Showing results for tags '76183'.
This modular station was inspired by a long since expired Cuusso / Ideas project, (not mine), and set 2150 Train Station from 1996 while the clock tower is inspired by Big Bentley Bust-Out (from Cars 2 set 8639) from 2011. I added a removable six track long platform and put a luggage ramp from the street side for use by the wheelchair pieces LEGO recently made. By the way: the logo right below the clock is the official LEGO trains logo built in bricks, while the words in the center (just between the middle pillars) reads "Ironwood Union Depot" in printed 1 x 1 tiles. The street side of the station has been extended towards the edge of the base-plate, allowing for a more room (and more details!) inside the building. The year of the stations completion, 1928, is right above the main entryway. The lower floor has the central ticket desk, plus pizza restaurant (complete with opening oven!) on the right side with seating available on the left wing. These wings also allow for access to the platform under the twin canopies. The second floor has the switching control room and station managers office which floats inside the exterior walls on some tile-topped pillars. This assembly is barely connected to the build by two studs. (NOTE: No stairs to the upper floor were made because that's how the official CITY sets are, so I didn't include any as I was going for an official LEGO set feel.) This a closeup of the four-sided clock tower and brick-built LEGO Trains logo. The modular station features two platform sections, two lower roof sections, one upper roof section, and the removable second floor on top of a cafe (with seating) on the lower level. The station platforms fit via Technic pins while the other sections attach via a few studs. The station building shown above has been built since 2018. I've been trying to add a good looking canopy and passenger stairs to it since about late 2019, but gave up and added one that is solid in roof panels to my Disney-lookalike instead in early-to-mid 2021. Then, in early October I saw 76183 (Riddler face off from the new "The Batman" line) and knew I had found a solution to the pedestrian staircase between both platforms. I hashed out a better, more see-through version of the canopy on the MOD Disney station which should work... it has a half stud gap right now, but it most likely is an LDD problem instead of a design one. (I hope!) The stairs are a color changed MOD of the ones in the set with more space between the tracks and a bit more height in the middle section by way of bumping the whole structure up a brick or two. There is eleven bricks of clearance from the railhead to the bottom part of the arches, meaning the twin staircase's fit most of my trains through with room to spare. However, the pantograph's on electric loco's and a caboose cupola for a freight train won't fit under the bridges. This view also showcases the neat little hanging lights used under the canopy area itself. The bridges are missing eight black candlestick parts for the lights on the part of the walkway, where the stairs have their landings. I'll also have to cut the two 48 x 48's down by eight studs on one side per baseplate to better fit the footprint of the canopy. EDIT 11/9/21: This canopy project would would cost around three hundred US dollars (or more) if I didn't have 850 of the more expensive parts already found from my own collection and with serious help from my brother. Sadly, the Disney Station MOD's canopy has been sacrificed to make this project work as well. (Using those parts knocked it down to about $160 for what you see above.) Thoughts on new development or the original station? Comments, questions and complaints are always welcome!
