Showing results for tags 'the clone wars'.
Let's start 2025 with yet another Imperial ship! My ever-growing Nanofig-scale collection gets a new model: the very sleek Imperial Gozanti Cruiser from Rebels. This build was painstakingly modeled to the most accurate reference material I could find. It features all the details of the original design: shield projectors, narrow viewport, symmetrical upper and ventral turrets, sensor array, tapered engines and wings... The docking clamps on the underside can hold four TIE fighters I made for display, or two of my Midi AT-ATs, which are now updated and fully compatible with the Gozanti. All models are at the same Nanofigure scale. The very organic shape of the whole upper section required a precise combination of angled panels in order to achieve a continuous, natural curve. This really felt like designing a fish, reproducing that "elongated teardrop" shape. You'd think making a fish out of Lego was challenging enough... the wings of the ship had to not only be compact but also have a slight inwards taper. On top of that, they had to hold the weight of two AT-ATs. All these things were achieved thanks to a thin and sturdy technic structure. This build also has detachable landing gear, and comes with two different stands: a short stand, ideal for displaying the Gozanti solely or with TIEs attached, and a beefier, taller stand to show it carrying two AT-ATs in mid-air. Badass. At 55cm in length and made of about 3,000 parts, it's still a slim model that can fit pretty much anywhere in your Lego room. Once mounted on its tall stand with two AT-ATs though, it becomes a fairly impressive display piece, with more than 5,300 parts in total. ► Instructions for the Gozanti are available at BrickVault! More pictures on my Flickr page.
*Your entry has earned 7 XP* Commanders and Generals need the best possible information about enemy positions for their proper decisions. Recon units, such as ARF Troopers, can find all hidden droid outpost, by approaching they unnoticed. During the battles on Exodeen, ARF troopers were scattered among the ruins of the buildings of the old city, to locate separatist patrols and convoys. "These clone troopers were often tasked with scouting out the enemy position on the battlefield. Although stealthy and well-trained, recon troopers' duties differed from that of Clone Commandos or Advance Recon Commandos as their focus was on gathering information about the enemy or carrying out surprise attacks."
- 17 replies
- factions
- thetriumvirate
(and 3 more)
Tagged with:
My first ever true Minifig-scale ship is finally here, and what better model to start with than the sleek BTL-B Y-Wing from The Clone Wars series. Being 23 meters long in universe, this accurately Minifig-scaled MOC is quite a unit: 57 cm long, 1,6 kg, 2,954 pieces. It can accommodate two clone pilots - one in the cockpit, the other in the turret. The model is available in three versions: classic (yellow), Rex's (blue), and red. With a spaceship of this kind, the main challenge is to achieve a level of smoothness and fluidity that gets as close to the original as possible. Using the Battlefront II model as a reference, my goal here was to closely match all key features of the ship: the subtle downwards angle on each side of the body, the curvy and tapered front section, the continuous yellow stripes that run across the entire fuselage, the intricate middle-section... and for such a smooth ship, going full SNOT (from top to bottom!) goes without saying. The T-shaped body of Y-Wings usually allow for simplistic structures, but in this case, figuring out the internals was one of the truly head-scratching parts of the build, since I had to properly incorporate angled fuselage assemblies and make a proper interior for Minifigs. Even so, the model is very swhooshable and can be grabbed from the underside, from the rear or even from both wings. Each color variant is accompanied by its specific set of instructions and parts list, giving you the freedom to build the one you prefer. The ship has two display modes, "in-flight" with its fully removable stand, and "landed" with retractable and easy-to-connect landing gear. The swooshing can begin. ► Instructions for the BTL-B Y-Wing are available at BrickVault! More pictures on my Flickr page.
- 10 replies
- minifig scale
- btl-b y-wing
- (and 21 more)
UPDATED TO v2.0 I've wanted an LAAT of my own for a long time, I missed the opportunity to get one of the Lego sets during my dark-ages and have absolutely nowhere to put a UCS sized pile of plastic, so I thought I'd continue the midi-scale thing and try to make something bookshelf friendly. This isn't intended to be any particular scale, just roughly the same size as the midi-sized Slave 1 (75312) with room for figures and strong enough to be played with. The cockpit bubble looks oversized and there’s obviously only one of them so I had to throw accuracy to the wind there, but I’ve squeezed in as many other recognisable details as I could. The roof opens up to allow access to the cockpit which has just enough room for two Clone Troopers/Pilots to get cozy. There’s a small weapons locker in the area between the front hatches, though it' mostly for decoration as its very hard to acces, and the side doors hinge outwards and fold back so that four Clones can be seated inside. There isn't enough headroom to have them hanging by a handrail but some fearless perching before deployment is definitely doable. Finally I squeezed a stupidly small BARC speeder up the back end of the ship. Overall the Republic Gunship is a 28cm long (including the guns), 27cm wide and weighs 410g. Instructions are on Rebrickable, I've only used common and cheap parts so the whole MOC with stand will cost around £35 for the 603 pieces. https://rebrickable.com/mocs/MOC-107732/ron_mcphatty/midi-republic-gunship And here's my other midi-scale efforts.
- 18 replies
- gunship
- midi-scale
(and 4 more)
Tagged with:
MOC of the Flarestar-class Attack Shuttle, a saucer-like craft used by Hondo Ohnaka's Weequay pirate gang. Sometimes also referred to as Penumbra-class Attack Shuttle. It showed up in season 1, transporting the captive Count Dooku, and in season 5. The ship in Lego form has been scaled down slightly, to system-scale, to make use of certain rounded pieces. The canopies open up, and two front boarding ramps lead up to them. These ramps can fold out but an extension has to be added for the stairs to reach the ground. There is also the main boarding ramp in the rear that can open up, leading to the main cargo hold with space for one figure, and folding landing gear (when displaying the model with a clear brick as support, the landing gear also needs extensions). More images are on my Flickr: https://www.flickr.com/photos/142795615@N07/
- 7 replies
- star wars
- the clone wars
(and 5 more)
Tagged with:
My first official brickfilm, I've worked on it for a while now, i hope you enjoy Ive posted the republic base seen in the film here, https://www.eurobricks.com/forum/index.php?/forums/topic/158256-lego-republic-base-on-unnamed-planet/&tab=comments#comment-2911783 @LegoRacer1 it took a while, but here it is. I hope you enjoy it.
75537 Darth Maul will be released in 2018. I'm very excited to get this figure, but he's going to be the standard TPM version. That means he's the same ol' humanoid figure with standard black pieces and limbs. I was kinda hoping he would be the cyborg version from The Clone Wars, so I decided to build one myself in Lego Digital Designer: LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 8 by Jek Porkchops, on Flickr He is made using mostly parts in existing colours, so I have the option of BrickLinking the parts if I decide to build him (and Maul's head sculpt will be released eventually). Some changes from these pictures will be made if I were to physically make him however: *The upper leg armour will be made using the 2016 Star Wars upper leg armour shells, as they have the perfect shape. They were however unavailable in LDD. Also, both the SW and 8M shells don't yet exist in dark bluish grey, so I might have to use black SW shells with custom grey stickers on them, or wait until they do exist. *The real one will have the regular lightsaber blade piece, but it was unavailable in LDD, so I used a substitute in the pictures. *The chest armour does not exist in regular red (without printing), so I could opt for a black version with custom red stickers. *I might make custom stickers of the black and red patterns for the torso piece, the chest and the upper arms. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 1 by Jek Porkchops, on Flickr I designed it as if it would be an official Lego set, so I had a lot of 'constraints' to work with because it also had to be sturdy and stable. While I by no means have any idea what the precise constraints are when designing such a set, I think there are are only a few things that would not make it if it were to be finalised: *The lightsaber hilt would probably be of the standard design, but I modified mine to look more like Maul's *The 'ribs' that hold his upper body in place are probably a little too fragile for little kids, but I think they are strong enough to be physically built, and I kept them this way because they are crucial to the overall look. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 2 by Jek Porkchops, on Flickr The 4M half beam is where it all began, as it is perfect for the shape of the mechanical detail in front of his stomach. I also like the light bluish grey peeking though, as it too is accurate. I wasn't able to make the 'ribs' round though, so that's something to improve upon. I also think the hip section should look a little more curved around the joints, but I do like the 'crotch' section as is. The hip / upper leg articulation is a little limited, like the K-2SO set, but not a lot. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 3 by Jek Porkchops, on Flickr I am very satisfied with the leg design, as it is proportionally accurate and pretty detailed. I have chosen DBG over gunmetal, because while gunmetal might look better, most of the parts used here aren't available in that colour and it looks very matte in the show anyway, not as shiny as gunmetal. Plus, the Lego figure from 2013 has a DBG lower body as well. The lower legs are made with a lot of system parts to create the shaping and the details. They are placed around a Technic axle that runs all the way through. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 4 by Jek Porkchops, on Flickr The toes are fully articulated using mini ball joints. The middle piece only has 3 ball joints, so I had to find a different way to add a fourth tow. In the end, this reduces its mobility, but it makes it more stable as the figure can securely lean on at least one toe per foot. Maul is posed similarly, with the hind toe extended back, in many of the official images. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 5 by Jek Porkchops, on Flickr The 1x2 plates on the backs of the lower legs represent details as well. The arms are very standard. I used a black bone on the forearm to subtly distinguish the gloves from the mechanical parts, and because Maul's elbows look mostly black. I wish the official Lego figures would return to this type of elbow joint, as the B-joints are very restrictive. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 6 by Jek Porkchops, on Flickr His back mostly consists of system elements. Maybe the shoulder blades could use some stickers as well. Sadly, I wasn't able to cover up the Technic pieces and that dreaded blue pin on his lower back, without making him too bulky. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul Custom Torso by Jek Porkchops, on Flickr His torso is completely custom, because it needed to be 1M longer than a standard torso (underneath the torso ball attachment point), both proportionally and to make more room for the mechanical 'ribs' and the custom hips. I started out with three glatorian necks as the neck and shoulders, and with the torso ball connector. It was very difficult go make it stable enough, as there were a lot of pin connections that had to be doubled up with axle connections, all within a limited space, but the end result is as sturdy as most custom Bionicle 2016 torso's. I have to wait and see before I order any actual parts, as the design can probably be optimised a bit more. Also, I hope the Maul headsculpt will work well with this MOC. I might have to change some parts to dark red after seeing what 75537 looks like. So that's it. I hope you liked it :) Please leave some constructive feedback if you want. Bonus creepy mock-up Darth Maul head: LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul with creepy head by Jek Porkchops, on Flickr
