R0Sch Posted 6 hours ago Posted 6 hours ago I counted ~64 teeth on the gear. Could be just 60 though to match existing gear ratios. Quote
Ngoc Nguyen Posted 6 hours ago Posted 6 hours ago 4 minutes ago, R0Sch said: I counted ~64 teeth on the gear. Could be just 60 though to match existing gear ratios. Shouldn't a 60 tooth gears have a diameter of 7 studs only, based on the turntable's size? That gear looks wider than 7 studs. Quote
R0Sch Posted 6 hours ago Posted 6 hours ago 3 minutes ago, Ngoc Nguyen said: Shouldn't a 60 tooth gears have a diameter of 7 studs only, based on the turntable's size? That gear looks wider than 7 studs. The 60 tooth turntable is 7.7 studs in diameter. But as others have also written it's most likely 64 teeth then. Quote
Aleh Posted 6 hours ago Posted 6 hours ago 1 hour ago, Ngoc Nguyen said: Also, why is that bike not a Technic set... Because it's build of a system parts. But I wish they produces some MTB from Technic Quote
R0Sch Posted 5 hours ago Posted 5 hours ago 12 minutes ago, Aleh said: Because it's build of a system parts. But I wish they produces some MTB from Technic That's why I made my own. Sick of waiting for LEGO to bring out something like this: Quote
Stereo Posted 5 hours ago Posted 5 hours ago ~30 stud wheel/tire is enormous, might have some interesting GBC applications depending what it looks like under the tire. I like how it uses 12 spokes so it can just go onto a pair of the classic pulleys turned so their holes are 30° different. Quote
Ngoc Nguyen Posted 5 hours ago Posted 5 hours ago 58 minutes ago, Aleh said: Because it's build of a system parts. But I wish they produces some MTB from Technic All I see is something that could have been the next 1:5 bike for the Technic lineup :( Quote
aeh5040 Posted 1 hour ago Posted 1 hour ago 5 hours ago, R0Sch said: The 60 tooth turntable is 7.7 studs in diameter. But as others have also written it's most likely 64 teeth then. I am definitely counting 64 too. Exciting times! Quote
gyenesvi Posted 51 minutes ago Posted 51 minutes ago Wow that's unexpected but interesting. Are the spokes 16L links? Quote
