Hi there,
While building a small rc car using a RIM 55982 (18 x 14) I needed a way to lock the wheels to be able to drive it with a motor. Almost started drilling holes ..... and then, after removing the tire, it turned out there is a little notch inside the wheel.
Looks like it is a space for a tiny piece of plastic to slide in, to lock the axle to the wheel. Exactly what I'm looking for!
Have I missed something? Is there a LEGO part that fits this notch and locks the wheel? Or should I make it myself.
https://drive.google.com/file/d/1UgLxSAbwba1zWIg1YRPNkqPdqAq3pMu7/view?usp=sharing
It to for case, when You need to push out some 1L pin or similar ( I think so)
Just now, Arioh said:
Maybe better solution would be to use these rims https://www.bricklink.com/v2/catalog/catalogitem.page?P=55982&idColor=5#T=C&C=86 ? They already come with cross axle hole instead of round pinhole
That's great, thanks for sharing.
That could indeed be the reason for this notch. Thanks.
