Showing results for tags 'alternative model'.
My 3rd alt from this year's new ARC 170 is here: a Republic Vector starfighter! More pictures and instructions here: https://rebrickable.com/mocs/MOC-229908/zsoltom/high-republic-vector-starfighter-75402-alternative/#admin Fits in a fig and an astromech, all wings are moveable, projectile shooter, displaystand, sturdy,swooshable
When I saw first pictures of set 42074 (racing yacht) I knew I have to take it and rebuild it into something else. So let me introduce you my latest alternative model - freight helicopter. It spins both rotors when you are turning gear on its bottom. Since set contains just 2 bevel gears I had to build another couple of them from bricks and connectors - I have already used this assembly for my dragster built out of set 42036. ...and little excursion into its innards:
- 7 replies
- 42074
- helicopter
(and 2 more)
Tagged with:
Let me introduce you what I was working on last week - it is going to be helicopter loosely inspired by Bell 47. I call it Nighthawk because it is also my tribute to set 8412 that I got when I was child. I will feature: crank for spinning both rotors fake six-cylinder flat engine with moving pistons lever in cockpit for tilting main rotor (this is not realistic function but it is reproduction of functionality of set 8412) Since I build almost exclusively alternative models this helicopter is no exception. I only use parts from rally car 42077. And now some pictures of my progress: Initial proof of concept to ensure that I have enough gears Prototype of cab with seat and lever The first assembly of whole helicopter (before I took it apart for structural upgrades)
- 9 replies
- alternative model
- helicopter
(and 1 more)
Tagged with:
LEGO Technic buggies have special place in my life - my very first LEGO set was Technic buggy 8829 and buggy 8048 took me definitely back from "dark age" so buying new buggy 42101 was sure thing for me. I also knew what I wanna build out of it - motorbike because it was official alternative model of set 8829. It took me a lot of effort to build it. I spent more than 12 hours by trial and error before I found the way how to build it. Final model features same functions as main model - steering and rear axle suspension. Building instructions are available at buildinst.cz
- motorbike
- alternative model
(and 1 more)
Tagged with:
Hi all, when I saw new The LEGO Movie 2 sets I fell in love with Ultrakatty set 70827 and began thinking about what else I can build out of this set. The first idea was to build Ultrapuppy but I was not able to give it cool enough appearance and personality. Then I got another idea that excited me much: What about giving Emmet and Lucy real alien that would fight with those Duplo monsters? ...and it should be the coolest alien of all - alien queen! "Who is cooler alien now?" I tried to build her as close to original as possible with limited sort of parts in set so I added such details as second jaw, big collar behind head and many thorns on back and tail. I also had to forfeit some details like the second pair of hands on chest and use pretty "wild" color scheme. Finished model features good articulation and big feet gives it some stability. I hope you like it. Any comments are welcome.
- 11 replies
- alternative model
- alien
(and 2 more)
Tagged with:
Although I'm not fan of Nexo Knights I was asked to built something else out of bricks from set 70321 - General Magmar's Siege Machine of Doom. Since this set contains 6 wheels I've decided to build something like american truck. It has three axles and long nose with maw full of teeth. There is also disk shooter over its rear axles. I've used just bricks from set 70321 so it can be called alternative model.
- 15 replies
- alternative model
- 70321
- (and 5 more)
Let me introduce you my latest alternative model built out of set 42094 - Snow groomer! It is already my third snowcat I've built out of LEGO Technic. You can see it here next to its lil bro from set 9391. It features two manual functions: lifting snow plow by turning gear on the roof of cab lifting rear blade by turning lever behind engine cover Since set 42094 contains just one linear actuator and no worm gears I used two shock absorbers to keep rear blade in two positions - up and down. The first version of model also featured gearbox for switching between functions above operated from same place on roof of cab. I had to remove it because gears were not able to transmit huge torque necesary for pushing springs on rear blade. Building instructions are available at rebrickable.com Any comments are welcomed.
- 14 replies
- alternative model
- technic
(and 1 more)
Tagged with:
I like idea of current TC18 contest so I decided to build something for it too. My initial idea was very simple - it has to be alternative model. Then I found out that set 42106 is the only set I own with four 43,2x14 wheels so I chose it as parts resource. This set also features pullback motor so I think I am the first who decided to use it in model for contest. Since I also wanted to add ordinary steering I had to find the way how to make them work together. I came with idea of two modes: Pullback - pullback car with blocked steering to keep it going straight Steering - car with steering and disabled pullback motor to allow reverse I began building chassis with necesary mechanisms and then tried to build body around it. Honestly this is my first "normal" car so I was very curious about result (I built only hot rods and buggies before). Building body became as interesting as I stopped taking care about chassis and made body one solid structure. I didn't take inspiration from any real car but I think it looks like hybrid between Škoda 135, Ford Mustang and some Asian tuning car. Body is connected to chassis only by two pins and four axles. It has very simple interior with steering wheel and no seats due to limited amount of parts in set 42106. Overall dimensions are: lenght 34 studs (41 with flames from exhausts), width 15 studs and height 12 studs. Back to functions - pullback motor is connected to rear axle through 3 gears that can be disconnected by gear behind right door. Connection is also secured with black pin to resist torque from pullback motor. Steering can be locked by two axles controlled by black lever. Thanks to its big weight this race car features small acceleration and low max. speed. Chassis in pullback mode Chassis in steering mode Building instructions are available at buildinst.cz Any comments are welcomed.
When I saw set 75936 first time I fell in love with this huge T. rex. Then during building it I found big similarity between body of T. rex and chicken I had for lunch. This gave me initial idea: "Is it possible to rebuild T. rex into chicken and use only its parts?" Now I can say YES! I used original legs, modified body, make neck longer, built new tail, wings and head and here is Chicken rex (in short C. rex). It feaures moving legs, wings, neck, head and opening beak. You can find its detailed review here. And by the way it is even life-size - you can see my chicken besides medium sized egg for comparison at picture bellow. Building instructions are available at rebrickable.com
- chicken
- jurassic park
(and 3 more)
Tagged with:
Two years ago I built freight helicopter out of set 42074 and few weeks ago I built another alternative model from this set - propeller plane. When you are moving it around it whirls its propeller. I enjoyed building it very much - it took me just three nights to build it and I like its bright color scheme. Building instructions are available at buildinst. Any comments are welcomed.
- 2 replies
- 42074
- alternative model
(and 1 more)
Tagged with:
I tried to build my own alternative model from set 42061 several times in past but all my attempts failed. When I was decided to sell this set I got idea to give it last try. My initial goal was to build some kind of buggy. After few hours I built working steering and in-line fake engine driven by rear wheels. Building car out of parts from set 42061 was painful (it has pretty bad assortment of parts) and I am not totally sutisfied with look of buggy so I call it "Ugly Buggy". By the way it fits to TC18 contest but I think it is too simple to submit it there. So I use it for TLCB Lock-Down Competition instead. When I finished building buggy I decided to build more - to build something easier. So helicopter was the best choice. I took little bit of inspiration from @BusterHaus - I like how he used gear rack for tail of his helicopter. My helicopter has both rotors connected by gears so you can spin them together by turning gear on bottom of helicopter. This is also my second entry to TLCB Lock-Down Competition. Building instructions for both alternative models are available at buildinst.cz Any comments are welcomed.
- 5 replies
- technic
- alternative model
(and 4 more)
Tagged with:
This deer is my second alternative model built out of set 70827 (Ultrakatty & Warrior Lucy!). It features big antlers and moving legs, neck and head. My goal with this model was to find some purpose for different thorns included in big amounts in set 70827. This model is my fourth entry to TLCB Lock-Down Competition. When I was done with deer I built simple turtle from leftover parts to give Emmet something for riding too. You also might remember my first alternative model from this set - Alien queen. Building instructions for both models are available at buildinst.cz Any comments are welcomed.
- 2 replies
- tlcb lock-down competition
- stag
(and 3 more)
Tagged with:
Few years ago I built dune buggy from set 42075 (First Responder)... ...now I am back with second alternative model - Pullback Helicopter. It features opening windscreen, engine with moving piston and cool spring loaded mechanism for spinning rotors. It works similarly to pullback motor but it uses shock absorber to store energy for spinning. I took inspiration for this mechanism from Isogawa Yoshihito's book "LEGO TECHNIC Tora no Maki". I also built this model for TLCB Lock-Down Competition. Building instructions for both models are available at buildinst.cz Any comments are welcomed.
- 6 replies
- pullback
- helicopter
(and 3 more)
Tagged with:
My wife asked me to take apart set 40171 I gave her few years ago. When I did it I got idea to build something from it. And what is the best alternative model from any set? Helicopter! This one is even little bit special. It features opening windscreen, both rotors can freely spin and it still keeps appearence of original hedgehog - snout, thorns and four legs. So this is what you get when you crossbreed hedgehog and helicopter - Hedgecopter Building instructions are available at buildinst.cz And this is original model: Any comments are welcomed.
- 2 replies
- helicopter
- hedgehog
(and 2 more)
Tagged with:
I would like to introduce you alternative model built out of little set 42045 - helicopter. This set contains just 180 pieces so building alternative model from them was pretty difficult and challenging. My helicopter has even few functions - it features two-cylinder fake engine and if you turn gear under tail rotor, pistons in engine will move and main rotor blade will spin. If you want to build it you can download building instructions from my website buildinst.cz
- 3 replies
- 42045
- helicopter
(and 1 more)
Tagged with:
Let me introduce you my latest alternative model built out of set 42081 - wheel skidder. I planned to build skidder for a long time and set 42081 looked like ideal resource of parts for it. I took most inspiration from CAT 525C and log loader built by M_longer. I used M_longer's grapple design and his statement: worked like challenge for me. My skidder features: articulated HoG steering lifting of decking blade dual-function arch working grapple All functions are operated by orange axle joiners. BUILDING INSTRUCTIONS are available at rebrickable.com With few logs... Any comments are welcome.
- 14 replies
- alternative model
- skidder
(and 1 more)
Tagged with:
Since I recently got LEGO Technic set 42036 and didn't built anything out of Technic for a long time I've decided to rebuild this motorbike into vehicle with four wheels. It was bigger challenge than I expected. I had to use few uncommon asseblies: replace front wheels by gears with chain replace connector in crankshaft by liftarm replace pair of bevel gears by bunch of connectors - this solution was proposed by Victor Imaginator Finished dragster features just V4 fake engine with moving pistons. I planed to add steering but I didn't have enough parts for it.
- 13 replies
- alternative model
- dragster
(and 2 more)
Tagged with:
I haven't posted any model here for a long time so let me introduce you my latest alternative models built out of set 42060 - Roadwork Crew. The first of them is Formula 1. It has pretty low functionality (just "hand of god" steering) but at least I've made something original. :-) Most of formula is only 3 studs high so it was big challenge to squeeze steering in it. Another alternative model is Propeller plane. It whirls its propeller when you're moving it around. This model is literally full of "crazy" building techniques because I had to connect together all those liftarms going in different directions. I've built both models for competition in building alternative models out of set 42060. If you wanna see what other competitors built, check this link: http://www.kostky.org/forum/index.php?topic=50909.0
- 11 replies
- 42060
- roadwork crew
(and 2 more)
Tagged with:
When I was thinking about what to build out of set 42065 (RC Tracked Racer) I've got idea to increase its playability by adding blade. So I started building bulldozer. Finished model features blade that allows you to push something. I had to deal with lack of liftarms and pins that led to sacrificing easy access to battery box - if you want to replace batteries you literally have to dismantle almost whole model. In short, it is compact, sturdy, too fast and fun to play with.
- 12 replies
Let me introduce you one of my coolest alternative models - Shark Mk II. Why do I call it Mk II? It is the second generation of moving sharks that I've built so far. The first one was built out of set 9394 (red jet) 6 years ago and was red. New shark is built out of set 42066 (blue-black jet) so it is BIGGER, better and finally blue. :-) It features two motorized functions: moving tail and opening maw to eat moving fish. You can turn them on separately or together with help of two red levers on stand. It contains 814 parts. I built it in the middle of last year but I haven't made video for it until today. Building instructions are available at rebrickable.com Any comments are welcomed.
- 20 replies
- shark
- alternative model
(and 1 more)
Tagged with:
I' ve decided to make an alternative model for 42054 CLAAS XERION 5000 TRAC VC set. I' ve wanted to design something different from all those excellent c models already made, so I made a truck capable of off-road conditions, with crane and many other functions. The result: Functions: rear axle drive with 4 piston engine steering live axle suspension side outriggers cabin tilting rear PTO (power take off) crane arm rotation crane arm 1st stage elevation crane arm 2nd stage elevation grabber closing/opening Please watch the video to see this machine in action and for more details. This model is powered by one m motor with rotation direction selection. It powers main selector, crane selector. and PTO. Main selector switches between worm gear powered functions and arm rotation. When worm gear functions are selected, there is another switch to choose between outriggers and cabin tilting. The crane selector switches between 1st and 2nd stage elevation. I had to use some interesting (I think) solutions because of parts selection in 42054 set: Piston engine There are no piston engine parts in the set, so i made them from some connectors. You can see it working in the video. Suspension There are no shock absorbers or wishbones too. So I' ve made a suspension based on twisting axles: Every wishbone is suspended independly. 3 of those connected to axle make a well-working long travel soft off-road suspension: Grabber There was a grabber in original set, but when building the grabber I've already used the worm gear for more important functions, so I' ve designed a different locking mechanism: Turning the green axle makes the red grabber frame move up and down and becouse of engaging the blue knob gear with h-frame opening and closing blue grabber. Instructions Instructions are already available here on rebrickable! I hope you liked this model.
- 27 replies
- unimog
- alternative model
(and 10 more)
Tagged with:
LEGO Technic set 42137 - Formula E Porsche 99x Electric was not received well so I decided to give it the second chance same as I did with set 42106. Formula E is equally priced as Mustang but it has 100 parts less and looks like its chassis. I wanted to build out of it something bigger and higher so I chose truck. This race truck is my first pure alternative model built out of set 42137. Why pure? Because I've already built another model from this set that I supplemented it with few gears to make it more "functional". I'm gonna show you it when video is ready. Back to race truck... It features two pullback motors with ratchet mechanism similar to original model. I had to build it just 13 studs wide (2 studs narrower than Formula E) because I ran out of parts. Building instructions are available for sale at rebrickable.com
- 12 replies
- alternative model
- technic
(and 1 more)
Tagged with:
Lego Technic 2 x 42132 Alternative Model - Mahawk Buggy (Building Instructions) This is alternative model for Lego Technic 2 x 42132 Motorcycle (you need to have two sets). This robust buggy with aggressive view is made for aggressive terrain, as well "aggressive" child play. It has detailed interior with that thing which allows you to control direction of the movement, but without that stick which helps you go faster or slower. Also, it has kind of sit for driver, which might be not recognizable from first glance. The model has next Technic functions: rotation of all four wheels in both directions! Overall, those functions give capability to move these models with enormous speed in lego world! This robust model has passed many children quality tests and proved they great playability. If you interested in building this advanced model by yourself, you can get building instructions download links in description when you click on pictures or video, or below the images (if they will not be deleted by admins :-) ). Images: Lego Technic Set 42132 x 2 Alternative Model - Mahawk Buggy (Link to Building Instructions in the description) Lego Technic Set 42132 x 2 - Mahawk Buggy (Link to Building Instructions in the description) Direct Download link for Technic Building Instructions: https://play.google.com/store/apps/details?id=max.technic.building.instructions
- 4 replies
- technic
- instructions
(and 6 more)
Tagged with:
When I was thinking about what else I can build out of adidas Superstar shoe (set 10282) I've got such ideas like space shuttle, Moby Dick (white whale), toilet, dog, panda but none of them have any connection with original model of shoe. Maybe only imperial "Superstar" destroyer took part of its name... ...then I've got it! I remembered 90's when I was going to Vietnamese marketplaces with my parents to buy clothes. It was right after collapse of iron courtain and we finally got western goods so we were able to buy branded clothes, shoes, electronics and so on in Czech Republic. I can remember that original adidas T-shirt costed about 1500 Czech crowns and it was much money if you take account of average monthly salary being about 10000 Czech crowns. So who couldn't afford it looked for cheaper alternatives in Vietnamese marketplaces. You could buy similar T-shirt for 300 crowns there. Of course it was not original but fake with better or worse quality. And there were those vendors who were trying to sell you their goods with minimum knowledge of Czech language so you could hear something like: Vendor: "Sir, sir, buy T-shirt adidas, quality very well!" Customer: "But it has four stripes instead of three!?" Vendor: "More stripes, more adidas!" Remembering phrase "more stripes, more adidas" I've built zebra which is definitely more adidas than original shoe! It is static model (same as original shoe) and only moving part is its tail. Even though proportions are little bit cartoonish (big head, small body, thick legs) it is very cute and recognizable. The best part of model is head. I used little bit of SNOT techniques to build snout that even features nostrils, 1x1 quarter tiles make cool eyes and mane is connected by ball joints and hinges. It could be better if it had more stripes but amount of black parts is very limited in donor set. Building instructions will be available soon.
- 4 replies
- alternative model
- adidas
(and 3 more)
Tagged with:
I haven't bought LEGO Creator set 31121 because I am fan of crocodiles but because it is the biggest Creator set with animals in last 10 years. - So, what will I do with it now? - I'm gonna make some alternative model out of its bricks! - And what could I build from pile of green bricks? - Aquaman! And is not Aquaman from Justice League but Czech Aquaman who is called "vodník" or "hastrman" in Czech. He often appears in traditional fairy tales. He lives in pond and his hobbies are sitting on willow, smoking pipe and collecting souls of drowned people. My figure features great articulation and few accessories: pipe, bench and little frog. Then I thought it would be cool to add one more fantasy creature from water so I built mermaid. She is not perfect but I tried to make her as cute and sexy as possible. It was pretty challenging building - especially head that is mostly built upside-down. She features great articulation thanks to longer ball joints although they doesn't look that good. Finally I made little stone for her from leftover parts so she can sit on it. Building instructions for both models are available at buildinst.cz Any comments are welcome.
- 3 replies
- moc
- alternative model
(and 2 more)
Tagged with:
