R0Sch Posted 1 hour ago Posted 1 hour ago (edited) This could also be a valid design for a one way clutch gear but needs 3 additional rollers. 13 minutes ago, aeh5040 said: Actually the 64t monster is looking a bit awkward for spacing. Besides the 16t at exactly 5 studs, the only reasonably good fits in the 1:1 studless technic grid seem to be: 8t at (4,2) (i.e. 4 studs across, 2 studs up), 0.03 studs too tight 24t at (5,2), 0.11 studs too tight 36t at (6,2), 0.07 studs too loose I did not investigate using technic bricks and plates yet. Hopefully Sariel will add this gear to his gear calculator soon. There is the tab "gear coupler" for exactly that purpose. https://gears.sariel.pl/ Alternatively, import this to Studio or 3D print it and experiment with Technic bricks and plates. https://www.printables.com/model/27084-lego-technic-compatible-64-tooth-gear Edited 55 minutes ago by R0Sch Quote
aeh5040 Posted 55 minutes ago Posted 55 minutes ago (edited) The all important 8t / 64t is the same spacing as 36t / 36t. I just tried this at the (4.2) grid point and it works nicely - not too tight for most purposes. Edited 11 minutes ago by aeh5040 Quote
R0Sch Posted 54 minutes ago Posted 54 minutes ago Just now, aeh5040 said: The all important 8t / 64t is the same spacing as 36t / 36t. I just tried this at the (4.2) grid point and it works nicely - not too tight. Of course because (8+64)/2 = (36+36)/2. Quote
aeh5040 Posted 10 minutes ago Posted 10 minutes ago (edited) 58 minutes ago, R0Sch said: Hopefully Sariel will add this gear to his gear calculator soon. There is the tab "gear coupler" for exactly that purpose. https://gears.sariel.pl/ No need to wait for that - it's just Pythagoras! Edited 7 minutes ago by aeh5040 Quote
