1 hour ago, msk6003 said:
25-26 FLL
What's that?
Edit: First Lego League? Okay so that's an event, not any set it seems...
Edited by astyanax
that new 'y' connector will also be in tan, in set 10348:
Edited by SNIPE
6 hours ago, R0Sch said:
Did someone wish for a recolor of the T-Rex heavy duty joint and 4x at that.
Awesome, I still hope these new gears gears work with these gears:
Well, it's now really only a matter of time to bring back the good ol' black 3L friction pins.. :D I hope I will still be there when it happens.
3 hours ago, mahjqa said:
If only they were available for literal cents on bricklink
You're right, but the main point is to bring them back (at least in 18+ sets) so as not to spend more money on pins to aesthetically correct a set's look.
Or, even better, add more colours to the currently available portfolio.
Edited by Jockos
2025 second half of the year new and rare parts
New part
6 spook 5.5L dia wheel cover in LBG
Mudguard 3x9 flat surface in Red
Mudguard extender 3x9 in Black
Tire 55.9x22 in Black
Bucket of L120
Big 6 spook, small 24 spook  7L diameter wheel cover in White
Bar Y shaped with 1L axle in Glow in dark white
Panel 3x3 triangle in Yellow, Black
Bucket of EC500
Recolored part
Almost every Dark turquoise in valkyrie
43857 liftarm 1x2 in Yellowish-Green
32123b half bushing in Yellowish-Green
15458 panel 3x11 in LBG
2509 mudguard 11x5x2 in LBG with 2 plane and 2 different print
80286 liftarm 2x5 with curved part in LBG
5429 wishbone 13x6x3 'Mclaren A pillar' in LBG
71709 panel 3x5 in Blue
39793 connector beam 3x3 'bisket' in Blue
5427 panel curved 3x9 in Red
2457 panel 2x3 #3 angled in Red
4569 brick slope 1x6 in Red
32199 soft axle 11L in LBG
2393 Technic Pin Connector Hub Perpendicular 3L with 2 Pins in Red
7101 panel 2x5 in Red
6612 liftarm 1x9 alternative in LBG
2477 liftarm 3x5 alternative in Yellow
87994 Bar 3L in Yellow
Maybe 2397 liftarm 1x7 alternative in Yellow
88323 link tread wide in White
14149 Rubber foot for link tread in Blue
14696 Technic chain in White
80278 & 80274 Panel 5x4 left and right in Blue
11478 liftarm 1x5 thin with both side axle hole in Orange
40918 XXL actuator in Black
24116 panel bent 6x3 in Dark turquoise
23443 Bar Holder with Hole and Bar Handle in Orange
72869 Bar Holder with Clip and 90° Angle (Mechanical Leg) in Orange
Rare part
64392 & 64682 panel 5x11 #17 and #18 in LBG - last release is 2010 (both 1 in 1 set)
62531 panel 3x11 curved with 2 hole in LBG - last release is 2020 (23 in 6 set)
64782 paenl 5x11 in LBG - last release is 2020 (99 in 19 set)
32580 soft axle 7L in LBG - last release is 2021 (6 in 1 set)
6632 liftarm 1x3 thin in orange - last release is 2023 (44 in 14 set)
2405 double side CV joint in LBG - last release is 2023 (2 in 1 set)
56908 43.2x26 wheel in Yellow - last release is 2011 (4 in 1 set)
32192 #4 connector in Yellow - last release is 2000 (2 in 1 set)
85825 hub with 2 switch in LBG - last release is 2022 (3 in 3 set)
18945 panel 5x11 tapered in Yellow - last release is 2023 (35 in 6 set)
57519 sprocket 10 tooth in Black - last release is 2022 (60 in 18 set)
43097 actuator XL in Black - last release is 2021 (6 in 1 set)
I didn't count lambo's part except Y shaped bar.
Edited by msk6003
Sorry for the stupid question, but the small angled panel or the red Ferrari's nose is a New angle? Looks 135° from this view.
Yes, new angle.
And flat angled panel at last! The parts inventory is improving, you can't deny that.
New part
Bucket of L120
Bucket of EC500
4 L double sided CV joints used in the Skyline for AWD
4L links uses for steering in Skyline and probably Bronco
New rim in the Bronco
o + o beam in the Valkyrie
Flat wheel arch in Bronco and Ferrari
Round wheel arch flare in Bronco
New wheels in the rover
45 degree small panel in front of Ferrari and I think on top of doors in Lambo
... And probably more
Edited by Zerobricks
Hum. I didn't noticed 4L link.  And thought angled panel is same angle with previous version. You are right. It is new angle version.
Other parts are already mentioned on list. For example, rover's wheel is actually tread link rapped on 14 tooth DBG sprocket with new wheel cover.
Edited by msk6003
Perhaps I glanced over it but I don't see anyone yet mentioning part 11455 in Red, at the front corner of the Ferrari FXX K.
I seen it but thought that is 44809. You will be right.
Probably not the most interesting to Technic builders but one of the Mario Kart sets also has Technic cams in dark azure.
3 hours ago, SNIPE said:
Looks like this part is replacing part 42610, at least it comes in way more colors according to newelementary
The new variation can be printed, the old one can not. I would think that if no print is required, they'll just use the old one again.
