On 6/1/2025 at 5:32 AM, NV Lego technic said:
A pin with 2 pinholes would be great too.
I assume you mean a #2 connector but with pinholes rather than axle holes.
If so the this acts as 2 of them :)
Edited by SNIPE
15 hours ago, SNIPE said:
Another part I would like would be a 7 x 9 frame, because sometimes the 7x11 is a bit too long to fit in a model.
Indeed, this would be useful, and also some other sizes.
There are many ways to imagine this, so not sure what you mean.
1 hour ago, Ngoc Nguyen said:
Since TLG has started crossbreeding the angled connectors with other type of parts, I would like to see angled liftarms.
Like this but with 3 pin holes.
That but with a straight pin instead of the bar.
Edited by NV Lego technic
So, like the existing pin with pinhole connector, but with 2 pinholes instead of one?
Or, same part but described in another way, a 2L beam with a pin on one end?
This is what I understand.
250x250p.jpg?1714159751.8426824250x250p.jpg?1714159757.1588023
Mix of this two parts.
Left one but 1L pin insted of axle hole.
I would like a 1L diameter shock, but instead of being 6.5L, it can be built mostly from other lego pieces and has a lot of customization.
I tried making a mock-up drawing by having basically an oval pinhole , like on this piece, and using a stud pin to hold the plunger inside of the body, but since I want the body to be 1x1 in diameter, the other parts would be too big.
Also since the plunger is just an axle, but has a pinhole on the end, it would be too big where the pinhole is in order to be inserted into the body. which just has a friction-less axle-hole...
We have the 5L axle joiner which has no friction on one end, we have just the metal springs on their own, as well as the 6.5L shock absorber body
We have axles with stops in different lengths, connector pins, other connectors but what we don't have, is a way to lock the axles so that they doesn't fall out, but also lock the pinhole on the end of the plunger axle so that also doesn't fall off.
So, we need a way to do that, while also allowing for a customizable shock absorber (because that's the LEGO way)
IDK if anyone can come up with some designs. a mini pin and bar hole could work, in order to keep the plunger and body locked together, but its not as flexible as a pinhole, whicha ccepts studs, pins, axles, also mini pins are weaker.
4 hours ago, Auroralampinen said:
new wheel rims
Actually really strange... the 42210 introduced wheel covers again, so wouldn't it be way easier to use the normal 30.4 mm wheel and just put a cover inside? There is plenty of room for both the rim spokes and the 3-star nut...?
Well i see on the pictures, that the new rim designs spokes are apparently half stud thick, that the molded bolt design makes the axle hole 1 stud deep. Othervice it would be only half stud. Maybe this interesting solution and design, was neseccary to make the steering work perfectly. Like with the 5 spoke design on the mustang:).
Edited by Auroralampinen
Fixed typing
On 6/12/2025 at 9:08 AM, Auroralampinen said:
The new ac cobra has brand new wheel rims:).
Huh, cool!
1 hour ago, Auroralampinen said:
In case you need white and orange wheel hubs. The new nike dunk set has got you covered:).
YESS! I have so many MOCs sitting around just waiting for these colors to be released! /s
Can you please post these recent sets in the General parts thread instead of here, as they don't have much to do with all the parts listed in this thread, neither do they list parts that we'd wish for. Thanks!
  • 5 months later...
On 1/13/2023 at 6:52 AM, gyenesvi said:
Many people (@dhc6twinotter, @1gor) would like to see more parts with towball sockets, so here are my ideas. The obvious ones are shorter liftamrs, the shortest one with an axle hole. Also, two variants for L-shapes; those would be very useful for building solid axles with planetary hubs. The wide one has a pinhole on the back.
I imagine it would also be possible and useful to have something more like
but I could not make it in Studio. Let me know if you have any more ideas for this!
Indeed, I use that a lot, but as you say, the curve is often in the way.
Hmm, I think I get what you mean.. Let's see if I can make something up. You'll have to show me how you'd use it in a build then!
How about the new curved 2x5 panel extender? Would that work in some situations? Or would the curve be often in the way?
Can you please share the Part file for these so they can be printed?
  • 2 months later...
I could really use this for the latest version of my 42110 land rover mod, but it would be useful for all sorts of technic models too, not just as a mechanism housing, but also as a connector or structural frame.
Because the 7x11 frames are too long in both directions, I can get away with using it so the axle goes thru the long sides of the frame
69-F2361-B-E5-C4-4-EFF-AFE4-EC9-A9-E2-DB
BUT then, I have no way to make the driveshaft go thru it, because since the gearbox clutch ring is 2L and so is the axle joiner, I have to offset my differential by 2L.
This frame still allows for a typical centered differential setup, as well as steering racks, and other possibilities.
The only downside is there are no 7L spaced pinholes that are on the sides of the frame,
However, you might have noticed that in my image there appears to be a collision error? well not quite, its actually a vertical and horizontal pinhole at the same time! because in the corners there may be enough plastic to have this be strong enough.
Edited by SNIPE
Well a 7x7 frame would be useful in whatever pinhole arrangement, even without overlapping pinhole, which might not be feasible. Another similar one I'd like to have is a 5x5.
While there may be enough plastic, it may be tricky to mold.
17 hours ago, Ngoc Nguyen said:
The frame I'd like to have is 3x5. There are some cases in that it fits better than the 3x5 dog bone liftarm.
What gears would you put in there? the center hole I assume you want facing vertically
So now you have 2 pinholes on the front and back that are not vertical - fine, but what gears would fit in there when the sides are in the way (because its 5L)
Unless you mean have 3 pinholes all on the front and back, but even that would only allow a gear to be placed  in the center...
Wouldn't it suffice to just have 2 3x5 flip flop beams to make a frame and then lock them together vertically
Edited by SNIPE
