Showing results for tags '60119'.
This is basically a stock CITY set (specifically set number 60119, "Ferry") The catch is it features about 27 more parts which make the ship look a lot better. I added some height to the walls to keep the imaginary water (as the boat does NOT really float) out and extended the bridge's length by two studs to make it a little less cramped, and Ii even put in a seat for the Captain. The additional wall height makes the loading ramps a bit more in tune to the rest of boat, as they now line up nicely with the walls when folded up. These are all the parts needed to modify set 60119 to be more sea worthy with the higher walls and extended bridge. Here is the original model to compare mine to. (image taken from BrickLink) I hope you like my model, you can make the modifications yourself, courtesy of this handy LDD file: http://www.moc-pages...1465332822m.lxf NOTE: The stock parts are grouped separately in the LDD file, while the remaining pieces are the extras. Comments, Questions and complaints are always welcome!
This mod is provided with opening (and locking!) doors, removable roof for the Captain / crew, and space for the number of the ship featured on the doors' exposed studs. (Unfortunately the printed tiles required are not available in LDD) I also added some height to the walls to keep the imaginary water (as the boat does NOT really float) out. ,and I extended the bridge's length by about double it's original amount of studs to make it a little less cramped. This ferry allows for three and 1/2 space of track, which isn't much, but is more than my original inspiration for this MOD, set 343 from 1968's blue track 4.5v era. Also, it uses up two of the annoying flex tracks! The doors open and shut, and with the included Technic pins (hidden in the pictures) allows for it to stay shut. The roof of the cabin comes off, allowing for access to the inside of the bridge. The loco seen is NOT included in the LDD file, but is merely to show off the 3 1/2 tracks worth of space for the placement of rail cars / engines. The LDD file is available here, if you want it. As usual, comments, questions, and complaints are always welcome!
(I was torn between Train Tech and Town forums for this thread, so if it needs moving - don't hesitate to move it, mods!) Recently a Flickr user named elijahleestewart commented on one of my riverboat pictures asking about me making a Ninjago ferry from season 4. I said I already had City set 60119 (Ferry) and was not interested in making another. But this conversation got wheels turning, and about two hours later I came up with this vessel you see here, which was made by tearing apart my original Ferry to revise it. The port / left side of the vessel. From here you can see the ladder to access the bridge. The starboard (or right side). The opening gates no longer fold down (as in the original set 60119), but they do split apart to allow train cars to be loaded two at a time. You can load two of the bigger cars (24 or 28 studs long), three 16-long cars, or a single 34 stud long depressed center car on this ferry or you can mix and match. (The last 34 stud long car type is too long to have two of it's kind on there, but it can fit one 34 long and another of anything shorter than that such as a 16, 24 or 28.) The roof section of the bridge is removable to place figures at the controls. Another source of inspiration was the Albatross, a former Vicksburg-area railroad ferry from 1907 that was converted to a St. Louis river cruising ship (one of the largest vessels ever on the river) called the Admiral in the late 1930's which then became a casino and then was sadly scrapped in 2011. You can read about the Admiral here on Wikipedia, and view a picture of the Albatross on Flickr here, courtesy of the Herman T. Pott National Inland Waterways Library. (You can loose a few hours perusing through steamboats on that Flickr page!) ...That's all I got. Thoughts, comments, opinions, and questions welcome!
