Showing results for tags '7939'.
The BR class 38 seen here is a one-off prototype. Engine number 7939 was made in 1989 to compare a Metro-Cammell made class 38 to a Brush Traction built class 60. The class 60 won the contract, and subsequently Metro-Cammell was sold and closed. The single class 38 soldiered on until 1997, when British Railways was fully privatized. The engine was then sold with a number of spare parts to Lego Rail Transportation Society, which has kept the engine running ever since as unit 7940. In the real world, the class 38 was never built. It was proposed and then dropped in favor of the class 60, which is what I based the story on. Metro Cammell really existed and was dismantled in 1989 sometime after loosing out to Brush Traction for the class 60 contract, and everyone knows that British Railways was taken apart in the mid-1990's. This LEGO model is a mash-up of a William Howard's diesel locomotives and the official Lego sets 7939 and 60098, with a set of Anthony Sava-derived three wheel sliding bogies. The rear of the bidirectional loco. The numbers "7940" go on printed 1 x 1 tiles on the sides while "LRTS" goes on the front and rear ends. The color scheme for this model was inspired by the British Rail Class D16/1 (also known as LMS engines 10000 and 10001), the first two mainline diesel locomotives in Great Britain. (see here for more on them.) Both ends of the locomotive have a engineer's cab that opens up to seat a figure at the controls, just like sets 7939 and 60098. (I just noticed there is one letter spot too few on the ends of the loco for the railways name as seen in the pictures, as there should be four studs, not the three shown) Bricksafe LDD file link: BR class 38 file Comments, Questions, and Complaints are always welcome!
- 5 replies
- 7939
- locomotive
- (and 6 more)
This loco was originally from the 2010 CITY set 7939 - Cargo Train and first designed in red for my brother. (who ended up not building it in real life after all) I removed the rear cab and replaced it with a personnel door for access to the train and recolored it to yellow for use by me. I then looked back on what I made, and realized it actually resembled a real engine completely on accident! It appears I made a General Electric 'Genesis' series loco, specifically a P42DC as those were the most common of the sub-types. The Genesis types weren't used by freight railroads - just passenger-only carriers like Amtrak or VIA - but this is my railroad and what I say goes! Here we see the front of the locomotive. The rear side of the loco with the crew access door at the very back. The cab front flips up to put a figure at the controls. (I removed the cab roof here to make taking the picture easier.) To read more about the Genesis locomotive types, check out this Wikipedia link. Thoughts?
- 2 replies
- general electric
- genesis
(and 8 more)
Tagged with:
I was messing around in LDD and looking at pictures of set 60098 (Heavy Haul train, not yet released for 2015. See it here: https://www.flickr.c...s-55973205@N08/ ) when I realized I probably could do a lot better using set 7939, the look-alike Cargo Train from 2010. I turned the electric locomotive into a diesel, and stretched the frame to allow for a beefier engine area. I didn't think about motorizing it with Power Functions until now, but I did make it build-able in two more varieties in case you wanted to color match 60098 with the red one, or maybe build you own engine with the black one. The cab still opens, and the driver can sit down and control the train from either end of the locomotive. This train was designed last year, but was unbuild-able until this year with the release of the back windscreen in trans-clear with a Marvel Superheroes set. The train consists of one baggage car, three passenger cars, and a observation lounge car. The rear car was based on the Milwaukee Road and it's beaver-tail observation cars. Here is the LDD file for the yellow 7939-style engine and the accompanying train cars: http://www.mocpages....1431959052m.lxf Here is the two other colors of the engine I was talking about earlier. The red one is supposed to represent 60098 (Heavy Haul Cargo train), while the yellow one is inspired by 7939 (Cargo Train). The black one is the only other color available for this type of engine. By The Way: the letters BRS should go on the three exposed studs on the sides of the locomotive, while the numbers for the engines should go on the sides of the fuel tank. 7939 for the yellow one, 7045 for the black one (because that's the only set that cockpit part comes in!) and 7944 for the red one, as it matches the other engines in sequence and was used in the 2007 set of that number. (Fire Hovercraft) ... or you could use your own numbering scheme. LDD file for the three different colored engines: http://www.mocpages.com/user_images/80135/1431958750m.lxf Thoughts, comments, and complaints welcome!
I have motorized my 7939-inspired MOC and added a new engine inspired by early Box-cab diesels. This is my first couple of motorized MOCs ever, and I'm not sure I did it quite right. I won't be building them, but if anyone wants to take a crack at them be my guest. Here is the front view. The yellow engine is also build able in red or black, while the blue engine is also build able in white. The cab on the yellow engine opens up, but the blue loco is inaccessible at this time. It may be possible to fix this, but it would require a roof redesign and I don't feel like redoing the engine (again) right now... Here we see the innards of the engines: The triple A Battery box and IR receiver. There are two 2x2 holes in the frame of the engine for a PF cord to the motor. No lights are included, but it may be possible to make them fit inside if you really wanted to. The roof sections that are hidden in this picture are removable, and are held on by four studs each. LDD file: http://www.mocpages.com/user_images/80135/1432672946m.lxf As I said above, these are my first motorized models, so please tell me if I did something wrong. Also, Comments, Questions, & Complains are always welcome!
Hello! I would like to get into trains but I can't decide which train should I pick. I would really appreciate if you could help me make a right choice. I have chosen 3 to limit the options: 1. 7939 + cheaper than 60052 + fully equipped (tracks, PF etc.) - looks 2. 60052 + looks + fully equipped (tracks, PF etc.) - more expensive than the rest 3. 10233 + looks!! + cheaper than the other 2 - no tracks - no PF It is a tough choice. Getting PF is not so hard, as I already have the remote so I would just need to get the motor (and SBrick will be shipped soon ) but tracks are bigger problem. What are your thoughts? Which one would you choose if you could only choose one?
- 30 replies
- first train
- intro
- (and 4 more)
Hi Everyone. I'm very new to Lego trains. I've read through several sites and forums and seem to be getting mixed answers. Basically I would like to know what the recommended design program is for basic tracks that will potentially include a parts list and an option to buy. LDD + Bricklinks appears to be close, but I would like to import the 7939 track design plus the 10128 Train Level Crossing, maybe add a bridge and then add on to that. Is that doable? Thanks
