Showing results for tags 'ferrari f40'.
Hi folks, I'm happy to share my latest creation to complete my 2022-lineup. With this model, the craziest journey is now over that I've ever had for an alternate build. This replica of a Ferrari F40 is purely built from Lego set 42143 Ferrari Daytona SP3 as an alternate model (B-model). Having the set 42143, all required parts will be donated and no additional parts are needed to build this F40. The model uses 23 spare parts from Daytona's large spares inventory, resulting in 3603 total parts for this MoC with 95% Daytona parts used. More info and instructions can be found here Functions & Features independent suspension in front and back manual steering with working steering wheel openable doors with locking system openable hood openable rear section working popup-headlights with linkage system 5+R speed transmission gearbox F40-V8-engine with moving pistons open window in bottom to view gearbox detailed interior and engine-bay modular building with separate premium PDF-files detailed design with printed parts fits all Supercars in 1:8 scale measures (all parts closed) 57cm x 26cm x 14cm Impressions Engine The V8-engine with moving pistons is directly connected through the gearbox to the rear differential. By opening and stabilizing the rear section, the engine and engine-bay can be revealed to watch inside this F40. The engine-bay is one of the most detailed part for an alternate model, with exhaust pipes completely made from the engine to the rear end. Even the crossbar from the back to the roof, that gives the real F40 more structure, has found a way into this model. The stabilizer-bar that keeps the rear section open can be stored safely under the rear without loosing them. Gearbox Welcome to my most realistic gearbox so far - the 5+R speed transmission gearbox inside the middle console of the car with a shifter layout very next to the original. For a full wheel spin, the engine fires 1.841 times in the first gear and only 0.663 times in the fifth gear. A higher selected gear results in less friction on the drivetrain and in lower moving pistons of the engine. Following is a summary of all gear ratios, measured from wheel (input) to engine shaft (output): Reverse - 1:1.767R 1. Gear - 1:1.841 2. Gear - 1:1.479 3. Gear - 1:1.104 4. Gear - 1:0.884 5. Gear - 1:0.663 Popup-headlights The model features iconic popup-headlights like the real F40 does, triggered by hand. Once the hood is open, the mechanism can be triggered to open and close the lights. This linkage mechanism is secured with a rubber band, holding the lights strong and in place. The following animation shows exactly how the popup-headlights works. Details The model uses most of the printed parts from its 42143 donor set, giving it the final touch and the instantly recognizable Ferrari brand. Doors of this F40 are implemented with a locking-mechanism. The doors snaps in automatically and stays in closed position. More features to mention are the iconic black stripes around the car, the air-intakes, the slightly angled shapes, the detailed interior with printed dashboard and the front lights, that are very detailed under the trans-clear parts. Instructions & building process The premium instructions for this model comes in 5 separate PDF-files with high quality images and building steps that are very close to the original Technic-instructions. The build can be quite challenging for inexperienced builders, but is for a 18+ set of course a satisfying experience for more practiced adults. Building this F40 starts on the 368 pages long main PDF with the ingenious 5+R speed transmission gearbox and the front axle to complete the front section of the chassis. The build continues with the second PDF and 136 pages later, the rear section is added to the front. After the marriage process with rear and front section, more parts are added to the chassis to make a solid structure, where every function works perfect at this point of the build. Iconic lines are more and more represented to give this model a real F40 experience. The third PDF takes over to complete the openable rear on 170 pages and added to the build. Some more details are added and the roof and windshield will be finished, getting closer to a real looking F40. On the fourth PDF, both doors are built and attached to the car 78 pages later. The F40 continues with the fifth and last PDF to build the hood on 185 pages with the triggering mechanism for the popup-headlights and then attached to the model. After 937 pages in total, the F40 alternate build is finished in all its glory. Comparison Final note With 95% Daytona parts used, this model pushes the limit of what is possible with a given inventory, offering builders a relative easy way to create this F40, where only the 42143 donor set is needed providing all the parts. I'm happy that I've finally managed the biggest brainfuck that I've ever had in my head with this model, resulting in the biggest model I've ever made and in one of the biggest alternate builds in history. Thanks to Uwe Wabra, my favourite designer, who makes this possible just with the Daytona. With several functions and authentic design-features very close to the original one, this model is not only a piece to display. More info and instructions can be found here Have fun with this Ferrari F40 alternate build.
- 16 replies
- pdf instructions
- alternate model
(and 6 more)
Tagged with:
Hello Ferrari and Speed Champions fans, the Ferrari F40 (tipo F120) is a mid-engine, rear-wheel drive sports car engineered by Nicola Materazzi with styling by Pininfarina. It was built from 1987 to 1992, with the LM and GTE race car versions continuing production until 1994 and 1996 respectively. As the successor to the 288 GTO (also engineered by Materazzi), it was designed to celebrate Ferrari's 40th anniversary and was the last Ferrari automobile personally approved by Enzo Ferrari. At the time it was Ferrari's fastest, most powerful, and most expensive car for sale. Building instructions are available on the following links: https://rebrickable.com/mocs/MOC-99799/_TLG_/ferrari-f40 https://www.mocsmarket.com/lego-mocs/ferrari-f40-building-instructions/ It is a studless build in the new, 8 studs wide Speed Champions style. I wanted to create a sleek model which is as accurate as possible in this small scale. I prefer the brick built solutions to keep the flexibility of the used parts in further builds, and therefore only Ferrari logo stickers are used. (If you preferred a better shaping instead of a real rear side grill, then 2pcs of parts 61409 could replaced by 2pcs of tiles and some additional stickers, see the picture 3.) My intent was to keep the width-length-height ratio of the real car and this size makes it possible. The model contains lots of details: for example the emblematic front, hood , side and rear intakes, the narrow black line on the front and sides, the front turn signals, the side view mirrors etc... Maybe the most challenging one was the iconic rear side with the vehicle registration plate and the rear spoiler, here there is a half stud offset. I tried to fill every unnecessary gaps and therefore some tricky build techniques are used. The model has space for one minifigure. I suggest to use small or middle sized hair. Thanks for visiting, _TLG_ Ferrari F40 - instructions 1 by László Torma, on Flickr Ferrari F40 - instructions 2 by László Torma, on Flickr Ferrari F40 - instructions 3 by László Torma, on Flickr Ferrari F40 - instructions 4 by László Torma, on Flickr Ferrari F40 - instructions 5 by László Torma, on Flickr Ferrari F40 - instructions 6 by László Torma, on Flickr Ferrari F40 - instructions 7 by László Torma, on Flickr Ferrari F40 - instructions 8 by László Torma, on Flickr Ferrari F40 - instructions 9 by László Torma, on Flickr
I have to do the video, edit and take some pics more but I think there won´t be more big changes . This is the manual one and I will do the LDD instructions for it, I think it will be for free, the RC one was for me for fight with the little space . The car is completely modular, trunk, bonnet, doors, back fender, roof, sides of the bodywork, gearbox, fake engine, rear axle, seats and chassis with the front axle. It has independent suspension with functional doors, trunk, bonnet and retractable headlights, 5 speed and reverse gearbox (Tyler Reid style) and a V8 fake engine. This is an appetizer as my style, I will update with new information. I hope you like.
