Showing results for tags 'display stand'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 6 results
  1. Hello everyone, some weeks ago I bought and downloaded the manual of the classic - and for me best - Z-95 Headhunter of the Designer Moppo (MOC-30461) from Rebrickable (link to the MOC: https://rebrickable.com/mocs/MOC-30461/Moppo/z95-headhunter/#parts). After I had all the parts together and could start building, I soon realized that the MOC was not suitable to be placed next to all the others in my showcase on an acrylic display stand, as the photo of the bottom side shows. In order to present it next to my other models and MOCs, I ordered a suitable Medium Angled Acrylic Display Stand with a 4x4 Top Plate from Wicked Bricks (https://www.wickedbrick.com/collections/vario-display-stands-1/products/small-angled-multi-use-display-stand-for-lego-vehicles), so that I could consider and implement the necessary modification of the original model after receiving it. The idea was to construct an additional carrier and to modify the bottom side of the Z-95 Headhunter accordingly, so that it will fit the model and the display stand at the end. To do this, a sketch had to be made to determine the parts to be ordered. Modification of the Z-95 Headhunter (bottom side). For the necessary modification you need the following parts: (Structure: Designation | part number | quantity | comment) Plate 1x4 2 Knobs | 4599498 | 2 Flat Tile 1x3 | 4558169 | 2 Flat Tile 1x2 | 4211414 | 1 Flat Tile 2x2 | 4211413 | 1 Once you have all the parts together, start by removing the three flat tiles 1x4 from the bottom of the Z-95. The same applies to the Flat Tiles 2x4. At the gained space you attach the above parts from the parts list in the arrangement shown on the photo. This way we realize a mounting possibility for the carrier, which will be built in the next step and serves as a bridge between Display Stand and Z-95 Headhunter. We need the dismantled Flat Tile 1x4 for the carrier, which we will focus on in the next step. The carrier. The carrier consists of two parts. We need the following parts for the carrier Plate 1x4 | 4211445 | 3 Flat Tile 1x4 | - | 1 | From the dismantled parts from above. Half Bow 1x2x2 Inv. | 6144138 | 2 | Half Bow 1x2x2 | 6028813 | 2 | Technic Brick 1x1 | 4211535 | 4 | Plate 1x2 | 4211398 | 2 Profiles Brick 1x2 | 4211383 | 2 | The construction is very simple and can be seen in the following picture. The result. The result is that the carrier sits very firmly on the display stand and the Z-95 Headhunter is also solidly attached to the carrier, so that nothing stands in the way of presenting the model on a shelf or in a showcase. The modification of the underside has been designed so that the hunter does not gain excess weight in one direction or the other to prevent accidental falling. So everyone can decide for himself whether the hunter tilts into a curve, rises steeply or descends. Besides the possibility to show the hunter on a display stand, I also implemented a modification for the attachment of landing supports. The realization is also very easy and fast with a little disassembly and assembly. Here you need - besides the above mentioned modification of the underside - the following components: Technic Lever 3M | 6331723 | 2 2M Cross Axle w. groove | 4142865 | 2 Fric/Stump with cross hole | 4158848 | 1 Fric/Forc with cross hole | 4210695 | 2 Plate 1x3 w/Stub/Along/U.P. | 4210882 | 1 Roof Brick 1x2/45° | 4211614 | 4 Flat Tile 1x2 | 4211414 | 2 Landing skid front. The assembly of the front landing skid is shown on the following photo. In addition, the two Technic Lever 2M, which were originally mounted, must be replaced by the Technic Lever 3M in order to attach the landing skid to the fighter. Landing struts underside. The landing skids of the underside are realized by two Roof Bricks each, which are connected by a 1x2 Flat Tile. Both are then attached to the 1x4 Plate with 2 Knobs on the underside (see above). Just align everything nicely and the Z-95 Headhunter is ready for presentation inside a hangar MOC, since it is now standing on its own landing struts:
  2. Western fans rejoice! The River steamboat has just rounded the bend in the river and is pulling up to the dock! 21356 River Steamboat Rated 18+, 4,090 pieces $329.99 / £289.99 / €329.99 Available at LEGO.com from 7th April The ship's display stand is removable, and the paddlewheel apparently rotates when the vessel is pushed on a flat surface. More pictures are visible at Brickset. Additionally, there will be a GWP: 5009157 Amelia Ticket Booth will be available exclusively with the River Steamboat between the 7th and 13th of April (or while supplies last) What are you thoughts on this new set and it's GWP? Leave them below!
  3. Some time ago I bought a set 75243, recently I was looking for a display stand for it. There were a few, but I didn't like the way Slave I attached was questionable Do you want something right do it yourself - I built my own, also did a tutorial - only 94 parts, - easy to assamble, - very high stability REBRICKABLE here: https://rebrickable.com/mocs/MOC-75109/EDGE OF BRICKS/display-stand-for-slave-i-75243/#details TUTORIAL
  4. Hey, I'm new to posting on here however I was wondering what people use to display their lego sets? I'm looking for a way to display my X-Wings with the wings open and also some of the new sets so they look airborne but I'm not really a fan on making the stands out of Lego. Sorry if there is already a topic on this but I couldn't find one already in the forums. Any ideas would be helpful Thanks Mat
  5. A display stand for model 75135 Obi-wan's jedi interceptor. Link to my Digital Designer page where you can download the .LXF file. http://ldd.us.lego.com/en-us/gallery/515bcc34-4643-4a46-9218-23577e970c17
  6. Rather than try to make good photos for my latest spaceship while having it sit on the floor of the backdrop, I decided to up the presentation a notch and provide a display stand for it to sit on. The height and angle of the arm can be adjusted by twisting the gear at the bottom of the mini-LA. At the top just about any sort of adapter plate or clamp can be built and attached in order to give a good connection to the model in question. The design is inspired somewhat by the Action Bases that Bandai sells alongside their popular Gunpla model kits. I didn't go for anything as elaborate as this design, which allows the arm and support to be repositioned on the base at will, as I didn't include a nameplate in the design and as such the orientation of the base doesn't matter. Best of all, I've made a digital model in .lxf form for anybody who'd like to build it for their own models! The model can be found on this page under the name "Display Stand Small Models". (If this doesn't fit in this section, moderators, feel free to move it; it's here because I built it go alongside my new spaceship but if it's better suited elsewhere that's okay too.)
