Showing results for tags 'imperial star destroyer'.
  • Search By Tags
  • Search By Author
    • Frontpage News
    • Forum Information and Help
    • General LEGO Discussion
  • Themes
    • LEGO Licensed
    • LEGO Star Wars
    • LEGO Historic Themes
    • LEGO Pirates
    • LEGO Sci-Fi
    • LEGO Town
    • LEGO Train Tech
    • LEGO Action Figures
    • Special LEGO Themes
  • Special Interests
    • The Military Section
    • Brick Flicks & Comics
    • LEGO Media and Gaming
  • Eurobricks Community
    • Hello! My name is...
    • LEGO Events and User Groups
    • Buy, Sell, Trade and Finds
    • Community
    • Culture & Multimedia
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Country
Special Tags 1
Special Tags 2
Special Tags 3
Special Tags 4
Special Tags 5
Special Tags 6
Country flag
Found 4 results
  1. Happy May the 4th everyone! Today is a special day. That's why I'm releasing my first MOC: the Torment Imperial-II Star Destroyer. Made of 3,011 pieces, 25 inches long (79 studs), weighing 2kg, it's a medium-sized, modular Imperial-II Star Destroyer holding on a single Lego stand. It features all of the recognizable elements of the real studio model: turrets, antennas, hangars, bridge, neck, engines, with close attention to every detail and proportions of the original Imperial-II ship from Episode V: The Empire Strikes Back. Designing took about 70 days, plus 15 days for building / testing, & another 15 days for making instructions and photos. More than 3 months of work. My goal was to build the most accurate SD as I could, in a limited scale - a moderately-sized build that could still easily fit on a desk or shelf, and be moved freely. This choice of scale made working on greeble and proportions a real challenge. Designing a single, secure stand was not an easy task either. But after all this work, I'm really happy with the result. Hope you guys enjoy it, and may the 4th be with you! ► Instructions for the Torment are available at BrickVault. More pictures on my Flickr page. Extra pictures (dark mode disabled!) :
  2. Well, i was proud of it at the time, but i feel now that my ISD isn't sufficient enough. Numerous add ons and additions have made the model a bit unstable and the inaccuracies need to be addressed. The main issue however is the disproportional build! The bridge is too large and wide compared to the rest of the body, and it lacks the correct amount of hangers and indents in the panels. This is all a result of me following along the structure of set 6211, which focused on an interior, messing up the proportions. I talk about it in the original post: Now however i start from scratch, and you guys get to follow on and give out suggestions! It starts now with the gathering of extra parts and deconstructing the original destroyer. The plan is to make it bigger, more sturdy and more accurate. Got to gather up all available reference material for this beast... Last photo of it intact. Major sections now removed. I plan to keep the bridge the same, perhaps with some slight corrections. However the rest needs to be broken up and sorted... Now people can see the frame of the build, and the messy interior...
  3. It has arrived: My UCS Moc of the Devastator. This is my largest and most accurate model to date, started off as a rebuild of my older model which was disproportional and poorly built in some places. The Model confines al the main features including a battery of 8 turbo lasers, 2 hangers with docking arms, underside tractor beam and swappable tractor beam targeting arrays that can change the ship between a Imperial I class destroyer to a Imperial II class destroyer. The model comes on a removable start and has no interior features, apart from storage for extra parts such as plugs to fill in the stand gaps in the hanger and the secondary Tractor beam array. The bridge and superstructure come in 2 removable parts to ease the weight of his heavy model. The two destroyer variants: Glory to the Empire! This is the topic for the build process, to see how it was done: Full album with additional photos here:
  4. I might be not the most frequent poster of Eurobricks... but I believe I might have something which some of you might enjoy. Pardon for reusing mocpages description, but it seems to be pretty complete. I just hope there are some of you guys here who don't read mocpages too often... :) Let me present you the Chimaera, famous flagship of equally famous Grand Admiral Thrawn. A prime example of an Imperial Star Destroyer Mark II. The Star Destroyer might be very well the best looking sci-fi vessel in any franchise and for a good reason. Its design combines simple, clean lines with fine detailing where required, and the way bridge section arrogantly perches on top of the massive warship tells much about the Empire itself. Most people know that a Star Destroyer measures 1600 meters in length, but not many know that it is actually about 1000 metres wide! Building a huge Star Destroyer was my long lasting child dream, and by some luck I came across such time of my life when I can build it. Year earlier it would be impossible and given amount of money required, it might not have been possible in the future. First, some raw data. The model dimensions are 202x125x58 centimeters, or 252x156x72 studs. This alone makes it bigger in ANY dimension than ANY of my previous builds. The already large Titow Battlecruiser was probably a tiny bit longer than the Chimeaera Star Destroyer is high, but the SD might be a bit too low actually. Such dimensions naturally causes considerable heft of the construction and indeed - the model weights approximately 50 kilos. Approximately because it is impossible to lift it by one person so I cannot really check precise value. It is not the structural integrity which is limiting, the model is durable enough - it is the pure weight and dimensions. The Star Destroyer design process started in early November and actual build started just after Christmas, when first (...large...) batch of parts arrived. Since the model was meant to be featured on Zbudujmy.to LUG exhibition in Swarzewo which was to start at 1st of July, 2014, it was also the deadline. The model was ultimately finished just few hours before the beginning, which is the reason why some little sections are unfinished.I also had no possibility of taking good quality photos, since when the model was encased in glass cabinet, sunlight and reflections made that almost impossible. The ship in its full glory, standing in the display cabinet. The stand itself is made of steel but does not enter the structure - model is simply lying on the stand which is profiled to match ship's anges. "Terraces" section of the vessel, also the highest concentation of greebles and sometimes difficult angles. While the whole ship is a SNOT-ly mess, the superstructure greebling is actually built with common studs-up technique which allowed me to use some trans-clear plates. They will be required later on. Each of those engines took about 1,5 hours to assemble, and first one took about 1,5 weeks just to get the design right. Imagine you have to build a smooth 15-cm diameter bowl which is empty inside, stays straight and is durable enough to survive transport. In such a massive ship, every detail that can fall off during transport, will fall off during transport. Generally the bigger your MOC is, the more durable it has to be. Altough exact proportions of the Star Destroyer Mark II are an absolute mystery, I based them on known ISD-I proportions and common notion that the second ship was a bit more narrow than the original. Thus, while ISD-I would be 200x132 cm, mine is 202x125 cm. Either way, this is a stunningly wide ship which I have realised only when I started the build. Notice how the ship stays straight... while weighing around 50 kilos, measuring 2 meters long and having absolutely no steel or non-lego structural supports inside. LEGO and LEGO only! :) Bridge and terraces section close-up. The goal of greebling was not to recreate greebling of original ship, this would cost me too much time given the strict deadline. Most important features are included, though and greebling is easy to replace so maybe one day... :) As said before, the entire frame is made with LEGO pieces only, and consists of well over 1.000 technic bricks, out of which 700 are 1x14 or 1x16. There are also hundreds of plates, pins, liftarms and unimog suspension parts... yeah, no mistake here :) The ship is modular - it is too heavy to be moved around by two people safely, so entire top section can be taken away. Not only it makes it lighter, but allows easy access to the frame which is both required for maintenance and also offers good holding points. One who wants to pick it up by the frame needs to have good leather gloves or it will hurt. A lot. With blood. :D This little viginette shows how empty the model is inside. I wonder how heavy would it be if it had an interior... not that the interior would be interesting, considering that if a minifig was to-scale with the ship, it would be shorter than one plate's height. That's me :) Maybe tired a bit after another sleepless night but happy anyway. One of LEGO-related dreams fulfilled! Kris Kelvin, The Prime Judge of the Zbudujmy.to association - friend who has helped me a lot during preparations to the exhibition and (mentally) during building. Plans for the future? The ship will stay at Zbudujmy.to exhibition at Swarzewo in Poland for next three months, after that I will take it back and properly finish. Altough detailing is more or less done, some parts of the structure are not reinforced and are too fragile in long-term. I also plan to add fully working lightning, which you sneakly peek at here: That photo dates back to March or so when the ship was still under constructions, but shows how hangar lightning already works. And in the end, few more or less interesting facts: - There were more than 1500 used of each of: 1x2 plates, 1x1 bricks with headlight, 1x4 bricks and 1x1 tiles - all in light bluish grey. - Sensor globes on the bridge were actually designed to be 6-stud diameter, but one BL seller decided it would be fun to change splash terms at night and cancel my order - few days before the deadline. So I had to use whatever I had at hand... - The halfway-done ship was entirely dismantled near April because I found out it was less than 10 centimeters too shallow. - For quite a time it was impossible to pick the ship up, because its structure relies not only on the frame but external covering as well. If one side - either top or bottom - is missing, the other side won't stay attached to the frame. - Originally I have based the model dimensions on drawings taken from Essential Guide to Star Wars Vehicles, which was a bad decision. The model would be 200x100cm while it should be 200x125cm.... even bigger problem surfaced when I have realised that my car's trunk opening is actually only 110 cm wide. It would be ok for the ill-proportioned EGSWV design but not for the proper one. - For last two weeks the model was built in the dining room. I was testing if it would fit in the car after "cutting off" the edges (and it did!), but I found out that it is impossible to drag it back to 1st floor due to narrow staircase. It was hard enough to get it down. - Original estimate for 1x2 plates was 2000. By a mistake I have ordered that lot twice... which eventually proved to be beneficial, as there are over 4300 of them used in the final iteration of the model. 1x2 plates are by far the most common element used. - The model can be actally hung from the ceiling on some kind of a steel wire - the frame will easily support the weight. The problem to solve is in the ceiling itself, it would need three quite massive hooks.
