6 hours ago, msk6003 said:
Finally TLG bring back double bent liftarm in green. Last release is 2002 but it is education set so actual last release is 1998.
Included set
8x in 8479(1997)
2x in 9780(1998)
2x in 970676(2002)
2x in 8217(1998)
9780 and 970676 is education set.
And angle connector #6 in green is also very rare parts. Last release is 1999.
I'm sorry to disappoint you but these parts will come in Bright Green not regular Green in the Kawasaki bike. You can look up the partial part list on lego.com (if you type in 42170 in the part number field). So the only new recolor is the 6-4 beam in Br. Green. :( I don't know why the images are so dark and misleading.
https://www.lego.com/de-de/pick-and-build/pick-a-brick?query=42170&includeOutOfStock=true&perPage=200
Edited by R0Sch
included link
Considering original bike's part is green and that list don't display full part list, I still belive it is real green.
Up to you what you believe, but I'm telling you it is not. The 2L beam is br. green and same color as the bent beam next to it, so is the 1x1 round tile. Also Kawasaki green is closer to LEGO's br. green. Don't know what other proof you need.
7 hours ago, Maaboo the Witch said:
The moulding mark on most new beams has been moved next to the pinholes, and is much less noticeable. Took TLG long enough.
Not to worry, there are plenty of parts they made worse in the same process. The sprue marks are now white even on transparent windows. :wall:
Edited by R0Sch
I don't recall anyone mentioning this yet, but the 60431 Space Exploration Rover from City includes a black/gold shock absorber, which is an interesting color scheme!
Apparently it has a hard spring.
It's be fun to see that in some Technic MOCs, though it shouldn't be too interesting functionally
Already discussed here:
And you can check the review here:
https://brickset.com/article/105523/review-60431-space-explorer-rover-and-alien-life
And the shock absorber is soft, the hard ones has a different spring shape with uneven windings in the middle or at start/end for new version.
Yeah, reading that review is what brought it to mind!
I was thinking it was hard because that's what it's listed as here:
https://brickset.com/parts/6472027/shock-absorber-hard-no-1
It's not necessarily right, though, nor is it necessarily the same naming convention we usually use. Hard ones do look like overkill here!
@Philo
In the part pack 1H 2022, the Vespa wheel doesn't load in Studio, can you please help?
As it's the only wheel that fits the tire it makes it kinda hard to use.
I hope it's OK dropping you abline here, as I saw you posting updates in this thread. And thank you so much for creating those parts packs! Keep them coming please :)
What do you mean doesn't load? Do other custom parts load?
You could try importing the part into Part Designer and then exporting it to Studio (might need to add connection points though).
All the parts from the pack show up in the tab, only the Vespa wheel is missing.
I thought of opening the part in Part Designer but the archive contains hundreds of files and I don't know from where to begin. Help appreciated here :)
Btw, does it load on your side?
Then it indeed seems that that one is faulty.
Yeah, that's a problem, what I do is try them one by one, and start with the large files (by file size, usually there are only a few, maybe ~10 in a pack), those are probably the actual parts, and the rest are just subparts.
I haven't tried, I usually don't load complete packs to keep my custom parts organized, only pick the ones I need.
This helps, thank you.
Honestly, I think Philo's pack was integrated in Studio at some point but nobody bothered to check if the parts loaded properly.
In fact, even in a 'vanilla installation' like yours, you will find the Vespa tires, but not the wheels.
Hi @Divitis
I haven't checked again my pack, but anyway, both the Vespa wheel rim and its tire are integrated to Studio now. Look for part numbers 84772 and 80542.
3 hours ago, Philo said:
Hi @Divitis
84772 returns no results. :pir_wacko:
Is your Studio up-to-date? I works here (version 2.23.12), in fact I just have to key in "8477" to see the rim appear (full file name: 84772pb01)
Yes, I'm fully up to date and even did a clean installation (didn't have anything custom but your part pack anyway).
The wheel still doesn't show up. :pir-murder:
Any chance you can be so kind to send it over to me?
Gotcha! The old painful masking of decorated parts! Uncheck "Decorated parts on/off" near the search field.
Thank you! Thank you! Thank you!
Seems like a new modified Technic axle and pin connector perpendicular with A-Link and ball joint tip is used for the McLaren MP4/4 and what looks to me like hard plastic tires (color and shine like ABS + tool split-line in middle visible) on 30 mm wheels similar to 2695. The front and back wheel hub is simply a 15460 Steering Arm with 3 tow balls.
lego-icons-10330-McLaren-MP4-4-und-Ayrto
1 hour ago, 2GodBDGlory said:
Looks like there's one or two new colors of Racing Small rims in this Ninjago set: Dark Blue, and maybe a darker yellow then we've had before? (It's hard to tell)
https://images.brickset.com/sets/AdditionalImages/71811-1/71811_alt2.jpg
And that's not even the most interesting thing. I see the new 2x3 liftarm with perpendicular holes from the John Deere tractor in dark purple! So I guess the 1:8 scale hypercar will be dark purple and probably a Lamborghini. Also nice comeback a 1x8 Technic brick in dark blue, last time seen in 2009 in the Grand Carousel and only been available in an Agents set before that.
Edited by R0Sch
correction
That ball joint connector is fascinating! Looks like an all-Technic connection, which should be convenient for attachment. It does look challenging to make a sprung axle with it, since there's nowhere to attach a shock, but the real question is, how wide is it? If it's only 4 studs wide, it could be an extremely convenient part to use for solid axles built around planetary hubs.
Also, is there any chance the steering links could be new 5L ones? It's hard to tell how wide it is, and I'd guess not, but it does look skinny enough that I have hope!
