  On 2/11/2025 at 9:45 PM, Zerobricks said:
And finally, I really don't know why we still have this lever around:
Expand
I actually use this frequently enough that I'd be annoyed if it was retired, it definitely has its uses. But for everything else, I completely agree. Especially the wheel hubs/differentials.
Expand
One thing I like about this piece is that the top row and bottom row are exactly 3 x 3 square. AFAIK, this arrangement doesn't exist anywhere else. It was very helpful to me in building a few gearboxes. I'm sure I can find these in the resale market for a long time.
I hated building the old fake motors, I liked that about as much as applying stickers. :-)
Edited by shroomzofdoom
  On 2/11/2025 at 10:51 PM, gyenesvi said:
The Audi hub cannot be used in live axles, because of the balls built in that cannot be swapped for normal pins. If there were small (L shaped) parts with towball sockets, it would be easier to replace the old hub with the Audi one. But we are not there yet.
On a similar note, it would be nice to see a revised version of the planetary hub in the form factor of the Audi hub. It would have more clearance around the steering links, and could be a swap-in replacement for the Audi hub in models.
The grey one is easier to lock (also its radius is slightly smaller, needs less clearance), and the ratio is slightly different. But those are marginal differences.
That one is actually quite useful still when you need that half stud extra spacer, because in many colors a half stud bush does not exist. Also, that 1 stud end feels to hold more stable than a thin version, even though half of it does not have an axle hole. I actually don't get why that is the case. It would be even more useful with a complete axle-hole end.
Expand
Agreed regarding hubs, but we are getting new, shorter suspension arms which will be useful for such scenarios.
  On 2/12/2025 at 12:23 AM, msk6003 said:
Used on 10261 roller coaster and 71389 lakitu expansion pack for that purpose too. And seems like TLG still has it's mould.(Please don't ask how I know this)
But yes. 8t has limited function. I need 12t and 16t version of that frictionless gear.
Expand
Thank you for the insight, I retract my statement then.
Can't say I've ever used those hubs, but to me the sliding 8t gears are wonderful and totally irreplaceable.
That odd 4L liftarm is sometimes useful. I have a particular soft spot for it because it is used so perfectly in the legendary 8480.
Edited by aeh5040
I've spotted the newly patendet heavy duty joint assembly in the upcoming T-Rex skeleton, which is massive!
LEGO-76968-Dinosaurier-Fossilien-Tyranno
Edited by R0Sch
  On 1/10/2025 at 7:44 AM, R0Sch said:
Good deduction! It's exactly used as you describe. Here is the mock-up of the parts and how they connect.
Maybe this heavy duty ratcheting joint will be used in the upcoming UCS AT-ST Walker.
*snip*
It's also interesting to know that the Designer behind this HD joint is Janko Grujic, who designed last year's large City Excavator 60460 (which introduced the 5713 element 3L Axle and Pin Connector). If we look at the upcoming list of City sets for June, we can find two possible candidates 60466 Bulldozer with Front Loader or my main hunch 60467 Heavy Duty Recovery Tow Truck with Crane, an 80$, 793 pcs vehicle probably similar in size as 60409. where this assembly would be of use.
Expand
Jesus this is such a stupidly clever mechanism... I'm genuinely amazed by it. Hope this means that Lego mech articulation will start improving!
  On 2/27/2025 at 9:18 AM, Ngoc Nguyen said:
Other than that?
Expand
What else would you need? You get them by halving angles, that's already a nice mathematical property. The two most basic angles are 90 and 180 degrees. You half the angular space between them, you get the 135 degree one. You keep halving the space between those three and you get the 112.5 degree one and the 157.5 degree one. And by the same logic in between 90 and 112.5 now we have 101.25 as #7.
The new joint is very exciting. As a fan of themes like Ninjago I'm looking forward to seeing what else it will be used for—Lego mechs/dragons/etc. have been pushing the limits of what existing joints can bear, so a stronger joint like this could create some impressive possibilities.
  On 2/27/2025 at 8:29 AM, Ngoc Nguyen said:
Speaking of angled connectors, any idea why the angles for #3 and #5 are 112.5 and 157.5? Do these angles have any special mathematical properties?
Expand
It matches the previous toothed-bushing connectors https://rebrickable.com/parts/4273b/technic-axle-and-pin-connector-toggle-joint-toothed-with-slots/ which have 16 teeth so divide 360 into 16.  I guess being conservative/backwards compatible they didn't want to change that system.  Same for the small click-joints that came later, it steps evenly by 22.5.  I think the larger style joints have 24 teeth and so they step by 15 degrees instead.
I wonder if these  new tan 12 tooth gears are compatible with the Daytona yellow gears 22 tooth and 14 tooth.
Also, I'm stoked to see this piece being used for something other than as a minifig accessory AND with technic pieces!
Shame lego didn't give it any anti studs (yes I own these pieces)
Edited by SNIPE
Expand
Good! So that means TLG should have no more excuses for large, heavy mechs without proper arm and knee articulation (cough, cough, Ninjago Movie Fire Mech, cough, cough).
Although unlikely, I am curious to see if this joint signals a future with a non- vehicle Technic sets like the action figures and robots we used to get. Perhaps, if we are fortunate enough, we could see these joints used in a studless, modern, scaled-up reincarnation of the old 8852 robot set in 2027 for Technic's 50th anniversary.
Technic sets using this new part are unlikely from my understanding, and after the T-Rex skeleton we will likely see them appear in Star Wars and other action-themed sets first, but I am curious about the potential of motorizing this part of it does appear in a Technic set.
Edited by HydroWorld Outlook
