Showing results for tags 'robot inventor'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 6 results
  1. This is my first creation with the Robot Inventor set, 51515-1 , created in stud.io using LDraw parts as custom parts. I hope you like it and it inspires you to build. The PDF building instructions and part list are available at Rebrickable for free. I haven't build it myself because I do not own the set, but greg10 did and posted a photo. In LEGO Studio the motor cables are not available so; I recommend to use the 49283 Wire Clip with Axle Hole (also available in the set) to manage them so that they will not end up in the wheels.
  2. I have read all sorts of complaints about Robot Inventor and by inference Spike Prime. Some are valid (eg poor documentation)... some are less so (eg colour scheme). One thing seems clear is that the hardware is well thought out (yes there are issues with cables). Now in robotics three elements stand out as being super important: being able to use multiple motors (motors are basic building blocks), multiple sensors plus having the computational brain (and software) to hold it all together. Unfortunately Lego only provide 6 ports on each hub and have 2 versions of software both of which initially appear limiting. Whereas wireless Inter-hub communication could be very helpful enabling models to use multiple hubs and access both software platforms this is not something that Lego have explicitly provided at the moment. There is however a very simple and seemingly reliable work around available immediately that could help in cases where high speed comms and high data volumes are less important. This is to use optical communication. The idea which I have tested is to use the distance sensor to signal light flashes to the colour sensor. The number of flashes in a fixed time frame thus delivers information from Transmitter to Receiver. As expected using downloaded compiled code speeds the process up though not massively. This process could be 2 way, could enable daisy chaining of hubs and could be expanded to longer instructions (again high speed not being a limitation). On the downside the process sacrifices at least one port on each of a pair of hubs (if the requirement is for one way communication between the pair). The sensors need to be carefully and firmly positioned for reliability although there is no other requirement for any connection between them. In this context a model containing the one hub could “launch” the second. As SP and RI software can be easily swapped on any hub the user has the choice of using SP/SP or SP/RI or RI/RI platforms. Unfortunately size limitations prevent me from uploading images of the set up and demo code at the moment.
  3. As there is not much going on here yet, and my own projects with EV3 are not working out as I would want, I'll post this video from someone who designed a 6 DOF with 1x RI. He used my program I made to be used for a 6 DOF with 2x EV3 and changed it to work without homing sensors, as it has only 6ports, each needed for a motor. With my help explaining how I build up the program, and how he could make it work and what changes would be needed. He did manage to get the forward and inverse kinematics working, allowing the 6DOF to make straight lines and smooth movements, each axis motion ending at the same time. Before he started I thought the calculating power of the RI would be to slow, but it seems to be even faster than with EV3! Cycletimes are faster allowing smaller intermediate steps. If I had a RI I would try to make this aswell to compare the EV3/RI 6DOF.
  4. For those looking to either use a custom application to monitor the robot state as it runs; or those looking to program the hub using a linux machine: I have just put up a new github repository of interest: https://github.com/smr99/lego-hub-tk I started with the spike tools (https://github.com/nutki/spike-tools, via https://github.com/sanjayseshan/spikeprime-tools) and then wrote a new communication layer that can use both USB and Bluetooth, with failover -- i.e. if you unplug from USB, it will automatically switch to Bluetooth. I added in a mechanism to continuously monitor the hub's sensors and devices, and the console output from a running program. It is a work-in-progress -- not all the hub messages are understood -- but useful enough. Let me know what you think!
  5. Hi all, Just want to share with you a RI5 creation that I have been working on for a few weeks. It is a biped robot built with 5 control+ motor and the Robot Inventor hub. https://www.youtube.com/watch?v=qfAfLVE8jtw The next step is to build the same bot using Control+ and hopefully by the time the build is done I will be able to program it using the new PoweredUp App. Enjoy!
  6. Hi, I want to present the Hot Rod Line follower based on LEGO Mindstorms Robot Inventor (#51515). The instruction is from Anton's Mindstorms website. I added a color sensor and removed the roof. The code is written in Python using Pybricks library. Happy watching! Best regards artpoz
