1 hour ago, Cardboy said:
Thanks but they only have up to Octobers parts I thought the image might have new parts for November?
R0sch said "this month" which I assume is referring to October. Comparing the image to the parts list in NE article also appears to have the same elements in them.
9 hours ago, Cardboy said:
Is it possible to share the image not using imgur or PM me? As imgur refuse to add age verification to there site so can't be viewed in the UK :sad:
You could just use free Proton VPN, which is recommended for online browsing anyway. But here's the link to the Technic parts list: https://www.lego.com/en-gb/pick-and-build/pick-a-brick?icmp=PAB_All_Pieces&system=TECHNIC&sort=created_at-desc
Bit of a throwback question, but I've noticed that my vintage Technic has 2 sizes of part 2825 1x4 thin beam.  The bigger size is 1 stud wide, the smaller one is a bit smaller, which seems to be the same size as other studless beams.   Does anyone know when this changed?  I would guess it's around 1995-97 when the other thin beams (1x3, 1x5) got added.
The Light Bluish Gray one is from Surface Space Loader; other two are Light Gray:
Also interesting to me that it's (c) 1992 on the new one, as the part was introduced in 1989 sets.
Edited by Stereo
In a size I think none of us anticipated :D
Oh man and I love how they detailed the front attachment section. Can't some of the buddies from Lego System department please switch sides to Technic? department :D
Next thing you know TLC will release the same combo of tires (49.2 car tread, 49.2 tractor tread, 49.2 offroad tread, 55 car tread, 55 tractor tread, 55 offroad tread) for the thin rims, I call it.
That would be a really nice trend! Actually, I realized that 56mm RC tires (I have two different sets) work better with the thin version of these small rims, and everything has better proportions that way.
Also, I think TLG should make thin versions of larger rims as well, and then thinner off-road tires for them. I think they made a mistake by forcing a bunch of new off-road tires to work with wide sports-car rims; everything is now too wide, and now it is hard to change all the rims because of tire compatibility. But thinner wheels could result in big improvements for off-roaders not only in terms of looks, but also leaving more space for better suspension. For example, the G-class could have had front diff locker if the wheels were thinner.
3 hours ago, Auroralampinen said:
Happy news for cement truck fans and moc builders. The new city cement truck has brand new Technic cement drum piece:).
Not that important in technic forum, but mixertruck's wheel is new part too.
Edited by msk6003
New parts related to technic in other themes 2026 model
viewimage.php?id=21b8d729&no=24b0d769e1d
56903 wheel 18x8 with axle hole in black is new
Front tractor tire maybe 43.2x22 in black is new
72206 wheel 24x12 with tire and pinhole in lime is new
66727 wheel 18x12 with pinhole in LBG is new
72206 wheel 24x12 with tire and pinhole in yellow is new
Mixer drum and wheel is new
66727 wheel 18x12 with pinhole in red is new
32271 liftarm bent 3-7 in reddish brown is new
56145 wheel 30.4x20 in bright light yellow is new
It's annoying that the rear tire pointed different direction with front.
4412 half dome 5x5 in yellow is new
Edited by msk6003
Yeah, 86652 wheel is compatible with the large hubs and would look good with large size offroad tires (doesn't have to be tractor style).  I don't know why it's only had one type of tire for it for 30 years.
7 hours ago, R0Sch said:
A bunch of new parts were added to B&P this month:
https://www.lego.com/de-de/pick-and-build/pick-a-brick?icmp=PAB_All_Pieces&sort=created_at-desc&system=TECHNIC
Bronco tires are sadly out of stock already.
The price of the 42215 bucket is very high! On bricklink it is about the half.
The triangular panels introduced in 42215 instead are much cheaper than on bricklink, about 1/5 of the current bricklink price.
The pneumatic hose has been like that for months and they have longer lengths for much less. A lot of there rubber parts seem to be very high  6475469 are £13 each There are now 3 sets that use them so I would expect the price to start falling.
Still Black 1/2 Bushes are back in March on the BMW be buying those till they go out of stock :laugh:
Edited by Cardboy
2 hours ago, Zerobricks said:
There are lots of new parts coming in the new education sets, amongst:
  • Studded C frames - perfect for meshing gears
  • New pulley wheels
  • 1x4 plates with jumpers
  • MONORAIL TRACKS!
  • and more...
Edit, source: https://www.lego.com/en-gb/aboutus/news/2026/january/lego-education-cs-ai
I have picture of all new parts but I don't know when can I upload it.
3.5x16 rack gear plate - dark purple and LBG
16x16 curved rack gear plate - white only
4x4x2 rack gear guide and gear mount - TR.clear only
2.5 and 1.5 2 stage pulley - black only (Last new release of any kind of pulley part which is not wheel is 1993 with micromotor pulley)
Technic brick 2x4 with 4 pinhole and 2 fixed friction pin - white only
Plate 1x4x2/3 with 1x2 cutout - coral only
Technic brick 6x5x1 with 4x4 cutout and 9 pinhole ㄷ shape - white only
The part sizes are estimates. I didn't have time to measure them.
I didn't try to find recolor.
Edited by msk6003
On 1/12/2026 at 9:32 AM, Ngoc Nguyen said:
Is Charizard's orange the regular orange? Angles connectors on the wings seem to be in an uncommon orange color.
Pretty sure it's regular orange (with reddish orange used for the lava on the stand underneath). The triple axle connectors on the wings are definitely new, the other two seem to be more common.
Pikachu also has the ball joint with through hole in yellow.
  • Recently Browsing   1 member
