23 hours ago, R0Sch said:
@Lipko Just cut two 60483 through the middle of the axle hole and glue them together.
This is a good idea, but difficult to do. I use to use the ref. 4185 when possible. Of course, a new piece would be welcome.
16 minutes ago, Stereo said:
Hmm, is this only partly completed?  The submarine should add a bunch of sand blue, and 1L yellow beams.
And I can not see white 9L beam wkth alternate pin holes...
This new part could be used with this to make a stronger linear clutch, the existing white one we have is very bendy, but these 2 parts have embedded pins and so you could just convert the pinhole into an axle hole anyhow:
250x250p.jpg250x250p.jpg?1658419075.8669405
we also get the thin 9L beam with 3 holes in green. it has not been used in a technic set yet, however the fairly new axle 3L with pinhole will be used in the 42205 Corvette stingray
Edited by SNIPE
I'm far from an expert on how a typical clutch works... would the way this joint "clicks" into place every 15° work with your typical use case, or would the uneven resistance make it too jerky overall?
not sure how hard it would be to turn, I have the dark bluish gray half but nothing to snap  it into..
I only bought that part to check if it would work with the existing linear clutch halves, it does not.
The aforementioned new part MAY fit inside of the 28 tooth mini turn table half but I doubt it will click into place.
However it doesn't seem to be that much because this set uses the exact combination anyhow :)
EDIT yeah in LDCAD it is too wide to fit inside of a 26 tooth turntable half :(
but at least you can have an independent axle running thru the middle, or can connect the pins to a 28 or 36 tooth double bevel gear.
Edited by SNIPE
I wonder if anyone can find a part that lets me attach a beam 5 via pinholes 2 and 4 into these pins but where theres a 0L gap instead of a 1L gap which the pin joiners have:
However it must still be able to rotate independently of both the turntable halves and also still allow for an independent center axle
That's cool! Probably stiff enough to only be necessary in extreme circumstances as a clutch, but there ought to be other uses for it as well
6 hours ago, Aurorasaurus said:
Can you provide a link to this part? I dont know what you're talking about, it sounds interesting.
On 12/3/2024 at 10:22 PM, msk6003 said:
viewimage.php?id=21b8d729&no=24b0d769e1d
10265 Ford mustang's 5 spook rim is now comming in lime and orient express's 9L connecting rod is comming in green.
Also this is first set after release new pullback motor which is use pullback motor but not technic set.
And I still wating Dark azure and Dark blue 1L liftarm.
What do yo mean by "a 1L gap which the pin joiners have"?
I don't see a 1L gap within a single pin joiner - just the small slot in its middle.
And the gap betwern the two pin joiners surely is not what you mean, is it?
I mean so that the beam will sit flush against the turntables pinholes.
the ideal part here (if it existed) would be a 1L thick disc with 5 pinholes in a + pattern
Edited by SNIPE
250x250p.jpg?1714159738.9423912
This will work. Or if you don't want connect with turntable, this will work.
250x250p.jpg?1658328553.571948
Edited by msk6003
that disc won't let the central axle spin independently because it has an axle hole
the 3x3 commetor will but it wont be able to spin independently to the turntable.
If you have an axle stabilizing the middle, you can use 2L liftarms:
Nothing else can use the space between the turntable pinholes anyway though (3x3x3, sort of), so maybe it's simpler to just offset the clutch mechanism so it sits in that space instead of in the turntable's ring.
Edited by Stereo
There are rims which nearly match the conditions - except for the diameter (about 3,5 L). So they won't fit within the 3 L x 3 L space, but have to be situated above the turntable. Moreover, they are thicker than 1 L (about 1,5 L).
Example:
https://www.bricklink.com/v2/catalog/catalogitem.page?P=60208#T=C
Or maybe you could built something with several connectors?
I would begin with two of these
https://www.bricklink.com/v2/catalog/catalogitem.page?P=27940
or two of these
https://www.bricklink.com/v2/catalog/catalogitem.page?P=32184
or maybe one of those new parts sitting flush against the turntable's pinholes
https://www.bricklink.com/v2/catalog/catalogitem.page?P=2393
Or maybe you could use three 5 L liftarms side by side (and stabilized by the outer pinholes which aren't used to lead axles through them).
Or maybe this rare part could serve your purposes:
https://www.bricklink.com/v2/catalog/catalogitem.page?P=61905#T=C&C=85
Is a height of 2 L allowed? Then you could attach two parts 2393 (with their pins pointing upwards) and connect them by a transversally mounted liftarm (which then provides the center pinhole for your contraption).
Edited by Timewhatistime
Actually I think the two 2L yellow beams would work! (I thought they would pivot too much but I guess the 5L beam locks them in place
EDIT: OK it has a little bit of play still but it's the closest solution to what I want that I can build, the better solution would be to use that rare inear actuator bracket (61905) along with two 15100 connected to the axle holes with 2L axles
Edited by SNIPE
3 minutes ago, gyenesvi said:
Oh, I see, I know that one, but thought that it's thicker than half a stud (the similar 5L and 11L one has ends that are thicker). So is this exactly half a stud thick?
Yes, they are half a stud thick, but very, very flexible. Not only do they use less material than normal half beams, they also seem to be made out of a softer plastic.
Yes it is thin, but not particularly strong, so I discard that possibility to use it because IMHO it is very flexible...
Indeed, I see, actually I did order some of them a while ago and checked now. Pity, not sure why it needs to be flexible; it could have been useful for some purposes..
