Showing results for tags 'santa fe'.
I remember when the original BNSF Lego set was delivered back in 2004 to my dad's house. (for him - not me, sadly!) That set, along with the complete Super Chief he already owned from two years prior, got me even more psyched for LEGO trains. Granted, I couldn't afford the set at the time, but now I'm 20 years older and have money! Thus, I decided one day late last month to redesign the 9v Train set 10133 - Burlington Northern Santa Fe (BNSF) GP-38 Locomotive - into the modern paint scheme of the BNSF railroad. In short: I took the dark green and made it black, as that's the way the railroad has painted their engines since 2005. As I couldn't possibly get the yellow train baseplate, I used Dark Bluish Grey, and since I HATE dealing with flex-tubes, I used premade fence parts for the walkway railings. I also revised the rooftop fans, the bogies, and the fuel tank. The front of the loco. The rear of the loco. The three 2x2 DBG donut tiles on the roof are missing fan printing here in LDD. The cab roof is still removable, just like in the original set. This area seats one mini figure at the controls. Only 126 bricks remain to be found or bought for this diesel locomotive in the real world at this time. (NOTE: Some differences exist between the digital model and the WIP.) Thoughts?
- 10 replies
- bnsf
- burlington
(and 8 more)
Tagged with:
I've always been a fan of the 10020, 10022 and 10025 sets. I have a full set with 2 limited edition locomotives, a set of rebricked 10022 and 10025 railcars in new greys and i've even created my own EMD FP45 MOC. After getting my hands on a Santa Fe Pleasure Dome railcar, I found out, that instructions for a B-unit and a full Hi-Level El Capitan consist exist. So over the timeframe of about 3 months, I've gathered all the light and dark grey bricks, that I needed to build these. The entire consist are 2 limited edition 10020 Santa Fe EMD F7 locomotive, 2 F7B B-units (each with a 9V motor), 3 x 10022 (dining, observation and sleeper car), 2 x 10025 (railroad post office and baggage car), Pleasure Dome and 6 Hi-Level El Capitan railcars (I build 2 Transition Coaches, one for each end). To be able to even move this train on my fairly large layout, I need 3 regulators along the track and I had to replace the magnets with stronger ones, which were sourced from Bevins Bricks and Lifelites. The stickers on all cars, that aren't official sets, where sourced from BrickStickerShop. I also build the entire consist in Stud.IO, because it's actually not that easy to find the space to take decent pictures of it. I tried none the less. Here is a video, that goes through every railcar with breakouts and has the trains driving at the end. It's been fun building this. It's even more fun seeing it in motion. /M
- 12 replies
- santa fe
- super chief
(and 1 more)
Tagged with:
First, some context: Here's a shout-out to Daedalus304 and his ATSF #2926 4-8-4 locomotive, for this locomotive of my own shares quite a lot of cosmetics with 2926. Onto my project: Santa Fe 3463 was built on October 30th, 1937 for the Santa Fe Railway as a passenger locomotive and was assigned to crack passenger trains that ran from Chicago, IL to La Junta, Colorado along with its sister locomotives. 3463 was assigned to lightweight trains such as the Chief when they first rolled out, but given their power, they were assigned to heavier trains on the Chicago-La Junta Division in January of 1938. This locomotive pulled trains like the aforementioned Chief, the Scout, The Oil Flyer, and even the Fast Mail Express. In fact, one of these 3460 class Hudsons', No. 3461 set a record for the longest run without any maintenance stops, the only exceptions of course were fuel and water. No. 3460 was given a very special streamline shrouding which earned it the nickname "The Blue Goose" and was the ONLY streamlined locomotive to run on Santa Fe rails. 3463 would soldier on until 1953 when it pulled its last train The Antelope. In 1956, it was put on display outside what is called the Stormont Vail Event Center in Topeka, Kansas, and has remained since. There was an attempt to get this locomotive restored by the CSR in 2012, however, legal issues plagued this for 5 years and after that, the favor was to go to the CSR in 2018. But even then, there were more turn of events that still render the locomotive dormant. To me, the poor girl's restoration was doomed from the start and personally, I would like to see her back in operation someday. This model demonstrates the Hudson in 1/35th scale, it is roughly 11-12 studs wide, approximately 17 studs tall and 113 studs long. This thing is LOADED with details, even an (almost) perfect valve gear system. 6 L-motors are the current power source in place, 2 in the locomotive to keep the drive wheels in order and 4 in the tender, this may be upgraded later but I doubt it. This train HAS been assembled before, however, it was HEAVILY flawed. Faulty drive design with the side rods and gear ratio, too small drive wheels of the incorrect design (I ordered #13 boxpok drivers a while back) which as far as design goes to the wheels, drivetrain, and cosmetics has been resolved. You can check out my wheel by searching for Baldwin Disk Driver. That very same driver will also be going on this locomotive in the future. I even went ahead and designed some special parts that will be incorporated into the locomotive as well. This locomotive is a design that dates back to October of 2021 and by spring of 2023, I plan to have it completed by then unless something comes up. Who knows, I may enter it into the Brick Train Awards if the timing is right and I may have a consist running by the summer of 2023 as well, but I cannot say for certain because the locomotive and tender will come first. For the most part it is complete, but still could probably use a few tweaks before being finalized. With that out of the way, here is the photo gallery of my engine. Here is the valve gear on the LEFT side of the locomotive Here is the valve gear on the RIGHT side of the locomotive I did my best to capture the cab. Unfortunately, I could only find ONE picture and the picture in question is the one with the locomotive in its current condition, that being derelict. Here, we have a water glass on the left, In-Cab signals in the middle, Steam pressure gauge is located below the signals, Speedometer is to the right of the firebox followed immediately after the throttle. The brakes are located below followed by the power reverse on the cab floor. Oil "stoker" is located under the water glass along with gauges.
Background for the locomotives and train: "Atchison Topeka & Santa Fe 302" is one of a very rare breed. Built in August 1949 as a “A” (cab) and “B” (booster) F7 diesel unit for the Atchison Topeka & Santa Fe Railway (AT&SF), This Electro-Motive Division (EMD) product was painted in a variant of the famous Warbonnet (red,yellow and silver) color scheme called Bluebonnet (blue yellow and silver). The engine was intended for freight service and did so faithfully for 28 years. In late 1977 the two unit set was on the short list for conversion to an CF7 hood unit when the Wabash Frisco & Pacific (or WF&P for short) went looking for a engine to pull it's recently refurbished Merrimack River Runner. The Santa Fe gave them a two-for-one special on the tired F7 units, with the WF&P buying the A unit and getting the B for free. The new owner realized the historic meaning of this deal more than the old owner did: this was one of the last bluebonnet engines left, and one of a handful of AT&SF F7's not converted to the horrid looking CF7 hood unit. Needless to say, the WF&P snapped up the offer, and even set the loco to the EMD La Grange, Illinois assembly plant for the motor to be replaced with a newer, more powerful and easier-to-maintain power plant. The units came back to the WF&P in 1979, and have since been teamed up with the recently restored Southern Pacific Daylight 4460 (owned by the St. Louis-based National Transportation Museum) for trips up and around WF&P system. The front of the two units. The inside of the Cab (or A) unit. The inside of the Booster (or B) unit. Here we see the Merrimack River Runner being pulled by ex - AT&SF unit #302 The open platform observation car beings up the rear of the train. It may be hard to tell, but each passenger car has tables and chairs with removable roof on top. The baggage car is empty, and the locomotives have mechanical stuff including engine blocks and cab controls. Builders notes: Atchison Topeka & Santa Fe 302 really existed, but I have no idea what it was painted. It was probably either scrapped or converted to a CF7 hood unit along with most of the other F7 locos. The number I used came from the LEGO set number 10020, which uses number 301 for it's Warbonnet painted loco. I wanted this to a be a sister loco, so I used the next one up: 302. The Wabash Frisco & Pacific is a real 12 inch gauge steam railway based in Glencoe, MO. For my purposes they have been turned into a "real" railway. The Merrimack River Runner is a copy of the Missouri River Runner, a real Amtrak train starting from St. Louis and ending in Kansas City before reversing course and going back to St. Louis with some stops in between both cities. Also, the original LEGO Atchison Topeka & Santa Fe (known as the Santa Fe) Super Chief trains cars from the early 2000's were looking a little dated, so I redid them. I added Emerald Night style doors, removed the expensive roof slopes, and added a rear platform instead of the (extremely costly) curved window glass. The Southern Pacific 4460 really exists, but has not steamed since 1959. It is located in St. Louis MO at the real-life Transportation Museum. This is my Bluebonnet powered passenger train made into a sprite of the same style used by Herby's New LEGO train Depot, which features every Lego train rendered as a sprite. (link to that website: http://www.fa-meier....epot/index.html ) Anyway, the train is pulled by two F7 locomotives (that's one cab unit and one booster unit), while the train is made up of one baggage car, three passenger coaches, and one observation / lounge car. Here is the LDD file for the train: http://www.mocpages....1417446093m.lxf And as always Comments, Questions and Complaints welcome!
Dear All, From the MTRkustoms train Factory i have the pleasure to announce my latest MOC, After some Spanish Train MOCs I wanted to make a Steam Locomotive, and I Started with the biggest and more powerful Spanish Steam, the “Santa Fe” 151 (French/Spanish) 2-10-2 (Whyte) This locomotive was able to pull a 450 tons train at 30km/h and a slope of 20mils The most difficult challenge was create a MOC that can run in R104 Blastemtrack, and R40 curves. To get the power I use a 9v dummy motor to pick up energy and 2 L PF Motors inside the boiler attached to the 9v pickup, is not a fast MOC, but is a very powerful Locomotive DIMENSIONS Locomotive length: 45 studs Tender length: 25 studs Total length: 70 studs Height: 9 bricks 7 wide Details To be a complete MOC I made some type of cars, 1 Closed boxcar, 5 open coal cars, and one caboose car. Details These 2 axle wagons have a flex hose coupling to be connected and allow Little turn of the axles. Also the coal wagons have an aperture system for the next project. All the pictures in Flickr Album And a little Video: Enjoy it
Right now I'm designing a updated Santa Fe train consist, hopefully to scratch the urges of the original without the hefty costs, but I want to ask a few questions before I start working on it. What parts from the original are the most expensive and difficult to buy? What are some better methods to tackle the nose without the expensive parts? I'll be posting updates and images, with LDD files as I work on this and at the end will upload to my Rebrickable, where I already host an old project.
(Thanks to raven1280 for the inspiration to create this model.) These Electro-Motive Division F7 diesel units are painted in the Atchison Topeka & Santa Fe (AT&SF) Warbonnet & Bluebonnet color schemes. They are based off of set number 10200 (Santa Fe Super Chief) and fellow Eurobricks user raven1280's Bluebonnet MOD with a couple of my own twists inserted in some places. For example, instead of using custom stickers for the windscreen and porthole windows, I'm using regular Lego parts. Also, the undercarriage is black (not gray) on the bluebonnet engine because of this photo: https://farm3.static...951e1b39f_z.jpg The rear of the locos feature the booster units, or B units, as they are sometimes called. The B units feature through crew walkways to the cab unit. Neither the A or B units contain interiors. LDD file: http://www.mocpages....1405274343m.lxf Please see the inspiration for this MOC / MOD at this topic here: http://www.eurobrick...81#entry1936703 What do you think of my MOD of a MOD? EDIT: Reworked some things and gave it a back-story. Atchison Topeka & Santa Fe 302 is one of a very rare breed. Built in August 1949 as a “A” (cab) and “B” (booster) F7 diesel unit for the Atchison Topeka & Santa Fe Railway (AT&SF), This Electro-Motive Division (EMD) product was painted in a variant of the famous Warbonnet (red,yellow and silver) color scheme called Bluebonnet (blue yellow and silver). The engine was intended for freight service and did so faithfully for 28 years. In late 1977 the two unit set was on the short list for conversion to an CF7 hood unit when the Wabash Frisco & Pacific (or WF&P for short) went looking for a engine to pull it's recently refurbished Merrimack River Runner. The Santa Fe gave them a two-for-one special on the tired F7 units, with the WF&P buying the A unit and getting the B for free. The new owner realized the historic meaning of this deal more than the old owner did: this was one of the last bluebonnet engines left, and one of a handful of AT&SF F7's not converted to the horrid looking CF7 hood unit. Needless to say, the WF&P snapped up the offer, and even set the loco to the EMD La Grange, Illinois assembly plant for the motor to be replaced with a newer, more powerful and easier-to-maintain power plant. The units came back to the WF&P in 1979, and have since been teamed up with the recently restored Southern Pacific Daylight 4460 (owned by the St. Louis-based National Transportation Museum) for trips up and around WF&P system. Builders notes: Atchison Topeka & Santa Fe 302 really existed, but I have no idea what it was painted. It was probably either scrapped or converted to a CF7 hood unit along with most of the other F7 locos. The number I used came from the LEGO set number 10020, which uses number 301 for it's Warbonnet painted loco. I wanted this to a be a brother loco, so I used the next one up: 302. The Wabash Frisco & Pacific is a real 12 inch gauge steam railway based in Glencoe, MO. For my purposes they have been turned into a "real" railway. The Merrimack River Runner is a copy of the Missouri River Runner, a real Amtrak train starting from St. Louis and ending in Kansas City before reversing course and going back to St. Louis with some stops in between both cities. The train cars are based on a real WF&P passenger car paint scheme. The Southern Pacific 4460 really exists, but has not steamed since 1959. It is located in St. Louis MO at the real-life Transportation Museum.
An overall shot Close Ups A city scene James River Crossing Metra Train BNSF Freight TGV and one I found an image of that I recreated here.
- 27 replies
- microscale
- train
(and 5 more)
Tagged with:
Hi all, First train MOC since I got back in to LEGO about 1.5 years ago. Finally got the space to do a permanent layout in the basement. Just need to set up some tables or make a workstation. Here it is! I redid the cow catcher at the last second. I changed it from 6 wide to 8. Much better this way. Allowed me to curve it more gracefully. Not happy with the headlight. I couldn't decide how to make it better though. It needs to be bigger. I didn't know I had so many 1x2 light grey grills.... I'm thinking the cover over the rear door needs to be raised a little to bring it closer to the roof. The windows took some SNOT work to get right. They're a little high on the chassis, but changing them would require tearing apart the whole thing. This engine is like... enormous compared the rest of my layout and trains. It completely dwarfs everything. If you open the door in the back, there's a little 9v battery box that powers.... An M-PF motor that turns all 4 cooling fans! All they need are some decals. That's all. Rolls around turns pretty nicely. It's a bit heavy though.
