2x2? I need a headlight piece for my MOC, but the 2x2 dish/plate/tile are too big, while the 1x1 ones are too small. Quote
2GodBDGlory Posted August 1, 2024 Posted August 1, 2024 13 minutes ago, Ngoc Nguyen said: Is there any round System piece that is transparent and is smaller than 2x2? I need a headlight piece for my MOC, but the 2x2 dish/plate/tile are too big, while the 1x1 ones are too small. I'm pretty sure there was an old part that was something like a 1.5x1.5 clear tile, but I can't quite remember what theme it was from. Clikits, Scala, or Belville, or something like that, I think Quote
HorcikDesigns Posted August 1, 2024 Posted August 1, 2024 (edited) I have seen bicycle wheels used as headlighs some time ago on some MOCs. Edited August 1, 2024 by HorcikDesigns Quote
Ngoc Nguyen Posted August 1, 2024 Posted August 1, 2024 Just now, HorcikDesigns said: I have seen bicycle wheels used as headlighs. Do you have the part id for that part? Or set numbers in which they appear? Quote
HorcikDesigns Posted August 1, 2024 Posted August 1, 2024 (edited) From bicycle with tricky connection point https://www.bricklink.com/v2/catalog/catalogitem.page?P=4719c01#T=C Or from the wheelchair - connects to standard 3mm bar-axle https://www.bricklink.com/v2/catalog/catalogitem.page?P=24314pb01&name=Wheel Wheelchair with Molded Black Hard Rubber Tire Pattern&category=[Wheel]#T=C But they might be too big... But... https://www.bricklink.com/v2/catalog/catalogitem.page?P=38799#T=C ... I was curious and found this one.  Btw, All trans clear parts available on BL https://www.bricklink.com/catalogList.asp?catType=P&colorPart=12&v=3  Edited August 1, 2024 by HorcikDesigns Quote
vascolp Posted August 1, 2024 Posted August 1, 2024 2 hours ago, Ngoc Nguyen said: Is there any round System piece that is transparent and is smaller than 2x2? I need a headlight piece for my MOC, but the 2x2 dish/plate/tile are too big, while the 1x1 ones are too small. There are also transparent minifig heads... Quote
Zerobricks Posted August 1, 2024 Posted August 1, 2024 How about those used in Creator Corvette? Quote
Fluwoeb Posted August 1, 2024 Posted August 1, 2024 (edited)  1 hour ago, Zerobricks said: How about those used in Creator Corvette? They are the same as the piece @HorcikDesigns mentioned here: 2 hours ago, HorcikDesigns said: But... https://www.bricklink.com/v2/catalog/catalogitem.page?P=38799#T=C ... I was curious and found this one. They look smaller than 2x2 and bigger than 1x1 so maybe 1.5x1.5?... Edited August 1, 2024 by Fluwoeb Quote
SNIPE Posted August 1, 2024 Posted August 1, 2024 (edited) I assumed he meant that it had to be 0.5L in depth and had a tyre, a barhole is not ideal but may suffice for his use case 6 hours ago, Ngoc Nguyen said: Is there any round System piece that is transparent and is smaller than 2x2? I need a headlight piece for my MOC, but the 2x2 dish/plate/tile are too big, while the 1x1 ones are too small. I'll take a look shortly Edited August 1, 2024 by SNIPE Quote
Stereo Posted August 1, 2024 Posted August 1, 2024 https://rebrickable.com/parts/38648pat0001/Â Magnifying Glass is also around 1.5 studs for the transparent part. Quote
SNIPE Posted August 1, 2024 Posted August 1, 2024 (edited) 2x2 dishes are a hair smaller than 2x2 round plates and come in trans clear bead002 is available in trans clear Probably a few more possible parts too, I use LDRAW parts bin to browse thru all ldraw parts quickly Edited August 1, 2024 by SNIPE Quote
Ngoc Nguyen Posted August 2, 2024 Posted August 2, 2024 23 hours ago, HorcikDesigns said: But... https://www.bricklink.com/v2/catalog/catalogitem.page?P=38799#T=C ... I was curious and found this one. This fits perfectly, thanks a lot! Quote
SNIPE Posted August 2, 2024 Posted August 2, 2024 Ok, I tested it myself once I got the new engine parts and, yes it technically fits but it does not snap in and has only a little friction: Does anyone know if this is a genuine lego Pin, according to bricklink there are 2 or 3 types of 1L friction pins, only 1 of which has a hole that is too small for a bar, however the slats are all on one side unlike mine, where they are are at 90 degrees to the centre slats: Quote
Stereo Posted August 2, 2024 Posted August 2, 2024 (edited) 1 hour ago, SNIPE said: Does anyone know if this is a genuine lego Pin, according to bricklink there are 2 or 3 types of 1L friction pins, only 1 of which has a hole that is too small for a bar, however the slats are all on one side unlike mine, where they are are at 90 degrees to the centre slats: From what I can see there are 4 types that'd be easy to tell apart, plus some smaller variants that are hard to tell apart. 4459 - 1980s - no middle slots 2780 - 1990s - middle slots, can't fit a bar 2780 - 2000-2020 - middle slots, can fit a bar 61332 - 2020-now - no middle slots, has a flat spot so they don't roll away. The middle slots are always at 90 degrees to the end slots that I've seen. Edited August 2, 2024 by Stereo Quote
SNIPE Posted August 2, 2024 Posted August 2, 2024 I just noticed that the 16L axle has a new mould, luckily this cutout does not effect the frictoon of half of full beams at that point: Quote
vliet Posted August 2, 2024 Posted August 2, 2024 Mine has that also, thought of replacing it but it has no effect on functioning Quote
TechnicRCRacer Posted August 2, 2024 Posted August 2, 2024 Somebody on Flickr posted a 1977 prototype 48 tooth gear. Â Quote
SNIPE Posted August 2, 2024 Posted August 2, 2024 1 hour ago, TechnicRCRacer said: Somebody on Flickr posted a 1977 prototype 48 tooth gear. Â I'm sure this was used in The Lego Movie and is also available in the lego unity minigame/psrts library, it just isn't in any set(s) Quote
oracid Posted August 3, 2024 Posted August 3, 2024 12 hours ago, SNIPE said: I just noticed that the 16L axle has a new mould, luckily this cutout does not effect the frictoon of half of full beams at that point: I have many of those. They come from China. Quote
astyanax Posted August 3, 2024 Posted August 3, 2024 14 hours ago, SNIPE said: I just noticed that the 16L axle has a new mould, luckily this cutout does not effect the frictoon of half of full beams at that point: How's the clutch of connectors on this 16L axle? I've always found that bushes and axle joiners just slide off the end of a 16L axle, as if the 16L axle is thinner than axles of different lengths. Quote
msk6003 Posted August 3, 2024 Posted August 3, 2024 12 hours ago, SNIPE said: I'm sure this was used in The Lego Movie and is also available in the lego unity minigame/psrts library, it just isn't in any set(s) Lego movie's one is 60t. Quote
SNIPE Posted August 3, 2024 Posted August 3, 2024 1 hour ago, msk6003 said: Lego movie's one is 60t. aah ok 2 hours ago, astyanax said: How's the clutch of connectors on this 16L axle? I've always found that bushes and axle joiners just slide off the end of a 16L axle, as if the 16L axle is thinner than axles of different lengths. Seems the same everywhere Quote
SNIPE Posted August 3, 2024 Posted August 3, 2024 (edited) so, the "shark fin" connector is the same angle as the #3 connector, not the #7 Here is a comparison between the unimog, 42110, and 42177 tyres: Edited August 3, 2024 by SNIPE Quote
