Showing results for tags 'game controller'.
BrickController2 is an Android and iOS application that allows you to control your Lego models using a compatible gamepad. It supports the following devices: - SBrick - BuWizz 1-2 - BuWizz 3 (basic support) - Lego Powered-Up devices: Boost, PUP HUB and Technic HUB (or Control+) - PF infrared (on Android devices having infrared emitter). Features: - Multiple profiles for a single creation - Multiple motor (or output) assignment to a single controller event - Different types of devices can be used at the same time - The same motor (or output) can be assigned to multiple controller events - Different joystick characteristic settings - Different button modes: normal button, simple toggle, ping-pong toggle, carousel toggle, ... - Train mode on joysticks - Normal and servo mode for the new Control+ motors - Sequences (like for flashing light) BrickController 2 on the Google Play Store: BrickController2 android BrickController 2 is also available on the Apple App Store. BrickController2 iOS Video tutorial created by @kbalage (many thanks for this): And another great video by @kbalage: Older versions: BrickController Android application. It lets you to control Lego creations via Lego infra-red, SBrick and BuWizz V1 and V2 using any Android compatible game controller: Current version: BrickController 0.6 User guide: BrickController User Guide Minimum system requirement: Android 4.4 and bluetooth low energy support on the phone (or tablet) Video on the older SBrickController application:
- 1,316 replies
- sbrick
- game controller
(and 8 more)
Tagged with:
Hello to all technic fans. Since I got a BuWizz, I always wanted to make a buggy car. And here is the result. My concept buggy from KTM The inspiration for the design came from the original concept of KTM AX buggy. It is not the same look and design, it was only ispiration for my build. It is driven by 2 PF L motors geared up with 20 to 12 gears. It is rear drive with diferential. Steering is with 1 PF servo motor. Lights are 2 pair of PF LED ligts. It is fully independent suspension. I also made a lifting roof for easier access to the BuWizz box for charging and switching. Due to its low weight it is very agile and fast. It is realy fun to drive with this litle buggy. Realy big thanx goes to BuWizz for this briliant magic box, and also respect to mister imurvai for his briliant solution for game controler. And the video. Thanx for reading and watching. Best regards, Valter
