Showing results for tags 'crawler crane'.
I present my new creation mini spider crane. Small model with working functions. Instructions: https://rebrickable.com/mocs/MOC-25491/blaz62/mini-spider-crane/#info More pictures: https://flic.kr/s/aHsmDZxmut
Hello, this is a model (MOC) of real existing lattice crane from China - Sany SCC40000A. Crane with capacity 4000 tons, his overall height can be over 200 meters. To transport that massive crane require more than 200 heavy transport trucks. My model is little smaller - height is max 3.4 meters and I really don´t know how much it can lift. I didn´t try - maybe several kilograms. Only to the first braking bricks :-). It took me several weeks to make it in LDD, several weeks to collect all the parts and build, some issues during build has occured, but nothing serious. I also made building instructions if you wish to build. Total parts count 10388. It is fully remote controled via IR receivers. 14 power function motors - 4 XL motors in the main undercarriage which control each tracks and 2 IR receivers, 4 XL motors in the rear ballast trailer one motor for each tracks and 2 IR receivers, 4 L motors in the superstructure for 4 winch drums and 2 IR receivers, last 2 M motors are located in the derrick with 1 IR receiver, this M motors control last two winch drums. Two rear winch drums in the superstructure are for the main boom, two front winch drums are for the lufffing jib. Winches located in the derrick are for main and auxiliary hooks. Crane can be made with Sbricks or Buwizz also. In rear ballast blocks are hidden non lego counterweight with aproximetly 3 kg. Building instructions: https://rebrickable.com/mocs/MOC-135246/kladovec/crawler-crane-sany-scc40000/ Video: https://youtu.be/IQzy3cn-eiU More pictures: https://bricksafe.com/pages/kladovec/sany-scc40000
Dear all, While the news went out that lego was designing a new liebherr crawler crane, I decided immediately to build my own version, with 6 PU motors, 3 L ones and 3 XL's. the boom will have 9X9 dimension. The body uses the turntable of the 42082 rtc. Untill now the body is more or less finished, but it needs still tweaking and further adjusting while the build advances. Now I'm waiting for parts for the boom including some weights for the hook. Here are some photos, including 1 with the previous 42042 crawler crane This is an early work in progress, the cogs are better reinforced and everything is working smoothly now Here the main body is more or less finished, including cabin and ballast (2 times 9 big panels) Here is an image from behind, I used the linear actuators for support of the ballast, and to connect the ballast directly to the axle of the pulleys. I thought it looked very cool a construction like this. The batteries of the batterybox can be easily replaced (no screws). You can also see part of the drivetrain, maybe this has to be geared down a little bit more, the crane runs still a bit too fast. And last but not least a photo for compairison of scale. I hope you liked it for now, as always comments or questions are always welcome
- 33 replies
I'm sure there's hundreds of these things modded up, and here is another take on the blue crawler. Added a couple sections, strengthened a few attachment points, added a few little details, took out clutch so it can pull pretty good now. Next job will be figuring out how to get a subtracter underneath this. (Any suggestions) Well there it is, simple mod but I like the look of it, a few things could probably be refined, and as always any pointers or wrong doings, I'd love to here it. https://bricksafe.com/pages/2ndgenguy/raptor/42042-crane-mod.-moc (Credit to silvio.tristram on rebrickable for the hook)
- 2 replies
- crane
- crawler crane
(and 2 more)
Tagged with:
This is a telescopic crawler crane I threw together almost overnight in the hope of overcoming builder's block. The undercarriage had been sitting around for months after I began (and never finished) a mod of 42055, so I just needed to remove a couple of unneeded motors and touch up the tracks. The model is the usual combination of RC and hands-on that I like. Some technical details: - undercarriage driven by 4 L motors (2 per track) geared down 1:25 and powered by 1 BuWizz unit; - superstructure featuring 5 independent functions - boom raising and extending, winch, rotation and cab tilt - activated by a two-way gearbox driven by an XL motor, plus a fake 4-cylinder engine (based on 42030's) driven by an M motor. I decided to use a brick-built actuator so I could get the boom to almost vertical. I always struggle with bodywork - I did my best not to make it too boxy. I'll make a video at some point - it started raining as soon as I took the last shot. (Apologies for the messy garden).
Hi there. For several day´s I was working on Nico71´s crawler crane which he made several years ago. Nico allowed me to show you that. I´ve made it in LDD only from his pictures. He never made instructions for it, only took several pictures of disassembled crane body. So I started step by step. And I´m proud to show you result. There is 4 motors in superstructure. XL for hook winch, M motor for rotating superstructure, another XL motor for main boom and M motor for luffing jib. Nico´s original crawler wasn´t motorized. So I´ve decided to add aditional L motors and AAA BBox with IR receiver. There was enough space for it. Last picture - entire crane disassembled to blocks. https://www.ulozto.cz/!hTHRd0qovvKh/crawler-crane-complete-lxf Hope you like it.
- 4 replies
- nico71´s
- crawler crane
(and 1 more)
Tagged with:
Improved 42042 Crawler Crane. Banana Man for scale. It's hard for me to overstate how much I love the Technic Crawler Crane 42042. I've been constantly tinkering with it and making improvements since I got it about 6 months ago. My method is basically to lift heavier and heavier stuff until it falls over or something breaks. Then I rebuild. This is how it got to where you see it today. I don't really care about the tracks or the slewing. I want to lift heavier stuff, higher! So far my mod/improvement list reads like this: Upgraded the block & tackle harness for better mechanical advantage Added a quick-adjust system for efficient rigging changes to the harness, main hoist, and hook Beefed up gantry or A-frame: wider, taller, and much stronger Improved existing back hitch and added a second back hitch Counterweight box Strong, longer boom Paid almost (!)$20 for stupid Technic metal hook Integrated claw storage on gantry XL Motor upgrade Boom foot return damper thing Replaced LEGO string with synthetic cable (from Chin-a) Here it is in action. Read on for a more thorough description and photos of each mod/improvement. Click through on the photos to view them at larger sizes. Block & Tackle The first thing I did was add blocks to the block & tackle system allowing me to really turn up the mechanical advantage the motor has over the load when raising and lowering the boom. This of course comes at the cost of speed, but I'm OK with that. The nice thing about this is I don't have to actually use all the blocks. Quick Adjust Rigging on Harness and Main Hoist You can see my bright red and yellow-handled quick adjust axles with the red and yellow grips on the side of the harness assembly. This makes it easy to slip the rigging in and out of the blocks to fine tune my power/speed balance for the specific load. I also have these at the end of the boom and on the pulley so I can adjust the speed/power tradeoff on the hoist line. I added this quick disconnect system after I'd re-strung the rigging for the hundredth time. I can re-thread the rigging on both the harness and the main hoist line to go from "high gear" with max lift speed to "low gear" for max power in just a minute or two. (I had originally made these with axles that have stoppers on the end, but ended up using regular axles, because I have a ton of them.) A couple of timelapse (YouTube) videos of the quick change. Stronger & Wider Gantry The gantry in the stock model is really weak. It is wholly comprised of 4 Technic lift arms held in place with 6 friction pins. As I added heavier loads this system was quickly outgrown. I was bending lift arms and even popping the entire assembly off the superstructure. So I rebuilt. The new gantry is wider, allowing for more blocks in the harness. It is many times over more rigid and is taller, allowing the harness mount to be further back over the body, which in turn allows the main boom to be drawn up higher to a much steeper final angle. This piece took a long time and has been through the most revisions over the months. I did a lot of research by looking at other LEGO models, other and peoples crane MOCs. Both arms of this gantry are heavily inspired by the gantry on LEGO Crawler Crane 8288 (http://brickset.com/sets/8288-1), which I would love to own a copy of someday (not today). Improved Back Hitch The back hitch (the two black lift arms supporting the gantry) also quickly became insufficient. The anchor it was tied into was bending and getting stress cracks, so I created a stronger attachment system for it elsewhere. I also added a second back hitch that ties directly into the improved counterweight... Counterweight Box One of the challenges with cranes is counterweight. As the amount of load it can lift and move improves, their is a corresponding increase in risk of tipping. The original model cleverly uses the battery box mounted all the way at the back edge of the body. It's literally the furthest element from the tip of the boom. I added a weight box behind it that is open and easily filled with ballast of my choosing. C Batteries work extremely well because of their density and modularity. It has an open design so it's easy to adjust the weight on the fly as needed depending on the load and the angle of the boom. After building it, I added a the second back hitch directly attached to the gantry to remove stress from the body connection of the weight box and from the first front back hitch (heh). When the gantry starts carrying a lot of load, I don't know that the front hitch bears any at all. Stronger, Longer, Better Boom Maybe the most noticeable feature is the length of the new boom. The original is 30 studs long, not counting the butt and tip, with an optional section to extend it to 45 studs. This booms main section is 75 studs long. At this length, it had some really concerning droop/bending at full extension. However, I was also able to easily reconfigure the inner supporting structure to be much stronger since I didn't care about the ability to easily add and remove sections. I also added the outer white panels to help with rigidity as they span the weak links between the blue 15L lift arms that are the main defining component of the boom. The boom tip received an upgrade in the form of a smoother operating block and tackle system (with quick disconnect axle just like the harness) controlling the main hoist. I also added an aviation warning light, obviously the most complex and impressive mod thus far :) Main Hook/Claw Storage I purchased a Technic Large Metal Hook (http://www.bricklink.com/v2/catalog/catalogitem.page?P=70644#T=P) for like $15. It's easily the most I've ever paid for a single LEGO piece. Considering the time I've spent on this model, though, I thought it was worth it. It's mounted to the main hoist with the smallest of my quick adjust rigging axles. I can attach the hook directly to something of course, or I can use it to hang the functional claw the system came with. When the claw is not in use, I have a storage peg for it that can be placed on either side of the gantry. I built this after I got tired of it sitting on the bench next to the crane most of the time. Much like the quick adjust rigging system, it's a simple mod that has a high convenience impact when moving this thing around for play, improvements, and storage. More Power (XL Motor upgrade) After removing the clutch gears and incrementally strengthening everything else to lift progressively heavier and heavier loads through probably hundreds of lifts at this point, the 9V Power Functions L Motor (99499) that came with the system finally died (predictably). To LEGO's credit, they're already shipping me another. They didn't even ask if it had been systematically subjected to increasing levels of abuse since purchase. Rather than wait for the replacement to arrive I hooked up an XL I had laying around. It's slower, but has more torque. As you can see it is mounted almost all the way at the front of the body, which is not ideal considering the weight. I may end up routing it further back if I can figure out a way to that looks this good. I did have to git rid of the ladder that was here on the original model, but this is Technic, so whatever. It's not like I'm bouncing minifigs around and doing voices when I play with the thing. Boom Return Damper/Helper If you increase the mechanical advantage of the harness too much, the boom has trouble releasing from very high angles. There just isn't enough weight to pull the cable off the spool on the base. I added this spring mechanism to the butt of the boom to help push it out when there is very little lateral load. I may be swapping these gray Technic springs out soon for the stronger yellow ones as it could be more effective. They will also look better matching the contrasting yellow parts of this assembly against the blue. Rigging Cable Through many rounds of adjusting and rebuilding I replaced the rigging cable several times. As I added to the superstructure more cable length was needed. Going down certain oaths and backtracking also had me replacing the cable with different lengths over and over. LEGO string is expensive, so I ended up buying a small spool of this stuff off Amazon: https://www.amazon.com/gp/product/B00LDIKURQ/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 after seeing it recommended elsewhere on these boards. It works well. It's thicker than LEGO string, so be aware, but it's also stronger and it has a bit of a metallic shine, so it looks more like the steel cable you'd see on the real life inspiration for this model. Conclusion That's about it. The major takeaway is that this thing can now lift 750 grams up off the floor below my bench and place it on the bench right next to it (from up to 80 cm away). Good stuff. I also think I retained most of the good looks of the original set. I'm not done tweaking yet, but I wanted to do this write up and show it off a bit before I break it again, because my next mod is likely going to happen in the gear box, if at all.
- 7 replies
- 42042
- crawler crane
(and 2 more)
Tagged with:
Hoi hoi One of my latest creations is a Sennabogen 5500 Starlift. It's almost completly rc controld, Only the driving of the crawler tracks are manual. I hade not inoff space in the underbody te make pf in it and make ik louw, The underbody is only 3 studs high. All the functions in the supere structure are rc. The model is made so that it can ereckt itself. And transported on trucks. I realy love the dragline but the real model can't be equipt whit a dragline bugget. The turntable for the crane is reinforst (later more about that) Think that some pic's will thel the rest of the story. (Don't no of i my post all the pic's in one post if not pleas say so thx ) Muddy Part 2 Muddy Part 3 If you like to see houw i made it you can take a look over here. http://www.mijnalbum.nl/Album=6MXLQY3Y Injoin it Muddy
- 13 replies
Ok folk, been working on this for a while now, please excuse the rubbish pics but im sure you get the ideaIve still to get a few power function parts for the base but the upper section is all working and had a lift of 2kg so far but with plans of trying for a bit moreOne thing im strugging with is, the two main winches in the body are run off the same motor and have to wind/unwind at the same speed but im strugging to get the string to wind nicely on the spool, anyone any ideas?Ok this is a 1:50th model of the real machine im working from
- 21 replies
I have been shamelessly plugging the Lego Technic 42042 Crawler Crane over in the "What should I buy" thread here at Eurobricks but I just came across a new reason to buy it that I thought was relevant to a more general audience. A company in Europe called PV Productions has created a C-Model that is a GBC contraption. (No relation, ownership nor knowledge of who they are.) calls it a D Model because he has two GBC C models created from the set, but only the D Model is available for purchase now... and purchase it, I did! My seven year old son is into small Lego Techic models as he doesn't have enough patience to build the 1,000+ piece models, but after showing him the video, he wants to build it with me this weekend. Only problem... I don't own any of the Lego soccer or basketballs that are used for GBC models and I have no desire to pay the crazy $2.50+ costs per ball!! I've attached a video below (I assume that's okay) to the Youtube video he created of the D model. I'll be picking up the C-Model as soon as it's available for purchase. He also has pending future GBC models for sales that are all C Models of 42043, 42054 and another that is a 2 set C Model but I cannot recall which... Watch the video and you want to buy the set and want to figure out how to buy some Lego balls or alternatives. If soeone has a good recommendation for an alternate source, I would love to know it. Update: just checked my Paypal receipt and the PV stands for Phillip Verbeek, I think.
- 96 replies
- 42042
- lego technic
(and 3 more)
Tagged with:
Time to unveil my latest creation, the crawler crane. Years ago I saw a nat. geo. documentary on a station in the south pole. During the construction of it, there was a crawler crane with a three section boom. Fast forward to April 2015, I built a three section boom for a crawler crane but due to having too many projects, it was never finished. When I saw the crane competition I realized that this was the perfect opportunity to make a crawler crane. SPECS Propulsion: -2x L motors -1x aaa battery box -1x v2 receiver Boom: extension: -1 XL motor Raising/lowering: -1 L motor Hoist: -1x L motor Superstructure rotation: -1x M motor Pictures: (comming soon) Video: Filmed with a Samsung galaxy s3, Fujifilm XP Quadcopter for air shots: Hubsan X4 H107C
