Showing results for tags '12 volt'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 5 results
  1. Hello again, I am looking for instructions of 753, 754 and 755. Didn't find them online. Do you know from where I can download them or do you have them?
  2. Hi all, since 7777 book came out, I've always wanted to integrate Trains and Technic worlds. Back in the 80's the problem was the complete lack of train wheels with a Technic axle hole. It was solved with RC trains a lot of years later. Therefore, I can convert a 9v train to PF without too many problems (aesthetically speaking). But for 12V trains it is different. Wheels are made in a specific way, they have the hole for connecting rods, they're more "fat" than RC/PF wheels. Frankly, I do not like 12V trains converted to 9V/PF standard bogies. But I like the PF motor, its speed, the possibility to increase speed gradually...and the fact it keeps the central hole for third wheel. So, in these years I repaired a lot of 12V motors...and some were really in bad shape. Look at the right wheel, it is completely destroyed inside. So I decided to try to implement my solution to connect standard, intact 12V wheels to technic axleholes (which I do not list here, since it was not satisfying). First, I got a standard Technic bush, and cut it a bit. Then I put it inside the damaged wheel hole. It fits fine, but needs to be glued. Once glued, it is time for some testing. The 6-long axle goes right in - but the red ring coming out from the wheel is too thick. So I prepared another wheel (gray bush). This time I cut the bush a bit shorter and fits right. The 5.5 axle is perfect , so I'll need to cut two 6-long axles to the right lenght. And this is the result - this is my 7740 no°3, totally converted to PF. It works fine, but as you all can imagine, it is all made by hand and bushes are not machinery-centered. Therefore the locomotive is not stable as I would like. For the moment, better than nothing!
  3. While scanning my 7777 I had the idea to write down some memories about my LEGO train childhood related to this fantastic ideas book. Huw from brickset not only was happy to offer the scans in his document library but also published my #ThrowbackThursday article about LEGO ideas book 7777 some hours ago. Feel free to jump over to brickset.com and read through the article. If you like, leave your own childhood train related memories here as a comment. And maybe some of you can confirm the original price of 7777 in your country (if it was ever available). Best regards, Holger
  4. The look of this train was partially inspired by several 4.5v and 12v-era sets, such 7715 / 7818 for the color scheme and 7740 along with it's supplemental sets 7815 and 7819 for the general look of the coaches. Some parts of this train (the coaches) have already been built from about five years back, while the loco is still a WIP for now. This steam locomotive was slightly inspired by the Rhodesia Railways "15th class" that was used in what is now Zimbabwe. This 4-6-4+4-6-4 Garratt type was 74-units strong and was built by Beyer-Peacock and Company starting in 1940, and after WWII from 1947 to 1952 in seven total batches. You can read more about this specific loco class on Wikipedia. My LEGO MOC version is 'fueled' by oil, whereas the real-world 15th class was coal fired. This is one of the reasons why I said it was "inspired by" and not an exact duplicate of a 15th class. However, the front unit does features a prototypical streamlined casing, and the rear unit partially does too. This LEGO model can take some serious curves (much more than what's shown above!), but that's what you get for building a Garratt: it's one of this type of locomotive's strengths. This picture just shows off the articulation points of my MOC, but technically it could split a switch* and still work just fine with the front engine on one track and rear unit on a second one! *NOTE: Don't try that with a real-world steam loco! The doors on the cab of the loco are supposed to be the 1980's ones with blue print on the lower half. Another missing print is on the oil tank hatches, while number / letter tiles go on the front and rear units. (The front unit gets the numbers, while the rear section gets the letters saying LLR, which stands for LegoLand Railroad.) This baggage / passenger car is called a combine which is short for "combination". All the doors can open on this train, even the sliding ones shown here. The three passenger coaches are identical in every way. The observation car, the rear-most coach on the train, features a platform for sight seeing. The steam loco is still being parted out using pieces from the previous streamlined electric engine and from parts from my collection. Until it's done this is a WIP thread, but suggestions / comments / questions are always welcome no matter the project stage. Drop your thoughts below!
  5. Hi All , just signed in to this forum cause I was wondering about something .... I'm into the 12 volt train system again and was wondering about modified 12 volt track . Hs anyone done some modifiyng on tracks , switches ,etc. ? Here's some pics of my own creations untill now... A half straight track with original contacts a point prototype with same angle as 2 curved rails Let's see what you guys have !
