Showing results for tags '343'.
This mod is provided with opening (and locking!) doors, removable roof for the Captain / crew, and space for the number of the ship featured on the doors' exposed studs. (Unfortunately the printed tiles required are not available in LDD) I also added some height to the walls to keep the imaginary water (as the boat does NOT really float) out. ,and I extended the bridge's length by about double it's original amount of studs to make it a little less cramped. This ferry allows for three and 1/2 space of track, which isn't much, but is more than my original inspiration for this MOD, set 343 from 1968's blue track 4.5v era. Also, it uses up two of the annoying flex tracks! The doors open and shut, and with the included Technic pins (hidden in the pictures) allows for it to stay shut. The roof of the cabin comes off, allowing for access to the inside of the bridge. The loco seen is NOT included in the LDD file, but is merely to show off the 3 1/2 tracks worth of space for the placement of rail cars / engines. The LDD file is available here, if you want it. As usual, comments, questions, and complaints are always welcome!
