Showing results for tags 'fake engine'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 6 results
  1. Hi there I got the idea to use the small pins with stud on top as cylinders for a fake engine. It allows the pistons to be very short, without a stop underneath/above to keep them in place. I kinda dont want to show you my complete RB26dett engine as it is part of a MOC I am working on, so you'll have to live with this little mockup guy for now Sadly this system only works for inline engines, as the pins wont go back down when at an angle, like in a V-engine. The engine runs incredibly smooth, and there is basically no resistance or rev limit. Gray Gear
  2. After building the 1:8 scale Spano GTA, I wanted to make something more compact, yet even more functional for the BuWizz camp 2021, which got postopned to 2022. The rules behind this model stated to build a 1:10 scale representation of a real existing car, which has to have a working gearbox, fake engine and working steering wheel. After researching different types of super and hypercars, I chose the Acura/Honda NSX since it had several good pros compared to the more famous brands like Ferrari or Lamborghini: The real car has a smaller profile, which means a lower weight It uses a hybrid AWD system, which would come in handy for the LEGO model for accelerating and braking on all wheels Engine powering is a V6, which doesn't take as much space as the typical V8, V10 or even V12 Since it's a less known supercar, my LEGO version could be the first one in such scale I used a simillar technique as with Spano GTA where I imported the 3D model into the Lego Digital Designer and used it as a 3D reference. Using this technique I ended up with a really close representation, and it really shows: As you can see in the gif above, not only does the model look very good, it's also full of functionality: 4x BuWizz motors for driving All wheel drive 2 Speed gearbox Working fake V6 coupled directly to the drive motors Working steering wheel 2x BuWizz 3.0 for control Double wishbone suspension on all wheels Dimensions and weight ended up as following: Length: 45 cm Width: 20 cm (without mirrors) Height: 12.5 cm Weight: cca 1,5 kg Here is how the model's underside looks like, drive motors are driving two independent gearboxes in order to evenly spread the mechanical load. This kind of a setup also cancels out any side forces on the central drive axle, thereby reducing friction and wear: In order to cram all the powertrain components in the rear the drive motors are placed in a V shape. This way there is just enough space between them for a functional V6 engine and a PU medium motor which switches the gearbox: Thanks to the compact powerline and driveline, the interrior is very spacious and both seats are almost 1:8 scale sized, measuring 6 studs wide. There are even stoppers and interrior details on the doors themselves: ž The end performance of the model is higher than what I expected, there is enough torque to freespin all 4 wheels, jump over ramps and top speed in high gear is almost 20 km/h! You can see how well it performs the video: To conclude, this is my first 1:10 scale supercar which also ended up extremely compact, functional, robust and good looking. I also think a 1:10 scale may be beneficial when it comes to reliability and robustness, since models tend to weight half the weight of their 1:8 counterparts while still incorporating a simillar level of functionality and details. Having said that, this will not be my last 1:10 supercar and I think for the next one I will ditch the gearbox and simply drive the wheels directly from the motors without any weak differentials.
  3. This time I look for mechanical simplicity, functional steering wheel, fake engine and suspension with maximum realism on the bodywork. I think I've already done the hard part, scissor doors with long travel but I still don´t know what system will operate them. There is nothing definitive, but I like what I see.
  4. I redid my 2012 tatra v12 engine with new parts to make it more robust, I never thought put it in a supercar as Bruno did in his LaFerrari but I think could be a good idea, the V12 Lego fake engine is huge for the 1:10 scale. My Tatra V12 from 2012. http://www.youtube.com/watch?v=aMzqBx-loAY&feature=youtu.be '>http://http://www.youtube.com/watch?v=g3-EXlwyxcI
  5. Hi all! This is my first idea/entry for the mini contest. It's a supercar with the color variation of classic technic sets. First I make it in LDD to see the parts count, now it's exactly 200. Two 1x4 red plate is missing from the LDD model, they connect the 11 and 15 L liftarms. They will also give the rigidity of the body. I tried to put in all of the regular supercar functions: - independent suspension (front&rear) - steering with working steering wheel - two speed gearbox - rear wheel drive - V6 fake engine There are some more little features. The front suspension's bottom swingarm is longer than the upper one, this means more reality in the front axle. The gearbox is linear, the two dkblgray pulleys are responsible for extension in the drive line. They look like clutch plates in real cars. The suspension works with original Lego rubber bands. It's nearly finished, but maybe some improvements (like instrument panel decal) will be done in the next weeks: More pictures, video, part list is coming soon.
  6. Here’s my new little MOC: I wanted a small MOC, using the container truck 42024 wheels. But I also wanted that the vehicle was not been done a lot. So I chose the reach stacker, not very famous. And TLC steal my idea I wanted a quite good design, "better than reality". (the real vehicle is not very nice ^^) I think the style of the real model is here. Functions are : Steering 3 cylinders fake engine Lifting arm Extending arm Clamp, to catch the container Steering is very simple. A "rack" is activated by a crank. Fake engine is activated by only one wheel. (not enough space to put a differential). The arm is controlled by 2 LA. You can torn the 2 sides of the axle, soi t’s easier to move the arm. The arm extension is very simple: there s just a 8t on a rack. It is braked by an other 8t with a pin with friction. It can be extended quite far. To catch the container, a clamp is closed on it. Do you know what element was the more difficult to do? The container! It was difficult to find the limit between weight and full design. I’m working on building instructions. I took screenshots on LDD and I’m assembling they on Photoshop. I though this idea would have been faster than a specialized software, but I’m not sure now. ^^' I don’t know when they will be finished.
