Waterline Models
#1
Posted 15 June 2012 - 08:28 PM
#2
Posted 15 June 2012 - 08:44 PM
The big advantage is that it looks awesome on the surface (check this out), a waterline model is great for combining with port and island dioramas.
#3
Posted 16 June 2012 - 04:44 PM
to make stable as to opposed to using prefab Lego hulls. Both have draw backs but stability is one of the hall marks of the prefab method.
My Digital Fleet (LDD)............................................HMS Scorpion
My Living Plastic Fleet......................................HM Sloop Narthex
My Brick Link (LFX Files).........................................HMHV Snake
Hat Tutorial..........................................................Schooner Raven
#4
Posted 16 June 2012 - 11:01 PM
Anyway, stability also depends a lot on the size of your ship, a very big ship has a lot more stability issues.
Maybe there's some confusion about the definition of a waterline model.
I believe it's a model with the submerged part cut off, in other words only that part of the ship that is above the water
#5
Posted 17 June 2012 - 12:31 AM
No, none at all. Didyou look at my ships? See the links below.
#6
Posted 17 June 2012 - 06:26 PM
Of course a water-line model can't have a full keel, your Snake, for instance, which does have a keel, isn't clearly water-line, or if it is supposed to be, well, then…
A ship is floating in the harbour now,
The wind is hovering o'er the mountain's brow;
There is a path on the sea's azure floor,
No keel has ever ploughed that path before
(Percy Bysshe Shelley)
#7
Posted 18 June 2012 - 08:19 PM
Sebeus I, on 15 June 2012 - 08:44 PM, said:
This is very true for brickbuild hulls exceeding a certain size. Got to stress that point.
Well, that's mostly because prefab ships tend to be rather small. I can remove the prefabs from the bottom of my ships and they stay intact without too much trouble. Pretty much everything else you said is wrong or confusing too.
No, obviously it cannot. But kurigan doesn't seem to understand.
INDEX: Historic Ships, Replicas, Figureheads and Models
"The better is the enemy of the good." - Voltaire
#8
Posted 18 June 2012 - 08:54 PM
My input doesn't change. Water line models tend to be more stable, particularly when built with prefab sections. By this I only reference the satbility of the sheer hulk it's self; considerations for rigging or other parts of the vessel not withstanding. Full hulls tend to be less stable regardless of their size because their member parts are smaller and more numerous, they almost necessarily being brick built. To most you'll find venturing upon a project of the full hull type, stability isn't a key issue as they tend to be intended as models, not toys or play sets. Water line tends to be favored for playable constructionsn to better simulate a ship at sea. As for perfectionist's point that larger vessels become less stabe as they grow; this is usally true for any build, prefab hulls aside. What you'll notice about most of the prefab hull builds, larger ones espically, is that they are usually built out wider a mid ship then the prefab sections.
Exceptions to the "rules":
Super link attempted upon a full with his Rapscallion still based on prefab sections. It wasn't terrible, but he decided to go with the water line after all.
Cb4's full hull technique is well know to be quit stable, images of his Xebec propped up on a single point proving it, can be see on his thread.
#9
Posted 18 June 2012 - 10:46 PM
Cb4's technique is indeed absolutely strong. I can easily hold my hull in any position without the slightest problem.
I never experienced real contact with a model using Anders' technique, but I do think that the hull is pretty solid, I'm more afraid with the above connection in terms of decks and tumblehome building.
#10
Posted 19 June 2012 - 03:47 AM
My waterline ships are much more interesting to build, and look much more realistic in my opinion, but they are definitely fragile! Especially at the size of my sixty four it just cant be lifted in one section. So the compromise is building in sections which provides a whole new set of challenges. For right now, I definately prefer waterline models, but since the introduction of black hulls and new techniques like Perfectionists NextGen technique that may change.
#11
Posted 08 July 2012 - 01:32 AM
#12
Posted 17 July 2012 - 11:53 PM
but that is also not really my reason for replying here.
Can somebody point me in the direction of this new technique of Perfectionist, I've read some notes about it here and there, but I can't seem to find the post. I've been away from EB for a wile so I missed a bit :(
Bart
Dus
my photos#13
Posted 18 July 2012 - 09:32 AM
Bart
More ships for the fleet
#14
Posted 18 July 2012 - 02:40 PM
Reply to this topic
