Showing results for tags 'grand prix'.
Hi, I'm looking for some sort of steering arm that will attach onto the axle in front of the two yellow bushes but when the suspension arms pivot they will get in the way as shown in the second image. The thing I need attached needs to have a pivot on it so a lift-arm or beam can move up and down like how the suspension arms do but it obviously rotates when the axle rotates for the steering. The bushes are there as a spacer as there is a gap since the spindle is offset by half a hole (0.5L) so whatever you put on the axle wont get obstructed by the two black connectors. The other thing is, if there is too many points in which it can pivot vertically when it is supposed to rotate horizontally to steer the car so I think it should have one vertical pivot on one side and another on the other side (just before it connects to the steering rack or other way of steering it with HOG or a motor). Reason being that it does not let the steering arm pivot horizontally without the axle also pivoting horizontally and it allows the steering arm to move with the suspension arms for clearance. The reason why I'm using a steering arm that is above the suspension arms is because the steering angle range is so large that it is very hard to have it work on both left and right turning without it being obstructed, even it if had one steering arm either side of the spindle.
- steeringarm
- lego
(and 4 more)
Tagged with:
The new 60025 excited me at first, but when it was out, I was so disappointed about the design. The 6-stud to 8-stud transition was awkward. I would say this is more like a starter set. However, the color scheme was good. At the same time, I was watching the news on the recent Le Mans 24-hour racing, and I was so fascinated by the champion Audi R18 car. Hey, that's exactly what Lego should have done, perhaps! It took me nearly 1 week to research on that car, and 3 days to create this Lego version of the R18. Let's get into the racing tracks and have a look! Overview of the car: The hardest part is the tail. I did 4 versions in total, and I finally adopted this. I used the 1x2x1 piece sideways as the side exhaust, and integrated the brake light into the bottom bumper line. Looks ready to dash, right? The crew is doing a fine tuning... Reference image of Audi R18: (Google R18 for more images!) Okay, after a week I finally completed the modification on the truck as well. And here you go, the transporter! I have been struggling for the whole week figuring out whether I should use 8-stud or 9-stud or 10-stud container. 8 is not enough as the R18 is actually a little more than 8.5 stud. 10 is too big and it is so difficult to make it look good with the 6-stud wide truck head. Finally I used the uncommon 9 stud, which is not bad at all. The R18 fits perfectly inside while the trailer can "grow" smoothly from the head using some tilting pieces. The tail. Come on quick quick quick! Unload it! So that's basically what it is like after the huge surgery. It doesn't take too many extra bricks, which are mostly used on the base for the trailer, top of the trailer (it is 2 bricks taller) and the racing car. I used the same amount of wheels from 60025 too! Well, the trailer can be detached, as usual. You can see the barrels of Octan petrol stored at the front of the trailer too! Maybe I will make a Shell LMP later to compete with this R18. Let me know what you think! :D
- 26 replies
- grand prix
- racing
- (and 6 more)
