Showing results for tags 'classic pirates'.
Ahoy, mateys! I'd like to present to you a Lego Ideas project - The Royal Flagship - a classic style, modular, set-like looking ship-of-the-line with lots of play features. SUPPORT NOW Stats and overview: Features: ---------- About: I started this project with a specific intention - to design a multi deck vessel that can be both - a Lego set-like looking ship that's fun to play with, and a decently realistic shelf model of a true ship-of-the-line. And all of this had to fit in the Lego Ideas framework, specifically it had to contain 3000 parts or less. No easy undertaking, and I've failed to come up with something that I liked a couple of times over the past years. This design now, however, I think it quite does it. Sure, it might not be playful enough to some, and not realistic enough looking to others, and then there's the fact there are only stud-shooters instead of ye olde Lego cannons... () But I hope the compromise I found is appealing to at least some of you; and that it proves that ships-of-the-line can be done as sets by Lego. Some decisions I took along the way: Use stud shooters instead of spring powered cannons (*boo-ing noises in the background* ) But hear me out - let's face it, no single set will ever contain that many classic cannons. So the Royal Flagship features easy to remove stud shooter based custom cannons that can be fired from outside the ship, but that can also as easily be replaced by your good old spring powered cannons - if you got enough of them, the space is there! Almost no interior, except for the captain's cabin. This decision was simply based on Lego Ideas' 3000 parts maximum. Feel free to fill the decks with whatever you would like to see though - there's enough headroom for minifigs to be placed on all decks! Relatively simple hull shape, little tumble home, no string rigging. Due to the modular approach, I just couldn't come up with anything more ornate/fancy/complicated - if you have some suggestions, however, feel free to elaborate! The Royal Flagship was very well received during last year's Bricks @nd Friends exhibition in Cologne; kids especially seemed to like the firing mechanism pretty well - we literally had a blast Let's see if I can take the ship to a few more exhibitions this year - if Corona permits. ---------- If you have questions, please ask! And if you got ideas for improvements, I'm all ears! If I convinced you - please support on Lego Ideas! And feel free to share with friends and other pirates enthusiasts - every vote counts! Thank you for watching SUPPORT NOW
- 10 replies
Captain George McIndoe leads the charge of a light company from the royal Corrington army. Video:
- 6 replies
- brethren of the brick seas
- imperial soldiers
- (and 3 more)
With the release of The Pirates of Barracuda Bay, TLC produced an incredible remake of the original Black Seas Barracuda. I'd always wanted a 'good guys' ship to go along with the new Barracuda, with TLC delivering a new and improved Eldorado Fortress and a contest, I felt it was time to try for a Clipper. The goal was to make a ship which was proportional to the original Clipper AND to the untrained eye looked like it was designed by the same people as the New Barracuda. I had to resort to using a bunch of parts off the barracuda, as a result I don't have a comparison shot. That said, part count is around 1300, dimensions/stud count have it only a few studs (4-6 I think) longer than the original clipper, and every vertical dimension is shorter than the new Barracuda. It looks great and should look just as good next to the new Barracuda as the original Clipper did next to the original Black Seas Barracuda. Shoutout to okbrickworks for the fresh clipper sails. Forgive the minifigures, I don't have Eldorado yet, so I had to use the 'old' new bluecoats. Sadly the admiral has a Dark Bluecoat and an old bicorne. I also don't have enough Black Tricornes with ponytail to have more soldiers (shakos don't go with the Clipper). As a result, the officer uses a modified tricorne with white wig combo and one of the sailors has no ponytail at all(gasp). This will be rectified in the future. My favorite ship angle a la Endurance. The anchor works same as the new Barracuda. All the exterior pics are with real bricks. I found a great lego yellow paint, so Owl with Spread Wings 67632 gloriously replaces the original yellow bird. Stern shot with fleur de lis design. Another side shot: the non gun side has 2 1x6 black tiles to keep the lines smooth. Gun/Anchor side has 1x2 holes so the gun ports can open down like the original Clipper. Notice the bell. Bluecoat ships need one to call hands when pirates are near. I originally wanted to simply copy the one from the Silent Mary. But with the discovery of TLC yellow paint, I used a 3172 Pith Helmet with a bar with ball joint inside. May not see it, but there's a bucket next to the angry soldier, he's swapping the deck. While I have built this using real bricks, I did most of the design in Stud.io. The interior shots are rendered with Stud.io. Three reasons: 1) Camera angles for interiors are tough sometimes. 2) Lighting. 3) When it came time to order parts, I didn't want to spend so much on blue cannon carriages, my build uses brown. I may break down in the future for some blue ones. Captains cabin. Another angle. Bed on the other side. The lantern is nice, but I could be talked into a violin. Under the main deck. Easy to remove and access. Remove the cannons for bunks. Not sure HOW they would remove them or where, but soldiers gotta sleep somewhere. Beds flip up to reveal a spot for personal items. Other side. You can switch out the tricornes for shakos and backpacks if on shore leave. Aft has storage. The little gray piece is a mouse. Reference to a regular bane of sailors' existence, also Sea Rats represent! I didn't render the interior of the bow, I just kept the toilet from the original PoBB One last note. when I embarked, I promised to stick to designs that TLC would use. I did make one major exception: The helm does control the rudder. Getting the old ships wheel to actually turn a rudder was ridiculous and some of the methods/connections are wonky (though still legal). TLC would never. This is why the box the wheel attaches to is so large; this is why the rear mast is a couple studs too far forward; and this is why the captain's cabin is so cramped/only accessible through the sides. I think it's hidden well enough to excuse. Flickr album here, I don't think there are any additional pictures or notes. I plan on putting up rebrickable instructions and probably a helm post at some point. But those will be awhile. Hope you like it!
- 8 replies
- caribbean clipper
- pirates
(and 4 more)
Tagged with:
Return to Classic LEGO Pirates with this updated 2023 version of set 6281: Pirate's Perilous Pitfall! Model contains about 2400 pieces and would retail around the same price point as the 2023 Eldorado Fortress. With 5 minifigures, 2 animals, special features, and 6 play functions, hours of adventure await! Model separates for a wider view and open play access: Additional connection points are included on the edges of the main rock structure to allow for other models to be attached to expand on the set. What is the meaning behind this spooky skeleton? It may warn of dangers ahead! Use the rock steps to access the platform: Watchtower includes climbing ladder, a table and seats with a treasure map, and a hiding place for a chest of treasure at the bottom: Crystals and stalactites fill the interior of the cave and rusty iron spikes protrude from the rocks beneath the bridge: The golden crown is kept safe in the throne room. What secret does the throne hide? Pivot and fire the cannon on the dock, rotate the tiller of the sunken ship, and keep guard with the stern deck swivel guns: "Cut" the ropes to allow the mast to topple! 1. 2. 3. Pull the rope to lift the bridge! 1. 2. 3. Step on the bridge trapdoor and fall onto the spikes below, releasing the boulder avalanche! 1. 2. 3. Pull the pin to release the throne trapdoor and drop unsuspecting adventurers into the prison below! 1. 2. 3. Look out for the crocodile if you try to escape the prison! 4. Pull the string on the back cliff to lift the trapdoor and push in the pin to hold it in place: 5. 6. I hope you enjoy this Classic Pirates set remake! Link to full image album on Flickr
- 26 replies
- pirates perilous pitfall
- 6281
(and 3 more)
Tagged with:
I have remade the classic 1795 Imperial Cannon Set into new mini build. I gave it a more streamlined profile and used some elements that weren't available in 1994, such as the masonry brick and the crab. It's the perfect little fortification for defending a harbor mouth or islet. My design: thumbnail_Chris-01 by Chris Boyd, on Flickr thumbnail_Chris-02 by Chris Boyd, on Flickr The original:
- 16 replies
- contest entry
- classic pirates
(and 1 more)
Tagged with:
After buying Eldorado Fortress, and not having bought Barracuda Bay when it came out, my brother and I thought about making a pirate build to go up against Eldorado Fortress. After looking at the classic pirates hideouts and forts, we decided upon Rock Island Refuge. So we bought the Redbeard and crewmates from Barracuda Bay off of bricklink, and started building. Similar to Eldorado fortress, Rock island refuge can take its classic form or turn into an elongated shape, perfect for displaying. The fortress has a full interior including a kitchen, desk for Redbeard/mapping area, a treasure stash hidden under a trapdoor, an armory, sleeping quarters and a prison cell, which can be broken open using a lever. Outside there is also multiple docks with a cannon, a crane, two ratlines on the sides and two rope bridges. There are also 2 watercrafts, a raft and a small bluecoat rowboat Overall, we love the final product, and hope you do too
- 26 replies
- barracuda bay
- pirates
- (and 8 more)
This is my final update, the ship is complete and ready to set sailt. There are some minor corrections I am going to make to the build further down the line, but those shouldn't be noticable. This is going to be my entry for the contest, a remake of the classic Skulls Eye Schooner. Sporting 4 cannons, three masts and striped black sails, the Skulls Eye Schooner outgunned and outclassed the Black Seas Barracuda. The dashing colorscheme strikes fear into the hearts of merchants and soldiers alike! A remake of this beloved classic seems almoust sacrilegious, though I never owened it myself and don't want to start a collection of vintage sets. Therefore, a remake has been in the back of my mind for quite some time. The name of the ship is rather inacurate, not beeing a schooner at all. Nevertheless, I decided to keep its original sailplan with its square-rigged fore- and mainmast and a lateen sail at the mizzen. The original set is typically stylized, with its high fore- and aftercastel and a low waist. I interpreted my version as an early 18th century corvette type vessel (e.g. https://www.modelships.de/L_Anemone/L_Anemone_photos.htm ) with an open gundeck like the original. I used a slightly updated version of the hull construction I developed for my bluecoat sloop and elongated it a bit. I changed the original colorscheme to some degrees, i replaced the brown hull with dark tan (out of necessity, due to the parts not beeing available in reddish brown) and the red accents with dark red. The green gunports were a bit to much for my taste, so I changed them to black (also because the only set to ever feature the green flag pieces was the original and because I don't own it and don't want to pay the prices for those pieces). The build has 1800 - 1900 parts, wich doesn't seem to much out of proportion for a Lego-Set (Considering that the original Eldorado Fortress had <500 parts and the remake has >2500). I don't have the energy left to edit some kind of box art, but I have made some sails (still wip, I'm gonna digitalize them to correct the designs, but the dimensions are fitting). IMG_0070 IMG_0072 Here are some details of the set: A hidden treasure on the island IMG_0074 The open gundeck, the cannons can be run out or pulled back to close the gunports IMG_0075 Storage compartments IMG_0077 The captains cabin IMG_0078 And finally some hidden gold onboard IMG_0081 Thank you all for your suggestions and may the tides be with ye.
- 37 replies
- skulls eye schooner
- classic pirates
(and 4 more)
Tagged with:
What is the black building material? Is it supposed to be rocks, like a continuation of the base? Is it just a black version of the imperial guard white? I'm thinking about making a moc of it and I hate using straight black for buildings (too hard to see details). What do you all think?
- 16 replies
- classic pirates
- rock island refuge
(and 1 more)
Tagged with:
"-Not much is known about Steves travels and whereabouts. How did he end up as a merchant and then later quartermaster on the Schooner? Well I've found some old records at Fort du Soleil while on a routine inspection. Before I unearth the how a few things must first be brought to light; Steves real title was Governor Jaune. Jaune had close ties with the king. This fact is important to Steves situation. Now that we have established some of his background I can proceed to tell you how Governor Jaunes situation came to be. Governor Jaune had been in command of Fort de Soleil for 9 years, the operation was running smoothly. As one could imagine given the heavy fortifications of Fort de Soleil, especially when paired with the two Clippers patrolling the surrounding waters. One might say things where running too smoothly. The royal tax collector had noticed that despite the flawless operation at Fort de Soleil not much tax was brought in from it. An operation at that scale and efficiency should generate quite a significant amount of revenue however little came through. After doing a rather extensive investigation the tax collector concluded that someone was helping themself to a rather hefty extra wage. That someone turned out to be non other than Governor Jaune. Here is where the Governors ties with the king actualizes. Despite the extent of his wrongdoings his life was spared due to this friendship. However the king could not be seen sparing his friends when crimes of this magnitude was brought to light. So the solution was to strip Governor Jaune of titles and accolades. His life was spared but he lost everything..." This is my entry to "The infamous Steve contest". Large build-category. It's a vintage MOC built using only colors that would have been available in the late 80s/early 90s. So no bluish grays as far as the eye can see! I've also made an effort to almost only use parts from this era as well. With a few exceptions. Most notably the quarter arch pieces over the main gate. May the best pirate win!
Well, the BDP is back, so here's my pirate entry. I'd love to thank all those who have commented on previous posts. The suggestions and support helped make this build possible. A couple of quick notes: Capstan works (the anchor raises and lowers), as does the larger ship's tiller Captain's cabin bed opens for storage. Minifigures are not included in the palate. I included them anyway in the photos for several reasons: They help give scale The build is very minifigure friendly, it feels fun/playable, the figures highlight that The majority ordering already have crews OR know where/how to order them Most importantly, one of the best parts of the build is the price: these are supposed to be cheap ships. Under 1200 parts, only 350ish unique parts (many of the "unique parts" are interior colors, released hinges, and stickered parts). This build could be $99, why make it $125 to get non-theme torsos that look terrible anyway? Everyone is tossing those as soon as it shows up. So here are some pictures, comment and let me know what you think! Voting link is here You can vote and find more photos here
- 3 replies
- bdp
- classic pirates
(and 3 more)
Tagged with:
She's done. It took a bit more time than I thought. I was a bit slow to get back to her after she missed out on BDP approval. But the new design is significantly better. Back angle. Much cleaner. Forgive the missing parts/mismatched colors. Here's the cloth conversion proof. Th square sail is unfortunately a custom (reasoning is below). The good news is that it is the same dimensions as the square sail from the Eldorado cutter. This means with some recoloring and a little crafting, you can easily convert it to a merchant or imperial vessel. Just about everything that bothered me about the build has been fixed except the following: 1) The brickbuilt gaff sail's connection has some stress and is likely illegal. To me, the simplicity of the design and the angle of the gaff are more important than a little stress on a technic 4 axle. 2) To get the sexy front hull curve without gaps on the outside, I needed to use jumper plates. so there's a little half step offset on the wall behind the ladders. There's probably a way of using some technic technique, but whatever, it's behind muskets, ladders, rigging, and similar color parts, nobody cares. 3) The front cannon has a stud that attaches into a round tile with technic hole. Illegal. 4) I wanted to get the part to lot ratio of 3:1. Couldn't get there. The double build and specialized ship parts killed the dream. Overall price is shockingly good. If you cut the dragon plume, muskets, swords, and make the cannon/swivel black you can hit 10 cents per part before shipping. 5) The curved up aft section. I love them, but it's a stupid number of plates and the bottom part (brown wedge and black wedge plate keel) doesn't attach well to the top part of the section (one 2x3 plate). Thankfully the rest of the attachment holds it into place. The build is solid. A kid could play with it. The back might get lose with rough play, but I'm not worried about a kid picking it up. You can pick the build up by the mast and it holds. but I wish it was more satisfying. 6) Some parts of the instructions need callouts instead of individual pages. Moving them, moved other things. I'm so tired of instructions. I left them in. 7) My original goal was to use a renegade runner style sail plan with no custom pieces, only the fore/aft sails from the Barracuda. There may not be a good way given how small they cut the gaff sail. The gaff is either comically low compared to the fore or ridiculously high compared to the stern. To make matters worse, the zip hoses TLC uses for rigging now are almost too long for this ship. Without a square sail, the rigging is way too high. This forced my hand, there needs to be a custom sail. Perhaps the saddest part is that the OG plan was to do a fore/aft for the sloop, then lengthen the hull and add a square sail for a bluecoat version. Now they'll look too similar. There you have it. She's done. More photos here. Instructions can be found on my rebrickable Thanks for your support! Let me know what you think!
Bigger Bluecoat ship for the BDP. I could use everyone's eyes for details on this. It will be paired with a smaller pirate sloop. Questions: 1) Is the hull color scheme good? It might be a little bland for me. Yellow rails on the top seem too pirate-y. What do you guys think? 2) What do you think of the 21L Hose with Connector Grips (vs the smoother 22L Hose)? 3) What are your opinions on the cannons? I'm wondering about placement/distance apart/connection (front/rear)/number AND if the deck is too crowded. 4) Opinion on anchors/placement? 5) Fore deck has to be black. Is it too dark elsewhere? Ideas? 6) Cabin... should I just make a Bluecoat version of the Scalawag Sloop's ? Something different? If so, what do you have in mind? 7) Rudder/TIller. Right now, the smaller ship uses 68888 4 Bar Axle Connector Hub (like the Eldorado ship). Is it weird that the larger of the two uses a tiller? (It does work btw). Should I just go no cabin and try to make a working helm? 8) Are the railings too plain? The smaller ship has a similar vibe to the Eldorado stern rails, should I go with that?
- 15 replies
- eldorado
- eldoradofortress
- (and 6 more)
Welp, here she is! Background: The Scalawag started as an attempt to get effective hull curves on a smaller frame, and I think I've nailed it. Originally, I had 1x6x3 1/3 (part 6060) arches for the front, but those weren't available for the BDP, but using round plates and tiles worked out. Some of my favorite pirate ships have been smaller form: the original Imperial Guard Flagship (6271), the Renegade Runner (6268), the Armada Flagship (6280). This was an attempt to make a ship that fused those with the smaller ship type from the IGTP and Eldorado. I also wanted a ship that could populate some of the harbors we have (Eldorado, Tortuga, and Barracuda Bay). Essentially, I wanted to "add" masts/sails to those ports. So the ship needed to be small enough to dock there without overwhelming the port. Speaking of Barracuda Bay, I wanted a sloop that can interact with the harbor. Not everyone could get 2 copies of it. One extra note: this ship should easily fit the gaff/jib PoBB sail if you want to go all cloth. And those are the easiest sails to leave out of the bay anyway. I tried to keep the overall aesthetic in line with TLC. I didn't want it to look like a crazy moc next to PoBB or Eldorado. Rudder is controllable from a tiller up top. Note the gentle upward slope of the stern. I don't think it's illegal, it was approved after all! The build is solid and stable, through and through. It should be playable, though the cannons can be a little weak. There will be stickers to add patches to the hammock piece. And yes a figure can sleep in the hammock with the stern deck in place! How would a pirate decorate his sleeping quarters? I don't think this one will be approved, but it's worth a shot! Here's a back-up incase the other is too racy! The build is pretty stable. I'm waiting on a bricklink order to confirm that the stays support the mast well enough, but the mast design was based on Lego's 3 in 1 Viking Ship, so the theory is sound. The curved hull is sturdy enough to allow figures to connect to it; it isn't overly fragile. Let me know what you think! And please vote here:
- 18 replies
- bricklink designer program
- lego pirates
- (and 5 more)
Hello, would like to present one simple and classic design. I 'm pretty sure you are all well familiar with the Caribbean Clipper (set no. 6274). And while my dream ship was the Black Seas Barracuda, I always yearned for the blue sails of the imperial soldiers. Even though I never had the set, I always found it to be lacking compared to the big pirate ships. So once I had my hands on the complete BSB, I also got myself a 70ish percent complete set of the BSB that I used to modify and enlarge the complete one. What I was left with was enough pieces to build my own redention of the Caribbean Clipper. Where I found it lacking was not in the style itself, but I found it to be too short in lenght, and lacking a second full mast. And for the past years I 've been building it slowly with extra parts I was left with from other creations. It's nothing that special, it's quite simple actually, but I hope I managed to catch that "Classic pirates" vibe I really love :) Brig - Two Masts - Two Square Sails on the Main 21C And ofcourse the bow and stern I hope you'll like it guys
- 6 replies
- caribbean clipper
- moc
(and 6 more)
Tagged with:
Hello again everybody, while I might risk sounding a bit like a spoiled brat, I 'll still tell you the "story" of my first "pirate theme" ship. Remember drooling over those 1989, 1990 and 1991 lego catalouges with the great Black Seas Barracuda (6285) and while the Skull's Eye Schooner (6286) was a far more elaborate ship, thoes red sails got imprinted in my retina. The BSB was simply my dream ship, and I asked my parents if they ever get the chance to get me that "red sail ship" and they got me the "red sail ship", only it wasn't BSB it was the Imperial Flagship (6271). That was my childhoods first and only lego pirate theme ship. I really liked that ship after I got used to the fact that it is not the actual red sail ship, but I still remember the initial disappointment that it wasn't the BSB. You can notice the size difference on this photo between 6271 and the modded 6285: A year ago I got the BSB and really loved it, but felt it was a bit small now that I've grown, so I modded it into a bit longer three masted ship. And with BSB around I felt the Imperial flagship was kinda outgunned in every possible way, and didn't feel that, even thoe it looks faster, the ships commander would ever sail into an engagment facing a ship as big as BSB. So I decided to make my own version. Btw, I always preferd the blue coats over the red coats. So ladies and pirates this is it: Brig - Two Masts - One Square Sail on the Main 6C Just kidding :D This was something I built during my dark age, one night I was back at my folks home going trought lego boxes. My first idea was to try and see if it looked any better in blue coats colours and I'll let you be the judge of that: And then I started planing for the total rehull. Orderd another hull mid section and parts for another mast and a few windows, and this is what I came up with (ofcourse used my lego stash aswell), a blue coats version of imperial flagship named "Impérial": It actually isn't fair to compare it to my moded version of BSB since I made it quite bigger, but still think that the commander of "Impérial" could face the BSB with a fighting chance on the high seas: The ships bow with the figurehead: And the stern: Hope you like the new blue coats flagship!
- 13 replies
Hello everybody, I 'll try to present myself as a classic lego sets fan by using this not that hugely modified El Dorado classic pirates set. The goal was to keep much of the charm of the classic sets and creating the atmosphere of those old style lego catalouges. Hope you 'll like it guys :) This is it, a small port town with its pier, tavern, fort, small mansion and a beach with gold digging pirates: A few close-ups And another shot with my redention of the anchored Caribbean Clipper in the forefront Please do give me suggestions and comments since I'm new at this!
- 20 replies
- classic pirates
- pirates
(and 2 more)
Tagged with:
