Showing results for tags 'pf servo motor'.
G'day from Australia everyone! This is my first topic created on Eurobricks and my first serious MOC since the end of my "dark age". I'm seriously super glad to be here and keen to share my Technic creations with you all from now onward. With this in mind, if there's any way I can improve how/what I post, by all means let me know so I can keep everyone (including staff) content. I am committed to giving this site the full respect it deserves. :) As a few of you have suggested, it's a good idea when coming out of your dark age to develop designing/building skill by drawing on other people's MOCs for inspiration and guidance for different building techniques... Partially inspired by SevenStuds' recreation of Tim Cameron's rock bouncer "Showtime", I present my own 4x4 Rock Bouncer. Features.. Drive: 2 PF XL motors (1 per axle). Final ratio is 3:1. Steering: 1 PF Servo motor with rack and pinion Suspension/axles: Full-time locked solid live axles with portal hubs (geared 3:1), suspended by 9.5L shock absorber (soft) (2 per axle) and stabilized by a double triangulated four-link setup. Tires: Third party scale RC tires similar to the "Rock Crusher" by RC4WD. Battery: 1 x PF AA battery box Receiver: 1 x PF V2 I initially began designing some kind of rock crawler which was to include PF XL motors, third party tires of some description and (after quite a while researching suspension design) double triangulated four-link suspension. This kind of suspension is ideal as it provides maximum articulation and strength of the axle while eliminating the requirement for a Panhard Bar or Watts Linkage because the triangular positioning of the upper and lower control arms oppose each other, eliminating sway and allowing all desirable movement. By far the most difficult part of designing was the requirement for a steering shaft which moved harmoniously with the suspension cycle of the front axle. Because the upper control arms are shorter than the lower ones, the angle of the axle relative to the chassis changes through it's cycle and this means that when positioning the steering shaft, it must be such that the radius of it's motion doesn't change (due to angle change) as TLG doesn't offer any part which works purposely as a slip joint to negotiate the effect of plunge. After many, many, many... many attempts, a sweet spot was discovered which offered a negligible discrepancy. (This was a happy moment). It's biggest performance drawback would have to be that when the angle of climb and drive torque applied is too great, the rear lower control arms buckle and the rear axle begins to walk under the chassis. Trust me, it's cringe-worthy. With 15L beams instead of 16L links and consequently different suspension geometry, however, this could be resolved. The turning circle also suffers due to the wheel base. Overall, I am reasonably happy with the final product as it is capable of most of the things I intended it to be and in my opinion, the body could look worse. ;) I unfortunately don't have video footage, but I do have photos (see below). Enjoy! All comments welcome. :D
- 6 replies
- rock bouncer
- 4x4
- (and 10 more)
