Showing results for tags 'original trilogy'.
Hello erveryone, After 13 Months of building I finally finished my A New Hope in Lego Series. I recreated more than 50 Scenes of our so beloved Star Wars movie from 1977. I hope you all enjoy my little photo series and I am happy to receive some feedback from you guys Next Project: "The Empire Strikes Back" in Lego. Follow me on Instagram to always see the latest parts of my upcoming series: https://www.instagram.com/codyaner_bricks/?hl=de A New Hope (1/6) by Codyaner_bricks, on Flickr A New Hope (2/6) by Codyaner_bricks, on Flickr A New Hope (3/6) by Codyaner_bricks, on Flickr A New Hope (4/6) by Codyaner_bricks, on Flickr A New Hope (5/6) by Codyaner_bricks, on Flickr A New Hope (6/6) by Codyaner_bricks, on Flickr Kind regards Codyaner
- 14 replies
- star wars
- a new hope
- (and 9 more)
Hello again everyone Following on from my Snowspeeder post a few weeks back I realised I had neglected to build the Rebel Transport from Empire Strikes Back. So I decided to rectify that. There are no really tricky elements to this build. It does switch from 2 to 3 studs at the bottom using the new 2x3 jumper plates. This then allows the 5-stud wide main body to get the shape at the front. It is not as round at the front as it should be but you can’t always do everything in this scale and you have to approximate. It also uses the old finger hinge plates to attach the side “panels”. It would have needed a 1 plate high gap between the clip/hinge and the main body to use clips or the clicky hinges so sometimes old is better! Hope you like it Jon
- 3 replies
- star wars
- rebel transport
(and 4 more)
Tagged with:
NEW MODELS WILL APPEAR IN THE REPLIES TO THIS THREAD - consolidated in to one thread for when further models are added Models in this thread: SNOWSPEEDER REBEL TRANSPORT OUTRIDER TIE SHUTTLE A-WING (MOD) SUPER STAR DESTROYER (MOD) SENTINEL-CLASS IMPERIAL LANDING CRAFT IMPERIAL STAR DESTROYER SNOWSPEEDER Hello again everybody With the emergence of pictures of the 20th Anniversary Snowspeeder Polybag I realised that I had not published my own (and if I do say so myself superior! ) MINI Snowspeeder model! This little model has been lurking around for a while continually being tinkered with. It started off as the unreleased LEGO set 8029: However, as you will see from the pictures it has almost entirely been rebuilt. The wings are still attached using the hinge bricks but everything else has been stripped down and rebuilt. As new pieces have been released I have updated this little model. Gotta love Snowspeeders! Anyway I will let the little model speak for itself. Jon
- 11 replies
- imperial landing craft
- sentinel
- (and 9 more)
Hey Eurobricks, First time poster but I wanted to share the my custom T-65 X-wing I have been working on for the past while. Flickr album: https://flic.kr/s/aHskC2ymYh LDD File: https://drive.google.com/open?id=1H2r8EemynUHE9wV_Q0ILHjciZeTAJIOq Part Count: 1056 Length: 34.5 cm, 13.6 inches, 43 studs. Width: 39 cm, 15.4 inches, 49 studs Height: 13 cm, 5.2 inches, 16 studs Bit of Background: I have loved the X-wing since I first saw the movies, and it was the first MOC I ever completed as a kid. Now as an AFOL I was recently able to block out some time for building a MOC and I wanted to update my first X-wing from many years ago. LEGO's versions have been solid, but the more I examined them the more I wanted to design my own that more closely matched the shape of the OT movie props. I was inspired by the amazing MOC X-wings I have seen created by many folks, including Gray Mouser, Inthert, Psiaki, cehnot, and dmaclego. My Objectives: Model building focused on three key components. Overall I wanted to make an X-wing that was relatively accurate to the source props but also very sturdy and still possessed important play features. 1) My first goal was to provide structural stability to allow for maximum swooshibillity. I will be the first to admit my MOC doesn't capture some aspects of the shape perfectly like others have done, but I wanted to focus on using a Technic solution to build a hull and wings that were very strong. I designed a custom skeleton using Technic beams and bricks across across the entire ship so the model can actually take a short fall without exploding entirely. :) 2) My second goals was to capture the proper shape with the heptagonal fuselage, proper angles and correct length and width proportions. Using the original model and screen grabs from the films as a base, I also drew inspiration from the great models of Gray Mouser, Inthert, Psiaki, cehnot, and dmaclego. I used hinge plates and Technic large ball bearings to achieve the slanted heptagonal shape and these were attached the rigid skeleton to maintain structure/swooshibility. It also means I can hold the model by the nose :) Here is a stress test swooshing videos. Two more are on the Flickr album. 3) Building working 'play' features such as retractable landing gear, removable R2 unit and opening s-foils. Since this was going to be for swooshing and not just display I wanted to incorporate the action features that were present in the official LEGO sets. The first was fitting an entire R2 unit behind the cockpit, legs and all. Fortunately, the skeleton allowed for a large space bind the cockpit and I used hinged panels around the R2 unit so the entire droid (legs and all) can be removed and inserted easily. I also made retractable landing gear a part of the rear engines and the front fuselage. Again the landing gear don't look quite as pretty as a display set, but I prefer the play-ability aspect myself. :) The s-foils can also be opened with a knob on the rear or a switch on the top of the craft. There is also an option to use a knob on the top of the fuselage, but I think the top knob would stick out too much. Just for fun here are the past two iterations of my MOC, from many moons ago I would love to hear thoughts about what others think of the model and I would be happy to answer questions or provide my LDD file, too! Thanks!
In 2012 LEGO released 10225, the UCS R2-D2. It remains one of my favorite sets of all time, but I've always felt like something was missing... and now with a new BB-8 model coming (that appears to be in the same scale as R2-D2), it's obvious that C-3PO needs to be done next. So I set out to build one myself... and so far I've succeeded... kind of. Legs by Brikkyy13 ., on Flickr back by Brikkyy13 ., on Flickr Sections by Brikkyy13 ., on Flickr With R2-D2 by Brikkyy13 ., on Flickr Currently we're looking at 1295 pieces, and it can only get bigger. The original plan was to have it in scale with the R2-D2 set, but since I'm a bit lazy instead of doing measurements I just eyeballed it, using the size of his feet to judge how big everything should be. So the feet ended up being in scale with R2, and everything else accidentally turned out bigger. I didn't actually realize this until I took the screenshots, and I was too proud of my work to go back and change it. The next step is to make C-3PO's feet bigger to be in scale with the rest of his legs, and to continue working upwards from there. I intend on bricklinking all the parts and building this bad boy for my collection once it's finished. I will eventually post the lxf and/or instructions too. I'll update this post as I update the model. Any and all feedback is appreciated. Thanks for checking it out!
Hello everyone, this is my second post here about a model that I am very proud of that I designed a while back. I present to you, Han Solo's DL-44 blaster replicated in 1:1 scale using Lego bricks. The model was blogged about on Bricknerd. Link for anyone interested is below: Link More Photos More Photos More Photos More Photos Comments and constructive criticism are appreciated as always.
