Well... yeah. We don't need neutral coloured  3L pin/axle with pin, but orange-white hub parts. :D Just a "What If...?" moment. What if they made the pins for the same colour as the outside of the model? So a yellow here, a green there, etc.
Expand
No, because Technic is too difficult to construct already and all us Technic builders are dumbasses and we need all the consistent colour coding we can to help us…bless them.
Expand
Just what I thought.. but I'd be inclined to think that the recolor request came from Nike, to make these parts blend in more..
I wonder if we use a buwizz buggy motor + the large vinyl pieces from that technic race yaught (42174 ) but as helicopter blades, if it will fly?
Edited by SNIPE
*snip*
Expand
Possibly worth testing. The momentum theory calculations to get initial power estimates vs rotational speed shouldn't be particularly challenging here.
Some potential practical challenges:
  • Low aspect ratio of the sail will lead to aerodynamic losses compared to a blade with high aspect ratio, will increase the required flight power. You can somewhat offset this by mounting the blades further out to increase the effective span, as long as you replace the inboard span
  • Flutter at high rotational speeds due to the thinness of the blade may cause resonance issues. You can tune this with tip weights to minimize torsion
  • The rigid leading edge will introduce aerodynamic penalties due to turbulent flow. You can somewhat mitigate this if it's on the underside of the blade (the pressure side)
  • Rotors are inherently unstable so you'll either need a swashplate with active control, or the whole rotor needs to be mounted on a gimbal. Depending on the system loads, this may be infeasible with Lego ball joints (which have a high amount of slack)
Edited by Bartybum
Expand
There are nice videos on YouTube of people trying various ways to get lift with Lego. They might give you some inspiration. :pir-sweet: My favorite:
*snip*
Expand
Oh my god I've always seen the thumbnail to this video but never got around to actually watching it. That's incredible. Probably helps that it uses higher voltage electronics :P
Edited by Bartybum
I was wondering if 42215's shovel is a one-time use, or perhaps a future set (let's say a backhoe loader) will contain it, too .
Expand
I wonder same with the 42209 shovel. And the 42100 shovel was not seen on any other set.
Also I think there is one or two red ones behind that which has not been seen since 2000. Also OCD alert they have miss aligned them on the axel :laugh:
icons-10358-transformers-soundwave-official-reveal-v0-xbcfw69lp1cf1.thumb.webp.7bd9b06c6e3f9488c63741678cf164cf.webp
Edited by Cardboy
  On 7/12/2025 at 3:15 PM, Corydoras said:
I need a little help. Is there a way to separate these Technic disk joint pieces without damaging them?
https://www.bricklink.com/v2/catalog/catalogitem.page?P=44225#T=C
https://www.bricklink.com/v2/catalog/catalogitem.page?P=44224#T=C
Expand
Yes, fortunately! You just have to pull them apart similarly as (or a little harder than) a Bionicle ball-socket joint (if you encountered one). So they aren't as hard and risky to take apart as a wheel hub. :sweet:
