9 minutes ago, SNIPE said:
I meant they are rare in white, but the 'r' connector is new in white, it came in bright green initially
Um, what is an "r" connector. I have never heard about this connector.
Its what I (at least) call this piece:
80336-D6-D-DCD1-4034-92-D1-936747753-F2-
Because the 'Y' connector is already taken by 2 other parts, there's also the 'k' connector
2 minutes ago, NV Lego technic said:
That was my first ever rc set. Both motors from it stopped working.
Interesting, mine used 42065 works fine. Even if it maybe had sat unused for many years on previous owner.
5 hours ago, Bartybum said:
Shorter suspension links make for shorter vehicles, pretty much
Even though I thought that smaller builds would be more limited by width than length, I have just used this part in a recent build, to hold the front axle from the front, pretty handy. But at the same time I wondered if this would also be helpful in steering mechanisms of live axles. Could also be useful!
Speaking of new links (pretty happy with the arrival of new parts this year), I just bought some new 8 long links, and saw that they are still axle shaped but wider in the middle. Not sure why they need to be axle shaped, that only makes them get caught up in nearby pieces easier. They could have rounded or octagonal shape. Does anyone know why acle shape is better?
Just speculating here, but the link shaft should ideally be as stiff as possible while still being not too thick for easy moulding and using less plastic, and cruciform shape for cross section fulfils these goals better than octagon or circular shape. As for being exactly like axles in shape - that's probably just a familiarity thing.
I wonder why these hemisphere pieces were not created/used for the Technic sets like Planet model too? No ugly pins sticking out. The only thing they lack is a central axle connection.
21358_Lifestyle_Build_04_en-gb.jpg?forma
Sometimes it takes multiple smaller steps to get to a design like this. It looks like this might be designed to complement that earlier piece, looks like they'd fit together seamlessly, so you could use the earlier version if you needed an central axle hole combined with this newer one for a more seamless dome on the front.
The transparent color these new ones come in also makes me wonder if these could work as headlight covers on any sort of model.
They're pretty big to be headlights I think, standard round headlights are 7" so these would be around 1:4.5 scale.  Maybe for the big motorcycle sets.  Or very old cars (Crowley's Bentley maybe)
Edited by Stereo
Surprising that we would get a 4L steering link before a 5L one! It should definitely be useful, though. Lots of great suspension parts this year!
Did anyone notice before a change in quality of the 57518 part? The 'new' variant has a different feel to it and should really be a different mould type in Bricklink, imho. It can be interconnected with the old parts but the color and feel don't match too well.
I found 10% of my 500 link treads being a different quality, Bricklink store are sure the parts are genuine Lego.
Made a short about it:
Yes, noticed it with the App Transformation Vehicle. The new one is more matte and much softer and can break up easier.
Yes. It disconnect easyer than before.
Actually, to much critically easy. I like old one 10000000x more.
Edited by msk6003
I am praying to the lego gods that this subpart can be removed from the wheel that it comes in
73-DE40-C6-C233-4-B67-8097-4-ECCE38-EB37
It has a "hard snap" but is friction-less, so it can kinda act like a 2L axle with stop
I also experienced issues with softer link, but with the yellow on the D11 thought.
With any given thread tension, it will snap or lose the threads if you try to climb hard things too much (like another lego RC for sumo fight for exemple).
BUT :
with the same thread stucture, mounted with old black links it doesn't snap even if you tension it enough so it can never lose threads. (The rest of the toy is different so it do not have the same weight, but it's in the same range)
