Showing results for tags 'rolling stock'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 14 results
  1. Functional Ramp and Autorack which can fit up to 6 Speed Champion cars. 65x10 Studs. Autorack_And_Ramp_06 by Terry Akuna, on FlickrAutorack_And_Ramp_01 by Terry Akuna, on Flickr
  2. Similar to my thread of a year ago, wanted to share a couple more freight cars I've been building on the side: Conrail N6A I've shown this Conrail transfer caboose in a couple of my threads, but never formally, so here it is. The prototype is one of several classes of transfer caboose Conrail inherited from the Penn Central. The model was designed almost two years ago, and I got around to putting it together last year. The "skirt" that covers the tops of the wheels is typically the toughest thing to model on American freight cars: if you run on R40 track, the bogies usually need to pivot enough such that the wheels will scrape... this isn't a problem on the N6A because it's quite short; no fancy engineering is required to compensate! The geometry of the skirt and such are still similar to that of my earlier flatcar. And with stickers Brickshelf Gallery PRR G43 Like the caboose, this gondola might have shown up a few times, but never formally. The G43 is a 52' gondola built during the last decade of the PRR. Most of them went to PC and then Conrail. This model was designed and built last year. The dimensions are very similar to the aforementioned flatcar, and it's basically built the same way: the structural component (the sides) is studs-out, and the floor and trucks are studs-up. Once again, much of the work done to make the skirts work on the flatcar are applicable here. Thus, the hardest thing here was figuring out what to do about the shallow trapezoidal part in the middle - eventually I went with wing plates. Finally, this probably should have been dark red or reddish brown, but all three colors seemed to somewhat off, so I ended up going with the most common. I also looked at weathered designs, but its a little bit too difficult when there are a lot of large, exposed parts like the wings. Brickshelf Gallery Alaska Railroad 15800 Series This is a side-dump car, typically used for MoW work. Technically Wikipedia thinks its a type of gondola. As you can see, the specialized feature of this type of car is that it empties sideways: unfortunately the model does not have this feature! This car has actually never been posted: I only recently completed the design and model: Doing the textures on the sides was a little big challenging, especially trying to "blend" it with the ends. On the prototype there are a ton of funny angles that are hard to model in LEGO. Construction is otherwise typical: studs-out for the body, studs-up for the chassis. Those droid-body things are really good for the big pneumatic pistons. Brickshelf gallery Finally, this is a repost, but here is the gondola and caboose running with my EMD Model 40:
  3. hello decided to start my BR Class 08 project and when sourcing parts I came across my PF powered wagon. I am planning in putting all the PF components into the Class 08 body, but having this push it around might be a good option while I sort out the mechanics for the 6 wheels. (PF train motor only has 4 wheels) Anyways for anyone interested heres my PF wagon and pushing my "Ruby Night"
  4. Presenting another Danish wagon...a design-project for another Danish LUG-member to build and test in real bricks (!) DSB Litra DB (II) The Danish State Railways' (DSB) improved Litra DB (II) travelling post offices (TPOs) were built by Scandia in Denmark. 5 were built in 1961. All have been scraped today, the last one in 2011. The model: Digital but has been built and being tested irl with free bulding instructions also in the works Original DSB maroon livery used from the fifties to the seventies - with Dark Red a very good match albeit a bit too clean Scale: ~1:54 Lenght: 34 studs Width: 7 studs Bricks: 808 (very heavy, so ball bearings recommended) Designed: 2012 & 2017 & 2019 Sadly the LEGO Digital Designer file was lost a few years ago when all my data were lost (including multiple backups). So I had to recreate the model from scratch using two remaining screenshots posted online. Rather strange experience to reverse engineering yourself Very high setting render from Stud.io with custom decals done in the PartDesigner tool and some manuel editing. The roof can be removed, giving access inside the wagon and the doors can slide in opposite directions by flipping the blocking hinge parts down. Technique used for the bogies - prepared for ball bearings
  5. In rail transport, the U.S. DOT-111 tank car, also known as the TC-111 in Canada, is a type of unpressurized general service tank car in common use in North America. Tank cars built to this specification must be circular in cross section, with elliptical, formed heads set convex outward. They have a minimum plate thickness of 7⁄16 inch (11.1 mm) and a maximum capacity of 34,500 US gallons (131,000 L; 28,700 imp gal). Tanks may be constructed from carbon steel, aluminum alloy, high alloy steel or nickel plate steel by fusion welding. The black car carries petroleum products and has a capacity of 30,110 US gallons (113,979 L; 25,071.8 imp gal), a tare weight of 65,000 pounds (29,500 kg) and a load limit of 198,000 pounds (89,800 kg). And the internals:
  6. Ever since I've finally managed to get a pile of the small train wheels, I've been building, or at least designing not only new narrow-gauge locomotives, but also narrow-gauge rolling stock, and I figured I'd just make a single thread for all of it (both completed & LDD images of planned builds), and update it whenever I get new designs finished or complete actual builds & post pics of them in the original post. EDIT: I have decided to just start new threads for additional narrow-gauge train stuff, and then link those topics in this thread, which will be linked in my signature, rather than bumping this thread every time I finish a new narrow-gauge MOC. Therefore, from here on out, this is basically a library of all my narrow-gauge stuff, including locomotives, so enjoy! So without further ado, first up is the Balin & Sons Mining Co Heisler locomotive & ore carts I made back in 2011 & posted about early 2012: NG Loco by Ben/Laura Bonebrake, on Flickr Next on the locomotive roster is the Balin & Sons Mining Co RR 8-ton Plymouth biofuel switcher: Plymouth 8-Ton Right-Side by Ben/Laura Bonebrake, on Flickr Next up is an Inter-Modal/Flatcar (it's used as a flatcar when it's not hauling shipping containers). I've included a pic of the Inter-Modal Car with one of my "standard" shipping containers & an updated version of the Heisler Locomotive I made almost 7 years ago to show how it compares with the more or less standard sized locomotives I use for my narrow-gauge stuff: Empty Intermodal Front Quarter View by Ben/Laura Bonebrake, on Flickr Here's a design for a narrow-gauge hopper car, which is a 6-wide modification of a 4-wide version I had designed in LDD 6 years ago, then just kinda shelved. It's based on the narrow-gauge coal hoppers that are on the East Broad Top Railroad, although I could only make these 2-bay hoppers instead of 3-bay due to space constraints. EDIT: Thanks to discovering that LEGO made 1x1 black letter & number tiles with white print, my 2-bay hopper is no longer inspired by the East Broad Top Railroad's 2-bay hoppers, but it now IS an East Broad Top RR 2-bay hopper, complete with EBT reporting mark & typical hopper car numbering scheme: EBT Narrow Gauge Hopper Side by Ben/Laura Bonebrake, on Flickr This is a narrow-gauge tank car I came up with last night (after pulling my hair out repeatedly trying to come up with something that looked reasonably decent & wasn't too flimsy). While the ladder attachments on the current build are pretty flimsy, I'm planning to use BrickArms U-Clips to clip the 3rd rung up from the bottom to the railing in order to stabilize it. Of course the nice thing about this here design is that the main tank body is made entirely from really common parts which are available in many different colors, so I could easily make a small train entirely of white, black, yellow, green, etc tank cars: Narrow Gauge Tank Car WIP by Ben/Laura Bonebrake, on Flickr And Last for now (but not least) is a workable narrow-gauge train car I came up with earlier this week (and modified 2 times since then) in the Balin & Sons Mining Co RR livery (of course it is entirely possible to make this in different colors, but part of the reason I went with mostly black with red highlights is that black train doors are the easiest type to acquire on BrickLink, especially thanks to the new Grindlewald's Escape set having a matched pair in it). The slightly elongated bogie is one I'll be using for all my narrow-gauge passenger stock & I'm planning on using a variation of it for when I try to model the East Broad Top RR's 55-ton GE Center-Cab Diesel that they got about 15 years ago from the Algoma Steel Works in Saul Ste Marie. Also of an interesting side note is that for standard gauge trains, for the most part, I use the 26L train base plates for passenger cars/coaches, and the 24L train base plates for freight cars & medium diesel locomotives. EDIT: After messing around a bit, I found a way to make some workable 6-L narrow-gauge bogies that work with a standard 6x24 LEGO train car base plate & are held on by 2x2 turntable plates. I already tested it & it can handle any standard LEGO narrow-gauge curved track configuration, so here's the improved version: Narrow Gauge Coach WIP v2 by Ben/Laura Bonebrake, on Flickr Anyways, I hope you all like these narrow-gauge cars & are inspired by them. Like I said at the beginning, I'll update this post whenever I come up with or build more narrow-gauge rolling stock.
  7. Hi EB! I haven't posted in a long time, but I have actually been building stuff. I promise. I had been looking to put together an american freight train for some time now: I originally thought I could get away with building a long articulated well car (which would make up the entire length of a practically sized lego train), but the well car has proven to have more restrictions and less reliability than I would have liked, and as such it was time to build some regular freight cars. Tank Car All of these freight cars were actually designed in maybe 2014, but at the time I did not actually intend to build them, preferring the aforementioned well car instead. This tank car was completed first because I was able to acquire almost all of the parts through my local LUG. The only expensive parts were the 8x8 dishes on the ends, which are apparently quite rare. As much as I hate to be imprecise, the car is a little bit of a freelance: I did work off a drawing to get the proportions, but I apparently could not find a photo or model of the thing in the drawing, so the greeble around the the dome and platform is a bit of a guess. The ladders are also a bit disproportioned, but that is more of a convenience. This car probably has the most interesting construction of the three here: I wanted to use the various 8-wide circle parts, but I did not want them to make up the load-bearing structure (so you can't pull the car apart). Therefore the load-bearing structure is actually a Technic frame that kind of moves up and down such that the top and bottom set of circle parts can connect at alternating bulkheads. Flat Car Like the tank car this is a little bit of a freelance, but I really wanted a flatcar such that I could put random stuff on it, and modern flatcars at our scale are far too long to run on R40. I found two models for reference, and I believe my drawing is for the bottom one, but the car itself really takes more from the top one. This one was actually the toughest one to build. As I designed it in 2014, there wasn't nearly enough structural integrity and the wheels would easily rub on various other parts in curves. It took me quite a few iterations to increase the structural integrity to an acceptable level without compromising the overall appearance of the car (mainly not making it too tall). As you can see the details of the final design look nothing like the details on my original LDD build. Build-wise, the key to making it structurally sound was to make the studs-out sides the load-bearing element, and the difficulty was doing that while still giving the trucks enough clearance to pivot fully in an R40 curve. If you press on the car in a turn there is still a but of scrubbing, but for now I consider that acceptable. Hopper Car Unlike the other two, this car is actually based solely on a specific model! It is the latest one to be completed, and I think it is actually my favorite of the lot. It took me a while to get around to it one because I thought it would need a lot of parts, but it was mainly just the 1x2 rails (something like 100 of them) and they were relatively cheap. Construction is mainly studs up for the chassis and studs forward/backward for the sides. Each side is a studs forward and a studs backward section held together with rails on the top and bottom with some additional SNOT needed to go around the ends. It's probably the sturdiest of the three cars, but also the heaviest. Well that's it for now. There is a full gallery with a few more pics if it ever gets moderated. I do have a new locomotive in the works too, and it will be interesting.
  8. An old project finalized after seven years Herningværket Vestkraft I/S All three typers of wagons were part of the company's famous coal train "kultoget" transporting coal from Vestkraft in the costal city of Esbjerg to Herningværket power plant in the inland city of Herning from the year 1982 to 2000. FALS coal wagon Digital model but built in 2012The 18 coal wagons were built in Denmark by Scandia in 1981-82 on license from Talbot in Germany.All were sold to France in 2000.My model:Scale: ~1:50Lenght: 30 bricksWidth: 8 bricksBricks: 312Weight: 335gDesigned: 2012 (slightly updated in 2018)Very high setting render from Stud.io with custom decals done in the PartDesigner tool. The doors can be opened up to 45 degrees: Top view: ASJ tank wagon Digital model but being built very soon... The six tank wagons bought by Vestkraft I/S in 1981 were originally built in 1948-49 by AB Svenska Järnvägsverkstäderna (ASJ) in Falun, Sweden. All six were scrapped in 1991. My model: Scale: ~1:45 Lenght: 26 bricks Width: 6-8 bricks Bricks: 302 Designed: 2019 Very high setting render from Stud.io using custom decorations from Stud.io, LDD to Pov-Ray and manual editing. Side view: The two 1-axle boogies can rotate and are held in place by a Hose, Flexible Ribbed with 8mm Ends, 10L. Technique used for the mid-cylinder: AVG tank wagon Digital model. The two AVG tank wagons bought by Vestkraft I/S in 1991 were originally built in 1968 by AB Gävle Vagnverkstäder (AGV) in Gävle, Sweden. Both were removed from service in 2002 and scrapped in 2003. My model: Scale: ~1:45 Lenght: 40 bricks Width: 6-8 bricks Bricks: 361 Designed: 2019 Very high setting render from Stud.io using custom decorations from Stud.io, LDD to Pov-Ray and manual editing. Some of the custom decorations were truly horrific to render due to their bend Top view: Technique used for the mid-cylinder: The locomotives (!) Both types of locomotives were from the Danish State Railways (DSB). In the the earlier years of operation from 1982 to 1993 two Litra MX (1001 & 1024) were used, one in the front and one in the back whereas in the later years from 1993 until the end of operation in 2000 a single more powerful Litra MZ (I) (1404) were used. DSB Litra MX The Litra MX locomotives were built on license from General Motors by Nydquist & Holm AB - Bofors-Nohab in Trollhättan, Sweden. 45 were built from 1960-1962. The Litra MX were very similar to their big brother Litra MY but had a smaller engine and lower weight with less pressure on the tracks making them popular on smaller railroads. Quite a few are still used today by private railway companies either domestic or abroad. One locomotive is on display at a railway museum in the city of Stuer, Denmark. My model: Digital model but based on my very first train MOC from 2011 with the same basic design. DSB red and black livery used in the 1980s. Room for lights in all headlights and the interior. Scale: ~1:60 Lenght: 40 bricks Width: 6 bricks Bricks: 546 Powered: 1 or 2 x PF, PUp or 9v train motor(s) Designed: 2019 (variant of my Litra MY update in 2018) Very high setting render from Stud.io with custom decals done in the PartDesigner tool. Interior: One of my pictures from 2013 with a Litra MY pulling some of the coal wagons: DSB Litra MZ (I) The Danish State Railways (DSB) powerful Litra MZ (I) locomotives were built by Swedish Nydquist & Holm AB (Nohab) in Sweden and subcontractors in Denmark on license from General Motors. 10 were built from 1967-1969. 61 in total were built across all MZ variants (I-IV). Quite a few are still used today by private railway companies either domestic or abroad, in Iran, Norway and Australia. My model: Digital model but based on my second train MOC from 2011 with the same basic design. DSB red and black livery used in the 1980s. Scale: ~1:60 Lenght: 40 bricks Width: 6 bricks Bricks: 653 Powered: 1 or 2 x PF, PUp or 9v train motor(s) Redesigned: 2015 (4st revision) Very high setting render from Stud.io with custom decals done in the PartDesigner tool and some manual color replacement of the upper headlights. The top can easily be lifted providing access to the battery box and all others parts inside: Photo inspired by LEGO train builder Sérgio Batista
  9. Did you know, the first journey most cars make after the production line is by train? It's true. About 65% do. And many people completely disregard the common autorack. Yes, it's not a glamorous car, but it's vital to our automotive society. The Deutsche Bahn DDm 915 class Doppelstock-Autotransportwagen are used for transporting cars from automobile factories to the dealers for sale. They were additionally used to carry cars on long-distance overnight trains. First built in 1969, these dual level cars carry from 8 to 10 vehicles. The upper level is fixed in height. I've taken considerable liberties in the creation of these due to constraints from building in LEGO to accommodate R40 curves and keeping it 6-wide. The center support is missing, along with the railings. Still, I believe they capture the essence of the wagen for use on my rails, especially behind my DB 185 class locomotive. Loading an empty DDm 915 from a ramp. Note the ends of the car fold down to create a continuous driving surface to load multiple autotransportwagens from one ramp. These would normally be on both levels, but were only implemented on the top level due to the bogies. Here is a picture I took of a DDm 915 at the DB Museum Koblenz in 2018. Here is a stand alone picture of the loading ramp. The upper ramp section is hinged to allow loading of both levels.
  10. some rolling stock i have planned for my Yellowstone AC9 project, although SP did not employ this type of flatcar during the time of the AC9 Yellowstone's life its still something I found rather unique with its articulated ends. I can't find much more info on these flatcars besides being used to transport locomotives and heavy duty equipment, More commonly used by the TTX Company who sustains a sizeable fleet.
  11. I've been split in scale since I began building LEGO trains with all my shunters, freight wagons and latest passenger train being 7-wide or 1:54 and all my older locomotives and passenger wagons being 6-wide or 1:60. With almost all of my buildings close to true minifig-scale, I've been contemplating to unify my scale for a few years now but I couldn't decide to go for either 7 or 8-wide...in addition to being pretty much satisfied with most of my 6-wide models as they are. Well, no more Presenting my favourite Danish State Railways’ (DSB) locomotive redesigned to 8-wide and digitally rendered in two versions and liveries... DSB Litra MZ The powerful Litra MZ locomotives were built by Swedish Nydquist & Holm AB (Nohab) and Danish subcontractors on license from General Motors. 10 MZ (I) were built from 1967-1969. 20 MZ (III) were built from 1972-1974. 61 in total were built across all four variants (I-IV). Quite a few are still used today by private railway companies either domestic or abroad, in Iran, Norway and Australia. My model of DSB Litra MZ (I): DSB maroon livery used in the 1960/70s with the highly recognizable crown and wing logo on the front. Scale: 1:46 Length: 56 studs from buffer to buffer Width: 8 bricks Bricks: 1.264 Powered: 2 x L-motors, 2 x AAA battery boxes + 2 x SBricks, 1 x AAA battery box + 1 x SBrick/PFx Brick or 2 x BuWizz battery boxes Control: PF with SBrick, PFx Brick or BuWizz Designed: 2020 My older 6-wide version from 2016: https://www.eurobricks.com/forum/index.php?/forums/topic/119474-moc-the-danish-state-railways-dsb-locomotive-litra-mz-i/ All renders are done on the very high setting in Stud.io with all of my own custom decals added in the PartDesigner tool. Upgearing from 20 to 12 teeth with a ratio of 5:3....more speed, less power PF L-motor design with good advice from some of the Brick Train Depot guys. Credit to Duq for coming up with the original idea of using the T-piece. 3-axled bogie: The center wheel will utilize a black hockey puck as a blind driver or a 2 x 2 round tile with open stud and 1 x 1 round tile placed on top on it as the alternative. https://www.bricklink.com/v2/catalog/catalogitem.page?P=47576#T=C My model of DSB Litra MZ (III): DSB "modern" red & black livery used in the 1980s. Scale: 1:46 Length: 56 studs from buffer to buffer Width: 8 bricks Bricks: 1.331 Powered: 2 x L-motors, 2 x AAA battery boxes + 2 x SBricks, 1 x AAA battery box + 1 x SBrick/PFx Brick or 2 x BuWizz battery boxes Control: PF with SBrick, PFx Brick or BuWizz Designed: 2020 My older 6-wide version from 2011 and redesigned in 2015: https://www.eurobricks.com/forum/index.php?/forums/topic/172599-moc-herningværket-vestkraft-is-complete-set-of-locomotives-and-wagons Part of the fun and what set LEGO trains apart from pure model railroading is the inclusion of minifigs, so whenever and whatever I always try to make space for them and also keep on some play features and interiors. The 8-wide body is quite roomy and has a fairly correct interior. 2 x PF L-motors with either 2 x AAA battery boxes + 2 x SBricks, 1 x AAA battery box + 1 x SBrick/PFx Brick or 2 x BuWizz battery boxes can be utilized: Both locomotives with DSB Litra MZ (I) in front of the later version DSB Litra MZ (III) in the background: Technical addendum: For the first time ever I have used technical drawings overlayed with LEGO scaled grids to get the dimensions right or as close to right as possible. The models haven't been built yet but some smaller builds have been used for testing during the design phase. My slightly shorter test train didn’t really like driving through R40 curves, no surprise there Too much length overall and the wheel sets in both ends of the bogies are also pretty far from each other producing some drag. Going through isn't impossible though but rather uneven and a tiny bit struggling, especially with added wagons. There are no problems driving on straight tracks and through larger radii curves. To my surprise however was the finding that the total number of parts were the same or even slightly less than a similar 7-wide model So henceforth, 8-wide it is
  12. So right around the time Electrosteam started his Retro-Future Atomic Train topic; I saw a video online showing the operation of a nuclear waste transporting train here in the U.S.: So I decided to get in on the nuclear Lego train fun by recreating one of the DODX (Department of Defense) nuclear waste train cars in Lego form... Or at least kind of recreating them. Re-watching the video now is making me want to redo the cars again to catch some finer details (although I doubt I'll get around to finding a way to get those crazy eight axle bogies under it!). So here they are (apologizes if they don't show up for a while due to Brickshelf's slow moderating system...) And here is the cutaway view revealing the prize inside... Yes I know that real nuclear waste is a dark dullish metallic gray color, but I decided the cartoon like Simpsons style trans-green glowing rods fits the more comical Lego world better than just a bunch of dark bley pieces! Enjoy! If you want to see more nuclear train fun, go back here to see Electrosteam's topic: http://www.eurobricks.com/forum/index.php?showtopic=131009
  13. Background info:Brick Railway Systems (BRS) was constructed in the early 1870's from pieces of other roads. It began small, with only 120 miles of track laid as of 1873. (Note: Only 57 of those miles were actually constructed by BRS, not by the former component roads) By 1910, BRS had rose through the ranks of the other roads to become the top freight hauler in the country. However, In World War One, the railway was was run into the ground by government control via the Imperial Railroad Administration (IRA), which took over control of all railroads in 1914 and kept them until 1920. Upon return of the company to it's civilian owners, the railroad itself was in shambles The company responded by trimming the unnecessary trains that had been kept running during the war years even though they were practically useless. By 1928, the company had remade itself so much so that it had electrified most of it's main line between Glencoe, Ironwood, & Fort Legoredo. This cut back majorly on some of the costs of steam engine fuel and maintenance for the railroad. The benefit of this was not evident immediately, but later payed for itself when the Great Depression hit. By the the Second World War, BRS was even better off than had been projected in the depths of the depression The war traffic barely affected the system, as the 1920's upgrades had unexpectedly prepared the system for the surge in goods and soldiers. In the late 40's, while several other roads had started getting rid of their steam engines for diesels, BRS was resisting the flow by building more steam, and experimenting with more advanced designs such as duplexes, triplexes, & Garrett’s These efforts never payed off, but the they did give the BRS engineers valuable advice on what to do and what not to do with steam. Meanwhile, diesels were on the railroad from starting around 1936, but not in great numbers until the late '60's. 'The System' (as she is sometimes called) was doing fine at this time, while other roads were struggling. By the '70's, diesel fuel prices had put a stop to the diesel takeover, and optimism was high. This feeling continued right up until 1987. The main competitor, Federal Railways, had gone up for sale and Brick Railway Systems was getting a ring-side seat on what could happen if a road got out of hand. Before their eyes, the road was torn apart by lack of leadership, (not helped by the fact the Federal Railway / Brick Railway Systems merger was denied) lack of funds and working motive power. Then, in late 1992, the railway was finally gone, eaten up by hungry debtors and rival railroads alike. (some of it was eventually bought by BRS) The other half of the '90's & the early 2000's had Brick Railway Systems wondering if the same financial breakdown would happen to it. By 2010 the shock had worn off, and the optimism had returned, albeit with a little more caution.Present Locomotives:2-6-0 "Mogul" Steam locomotive Built in 1917 by Zephyr Locomotive Works for Brick Railway Systems (BRS for short), engine #4613 was one of a class of 44 locomotives numbered 4610 to 4654. They were the last class of BRS engines painted in dark green & black with gold highlights. They were also the first class to feature modern tenders with increased water & fuel storage capacity. These two traits created a oddity in the BRS loco department, as it was both old and new. They have all since been repainted except for 4613, which proudly still wears in “Green and Gold” as a testament to the first 50 years of the railroads existence. 2-6-2 "Prairie" steam locomotive Built in 1919 by Baldwin Locomotive Works for Brick Railway Systems (BRS for short), engine 4754 was one of a class of 110 engines ranging from number 4749 4859. They were built at the time when the Imperial Railroad Administration was running BRS due to World War I. These engines proved themselves good freight haulers, but the a severe side-to-side swaying motion kept them from passenger service. They are all painted black with the usual red box on the tender 0-4-0 "Yard Switcher" steam locomotive Built in 1923 by Baldwin Locomotive Works for Brick Railway Systems (BRS), engine #4990 was part of a 250 strong class of switchers made for the tight industrial & dockyard trackage of Brick Railway Systems. The class spread from number 4860 to 5110. They were painted in classic BRS black with a red stripe with a little red ring surrounding the funnel. 2-8-0 "Consolidation" steam locomotive Built in 1926 by Lima Locomotive Works for Brick Railway Systems, engine #5775 was the second to last engine in an order of 30 engines. The engines were numbered 5746 – 5776 and were painted in the traditional black and red paint scheme. This consists of a red box on the tender surrounding the letters BRS, which stand for Brick Railway Systems. 0-6-0 "Mixed Traffic" steam locomotive Built in 1929 by Baldwin Locomotive Works for Brick Railway Systems (BRS), engine #5972 was supposed to be part of a 75-strong engine order, but the Great Depression startted, causing BRS to cancel the last eight engines, leaving 5972 the last of it's class. The type has been painted in standard black with a red stripe with a small ring of red around the funnel. 2-8-4 "Berkshire" steam locomotive Engines 7221 – 7235 were built in 1933 by Lima Locomotive Works for Brick Railway Systems. These fourteen 2-8-4 (2 leading, 8 drivers, and 4 trailing wheels) locomotives were intended for heavy freight service on the mountainous 'Southern Division' of Brick Railway Systems. (BRS) However, it was discovered that these engines could pull long passenger trains better than the usual locomotives assigned to that route. The engines were given control over crack express trains such as the '909 Limited'. (known for going 900 miles in 9 hours, at about 100 miles per hour) These engines performed wonderfully for over 25 years. However, the cost of running these fleet-footed engine became so great in the early 1970's that BRS seriously considered getting diesels to do the steam engines work. Thankfully, the oil embargo of 1974 put a stop to that by restricting diesel fuel consumption by just enough to put the steam engines in a more favorable position. Safe from the threat of a diesel takeover, the locomotives run like clockwork to this very day. 2-10-4 "Texas" steam locomotive These twenty four 2-10-4 (2 leading, 10 drivers, and 4 trailing wheels) locomotives numbered 6394 – 6418 were built in 1939 – 1940 by Lima locomotive Works. They were based off the very successful 2-8-4 Berkshire type Lima had sold to Brick Railway Systems (BRS) in 1933. One of these engines was 6398, which was painted in the BRS standard black with a red box on the tender and red stripe on the funnel. Number 6398 served well on the heavy freight duties it was designed for, though, as with the Berkshires, the engines proved equally adapt at handling the passenger trains as well as the heavy freights. GG-1 electric locomotive This GG-1 electric locomotive was built in 1943 by Altoona Works as unit 4939 for the Pennsylvania Railroad. When that railroad merged with New York Central in 1968, the ensuring legal nightmare concerned with the merger (& the subsequent bankruptcy of Penn Central) caused the engine to be "lost" in the paperwork. After being stored for 20 years in a shed on a branch line in New York, the engine was located by a local railroad club, and restored to working order. As the engine was owned by a defunct railroad, it was sold at auction by the club to Brick Railway Systems, who had bought 12 other GG-1's from Altoona in 1943. The engine was taken apart into 3 sections and shipped to Brick Railway. It started work in 1989, was repainted into the classic Brick Railway black / red color scheme, and was renumbered 8620, to better fit with the other GG-1 locomotives. FA (A Unit) & FB (B unit) diesel locomotives In 1947, Brick Railway Systems (BRS) bought seven PB-1 & seven PA-1 series locomotives from the American Locomotive Company (ALCO). They were numbered 8666 - 8673. Both units carried the same numbers and were semi-permanently coupled. The fourteen engines were delivered to Brick Railway but were slightly modified when they arrived. They were then painted in a variant of the famous BRS black-with-red-stripe paint scheme and had the front coupler removed. The engines were used on the non - electrified sections of main line to pull many named trains that couldn't be pulled by steam. This started in 1948 and continued until 1963, when the whole main-line system of Brick Railway Systems was electrified. Regulated to freight traffic & branch line work, the engines worked until 1982 when the engines were finally pushed back to "reserve" status. As such, they are not run often, but are kept in operating condition to this very day MRS-1 (Military Road Switcher -1) diesel locomotive In the early 1950's the United States Army Transportation Corps (USATC) was considering what would happen to an enemy railroad if another European war broke out. If the native locomotives in said enemy country were destroyed or rendered inoperable (as they likely would have been) what would pull the US military trains on their soil? The answer was not easy, as many countries have different gauges, loading clearances and couplers. The USATC decided on specific set of guidelines for it's Military Road Switcher (MRS) and waited to see which companies would offer the best design. American Locomotive Company (ALCO) beat out Electro-Motive Division (EMD), and won the contact. Engine #8945 was built by ALCO in 1954 and stored until 1970, awaiting a European war that never came. It was sold, unused, to Brick Railway Systems in 1971. It was immediately put to work along with another MRS-1 unit (#8946) on slow freight trains, though #8945 did pull a passenger train in an emergency in 1988. The engine remains in operable condition to this day and has been painted in the Black & red paint scheme. SW-1500 switcher Built in 1966 by Electro-Motive Division for Brick Railway Systems, engine #6715 was the first engine in an order of 15 engines. The engines were numbered 6715 – 6730 and were painted in the traditional black and red paint scheme. This consists of a stripe near the bottom of the loco and letters on the cab sides which say BRS. RS-2 Road switcher This RS-2 road switcher was ordered from the American Locomotive Company (ALCO) in January 1949 for Brick Railway Systems (BRS). It was delivered in July 1949 with 19 others of its type, and was given the number 6505. (The other RS-2's are numbered 6500 - 6520) This type wears the famous “Black with red stripe” that most BRS engines wear. 4-4-0 "American" steam locomotive This 4-4-0 (also known as an American type) was built by Rodgers Locomotive & Machine Works for Brick Railway Systems (BRS) in 1876, and features a bright red-yellow-&-black paint scheme. Number 210 pulled passenger trains for 10 years before being reassigned to Freight duties in 1888. By 1900, the engine was worn out, and sent to a scrapper, who sold the engine to a museum for $100. Eventually, the museum was reorganized as the Imperial Rail Museum, where the engine rests today in non-operable condition. There were plans to get #210 in working order for the US Bicentennial in 1976, but nothing ever came of it, and the engine has remained cold and silent to this day. This is the oldest surviving BRS loco in existence. 2-6-2 "Prairie" steam locomotive This is locomotive #263, of the 2-6-2 Prairie type. This one was built by Sava Locomotives Incorporated in 1883 and was designed for slow freight trains. (It has smaller diameter wheels than faster passenger engines) It served until 1902, when the engine suffered a boiler explosion near Golden Gulch in Legoredo County. The engineer and fireman died in the explosion, but the engine was salvaged and repaired. Loco #263 was retired in 1925 when it was bought by a Hollywood film company for use in a Western movie. After filming ended, the engine was donated to the Imperial Rail Museum in the city of Legoredo, where it rests today in operable condition 2-6-0 "Mogul" steam locomotive The locomotive is engine #272, a 2-6-0 Mogul type. It was built by Zephyr Locomotive Works in 1885 and was a passenger engine, usually only in fast, named-train passenger service. (Thus the large driving wheels for greater speed) It was last used on the faster passenger trains in 1909, when it was painted in the new black & red paint scheme and sent into regular freight / local passenger service. It was supposed to have been scrapped in 1921, but was saved along with late 1800's passenger stock and a caboose. It was sent to the Imperial Rail Museum where it is stored in it's original dark green & black paint scheme. Engine #272 is operational, but is only steamed on special occasions. Present Rolling Stock:1930's streamline coaches These are not really based on any one prototype, but I was going for a Anthony Sava (Tequila Sunrise) meets Atchison Topeka & Santa Fe Super Chief look. It looks more like a early 1930's consist to me, like something Pennsylvania Railroad would have done in brown or dark red. 1920's Heavyweight Passenger Cars Again, these are not really based on any one prototype, but I was going for a Anthony Sava (Polar Express coaches) look. It looks more like a early 1920's consist to me, though. 1950's Blue & White passenger consist I based this one off of two sources: the Wabash Frisco & Pacific Railroad (a 12 inch gauge ride-on steam line in Glencoe Missouri, near St. Louis) and the coaches formerly owned by the Museum of Transportation (also in St. Louis) before they were sold in 2012. Express passenger cars (2003-style) In reality, these cars are modeled after set 4511 (2003's High Speed Train) and the Carolina Train Builders passenger coach instructions available at the Railbricks website.-Express Coach (x3)-Cargo / Express Coach (x1)There is one part missing from this picture: http://www.bricklink...sp?P=44572pb005It is not in LDD as a decoration but the basic part is. 1950's Freight Cars In the real world, the modified tank cars are originally from set #7939, (Cargo Train), while the boxcars are from set #3677 (Red Cargo Train). The rock gondola was my own idea and the caboose is a mashed up Toy Story Caboose #7597 (Western Train Chase) and the vintage 10014 (Caboose) from 2001. Wide Vision / Bay Window Caboose I made this model about a year ago from instructions for an Bay Window caboose mixed with instructions for a Wide Vision caboose. I recently rediscovered the photo I posted to Flickr at that time and I wanted to make the model better. I removed some expensive parts (the red train base-plate, for one!) and replaced them with other, cheaper parts. 1920's Commuter Cars These cars consist of 1 baggage / mail car, while the other 3 cars are coaches 1910 Dark Green clerestory passenger train This wonderful train comes with one steam locomotive, one baggage car, two passenger coaches and one observation car. Comments & Critics welcome! I currently own (in real life) the PA / PB set, the 2-8-4, the 1920's heavyweight train, the GG-1, the streamline consist, some of the freight train, the 1920's commuter cars, and the 2-6-2 & the 2-6-0 Western trains.Most of these are modified versions of Anthony Sava's wonderful designs. He has a a Bricklink store from which I purchased everything but the two far left models. (Here is his store: http://www.bricklink...asp?p=AggieSava ) The LDD files or copies of the models I made from his instructions are NOT for sale... so please don't ask. The GG-1 was inspired by this builder from Brickshelf: http://www.brickshel...ry.cgi?f=301802 The FA / FB models were inspired by Flickr user valgarise & his train called the "Invencible": http://www.flickr.co...ise/6238331351/ The SW-1500 is from LGauge, a LEGO train MOC site. (Link: http://www.lgauge.com/ ) The Alco RS-2 was inspired by memories of a diesel creation my Father & me made when I was 7. The LDD file for the GG-1: http://www.mocpages....1395173382m.lxf The LDD file for the RS-2 & SW-1500: http://www.mocpages....1395678142m.lxf The LDD file for the ALCO PA & PB units: http://www.mocpages....1395680308m.lxf The LDD file for the 0-6-0 steamer: http://www.mocpages....1398707791m.lxf The LDD file for the 0-4-0 switcher: http://www.mocpages....1398707178m.lxf The LDD file for the 2-6-0 Mogul steamer: http://www.mocpages....1401200779m.lxf The LDD file for Black & red 30's stream train: http://www.mocpages....1395862145m.lxf The LDD file for the brown 20's heavyweight cars: http://www.mocpages....1395861942m.lxf The LDD file for the white and blue 50's train: http://www.mocpages....1395862516m.lxf The LDD file for the modern white & green train: http://www.mocpages....1395860545m.lxf The LDD file for the Freight train: http://www.mocpages....1395860725m.lxf The LDD file for the Wide vision / bay window caboose http://www.mocpages....1395936808m.lxf The LDD file for the black and red commuter train: http://www.mocpages....1398787896m.lxf The LDD file for the 2-6-2 Prairie (black and red, large): http://www.mocpages....1406727379m.lxf The LDD file for VERSION 2 of the 2-6-2 Prairie (black and red, large): http://www.mocpages....1412537572m.lxf The LDD file for the 1910 Passenger train & Updated 2-6-0 Mogul: http://www.mocpages....1407852914m.lxf The LDD file for the 2-10-4 Texas steam locomotive: http://www.mocpages.com/user_images/80135/1413678781m.lxf
  14. What's your favorite railway museum, and why? I was at the China Railway Museum here in Beijing a few weeks ago for the third time and it got me to thinking about all the wonderful train museums I've seen in my travels. I thought it might make for an interesting discussion here in the train forum. Mine would have to be the Museum of Transportation in St. Louis, Missouri. It's been awhile since I've been there, but some pieces that stick out in my mind are the Big Boy (above, photo from their website) and UP 6944 (below, photo from UP150.com): This GM Aerotrain (designed to pull modified highway bus coaches for commuters) always fascinated me (photo from Wikipedia): They also have the original EMD FT Demo engine # 103 which is a model I always admired (photo from American-Rails.com): Anyway, they have a lot of stuff there! If you're anywhere near it, don't hesitate to take a look. Their web site is here. Besides the large array of historical pieces, the fact that it was within walking distance of my home factors in a lot to it's ranking as my favorite. A couple other American museums that I remember as being exceptional are: California State Railway Museum in Sacramento, CA B & O Railway Museum in Baltimore, MD ...but I'll leave those for others to discuss as I'm not so familiar with them. Oh, the China Railway Museum in Beijing? It's pretty good! It's completely enclosed in one huge shed and they have an interesting array of motive power there. It would be better if they had more English placards and maybe a bus that goes there as it can be tricky to find and hard to get a taxi out of. If you happen to be in Beijing and have an afternoon to kill, go take a look. Their web site (in Chinese) is here, the Wikipedia entry (in English) is here. They also have an annex in the center of the city in the old Qianmen Railway Station, but I've never been there. I don't think that there's any rolling stock there. Ok, so which museum(s) is/are your favorite? Joe
