Showing results for tags 'double track'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 6 results
  1. A little less than a month or so ago, my brother designed me a 6-track long functional (I.E. weight bearing) single-track train bridge. This model was designed and built by him in less than a day after I expressed a need for another small-size bridge. I then added railings and recreated it digitally just in case I had any issues with it or wanted to modify it. This MOC is designed to be slung between two tables, and worked beautifully as a single track bridge. More recently, I decided to add a second track and as such two more sets of latitudinal supports were placed underneath to make it even stronger now that the load it has to carry has doubled. The longitudinal supports were also lengthened to support the larger bridge deck and the second track. This thing is built using many layers of overlapping plates and bricks and it is STRONG. Underneath, where all the structure's strength is. The bridge on my layout. It is SOLID, with only slight bending at the extreme ends due to the construction method used. Thanks again to my brother for designing such a beautiful bridge! Thoughts?
  2. This through-truss bridge design was originally downloaded by me (I don't remember the name of the original designer who created the bridge) from the LEGO Factory / Design By ME page in 2010-ish and was never built in real life due to questions about it's strength. I came across it again while looking at my MOCpage account's older files and made it into the version seen above using newer parts and a longer frame quite a while ago. (and as to those original questions about it's strength: It's built like a safe, yet I can pick it up with a single finger by the top.) More recently, I revised the deck where the track goes to be able to take the RC track up and be able to put down 9V down more easily. (We run 9V trains at shows in Gateway LUG.) In short, the track is now more easily removable to become 9V, 12V, or even a road bridge. The bridge fits any of my trains, and should fit all official LEGO trains except for double stack containers such as sets 10219 (Maersk Train) and 10170 (TTX Intermodal Double-Stack Car). Comments, questions, and complaints are always welcome! UPDATED 5/29/25: Sorry for the six-year bump, but this model has been torn apart to be made double track! Here we see how it will look when finished, as viewed in LDD. ...and here's the current progress on my double track revamp of my Western truss bridge. Most parts have arrived, but one of the orders is still out... not sure when that's gonna arrive. Thoughts on this new development? EDIT 6/29/25: Sadly, this project is dead. I tried to get it together and couldn't manage it (something was wrong with it), then I had to move and the box of parts got dropped outside. So this upgrade isn't happening. sorry everyone!
  3. This double track train trestle is finally finished! The bridge uses four girder parts from City set 7900 from 2006 that I've had laying around for 18 years without much luck at making a bridge (despite several attempts) - until now! The bridge is ~30 inches long, and is designed to hang between two tables with the parts under track off the end of the bridge proper serving as feet, holding the bridge level and on the table top. Looking up track through the centerline of the bridge. There are 16 bricks of space from top of the rail to the roof girders, which means it can take double-stack Maersk container cars with a plate to spare. To pick the bridge up, you can grab anywhere but the roof lattice - those plates aren't reinforced enough to take the weight. The underside has been reinforced since the initial design stage... It's a lot stronger now, and *should* be able to hang between two tables without breaking while trains run over it. (I've not been able to test this with motorized trains as I don't own any.) Thoughts, comments, questions? Feedback is appreciated! EDIT 7/6/24: Please pardon my messy layout! I've really got nowhere to go with most of this stuff, but nevertheless I just managed to rearrange it around, moving tables and adding my bridge to the mix. The bridge works beautifully and hasn't collapsed yet which I consider a major win for my design skills! A digital look at what the layout looks like without the stuff in the way.
  4. This model was inspired from this set-733 like MOC by @AFOL7777. I turned it into a railroad-served industrial track ballast loading facility to have the crane load dark bluish gray 1 x 1 round bricks into the crane's bucket. Then you can drop them into train hopper's when they arrive with the pull of a sliding plate. You may have noticed I had to extend the height of the model 1 brick, to allow for Diesel 10 to fit underneath, as he is the primary engine to work the ballast facility. (His claw made him too tall, but it's okay now.) The tan tile parts under the crane are the pull pins to make the coal fall into the hopper cars. Inside of the crane with "controls" for the bucket motors and the crane itself, which travels along some narrow-gauge tracks and can swing from side to side. In reality, the "hand of god" method is used to make the crane move, with a rope extending to the roof of the crane cabin which I can wind and unwind to load and unload the ballast into the train cars. The office of the owner of the ballast operations. The reason for the odd footprint is the factory MOC I made earlier this year resulted in a base-plate piece (dimensions 16 x 48 studs) that I was looking to use somewhere.... enter into the picture this model, and now I've nearly solved that little issue. This 6 wide BR "Warship"class with hydraulic claw (AKA Diesel 10) model has been heavily modified by me from a old Class 37 file by LazarusBricks to have new removable roof sections for the cabs with seats for figures and cab controls. As you can see, I chose to leave off the face to keep the engine more in line with the rest of my locomotives. Diesel 10 works the ballast facility most of the time, so I included him here. I'm going to have my Diesel 10 model pull 6 of these coal cars plus a brake van inspired by the 1980's 12v era red/ yellow sets to my gravel facility. The 12v era model and Diesel 10 are already built, and the plank wagons are on order as of 1/11/2020. NOTE: All credit for the six dark grey wagon models seen in the picture above goes to @Pdaitabird, who designed them. See here on Flickr for the awesome tutorial by him for the construction of the BR plank wagon. BUILDERS NOTES: The ballast facility is now done, but the trucks to be filled with the crushed rocks are not (yet). More pictures to come soon!
  5. These buildings were inspired color scheme - wise by set 7222 and the steam locos of the 12v era, which later became Brick Railways Systems main colors. This model was originally built by my father around 2005 / 2006 for an old-style MOC steam engine we built together based off set 7722. It was three tracks long and one track wide at first, but recently I reworked it to be five tracks long and two tracks wide, and with a completely new removable roof. This model can hold any of my steam engines (okay, maybe not the western one, as it is pretty tall), although it is probably too short in length for my diesel units. The rear of the shed. The building is 5 tracks long, which is 80 studs in length. The maximum side clearance is good enough for a 10 stud wide model while the trains can be no more than 11 bricks tall. The original model's roof is permanently attached, while the remake features one large removable section. My father built his original old grey water tower way back in the 1990's back when 9V was king. When he built my first LEGO train (it was a set 7722 inspired steamer, which gave me the idea for my red & black color scheme) in 2006, he built me the water tower to go with it. It wasn't until 2014 when I built myself a long-awaited coaling tower using inspiration from the website called LGauge (link: http://lgauge.com/ ) Anyway, these models are built to be sat the correct height for most official engines, such as the My Own Train series, along with all my custom engines such as my 4-8-2 "Mountain", 2-8-2 "Mikado", 2-6-0 "Mogul", 4-4-0 "American", and so on. The coaling tower features a movable chute to load the (imaginary) coal into the engine's coal bunker or separate tender. The Forgotten Daylight 4460 is a oil burner, so it does not use this particular tower. The girders on the rear of the coal tower are supposed to represent real-world idea of housing a bucket-conveyor system to load the bin inside the tower. Here, in LEGO, it is just for looks. The water tower features a movable spout to fill up the engine's tanks / tender. Here are the LDD files for the buildings so far: LDD file for the double track shed: shed with doors ldd file LDD file for both refueling towers: refueling towers file NOTE: This thread is a W-I-P: the shed parts have been ordered as of 2/3/16, but the switch tower is a ways off into the future. I should have the shed built by this time next week or the week after! EDIT 2/22/16: The shed is finished, while the switch tower is pushed back some.. it won't be built for a while. EDITED 1/14/17: As of January 2017 the shed now has opening engine doors which are colored to match the red stripe on the walls. They will be added to the real life model as soon as funds allow, but there is a sneak peek in the latest post! (The LDD file has been updated as well with the doors.)
  6. The single track tunnel was made by my father back in 2000. I updated / extended it, made a two-track version, took off the baseplates, and put the pins in. Here are the pictures: The two tunnels. These are the basics, and you can modify them however you want, such as hiding them under green plates or BURPs & LURPs. Double track, with the connecting pins. Single track, also with some pins. NOTE: Connecting the tunnels will only work in this way or some variation of this type. For example, here is a picture of what can be done. Notice the one track section in front of the tunnels? (In the case of single to double tunnels , four should be used.) That is to make sure if your engine overhangs, it will swing clear. EDITED 9/5/21: added photos back to the post. I finally found them on my Flickr from 2012.. The file, however, is lost to time.
