Jim Posted September 7, 2015 Posted September 7, 2015 TECHNIC CRANE CONTEST ENTRY TOPIC CONTEST INFORMATION More information about the contest can be found in the general discussion topic. WHAT DO I NEED TO ENTER? Please take a careful look at the rules before posting in this topic. Each participant is obliged to create a post in this entry topic. Posts need to follow the rules stated below. Posts not following the rules will be disqualified so please read them carefully. ENTRY POST The entry post in this topic needs to contain: Entry name Short summary of the functions. One or more images (max 10) Video (mandatory) Link to the discussion topic IMPORTANT This topic should be used for entries only, so commenting is prohibited. Please use the general discussion topic for comments on the entries.
efferman Posted October 26, 2015 Posted October 26, 2015 1. Kenworth K100 Crane Truck Chassis functions: Steering by servo on axle 1,2 and 5 Drive by two Pf-L on axles 3 and 4 Spring loaded suspension on axles 3 and 4 X- style outriggers, spreaded by mini-LA, driven by Pf-L Stabilizers with mini-LA, driven by Pf-L Uppercarriage functions: Rotation by Pf-M Boom lift by Pf-L Telescopic boom by Pf-M Winch by Pf-L some pictures And a video where the crane installs the boom on 42042 The building process and the Discussion about this model can be watched in this topic.
doug72 Posted October 28, 2015 Posted October 28, 2015 (edited) 2. TEREX LUFFING JIB TOWER CRANE This model I will be submitting for the contest was inspired by a crane of this type currently at work near where I live on a regeneration project. Terex C180-16 Luffing Jib Tower Crane on site. by Doug Ridgway, on Flickr The crane being used is a Terex CTL180-16 with a load capacity of 16 tons and is operated by Bower & Kirkland. The Lego model crane is operated by LW Lifting Service. This is my first attempt at a large Lego MOC. Functions:- Three L motors operate: 1/. Slewing of the crane with 200:1 reduction 2/. Luffing of the jib between near vertical to horizontal with 40:1 reduction for the hoist drum and with 5:1 rope pulley system to the jib.. 3/. Hoisting with 8:1 reduction. Height of tower = 60 Cm. Height with jib fully raised = 102 Cm. Length of jib = 50 Cm Control / Power Supply Unit: The crane is operated using a 9573 Technic Control Centre by using PF 8” extension / adaptor leads. This can be operated manually or two programs can set up to perform an automatic sequence of movements. Crane base with a cluster of three L motors and their individual right angle drives up the tower. IMG_2675 by Doug Ridgway, on Flickr Winding House, operators cabin and counterweight. Contains the two coaxial drives from the turntable and the right angle drives to the two rope drums, for hoisting and luffing. IMG_2676 by Doug Ridgway, on Flickr View from Counterweight end. IMG_2695 by Doug Ridgway, on Flickr Jib fully raised: IMG_2670 by Doug Ridgway, on Flickr Jib lowered to horizontal: IMG_2671 by Doug Ridgway, on Flickr New Video showing crane in operation with improved slewing system. MVI_2703 by Doug Ridgway, on Flickr Video: YouTube version [m.e.d.i.a.] [/m.e.d.i.a.]Gear reduction for slewing now at top of tower with a compact 64:1 using two stage worm gears meshing with 8T gears making for a more compact and neater unit. Front view of 64:1 gear reduction unit. IMG_2704 by Doug Ridgway, on Flickr Rear view IMG_2705 by Doug Ridgway, on Flickr The build and the discussion about this model can be found here Doug72 Edited November 2, 2015 by Doug72
Hanso Posted October 29, 2015 Posted October 29, 2015 (edited) (Disqualified) Edited November 3, 2015 by Jim Disqualified
Zerobricks Posted October 29, 2015 Posted October 29, 2015 (edited) 3. Mammoth 8x8 All Terrain Mobile Crane Inspired by this real thing: Functions: - All wheel drive (8x8xx) powered by 4 XL motors - Full live axle suspension - Working lights, fake engine and steering wheel - Four angled supports with pneumatic rams powered by an autopump - Liftable crane also powered by an autopump - 3-part extendable crane arm with working winch and slewing - Working winch with an automatic stopping system - Tiltable cab to reaveal the V8 piston engine - All functions with exception of winch are remotely controlled Dimesions: Length: 89 cm Width: 23 cm Height: 30 cm Total weight: 5,5 kg Additional images: Video: Topic with WIP pictures and more info: http://www.eurobrick...howtopic=114356 Edited November 3, 2015 by Zblj
lindr6 Posted October 30, 2015 Posted October 30, 2015 4. Grove Shuttlelift CD3339 Here are the functions: 1 Servo motor for 4 wheel steering (also turns the steering wheel in the cabin). 1 XL motor powering the wheels. This thing is 4 wheel drive implemented using 3 differentials 1 Large motor for lowering the four stabilizers (one on each corner). 1 Medium motor for rotating the boom structure. 1 Large motor for raising/lowering the boom. 1 Medium motor for extending the boom. 1 Medium motor powering the winch to raise/lower the hook. 1 PF Lights used for headlights. Discussion topic for additional information, pictures, and build retrospective: http://www.eurobrick...howtopic=116572
paave Posted October 30, 2015 Posted October 30, 2015 5. Gantry Crane Features & Functions: trolley movement mechanism (M-Motor) hoisting mechanism (M-Motor) crane movement mechanism (L-Motor) powered by LiPo Battery remote control with 2x IR receivers Video: Discussion topic: http://www.eurobrick...howtopic=116549
Skandinavc FH Posted October 30, 2015 Posted October 30, 2015 (edited) (Disqualified) Edited November 3, 2015 by Jim Disqualified
DavSod Posted October 31, 2015 Posted October 31, 2015 6. Jerfeds Hamnkran Facts: Scale - 1:25 Height - 1.2m Rail width - 53 studs Rope length - 4 x 2.7m Functions: Slewing, M-motor Luffing, M-motor Hoisting, L-motor Grab closing/opening, L-motor Travel along track, manually Video: Discussion topic: http://www.eurobrick...howtopic=116665
kubic Posted October 31, 2015 Posted October 31, 2015 7. 6-Axle Mobile Crane Functions: -slewing (M-Motor) -boom extension (XL-Motor) -hoisting (XL-Motor) -extending the counterweight/pneumatic pump (L-Motor via manual gearbox) -raising the boom (two large pneumatic cylinders) -opening cabin's roof (small pneumatic cylinder) -outriggers (manual, independent, they lock in position) -opening cabin doors (manual) -V12 piston engine driven by axles 3 & 4 Video Discussion topic: http://www.eurobrick...howtopic=116650
Epic Technic Posted November 1, 2015 Posted November 1, 2015 (edited) 8. Crawler Crane with a Three Stage Boom WIP Topic: http://www.eurobrick...howtopic=116711 Crawler Functions: -Drive - 2 L motors Superstructure Functions: -Rotation - M motor -Boom raising/lowering - 1 L motor -Boom extension - 1 XL motor -Hoist - 1 L motor Discussion topic: http://www.eurobrick...howtopic=116711 Thanks for voting for my crawler crane! Edited November 4, 2015 by Epic Technic
JamesJT Posted November 1, 2015 Posted November 1, 2015 9. UNIC URW-094 Mini Spider Crane My cranes uses 4 RC controlled XL motors and has 3 modes: 1 Drive - Left and Right Tracks 2 Outriggers - 3 stage - swing, fold and extend. 3 Crane - Rotate boom, lift boom, extend boom and hoist. Push left lever for outriggers, pull for crane. Push right lever for drive. Push yellow bush for power on. 3 functions through the turntable. Boom raise, boom extend and hoist. Discussion topic: http://www.eurobrick...ic=116043&st=25
Doc_Brown Posted November 1, 2015 Posted November 1, 2015 10. Dock Container Crane Main functions are: •Sideways movement via 2 M motors •To and Fro action controlled by cable, powered by L motor. •Raise and Lower controlled by 4 cables, powered by 2x L motors •Grab action using pneumatic cylinder. •Extra L motors for pneumatic switch control and pneumatic pump. •Sbrick controlled Discussion topic" http://www.eurobrick...howtopic=116244
MacKaiwer Posted November 1, 2015 Posted November 1, 2015 11. Big Ol' Red Pipelayer Specs: * Chains/Tracks set 42028 b-model design turned upside down * Mechanical, manually lockable boom and manual winch with simple brake + grabber for the pipes * Massive counterweight made from normal lego battery box and covered with multiple black and yellow beams * Cabin with rotating/adjustable seat, control sticks and ladders to climb in * Head and tail lights * Exhaust pipe on the hood Link to discussion: http://www.eurobrick...howtopic=116511 Video:
Erik Leppen Posted November 1, 2015 Posted November 1, 2015 12. Folding Crane Functions Steering on all axles Four simultaneous outriggers that actually lift the model by locking over center Superstructure can be rotated manually Boom lifts via cable, driven by external motor Boom extends via cable, driven by external motor Boom first jib unfolds together with extension Boom second jib section attaches manually Trolly with hook is moved manually Hook is raised and lowered via knob on trolley Images Video Discussion topic Folding crane
Sir Wolf Posted November 1, 2015 Posted November 1, 2015 13. Modular Crawler Crane Features and Functions * RC via SBrick with control to the 3 motors: 1. M-motor controls the lifting and lowering of the jib 2. L-Motor controls the hook 3. XL-Motor controls the gantry which in turn sters the elevation of the boom. * Turntable turns (not motorized) * Tracks move (also not motorized) * Easy access battery box. * Cabin tilts 3 Configurations Lattice jib only Lattice jib + mast Lattice flying luffing jib + mast Cabin detail Dare devil construction workers Video (thanks to miguev for helping me film it) Discussion thread
lcvisser Posted November 1, 2015 Posted November 1, 2015 14. Trailer Crane (tractor not included) Functions The trailer crane has the following functions: Outriggers in X-configuration (unfolded by mini-LAs, pneumatically extended) Pneumatically lifted 3-section boom Boom extension synchronized with hook cable spool Manual rotation of upper structure Landing gear Pendular suspension All functions are manually operated. More images (originals are here: http://bricksafe.com...8-trailer-crane) Video Discussion topic The (really short) discussion topic is here: http://www.eurobrick...howtopic=116413
rhplus Posted November 1, 2015 Posted November 1, 2015 15. Ancient Greek Crane Functions: - two simple winches, each powered by 1 PF M motor - efficient pulleys set up link for discussion topic: http://www.eurobrick...howtopic=116040
Milan Posted November 1, 2015 Posted November 1, 2015 (edited) 16. 1:13 Liebherr LTC 1045 - 3.1 Mobile Crane Discussion Topic Scale: 1:13 Weight: 10kg Length: 90cm Main functions carrier: All Wheel Drive All Wheel Steer All Wheel Suspended All Axles Lockable 4 Steering Modes Active Suspension, Adjustable via 12 small pneumatic cylinders, can lift and lower the whole crane 1cm Durable Live Axles Separated Outriggers, each box individually controlled Main functions superstructure 3 sections boom, manually extendable Very strong main lifting cylinder, oval form Winch Rotating superstructure mounted on a wide one piece base, 3 rollers installed for smooth rotation Cabin can be lifted via second cylinder Cabin can be extended via third cylinder Cabin can tilt, manually Other features: Cabin door has extendable path Cabin door can really slide open and close Cabin instruments are printed scans from real machine Front tool box - bumper section is removable, to shorten turning circle Lots of little doors and storage compartments Additional lattice boom is also present Brick Built Wheels and Tires, each has 200 parts Trial Truck grade axles Each wheel has turntable bearings Pictures: Real machine: LEGO model: Size comparison: VIDEO: Edited November 3, 2015 by Milan
fabione Posted November 1, 2015 Posted November 1, 2015 (edited) 17. LIEBHERR LR1100 D Carriage function : 2x XL Motor for the track's 1x 5225 Motor for the outrigger 1x 5225 Motor for the rotation 1x 88000 Battery box 2x 8884 receiver Upper carriage 1x XL Motor for the boom 1x XL Motor for the principal winch 1x 5225 Motor for the tilt cabin 1x 5225 Motor for the upper conterweight 1x 88000 Battery box 2x 8884 Receiver 1 Gear shift to decrease the speed for the boom and the hook Video: Link for discussion topic: http://www.eurobrick...howtopic=116684 Edited November 3, 2015 by fabione
aminnich Posted November 2, 2015 Posted November 2, 2015 18. Grove Trailer Crane I modeled this crane after the GSK55 trailer trailer crane. The model features all the key functions of the real crane. The crane itself has 4 functions; outriggers, spinning the superstructure, raising and lowering the boom, and extending the boom. Link to the WIP topic; http://www.eurobrick...114809&hl=grove Here is a link to my bricksafe file, the video can be downloaded as a media file. https://www.bricksaf...ll-scale-/final
Jim Posted November 3, 2015 Author Posted November 3, 2015 Topic locked! Waiting for two videos (#17 and #18).
