  • 4 weeks later...
Probably not an og brick, but a custom 3D printed one specifically for the case. On pics from slightly lower angle, it clearly shows to be 4 wide which doesn't exist as an original Lego part.
I thought maybe the lightning make it appear like the middle gap between the two bricks is invisible on the sloped side. If you look closely at the underside, it looks like there are 2 bricks. But maybe it's just one custom brick like you suggest :thumbup:
Maybe you found something special? I couldn't find it in that colour either. Is there any unique lettering on it that might indicate it's a test or prototype piece? FF is used on prototype pieces sometimes, for example.
Hi community! It is a random thursday for me and I get wondered if I could somehow find a name of my first LEGO set. I already sitting and googling for like 2 hours trying to identife my set but failing to do so, so I get here for some help and maybe links or sources. Description: it was a set about some beach bar with sand color square plate, the thing that I remember it was like red\black theme with black roof and some 2 or 4 1x1x5 red "sticks" that it stayed on. This set I get around 2004-2006. If this community will help me to find name or just some useful sources I would be very grateful to you! Thank you in advance for your time!
Oh and also minifigure - there was a guy totally black legs and hands and body was like a black biker coat and a red t-shirt under it.
On 8/29/2022 at 8:48 PM, Bricky Steamboat said:
Any ideas on this hollow column? I've scoured the 'support' pieces on B/L but no luck. It's one piece, the plate is part of it.
If you don`t find out yet this is a base for a shit that hold its sails - some like from here https://www.jmbricklayer.com/best-lego-pirate-ships-from-oldest-to-newest/
It’s a boat mast.
https://www.bricklink.com/v2/catalog/catalogitem.page?P=4844#T=C
and I just realized that you replied to a post from 2 years ago.
Edited by CallMeCarbiz
On 9/20/2024 at 2:44 AM, Stereo said:
Depending which clues you weight more, https://rebrickable.com/sets/6736-1/beach-lookout/?inventory=1#comments Beach Lookout or https://rebrickable.com/sets/6563-1/gator-landing/?inventory=1#comments Gator Landing seems like options.  I think Gator Landing is the only set with the black suit + red 1x1x5 bricks.
Wow man, its really awesome, thank you for your time I believe it is set that I had - but now I am wondering where did I get that beach plate from:pir_laugh2:
On 9/19/2024 at 10:55 PM, CallMeCarbiz said:
It’s a boat mast.
just was wondering around)
Hello, I can't identify some LEGO colors.
Please check this photo and let me know if my guesses are incorrect.  I am pretty confident I got the colors right in the first row.  Magenta, Dark Pink, Bright Pink, Pink.  Although the last one might be Paradisa Pink, which I recall used to be a separate color on BrickLink, but now appears that BL considers Paradisa Pink and Pink the same color.
I am not so sure about the ones in the second and the third rows.  Second row third and fourth brick are clearly not the same color, and one must be Light Purple (not sure which) but then what would the other be?
Same about the third row first and second bricks.  They are very close, but not quite the same.  I would say one of them is Bright Light Blue, but what is the other?
There are other parts in my inventory that would indicate that some of these parts were originally part of this set: https://www.bricklink.com/catalogItemInv.asp?S=4679b-2
For example: 1x1 bricks is Aqua, the Blue-Violet slopes, the Earth-Orange plate etc.  So it is quite possible that these are just color variations, due to manufacturing inconsistency.
I might say your left "light purple" is magenta but it's hard to be sure just from a photo.  The light blue bricks are probably the same colour, just variation or yellowing.
Thanks for your input!  The two Light Purples are indeed quite apart in hue.  I don't think either is Magenta, I have a Magenta part in this pic and it is a different from both these Light Purple variations.  For the time being, I will consider these both Light Purple.  I am considering picking the parts from my stock to "build" a 4679b-2 set.  (t looks like I have parts for two copies, almost complete.
The Bright Light Blue bricks are different not only in color, but some other small detail.  The stud logos are quite different on the two bricks.  Then again, this can be a manufacturing inconsistency.  On the left brick, there is a "ring" around the logo, and the letters are not so "sharp" and they are less tall.  On the right one, there is no ring, the letters have more definition and they are slightly taller.
The color of each bick is perfectly even, too even to be yellowed.  Same color on every surface, even on the insides.
Again, I will consider these two to be the same color, for the time being.  The difference is very subtle.  If in fact I have two copies of the set these came with, this is the most likely explanation why I have these pieces in the first place.
I too considered Maersk Blue.  The set I suspect they were originally a part of (4679b-1 on BrickLink) was released in 2005, which is the same time the Maersk Container ships were released (2004&2005&2006).  I actually have a copy of the 2004 edition, but "unfortunately" it is still MISB, so I can't compare the colors.
Hello,
Would anyone be able to help and try to identify if there are two colors of bricks in this photo?
Yellow variation
I am confident the bricks in the lower half of the photo are Bright Light Yellow, I have matched them to parts from a recently opened set. I am unsure about the top half. The halves are visibly distinct to me, but I am pretty colorblind so that always throws a wrench into identifying colors. Does this just appear to be color variation, or is it two different colors? I am not sure what the upper half color would be, if it is different than the lower half. Initially I was thinking Light Yellow, but that wasn’t produced long and I think can be ruled out given the parts in question.
Thanks!
Edited by nimrod6134
I see 3 distinct shades there. Top left although looking different, is likely the same 'colour' as the bottom, but the top right might be something else. What though? They're probably all the same Lego colour. Especially if as you say the bottom is "bright light yellow".
They all look the same colour to me. Minor variations, sure, but any given piece I'd say is bright light yellow, and I can't see a distinct enough difference between any two to counter my instincts.
It's certainly not light yellow. That would be far more immediately obvious.
