Showing results for tags 'buildable figure'.
MOC-HUNTER + (ALT HEAD BUILD) My third release in the buildable figure series from The Bad Batch. The scale of the figure is the same as my other MOCs of Tech and Crosshair. Both the helmet and alternate head version are done in the same scale as the official buildable Harry Potter buildable figures by LEGO. Creating Hunter's signature mullet was a bit difficult but I'm happy with how it turned out. The helmet version features a similar build style to crosshair with a different layering style to capture his unique helmet style. Echo and Wrecker are in the works with the possibility of a surprise figure. Instructions are available on BrickWars.net or follow me on Instagram for more original creations. Specifications for Helmet version + Alt Head Build Pieces: 1,655 Weight: 41.3oz | 2.58lbs Width: 19 cm | 7.5 in Length: 20.5 cm | 8.1 in Height: 27.4 cm | 10.8 in Estimate Part Costs: $170 - $200 Alternate Head build using custom UV printed parts on genuine LEGO pieces. Group Image with Alt Head of Hunter Group Image with Helmet Version of Hunter Upgraded Gear System The upgraded internal gear system allows arms and legs to be posable. If you plan on posing the legs, it may be necessary to attach the feet to a plate as the weight of the backpack and knives can change the center of gravity. The Clone force 99 Shoulder pads can be removed for more additional range of motion. While the helmet version of Hunter does rotate almost 280 degrees, the alternative build of the head has minimal movement due to the thickness of the neck. Custom Printed Clone Force 99 Emblems for Shoulder Pads. Details of Hunter's Signature Bandana (giving off some Rambo vibes). Sample Instructions Professionally produced, high resolution, step-by-step instructions of Hunter from Star Wars The Bad Batch. Custom printed face, Clone Force 99 emblems and skull bandana are included with the alternate build of Hunter. Instructions available at BrickWars.net
- moc
- the bad batch
(and 7 more)
Tagged with:
75537 Darth Maul will be released in 2018. I'm very excited to get this figure, but he's going to be the standard TPM version. That means he's the same ol' humanoid figure with standard black pieces and limbs. I was kinda hoping he would be the cyborg version from The Clone Wars, so I decided to build one myself in Lego Digital Designer: LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 8 by Jek Porkchops, on Flickr He is made using mostly parts in existing colours, so I have the option of BrickLinking the parts if I decide to build him (and Maul's head sculpt will be released eventually). Some changes from these pictures will be made if I were to physically make him however: *The upper leg armour will be made using the 2016 Star Wars upper leg armour shells, as they have the perfect shape. They were however unavailable in LDD. Also, both the SW and 8M shells don't yet exist in dark bluish grey, so I might have to use black SW shells with custom grey stickers on them, or wait until they do exist. *The real one will have the regular lightsaber blade piece, but it was unavailable in LDD, so I used a substitute in the pictures. *The chest armour does not exist in regular red (without printing), so I could opt for a black version with custom red stickers. *I might make custom stickers of the black and red patterns for the torso piece, the chest and the upper arms. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 1 by Jek Porkchops, on Flickr I designed it as if it would be an official Lego set, so I had a lot of 'constraints' to work with because it also had to be sturdy and stable. While I by no means have any idea what the precise constraints are when designing such a set, I think there are are only a few things that would not make it if it were to be finalised: *The lightsaber hilt would probably be of the standard design, but I modified mine to look more like Maul's *The 'ribs' that hold his upper body in place are probably a little too fragile for little kids, but I think they are strong enough to be physically built, and I kept them this way because they are crucial to the overall look. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 2 by Jek Porkchops, on Flickr The 4M half beam is where it all began, as it is perfect for the shape of the mechanical detail in front of his stomach. I also like the light bluish grey peeking though, as it too is accurate. I wasn't able to make the 'ribs' round though, so that's something to improve upon. I also think the hip section should look a little more curved around the joints, but I do like the 'crotch' section as is. The hip / upper leg articulation is a little limited, like the K-2SO set, but not a lot. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 3 by Jek Porkchops, on Flickr I am very satisfied with the leg design, as it is proportionally accurate and pretty detailed. I have chosen DBG over gunmetal, because while gunmetal might look better, most of the parts used here aren't available in that colour and it looks very matte in the show anyway, not as shiny as gunmetal. Plus, the Lego figure from 2013 has a DBG lower body as well. The lower legs are made with a lot of system parts to create the shaping and the details. They are placed around a Technic axle that runs all the way through. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 4 by Jek Porkchops, on Flickr The toes are fully articulated using mini ball joints. The middle piece only has 3 ball joints, so I had to find a different way to add a fourth tow. In the end, this reduces its mobility, but it makes it more stable as the figure can securely lean on at least one toe per foot. Maul is posed similarly, with the hind toe extended back, in many of the official images. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 5 by Jek Porkchops, on Flickr The 1x2 plates on the backs of the lower legs represent details as well. The arms are very standard. I used a black bone on the forearm to subtly distinguish the gloves from the mechanical parts, and because Maul's elbows look mostly black. I wish the official Lego figures would return to this type of elbow joint, as the B-joints are very restrictive. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul 6 by Jek Porkchops, on Flickr His back mostly consists of system elements. Maybe the shoulder blades could use some stickers as well. Sadly, I wasn't able to cover up the Technic pieces and that dreaded blue pin on his lower back, without making him too bulky. LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul Custom Torso by Jek Porkchops, on Flickr His torso is completely custom, because it needed to be 1M longer than a standard torso (underneath the torso ball attachment point), both proportionally and to make more room for the mechanical 'ribs' and the custom hips. I started out with three glatorian necks as the neck and shoulders, and with the torso ball connector. It was very difficult go make it stable enough, as there were a lot of pin connections that had to be doubled up with axle connections, all within a limited space, but the end result is as sturdy as most custom Bionicle 2016 torso's. I have to wait and see before I order any actual parts, as the design can probably be optimised a bit more. Also, I hope the Maul headsculpt will work well with this MOC. I might have to change some parts to dark red after seeing what 75537 looks like. So that's it. I hope you liked it :) Please leave some constructive feedback if you want. Bonus creepy mock-up Darth Maul head: LDD MOC: Lego Star Wars Buildable Figure Cyborg Darth Maul with creepy head by Jek Porkchops, on Flickr
