Showing results for tags 'mobile crane'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 17 results
  1. Technic Mobile Crane Thanks to Lego and EB for this review set - I had seen nothing about this set before reviewing it, and I've deliberately tried to stay away from discussions on it, so you can get my own thoughts on the set. Name: Mobile Crane Set Number: 42108 Pieces: 1292 Price: $99.99 Minifigs: 0 Theme: Technic The Box Front A very nice front to the box. Good action shot, a nice backdrop, but for some reason, the Lego graphic designers decided to cut off just a hair of the set at the top and bottom. The Box Back A usual Technic back - all the action features on display, some see-thru images, but wait... NO B MODEL? Seriously? On a $100 set, there's no mention of an alternate model? Not a good thing. The Contents Again, pretty normal. Manual and stickers in a bag, parts in 3 sets of bags, plus an un-numbered back with the tires. The Manual Those parts will neatly break down into building steps. First the chassis, then the cab and part of the crane, and then the rest of the crane. The Stickers Again, typical Technic sticker sheet. Warnings, control instructions, and decorative parts. And with all the OK references in there, I'm assuming Olav Krøigaard designed this set. The Build, 1 After a little bit of building, you have this frame. The 4 axles are in place, all of which steer. The outriggers are also in place, as are the front seats. The two vertical grey connectors behind the seats are both connected to the steering, so I see the HOG steering system already forming as well. The Build, 1b This crane seats three. And although those curved panels seem logically designed to be mudguard or similar, I'm pretty sure that seats has been their most common usage. The Build, 2 At the end of bag set 2, the front end is done and the base of the crane is in place. Yes, that's one of the new long linear actuators as well. And unsurprisingly, the hazard lights on top of the cab are the steering knobs. The Build, 2b Most of the crane mechanism is in place. Both the linear actuator and the cable spool are here and functional. The Build, 2c Speaking of the cable spool, I appreciate the usage of the slit in the technic wedge belt wheel here. This was probably the easiest string to get started of any Technic set I've ever built. The Build, 2d Here's the underside. There's no drive connected to any of the axles - the "driveshaft" going the length of the crane is for steering. There's no fake engine in this, nor any suspension or any other complications. The Build, 3 Add the last of the parts and the crane is done. It looks pretty nice in this position, certainly very recognizable as to what it is. The crane arm gets in the way of the lights used for steering on top of the cab, but it's still drivable. The turning radius is surprisingly small, since all 4 axles steer. And yes, the 1 and 4 axles steer more than the 2 and 3 do, so the geometry is pretty good. But please, could you make that 20 tooth double bevel gear in a color other than blue? So far, this version of the gear (which has a smooth center hole, not an axle hole) only comes in blue. It just looks so glaring at the top of the boom there. Moving on to other details... The Outriggers, Rear The rear outriggers are simple and semi-effective. They're easy to operate with the black gear knob, but they only just barely go overcenter, so wiggling the crane around can make them close. They just barely lift the crane off the ground - you have to be on a hard surface to notice. On carpet, it's not enough height. The Outriggers, Front The front outriggers are less good, IMHO. They have the same geometry, so the same issues with not actually doing a ton. To operate them though, you just pull the red ball with a finger. Once the wheels are attached, there's not much room to get at it. Kids would have less issues than I do, I'm sure. The Controls, Left The controls for the crane are very direct. There's no complicated gearbox or anything. On this side, the black knob extends and retracts the inner section of the boom. The red catch on top keeps it from retracting unexpectedly. And again with the blue gear... The Controls, Right The right side has 2 knobs. One raises and lowers the boom and the other winds the cable. It too has a catch like the boom extension. Again, simple and ready to play with, but not complicated for the adult builders to enjoy. However, be ready to spend some time raising and lowering the boom. Thanks to the long actuator, it took me 60 twists of the knob (turning it about half way around each time) to raise it. That's a lot of twisting... The Chassis The crane looked good in the down position, but when you raise the boom, there's a big gaping hole in the middle of the chassis. Would a few more pieces to fill that in have been too much to ask for? The Finished Crane Once you've finished building and raised the crane, this thing is huge. The height is very impressive. In fact, that may be the tallest of the Technic cranes. If you have the boom horizontal, out to the side, and fully extended, the crane WILL tip over unless you have the outriggers down, and then it just barely stays upright. The Comparison The logical comparison is to the previous Mobile Crane, set 42009. That 2013 set is significantly larger - the price was more than twice as much ($220 vs $100) with double the parts (2606 vs 1292, and it came with a battery box and motor). Even though they are at different scales, the actual crane booms are very close in length. 42009 had a 3 segment boom - so did the extra segment help with size? The Comparison - Height Nope, the extra segment doesn't help at all. The smaller set actually reaches slightly higher. The extra segment on 42009 requires more overlap between the sections and more complicated mechanisms, so it doesn't actually extend the reach. The Conclusion I think the new crane is a great set, for certain buyers. It's not for the AFOL - we've got 42009 to meet our desires for big and complicated. The new mobile crane is a great play set. The controls are simple and direct, so kids will have no problem playing with it as a crane. Where it falls flat is the lack of B model, which leaves it feeling overpriced. By the standard 10 cents/part measure, it's a good value. But in reality, it doesn't quite feel like a $100 set. On sale, or if you have a newer Technic fan who wants a crane, then buy all means, grab it! It's also a pretty solid parts pack - quite a few wheels, gears, long beams, and of course the new long linear actuator. Overall, I give this set a B. It's solid, but not a star.
  2. In the past 2 months I've been working on a mobile crane. I initially started with the Liebherr 1350-6.1 but then decided to add another axle and go for the 1400-7.1 For reference I'm attaching an image of the Felbermayr livery I'm going for. I think blue is a nice alternative to the usual "yellow" technics mocs/cranes! image share Some of the features: integrated pneumatic suspensions (currently this crane can run both on pneumatics or normal shock absorbers) 7 solid axles of which 6 are steered and 5 are driven studded design (although the axles themselves are built in studless technique) as many details as possible (I haven't completed this MOC yet so at this stage there is room for adding more) decals/stickers where needed 2 or 3 Sbricks (1 in the carrier and 1or 2 in the upper structure) 2 L motor for driving 1 L motor for steering 1 M motor to extend the outriggers 1 M motor with autovalve to lower/raise the outriggers pneumatics. At the moment only the carrier has been completed digitally, upper structure to follow The chassis itself it's a 5 studs tall/thick and should provide enough rigidity. As you can see the outriggers take quite a lot of space, both driving and steering shafts had to go either below or above them! upload pictures Here a view of all the axles: currently showing pneumatic pumps but given how much they cost I've decided to use standard shock absorbers More renders. hosting images online image sharing sites free Hope you've enjoyed this. Will start building it soon hoping everything goes smooth! Then will develop the upper structure and share more images. Cheers, TheItalianBrick!
  3. Hi guys, i'm a new to world of LEGO but i'm so addicted after my first year of recording reviews. I know that many people don't like my work because I've found a local seller who sold me these sets earlier. Hope videos bellow will help you. Do not hesitate to ask for some specific information, i'll try to answer to every request. LEGO 42109 Top Gear Rally Car Testing speed, slope, strenght and more. Speedbuild and new differential review: LEGO 42108 Mobile Crane LEGO 42106 Stunt Show Truck and Bike, LEGO 42104 Race Truck LEGO 42103 Dragster LEGO 42102 Mini CLAAS XERION LEGO 42101 Buggy LEGO 42107 Absolutely no information about these sets. maybe cancelled? Unboxing video and parts lists
  4. Combination of 2 sets of 60324 Mobile Crane. No extra parts involved.
  5. Hi, as a crane fans, i'm happy to introduce my lastest building GROVE GMK5250L in scale 1:20 it's a revise version to my last crane project more accurate appearance and gear functions are more effective the 6 panel boom max can reach around 140 cm after extendend, and the crane high is 165-170 cm The angle of rise can reach 82 degrees, just like the real crane the counterweight is datchable Thanks for viewing and appreciate any feedback! 07/08/2021 the video added 09/09/2021 the instruction is available on rebrickable https://rebrickable.com/mocs/MOC-86030/mitx2529/grove-gmk-5250l-mobile-crane
  6. Hello everyone. Happy to present my latest MOC: LIEBHERR Concept Mobile Crane. All motorized functions: - 3 XL for propulsion (1 for each axle) - Servo for front axle steering - 1 PF L - outriggers - 1 PF M - 360 degree tower rotation - 1 PF XL - custom wormgear actuator arrow control - 1 PF M - string based second stage - 1 PF M - hook control - 1 PF lights - 2 light bricks - 1 Buwizz 2.0 - 2 battery boxes 8881 - 1 train battery box 88000 - 3 IR recievers - 1 pole reverser Manual functions: - Openable hood (V6 line engine + propeller;)) - Openable doors - Full cabin detalization for 2 persons - Openable engine compartment (inside the cabin) - Openable side compartment (access to train bb) - Openable hatch under the arrow (access to Buwizz) - Full crane cabin detalization - Openable tower engine compartment (access to BBs) MOC done in the scale of ~ 1:11. Parts counting around 7k. Tbh I lost the count somewhere around 4k when it was body only. Weight - 7 kg. Dimensions: 0,86m long (0,98m with arrow) x 0,3m width x 0,32m height. Note that: From the very beginning, it was not the purpose to make a full scale 1 to smth copy of a specific crane, but rather make a functional crane with the features of a real one. If you did not follow the topic when it was only WIP - sad to say that I had to make hard front axle because it was getting really heavy. The 2nd and 3rd axles are made as pendulum suspension with 6.5 hard shock absorbers to support. Of course with the weight all of the offroad utility was shaved down quite a lot. Drastic contrast from the original 3axle cranes is the body length and outriggers design I guess. All other mechanisms are here. More photos at: https://bricksafe.com/pages/gate/ural-4320-trial-truck/leibherr-ltm1060-3.1-mobile-crane WIP videos: To conclude this MOC: This was a really hard one, cannot even count the times I staggered in thinking of what and how to do next. But I always had general idea which helped me finish the MOC. As well as people who gave me some ideas in this topic specifically. So special thanks to @suffocation, @Erik Leppen, @BrickbyBrickTechnic! Also thanks to 42055 and 42082 for that they exist. This was a huge experience to me and the first mobile crane I've built myself. The general notes I took for myself were: - always plan outriggers before or at the early stages of the chassis; - suspension is not the best idea for a 7 kg crane; - if your model is really huge and heavy - drive it as the stages of building go, with extra weight it starts acting completely different. - think twice before naming your MOC
  7. After seeing @jwarner's excellent smalle crane and @Ludo Visser's WIP on a good looking undercarrage, I kept being reminded I still had one of these on my "to-do list". It's the last (I think) in what turned out to be a series for me of small versions of vehicles that are usally the big 4 "flagships" in Technic that return every couple of years. It features: - Boom lift by pneumatic cylinder - 1 stage boom extension - Rope (with old school 90's lock and also a hook from the 90's ) - 3 axle steering with different steering angle for the front wheels (bottom 12T bevel gear at the rear) - Working V4 (allthough a little out of sync, can fix that as soon as Lego actually makes parts to shift direction at this scale on 1 stud instead of 2 ) - Cabin tilt on the superstructure (through a worm gear controlled by 12T bevel on top) - Superstructure rotation (top 12T bevel gear at the back) - Outriggers (couldn't fit a central operating method so they are moved at the rear through the LBG crank shaft parts usually used for fake engines) Stuff I couldn't squeeze in no matter how hard I wanted to: - 2 stage boom extension (with 11L thin pneumatic cylinder). I tried, but with ropes in play I was looking at a 2 studs wide crane without a shell to give it ridigity, anything with 3 and 4 studs in width with the shell still felt very flimsy. And shortly after switching to a 1 stage boom with these 11x3 panels I really started to like that clean look on the crane vs the thin liftarm extravaganza I had in play earlier - A diff (or at least have the fake engine run in some form on both non-steering wheels). I barely managed to get 1 wheel driven. Had to use some ancient 90's Space Shuttle technique with a rubber band to get the stuff routed. I considered a blue clutch gear from the Chiron on the steering shaft, but besides that really killing my ground clearance it wouldn't fit up top thanks to the pneumatic cylinder. Why not leave the feature out? Can't do that when all the other mini's I made had fake engines. It was this or never getting finished pretty much - And as mentioned earlier: the outriggers being controlled by 1 knob. Couldn't route it to the rear, already crowded, the cabin in the front was blocked by steering angle of front wheels and crane up top. I am happy though that they at least can lock into place and lift the whole vehicle. And a couple of more images: Instead of messing with the length of the hubs on the 2 rear steering axles to get different steering angles, I shortened the front steering hubs by 1 stud to get a sharper angle with space lost in height (rear of the driver's cabin) but not in length. It's turning radius is pretty sweet, very small. Tried to get some details in the cabin, but they are missing half of their bottom seats thanks to the steering wheels. Also messed around a little with options to get the outriggers folded into the body as much as possible, not sticking out more than 1 stud up top and when extended looking at a decent angle. Hmmm, now that I am looking at this picture, perhaps I should swap the 4L thin levers for LBG or something to make the fake engine "pop" from the black chassis. Anywho, thanks for watching and reading.
  8. I've been floating around EB for a while, so it's about time I share my first Technic MOC: Mid-Scale 5-Axle Mobile Crane MOC. by jwarner1718, on Flickr Between wrapping up school and work, I've spent a lot longer on this project than I had anticipated, but I'm very pleased with the result. The finished model is around 950 peices, and with full manual functions: Four-axle steering One stage outriggers Boom extension Boom raising/lowering Superstructure rotation Cable extension/retraction Opening doors With the exception of the doors and superstructure rotation (which are operated simply by hand), all functions are controlled using 12T gears at the rear of the model. I made consolidating the controls a top priority since a lot of manual MOCs have control knobs all over the place. The lower superstructure gear operates both the boom extension and the raising/lowering, and there's a switch on top of the superstructure to switch between the two. Mid-Scale 5-Axle Mobile Crane MOC. by jwarner1718, on Flickr Mid-Scale 5-Axle Mobile Crane MOC. by jwarner1718, on Flickr Mid-Scale 5-Axle Mobile Crane MOC. by jwarner1718, on Flickr Mid-Scale 5-Axle Mobile Crane MOC. by jwarner1718, on Flickr Mid-Scale 5-Axle Mobile Crane MOC. by jwarner1718, on Flickr The crane measures 14" long (36 cm) with the boom down, and the boom itself can be raised to almost 18" (45 cm). Let me know your thoughts!
  9. The original builder is member of EB, but doesn't post here often. Says he is having difficulty with logging in so I am posting this here for him. Needless to say, wonderful and accurate build. I only wish there were a video. The amount of functions fit into a model at this scale is terrific, and boy, does it look great!. All five axles are with suspension. Four stage boom where the height better resembles the real thing. Check out the link for full details, and I have posted some pictures as well. http://www.moc-pages.com/moc.php/443667
  10. Since the beginning of my AFOL-hood, I have been a crane guy, with many mobile cranes built in the past. Now, during the more recent years I tried to diversify, partly thanks to competitions like those on Eurobricks, and built various other vehicles. I think it's time to see if I haven't unlearned how to build a crane :) So, the goal. I aim for a five-axle crane in the same scale of 42009. I think five axles is a perfect balance: enough to be imposing, but not so much it becomes awkward :) I use the Liebherr LTM1200 as a source of inspiration. The extra space between axle 3 and 4 gives me some extra leeway, but I also find it to look better. This image is from the Liebherr folder; I drew a grid over it with 8 studs for the wheels, and some markings in red. Most functions will be manual. Not sure if I can even get a motor in, but I will try. But there is one function I really want: suspension. I think it just looks cool to have a multi-axle vehicle with suspension on all wheels, and it makes my model less of a 42009-clone. To do this, some other functions will have to be dropped, like the motorized double-acting outriggers. This is the progress so far. Each axle is a fixed unit that is connected to the frame by two shocks and two ball joints. As vertical space is limited and Lego suspensions always tend to become taller than desired, I had to find a way to create a sturdy frame, so I went for studded Technic bricks. This makes the frame very strong. Also I think it's a nice deviation from all-studless building :) (This will principally be a studless model, don't worry.) Then, the steering. If you ever want to add and connect the steering to so many suspended axles, let me warn you: it's not fun. Every axle needs two U-joints. I just ran an axle with lots of U-joints (at least 6) through the entire thing. Not optimal, but it works. The outrigger housing is a real pain to work around. Steering angles per axle are varied the 42009 way: by having different steering arm lengths. The ratios are 100% : 50% : 0% : -67% : -100%, or, in easier numbers: 1/2 : 1/4 : 0 : -1/3 : -1/2, where the denominator is the length of the steering arm. Axle 3 is the only axle connected to the fake engine. Speaking of which, there's hardly any room left for that! So I decided I will add a boxer engine (which is lower), and it will still have to stick out one stud above the roof of the cabin. So be it. Driving the fake engine will be a challenge by itself too, because the unwieldy geartrain for the front axle's steering is in the way. I will have to sacrifice a lot of ground clearance for the driving axle. Next up: add the fake engine, add the outriggers, lay out the measurements of the cabin, and see if I can get the first boom segment in place. One note about colors. It will not be yellow. I just don't want to add another yellow crane, but I'm still in doubt about color options. I love trying out weird color combos as you might know, but the boom will probably be white, because of the panels I have (thanks to 42025). So I will probably do a multicolor scheme where white and black/gray are combined with one or two non-grayscale colors. I love to hear what you think of the first take :)
  11. Somehow the thread was duplicated. Please delete this thread dear Moderators.
  12. Imma start a dedicated thread for this set as well. All info so far: Rough terrain crane 4057 parts 229 Euro 1 meter telescopic crane. With power functions. Largest TECHNIC set for parts. 4 wheel steering. V8 engine sticking out at the rear, uncovered. Unimog wheels with covers. 5 motorized functions: - Raising boom - Extending boom - Lowering winch - Lowering outriggers - Rotating superstructure B mode: drilling vehicle.
  13. some of you have maybe seen my video with the of the xl actuator and how the boom is bending under the load. here are two pictures do you have any ideas to prevent this.
  14. Here's a small scale mobile crane loosely based on the Liebherr LTM 11200. Not all of the details were implemented due to scale, since I wanted it to be functional and detailed. There was also a little bit of cheating with the counter-weight being a slab of steel taped on (it would've taken too many of bricks otherwise). The images don't seem to be embedding so links will have to do for now. Here it is with luffing jib and super-lift. Full height Better view of winches and super-lift Truck Loading counterweight and auxilliary winch Semi transport config Transport config
  15. I know I'm a bit (quite a lot) late with this video, considering how long ago this set was released, but better late than never! The description: "Yay, I finally found time to make another video! In this video, I learned how to adjust brightness within the video clip, played with keyframes for audio fade in and fade out as opposed to using Adobe Soundbooth, thereby making the entire process faster, and upped the usage of cross-dissolves and title cards. My most professional video yet, I think. Also, there's a fancy new intro graphic!" "On the other hand, I'm not happy about the shoddy camera work and the dismal lighting. As I didn't really plan out the shoot *at all*, I was limited in the space I could work with and settled on a temporary camera mount. I intend to get a GoPro tripod mount, but in the meantime I'll have to cobble together a solution out of more Lego. As for the lighting, it turns out the GoPro has really terrible low-light capabilities, which is why I brought in a studio light towards the end. Next time I'll see about borrowing both that are available in this household and using them from the beginning." "I could have fixed these issues if I had taken apart the set and built it again HA HA HA nope. (2600 pieces)" "Camera: GoPro Hero3 White Edition Music used: "Cumulonimbus" ~ Cumulonimbus composed/produced by Steve Lowther provided by freesoundtrackmusic.com ~ Software: Adobe Premiere Pro CS6, Adobe Photoshop CS6, Adobe Media Encoder CS6"
  16. Hello! I made some experiments nowadays, also this string operated actuator for heavy equipments: http://www.brickshelf.com/cgi-bin/gallery.cgi?f=534220 (this last picture is from another model, just shows the working method) The working pricniple is very simple and effective: the winch in the end of the housing (yellow) pulls out the liftarm construction (gray) with string(s). This isn't realistic, but think about TLC's actuators, they aren't also. I made it for heavy equipment, like crane booms, excavator arms, etc. For raising a big boom, pneumatic has no chance, Lego actuators also. There are two ways after that: custom actuators/custom pieces, or built actuators. I think string is "legal", it can be made also with Lego strings (but would be expensive), so it's 100% legal. The extension is 15 stud (can be a few studs more, but that would be in the "limit zone"). With longer construction it can be even 30 studs (more would cause deflection). I wanted to make it as small as possible, it's 3,8 studs wide, 3 tall. The length can be chosen freely (as long as you want - you just need longer liftarms, or more). The final version in my projects will have bley thin liftarms instead of these black ones, so it will be looking like a real cylinder from a distance. There is 4 paralell strings in this actuator, and at the beginning of the housing there is a little pulley to decrease friction ( http://www.brickshelf.com/gallery/mbmc137/Ideas-Technologies/Extrem-Cylinder/003.jpg ). Strings are very good for smart techniques, this actautor doesn't requires much additional space for motorizing, just make a gearing with a motor after the winch's axle. Of course, you can change the strength of the actuator with stronger/weaker strings. The one in the pictures can create about 100 N of pushing force. This is a bit more than a 10 kg vertical lifting. The backward movement is done by the gravity, but it's not impossible to modify it to pull back the inner part (you can add another string, like 8421's boom extension works). What do you think?
  17. Hello! I'm finished with uploading and lot of work, you can see one of my biggest and most complex moc. I always loved mobile cranes, so I decided to make a Liebherr LTM 1090 with medium sized (62,4 mm) wheels: folder with bigger pictures: http://www.brickshel...ry.cgi?f=533546 big montage: http://www.brickshel...90-62mm/002.jpg boom: http://www.brickshel...ry.cgi?f=533548 details: http://www.brickshel...ry.cgi?f=533547 About the mobile crane: Every function is remote controlled: - driving (1 XL motor) - steering (1 M motor) - outriggers outcoming and legs moving (1 pneumatic circuit with rubber band "control", 1 M motor for pneu switch) - upper structure rotating - boom raising - boom extension - winch (hook) - compressor for making pressure - front lights (together with driving (and steering with "turn signals") ) After outriggers, these functions are working also with one M motor, or directly from the receiver's output. Dimensions: Length: 610 mm Width: 135 mm Height: 211 mm Scale: 1:20,5 Dimensions with raised and extended boom: Length: 1235 mm Height: 1260 mm Other dates: Number of pieces: 3433 Weight: 3460 g Building time: 23 days Speed: first gear: 0,14 km/h second gear: 0,23 km/h third gear: 0,38 km/h fourth gear: 0,55 km/h Maximum boom extension: DETAILS: Flashing light in the back (made with two light brick, but one is covered with that black piece): Lights: Exhaust: Instrument panel: Manometer (for seeing the outrigger's pressure) and gearbox (manual) cover (the dkbluishgray one): You can use the airtnak in the pneumatic system, or not, depends on these two pneu valves: http://www.brickshel...90-62mm/024.jpg Truck The truck part is an 8x8x8 driven construction ( http://www.brickshel...y.cgi?i=5936235 ), with a manual gearbox and One Xl motor for drive. The outriggers are working with pneumatic, as can be seen in the pictures, one motor with pneu valve is enough for control, because the backward movement is done with rubber bands. The pneumatic system is enough strong to pull out the rubber bands and lift the mobile crane's own weight. http://www.brickshel...y.cgi?i=5936260 - I simply wanted to try out this solution (the original also has also a clyinder to push out the legs). It doesn't works 100%, sometimes a little help is needed to came back. The motorized pneu valve isn't my idea, I saearched a lot to find the designer, but it wasn't success. A compressor makes pressure in the aritank (or directly to the legs, see the description above), then the valves can be opened or closed. The PF system has 8 channels overall, so some functions are together with other ones, like the front lights with steering. One PF led is for light. Crane part (upper structure) The most important in this part is the strenghtening in the turntable, I made it with 4 pulleys, and 2 mm width rubber bands (O rings): http://www.brickshel...y.cgi?i=5936256 Works, well, in extended state the boom doesn't deforms the structure. The 4 pneumatic cylinder can raise the quite heavy (3 section) boom, but not in extended state (as most of the originals). The whole boom can be extended up to 1260 mm height. The backward movement is done with strings, not with gravity, it's more reliable. One small Li-Po battery can power the machine, this black button is for power on/off: http://www.brickshel...y.cgi?i=5936219 http://www.brickshel...90-62mm/004.jpg - you can switch after the operator's cabin with the dkblgray pneu switch to raise the cabin in angle or not (done with one little pneu cylinder). This video can tell more than me, it took me a time to make it, but it's necessary for this model: Hope you like it. Maybe I didn't write everything, feel free to ask, if something isn't clear.
