Showing results for tags 'pneumatic suspension'.
Here is a sneak peak of one of my biggest projects up to date: Project started with a new type of a gearbox, which uses only two toothgears at any time in order to transfer power from motors efficient to the wheels: Here are a few specs of the model: Length cca. 80cm when folded Width cca. 30cm Height cca. 25cm Weight cca. 4,5 cm Dual rear live axles in the back independent suspension in front 4 electrically controlled gears + 1 additional electro-pneumatically controlled gear Working towing arm in the back capable of lifting weights of over 1kg Dynamic lights All functions controlled by 3 Sbricks Currently we have snow here and I can't shoot a video as planned I will post more info as soon as I manage to take more photos and a video.
- 32 replies
- power functions
- gearbox
(and 6 more)
Tagged with:
Since a little moment, I wanted to make a Citroën DS for 2 reasons: This car has a very particular design and it had an innovative mecanic It has not prevously been made in Technic. So I can be the first! ^^ I wanted to reproduce all the features: Suspension Steering with the headlights moving with the wheels Height adjustment using pneumatic (Just up/down, not intermédiary) Gearbox (not defivitive yet, see below) Openable hood, trunk and doors Perhaps the body will be detachable (like the Nico71's 2CV) And a nice design! Actually, I did the chassis. It is not finished, but almost. And it was very complicated to make, this chassis! On the real car, almost all the macanic is in the front part of he car (under the hood). The problem is that it's not really possible in Lego, furthermore I wanted a chassis' height of 3 studs. So, I put the gearbox in the back of the chassis. That is working, but it's not realistic. So can you answer this question: do you like this construction, or do you perfer that I try to put a 2 speed gearbox just under the engine? Here, you can see the headlights moving with the wheels: It's simple, but we don't see that on supercars. There is not HOG yet. I don't know if it will be the steering wheel only, or if there will be one other on the dashboard. The chassis height adjustment allows almost put it down. The suspensions are soft. They give to the car a "boat" effect. And the gearbox: It is linked to the front wheels, but not actually to the engine. I wanted a DBG body, but the parts don't exist in this colour. So, it will be white. Tell me what you think about this begining!
- 33 replies
- citroën ds
- pneumatic suspension
- (and 3 more)
