Showing results for tags 'bad batch'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 6 results
  1. Hello everyone! It’s been a while since I posted anything as work and life has been rather busy. I have been building in that time just that not got round to taking photos (bad ones) writing this essay etc. I return with an update of 6 models from Seasons 2 &3 of The Bad Batch. Let’s start with season 2. AT-AC The All Terrain Armored Cannon (AT-AC), was a bipedal walker used by the ground forces of the Galactic Empire during the early Imperial Era. The walker was an early model in the production line that would eventually produce the AT-ST (RoTJ) and AT-DP (Rebels). The front of the head of this walker reminds me of the Imperial Troop Transport. There are no real tricks for this one although I have used the ball joints for the top joint of the legs. I don’t know why I have not used these before on walkers…… Displayed with an Echo minifigure. REMORA The Remora was a transport utilized by Echo during his time with the Clone Underground. The ship was once a mining vessel that had been retrofitted for stealth infiltration, making it ideal for insertion and extraction missions. The high-speed ship was also equipped with a detachable leech vessel (which I have also included). The design of this is based on the Meson Martinet captained by Sidon Ithano and briefly seen in Force Awakens and later in Resistance (I have built that too but that’s for another day). Again, no real tricks for this one, although I like the use of those technic pieces for the engines. A custom Fireball clone figure is used for the display. Now on to Season 3. CX DAGGER VESSEL The CX Dagger vessel was used by the Clone X trooper division of the Galactic Empire in around 18 BBY. It was dagger-shaped and featured twin red-colored engines in the back. A really simple little build. Only little trick is that the dark grey engine section is attached to the rest of the body by the two prongs at the back and is not connected to the large wedges at the front. This was to keep the thickness to a minimum. I am not overly happy with this one but not sure how else to build it in this scale. Displayed with a custom CX Trooper. The helmet is from the General Zod minifigure with the chrome removed using peroxide and then scraped gently with a craft knife. I would rather use official pieces but there was nothing close. IMPERIAL RESEARCH VESSEL This was a type of Imperial transport utilized for the capture, containment and transport of various cloning experiments conducted by the Advanced Science Division. It was manned by Imperial commandos led by Imperial royal guards. One such transport, transport 904, saw its Zillo Beast "Specimen A" escape while traveling in hyperspace forcing it to crash. Another fairly simple build and probably my favourite build of this batch (pun intended). There are a couple of little tricks, like using the door rail plates to fill in gaps when the model goes to 3 studs wide at the front. I also like the use of the horizontal hinge for the bridge at the front. The front prongs are attached using bars and bricks with one stud. Displayed with a custom Dr Hemlock minifigure. No mutilations this time, just labels. ASAJJ VENTRESS’ SHIP The ship had a unique silhouette due to the uneven wings of its fuselage. Outfitted with proton torpedo launchers for escaping dangerous entanglements, the uneven wings on either side of the fuselage cut a silhouette as unique as the ship’s captain. This was a fun build. It was a challenge to keep the wings only two studs high but managed with interlocking parts. The brackets for the engines also helped with the stability. The main trick was for the tie fighter like panels and how to attach them. Took a bit of tinkering but using brackets, clip tiles and plates with handles I finally found something that worked. I also like the use of those tooth pieces for the part of the engines on the wings. Due to the wingspan this model could have seriously got out of hand size wise. Displayed with a custom Ventress figure (all official parts!). PROVIDENCE The Providence was a starship owned by the pirate and treasure hunter Phee Genoa. It has that Star Wars Ugly feel with what is obviously the engine section from an Imperial Shuttle of some sort. Quite a simple build with the tail held together along an umbrella stand bar. The front section is built around brackets. The Phee minifigure for the display is built with all official parts. The hair is from a mini doll. Let me know what you think Cheers, Jon Link to the full Bad Batch Gallery below: https://bricksafe.com/pages/obijon/bad-batch
  2. My first ever true Minifig-scale ship is finally here, and what better model to start with than the sleek BTL-B Y-Wing from The Clone Wars series. Being 23 meters long in universe, this accurately Minifig-scaled MOC is quite a unit: 57 cm long, 1,6 kg, 2,954 pieces. It can accommodate two clone pilots - one in the cockpit, the other in the turret. The model is available in three versions: classic (yellow), Rex's (blue), and red. With a spaceship of this kind, the main challenge is to achieve a level of smoothness and fluidity that gets as close to the original as possible. Using the Battlefront II model as a reference, my goal here was to closely match all key features of the ship: the subtle downwards angle on each side of the body, the curvy and tapered front section, the continuous yellow stripes that run across the entire fuselage, the intricate middle-section... and for such a smooth ship, going full SNOT (from top to bottom!) goes without saying. The T-shaped body of Y-Wings usually allow for simplistic structures, but in this case, figuring out the internals was one of the truly head-scratching parts of the build, since I had to properly incorporate angled fuselage assemblies and make a proper interior for Minifigs. Even so, the model is very swhooshable and can be grabbed from the underside, from the rear or even from both wings. Each color variant is accompanied by its specific set of instructions and parts list, giving you the freedom to build the one you prefer. The ship has two display modes, "in-flight" with its fully removable stand, and "landed" with retractable and easy-to-connect landing gear. The swooshing can begin. ► Instructions for the BTL-B Y-Wing are available at BrickVault! More pictures on my Flickr page.
  3. "Wrecker, easy with my ship. "Your ship?" My Midi-Scale collection expands again with this nanofig-scaled Havoc Marauder from the Bad Batch series. Despite the small size, I once again went for a full SNOT look and paid close attention to proportions of the original shuttle. The build comes with a discrete, transparent stand to be displayed in flight mode. ► Instructions for the Havoc Marauder are available at Rebrickable or via email at flyinspace.mocs@gmail.com More pictures on my Flickr page.
  4. This is an alternative build using The Mandalorian Razor Crest set 75292. For this model You can build the Havoc marauder from the tv series Bad Batch. Instructions at Rebrickable: https://rebrickable.com/mocs/MOC-80074/A_Great_Builder/bad-batchs-havoc-marauder-75292-c-model/#details
  5. To me, the “purist” line is drawn at using fake/custom/3D printed moulds and permanent modification. For many of my custom figures, I make pauldrons and kamas out of paper, and sometimes even torso wrap-around things. I also make “paper decals” (idk) where I would usually just create markings and the like which I use blu-tack to stick onto the figure. As LEGO fans, would you approve of this and/or consider it “purist”?
  6. New models will appear in replies to this thread. Hello again everyone, I have been unwell and otherwise busy workwise so not posted anything for a while but I return with the signature ship from The Bad Batch, the “Havoc Marauder”. The Havoc Marauder was a Omicron-class attack shuttle that served as the personal starship of Clone Force 99, also known as the "Bad Batch." The craft was unique compared to other Grand Army of the Republic starships, so it was used for the Bad Batch's covert and undercover missions throughout the Clone Wars. I could have added this model to the Clone Wars thread as it first appeared there in the final season but it will be more prominent in the new series (unless it goes the way of the Razor Crest 😉). I have not watched any of the Bad batch yet, I will wait until it’s nearly all available and then binge watch. If it's half as good as Clone Wars........... Now enough waffle and on to the model. The only real tricky part was the pointed cockpit section, which is all built on one of those old space robot bodies and attached to the main body using a headlight brick and a 1x6 plate which runs along the length of the body. The ship is very angular so I settled on using the 1x2 grille slopes along the sides and whilst there are the obvious gaps the curved slopes just didn’t look right. I think overall I have captured the shape pretty well. The relatively new 6 x 4 wedge plates are also perfect for the main construction of the folding wings. The Echo minifig is a custom from an ebay seller. Let me know what you think. More models soon. Jon
