Showing results for tags 'attack of the clones'.
As my exploration of Prequel ships continues, I'm trying to shift my focus to Minifig-scale more, and decided to give a crack at Obi-Wan's sleek Delta-7 from Episode II: Attack of the Clones. At exactly 400 pieces, this compact and angular ship was full of technical challenges, especially with the constraint of making a proper interior that could accommodate a full Obi-Wan Minifigure without ending up with a bulky design. Following my "wings must be as thin as possible" philosophy (like the Eta-2), I used a combination of plates & tiles for the outline of the wings, and bricks on their sides for the rest: this resulted in 2-plate thick wings, which give the ship all its slenderness, especially seen from lower angles. At this scale, and given how compact the ship is in-universe, I wanted to respect the slim and sharp look of the original design. Making a functional cockpit with comfortable space was the most daunting task as I needed to securely attach the fin section and both angled fuselage parts that surround the cockpit without using any vertical space, where Obi-Wan sits. I also managed to incorporate a dashboard that doesn't obstruct the pilot's view and depicts the screen fairly well. The model features detachable landing gear to be displayed on the ground, as well as a canted stand for a more dynamic pose. The model is very stable overall and perfectly swooshable. â–º Instructions for the Delta-7 are available on Rebrickable! More pictures on my Flickr page.
Here we are! My very first UCS-style model is finally out, and it's a big one: the mighty Acclamator-class assault ship from Episode II: Attack of the Clones. Made of 5,152 pieces, at 72cm (28,4′′) in length, weighing 3,2kg, it's by far my biggest project to date. This 100% SNOT build was painstakingly modeled to accurate reference material, from exact profile dimensions to surface detail on top and underneath. The underside was also full of geomertic challenges due to its numerous angles and shapes. I wanted to include essential functionality like detachable landing gear for landed display, and openable hangar doors with boarding ramps that slide down to reach the ground. The ship also features a removable stand, as well as a hidden handle to make switching display modes easier. In addition to the "standard" version with Republic markings, I also made a "class-II", all-gray version, which comes with its own instructions and parts list. The Acclamator is technically one of my oldest projects: the initial version of the design was made right after the Torment in 2021, but I eventually shelved it as I wasn't truly satisfied with it. Since then I had so many requests for this ship that the idea of making a new version progressively grew on me, until I took the plunge in late January 2024. Starting the new design from scratch, I decided to scale it exactly to Martin Latta's fantastic UCCS (Ultimate Collector Series) Venator, which happens to be in ~1/1000 scale. So I hope my Acclamator will, along with Latta's Venator, form the basis of a bigger 1/1000 scale BrickVault Republic fleet in the future! ► Instructions for the Acclamator are available at BrickVault! More pictures on my Flickr page.
- 11 replies
- lego
- acclamator
- (and 12 more)
things changed: -lowered cockpit down roughly 1 brick, changed build around cockpit region to slope into wings, taper into body, round out the rear to more accurately reflect the shape of the model in canon -filled in gaps with 1 tile width across whole body; requires some gaps in wing construction -replaced guns for accuracy; subject to further change to reduce conspicuousness -cut up stickers to apply across model -cut cockpit -nexo tile at front to hammer in the point :) working on instructions if anyone's interested. if ur curious on scale it works like this
UPDATED TO v2.0 I've wanted an LAAT of my own for a long time, I missed the opportunity to get one of the Lego sets during my dark-ages and have absolutely nowhere to put a UCS sized pile of plastic, so I thought I'd continue the midi-scale thing and try to make something bookshelf friendly. This isn't intended to be any particular scale, just roughly the same size as the midi-sized Slave 1 (75312) with room for figures and strong enough to be played with. The cockpit bubble looks oversized and there’s obviously only one of them so I had to throw accuracy to the wind there, but I’ve squeezed in as many other recognisable details as I could. The roof opens up to allow access to the cockpit which has just enough room for two Clone Troopers/Pilots to get cozy. There’s a small weapons locker in the area between the front hatches, though it' mostly for decoration as its very hard to acces, and the side doors hinge outwards and fold back so that four Clones can be seated inside. There isn't enough headroom to have them hanging by a handrail but some fearless perching before deployment is definitely doable. Finally I squeezed a stupidly small BARC speeder up the back end of the ship. Overall the Republic Gunship is a 28cm long (including the guns), 27cm wide and weighs 410g. Instructions are on Rebrickable, I've only used common and cheap parts so the whole MOC with stand will cost around £35 for the 603 pieces. https://rebrickable.com/mocs/MOC-107732/ron_mcphatty/midi-republic-gunship And here's my other midi-scale efforts.
- 18 replies
- gunship
- midi-scale
(and 4 more)
Tagged with:
I started modifying the new set straight away after the press images were published, hashing out some ideas in Studio. I was I inspired long ago by Mr_Idler's amazingly detailed and well proportioned Delta-7 and I've always wanted a little Jedi Starfighter on my shelf, this set presented the perfect opportunity. At first I added a lot of wedge plates to create complicated but fragile slopes around the cockpit, but after getting hold of the original set inventory and recreating it in Studio I managed to rebuild the ship with a lowered cockpit without using any extra pieces at all. Here is the complete mod along with an LED Kamino Landing Pad that I threw together, instructions are on Rebrickable. I've lowered the cockpit area by 2 plates and added a layer to the nose which is now slightly more substantial looking and helps the cockit blend better into the ship. I've made some minor changes to the wings, R4 and the Republic crest are closer to the centre and I also moved the black inverted slopes to the edges of the wings in place of landing gear. The nose of the ship now sits a whole 3 plates lower when landed and the top of the cockpit is 5 plates lower. Rather than towering over the minifigures the ship looks much closer to scale. I've also rearranged the notched-wedge pieces from the tail to create the point over the cockpit canopy, which can't be hinged open but can still be easily removed. The landing pad in the photo above is buildable but the circle shape is slightly illegal, putting the wedge plates under stress, and so the build is hard to pick up once assembled. It is however cheap, compact and compatible with the cheap USB LED kits on eBay consisting of a string of six 1x4 plates. The landing pad instructions and Studio model (use this for parts list) are in a seperate zip file on my 75333 mod Rebrickable page. Thanks and I hope you like the mod!
Hello everyone ! It is my pleasure to finally show you a model that has been in the making for a while now, My take on the Delta 7 Starfighter. The Delta 7 has been one of my favorite starchips in Star Wars for a while, in fact it was the first major set i got, so it was very important to me to make justice to this craft. Befor anything, huge shoutout to: M G, Atlas & Maelven for being the main inspiration for this model. This particular model was made to be as close to minifig scale as i could get it to be, this being 11 studs width, 23 studs in lenght and 4.5 studs in height. (taking in acount a minifig being 6 foot-ish) my model comes slightly larger than that being 25 studs in lenght & 6 studs in height, but this is due to the parts i used and to make it quite swooshable. I'll admit that some of the proportions are a bit off, but considering the size this is made on, i think that's a fair trade off. One of the most intuitive features of this model is it's ability to sport all the colors and variations seen in canon (from Mace Windu's to Ashoka's), which just shows how customizable the model is. Here are some renders of Obi Wan's along with the rest of the crew's: As with most of my models i did in fact make instructions for these, which you can buy over here !: https://ebay.us/4EBNjp Besides you also get some original artwork i made for it: Really hope you like it ! As always any feedback is more than welcome. May the force be with you -Prime
- 16 replies
- minifig scale
- attack of the clones
(and 2 more)
Tagged with:
So I've been going through old minifigures from the Star Wars theme and found miifigs like Kit Fisto and Plo Koon. The paint on them isn't there anymore. Any ideas on what to do?
- star wars
- phantom menace
- (and 10 more)
Villa Del Balbianello is a lakeside villa in Italy built in 1785 expanding on an existing structure from the 13th century. With later additions added throughout the years such as relics added from an explorer. It was also featured in films such as Star Wars: Episode II - Attack of the Clones (2002) and James Bond: Casino Royale (2006). Also a set on LEGO Ideas: https://ideas.lego.com/projects/85ec2902-0e20-40a8-9b18-4a79c9f560af
- 6 replies
- naboo
- padme
(and 43 more)
Tagged with:
- naboo
- padme
- james bond
- villa
- italy
- italia
- lake
- port
- building
- vines
- moss
- ferns
- shrubbery
- tree
- fence
- bars
- post
- garden
- statue
- relic
- items
- history
- episode 2
- episode ii
- 2002
- set
- lego
- lego ideas
- lego ideas house
- lego ideas set
- lego ideas villa
- lego ideas italy
- lego ideas star wars
- lego ideas naboo
- lego ideas minfigure
- lego ideas minifigures
- lego ideas interior
- lego ideas clock tower
- clock tower
- petals
- flowers
- dinorama
- lego ideas moc
- moc
Hi everyone, I'm back with some new old creations! Those are models that I built between 2008 and 2011 and which have now been disassembled. This is my Midi-scale model of the Acclamator-class assault transport seen in Attack of the Clones, the outstanding Dark Horse "Star Wars: Republic" comics, the 2003 Tartarovsky Clone Wars cartoon, the 2008 Filoni Wars cartoon, and the videogame Empire at War. I built this when I was 13 or 14 years old, so please don't be too harsh on me, I like to think I've improved since then. MIDI Acclamator-class assault transport - starboard by Ephseb, auf Flickr MIDI Acclamator-class assault transport - rear 1 by Ephseb, auf Flickr MIDI KDY Acclamator-class assault transport - dorsal by Ephseb, auf Flickr There are more pictures in my Flickr album: https://www.flickr.com/photos/133484576@N06/albums/72157687600086663 And as always, you can find more information and data here: http://starwars.wikia.com/wiki/Acclamator-class_assault_ship And keep your eyes open for the next model! Same scale as this one, but much stronger in-universe...
- aotc
- episode ii
- (and 6 more)
This is my version of khatmorg's incredible delta-7 model (which you should view here www.flickr.com/photos/95628537@N02/8735306298/in/dateposted/ and here http://www.eurobrick...2931&hl=delta-7) . I originally built their model as per the original build over a year ago but a few months ago I started fiddling with it and have now arrived at a point where I'm satisfied with it. It was difficult to find other ways to achieve some angles (the source is so good already!) especially in the back and as a result that area is quite fragile and use some illegal connections. Most of the changes are concerned with the bottom, spine and rear sections. I haven't been able to find a way to find a way to hide some little landing gears in the back of the wedge where it fattens out a bit yet so the ones you can see in the other photos are just attached externally. Also it is about 8 to 10 studs too long as a result of the angle of the 1x3 wedge plate, according to the rough scale I used. That isn't ideal for me as I like to scale it right to a degree, but the additional detail you can add on a bigger model is good as well. I also wanted to try an alternative solution to miniaturise the dual laser cannons, and add the other half on the bottom but haven't solved that issue either. I might pick this up again later and play with it some more but for now I'm content to reveal it. I hope all of you enjoy. Thanks to khatmorg for being so great about sharing their creation. The stand is based on sydag's method which you can see here (www.flickr.com/photos/sydag/16129935387/in/dateposted/). It's simple and ingenious. You can view the rest of photos in the album (www.flickr.com/photos/48109771@N05/albums/72157668258477972).
- 14 replies
- obi-wan
- jedi starfighter
(and 7 more)
Tagged with:
This is my entry to the Brickset 2016 Star Wars competition where you had to design a set based on a specific scene that hasn't been represented yet. Anakin, Padme, R2-D2 and C-3PO have infiltrated the Separatist droid foundry on Geonosis and are ambushed by the Geonosians! Pull the pins to shut the door and drop the heroes onto the conveyor belt. Turn the wheel to move the conveyor belts and help them escape through the assembly line! Watch out for swinging robot arms, stomping presses, and chopping blades! Use the swiveling robot arm to assemble the droids. C-3PO has lost his head! Attach R2-D2's rocket boosters and turn the knob on the tower to have him fly to the rescue! Rearrange the assembly modules to create your own foundry layout. Includes Anakin Skywalker, Padme, R2-D2, C-3PO, one Geonosian with stud shooter, and 4 battle droids. Droid Foundry Escape by Okay Yaramanoglu, on Flickr Droid Foundry Escape door open by Okay Yaramanoglu, on Flickr Droid Foundry Escape door closed by Okay Yaramanoglu, on Flickr Droid Foundry Escape door feature 1 by Okay Yaramanoglu, on Flickr Droid Foundry Escape door feature 2 by Okay Yaramanoglu, on Flickr Droid Foundry Escape - R2 to the Rescue by Okay Yaramanoglu, on Flickr Droid Foundry Escape module 2 by Okay Yaramanoglu, on Flickr Droid Foundry Escape module 4 by Okay Yaramanoglu, on Flickr Droid Foundry Escape module 4 back by Okay Yaramanoglu, on Flickr Droid Foundry Escape minifigs by Okay Yaramanoglu, on Flickr You can see video demonstrations of the Technic functions here and here. Here is the scene from the movie for reference: I hope you like it. May the force be with you and have a happy new year!
My Geonosis Arena model renders. It includes the three arena beasts (Acklay, Reek & Nexu), some geonosians, a droideka an orray along with a section of the arena. Project Links Lego Ideas Link: https://ideas.lego.com/projects/164837 (Some more Images & Support page) (Please support it if you like it lets get this to 10 K, If it's not accepted it could make LEGO consider making it a set for the official line) LDD File: http://www.mediafire.com/file/ae2for3qxgigwba/Geonosis_Arena_ThunderousBlade_Lego_Ideas.lxf (Uses non-existent colour bricks) Hope you enjoy it! Was interested in this scene since 2002.
This is my rendition of the Geonosian Arena from STAR WARS Attack Of The Clones. This has always been one of LEGO's most glaring omissions from the Star Wars line, hence why I decided to test out this MOC. OK, it's not excessively massive or complicated, but I just think it makes a neat little playset. Comment your opinions. Also don't forget to check out my LEGO IDEAS page for more information on this, and please support! :) from there you can read all about the design plan, the history, and also see any other photos of the MOC. https://ideas.lego.com/projects/158217
